![]() Join Date: Mar 2019
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() Thanks: 15
(Thread Starter) | Not Ranked : 0 score Hello all, I'm new here and firstly I just want to say that I did search many different AFR threads to see if I could find the answer, and wasn't able to locate the answer to my specific question. I'm an admitted newb to the tuning thing, so if this is common knowledge I'm sorry. I just recently got an Accessport and have been running either the Stage 1 or Stage 1+ Cobb OTS tune. I have an HPS SRI and Koni Yellows on the car with the intention of doing OCC and RMM in the next month or so and TIP after that. I've done several datalogs, all using the Stage 1+ OTS Cobb tune, that show the AFR in the 11.6-12.3 range at WOT, which I believe is the correct area I should be in based on the research I've done to this point. At idle, I sit right in the 14.6-14.8 range which my research also tells me is a good spot to be. My question is this: On the data logs, right after I let off the throttle on a WOT pull I notice there is 1 data point where the AFR spikes into the 9-10 range. Literally only the 1 data point spikes down, and then it stabilizes back to where it should be. Is this just a fraction of a second of lag between the throttle and the HPFP where the engine is still giving more fuel and therefore showing a rich AFR? In my head this explanation seems to make sense, but like I said I'm definitely still learning and want to make sure that this isn't out of the ordinary. And seriously if this question has already been answered, I'm sorry.
__________________ '07 Mazdaspeed3 Mostly Stock... for now. |
![]() Join Date: Oct 2011 Location: San Leandro, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 460
Groans: 87
| Not Ranked : 0 score You'll often see the AFR dip into the 9s on these cars with aggressive throttle changes like when you stab the throttle. It's very brief and not really a concern. Rich is better than running lean.
__________________ 2018 Audi RS3 2013 CWP Mazdaspeed3 - CS Turbo 2007 Acura TSX 6MT |
Rep Power: 3747 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,744
| What he said ^^ However, if you're actually in the ~12.3 range at WOT, that's actually quite lean and potentially quite hazardous for your motor unless you're running race gas, E85, or some mix thereof.
(Thread Starter) | Not Ranked : 0 score Usually closer to 11.7 at WOT. Would it help if I posted one of the logs? I just want to make sure that I'm not pushing the car on an unsafe mixture. Can post when I get home later.
(Thread Starter) | Not Ranked : 0 score Do you mind taking a quick look at the datalogs I attached and tell me if I was running too lean on the Stage 1+ map? I was going off of memory when I made my post earlier and I think I may have given you some bad numbers to go off of in my OP.
![]() Join Date: Aug 2011 Location: Boerne, TX
Rep Power: 112 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 39
| Not Ranked : 0 score Unrelated to your specific question, but are you planning to do HPFP internals and a real tune when you do the tip? Stock HPFP may not keep up and lean is lethal. OTS are probably ok where you are now, but as you add, a custom e-tune will keep it safe and better utilize your mods. Freektune, Nishan, or Purple Drank are all good.
__________________ _____________ 2006 Platinum MS6 GT zzb at 156k - stock 2013 gen2 replacement - Cobb APv3, Fidanza LW Flywheel/Luk clutch, CorkSport BPV, Cobb SRI |
Maybe I should've been a little more explicit with my extended plans for the car, but yes HPFP internals are definitely high on the list of things to take care of. I actually had the HPFP(planning to do Corksport unless Autotech is that much better) slated to go in next after the TIP (gonna go with the JBR or CP-E, still undecided). I've found a lot of conflicting information about whether a custom tune and/or HPFP internals are needed to support the TIP, but I guess your point is better to be safe than sorry. If that's the case, I'll happily order the TIP and wait to install until after getting the HPFP internals in. The only reason I felt comfortable doing the TIP first is that the stock HPFP is having no problem whatsoever hitting the 1669 Target at WOT, and holds steady between 1650-1725 at WOT based on the datalogs. Car is an 07' that I purchased 3/24/2018 with 16.8k original miles, clean Carfax just so you have a little more background info. I'll turn 40k when I go to the store after making this post. For the sake of discussion, COBB claims that their Stage 1+ is for cars with SRI, TIP and either stock exhaust or CBE. As far as I can tell there are about 4 different companies that all make the same TIP, so I felt pretty confident that putting either a COBB/JBR/CP-E/Mishimoto TIP on the car amounts to putting the same part on the car with a different logo on the thing. Again, is this something where you're saying 'in theory' it should be fine, but better to be safe than sorry? And just for shits and gigs, I'll attach both datalogs I've got in case anyone wants to take a peek.
__________________ '07 Mazdaspeed3 Mostly Stock... for now. | |
| They look OK to me at WOT. I would make sure to log knock retard as well. That's a strong indicator of whether or not your tune is safe for the motor.
| The Following User Says Thank You to Vansquish For This Useful Post: | joefromkocomo (01-06-2020) |
(Thread Starter) | Not Ranked : 0 score It's funny you say that, I just added that last night as I was going through and changing a few settings for gauges and such.
![]() Join Date: Jun 2009
| Not Ranked : 0 score FWIW, I’d give upgraded hpfp internals priority #1 . Sustained pump pressure in the 1,700+psi range is critically important once you start raising boost above stock levels. Also, TIP change is purely cosmetic unless you are changing MAF housing diameter. Despite its odd shape the stock TIP outflows the K04 turbo on pump gas. No provable gains. Better ways to spend hard earned money, IMO. The engine responds greatly to a better intake system, either SRI or CAI, but the stock TIP, itself, is fine.
| The Following User Says Thank You to MSMS3 For This Useful Post: | joefromkocomo (01-06-2020) |
| The Following User Says Thank You to joefromkocomo For This Useful Post: | MSMS3 (01-06-2020) |
Groans: 87
| Not Ranked : 0 score Logs look fine even though knock wasn't logged. Under WOT I didn't see any dips in ignition timing. AFR usually dips into the 10s if there is knock. The ECU is hard coded to dump in extra fuel when there are knock events to help cool the combustion chamber. Definitely upgrade the HPFP. Other mods depends on your goals for the car. I don't know how far you are willing to take it. IMO I'd skip the stockish size TIP.
| The Following User Says Thank You to tegxsi For This Useful Post: | joefromkocomo (01-06-2020) |
At that point it will turn into much more of a play toy and I will probably go with a bigger turbo and possibly different fuel solutions to make 350+, but I don't really ever want this car to go above 400 whp. Just not a fan of trying to put 400+ to the ground with a front wheel drive car. I do love the platform, I think it's a very well balanced car.
It’s going to take a big turbo conversion and supporting mods to get 350-400 whp. There are a lot of Cobb OTS stage 2 cars here with catless dp/rp exhausts having trouble hitting a true 300 whp on pump gas. You will need a custom Cobb e-tune or VersaTune because Cobb’s OTS maps suck. Heck I did better, hitting 300-310 whp with my mods with the simple plug and play Hypertech. The key for K04 power on pump gas is upgraded hpfp internals, a good high flowing CAI or SRI and a big 3” downpipe and racepipe with a tune that optimizes the flow. All else is pretty much irrelevant.
I'm sure there's a thread already opened about this somewhere, I'm posting this as I'm running out the door at work.
| The Following User Says Thank You to joefromkocomo For This Useful Post: | MSMS3 (01-07-2020) |
The HPS intake internal diameter doesn't matter so much as the internal diameter of the MAF housing does. That said, anything beyond about 15% larger cross-sectional area than the stock MAF housing will require a custom tune as well. To be clear, the stock MAF housing is 2.65" in diameter. A 2.75" MAF housing with the OEM tune is still OK, because it's only about 7% larger than the OE housing and the ECU can accommodate that increase. Of course, in making accommodations, the ECU is also going to pull power as it learns and adjusts to the increased flow. The most important items to buy for your car's power numbers are as follows: 1. Upgraded HPFP internals 2. Tuning solution (Cobb Accessport/Versatuner/Hypertech/etc.) and a custom tune. 3. Intake with 3" MAF housing and an aftermarket downpipe (with or without a high flow catalyst) and a customized tune that accounts for the increased flow. With those items, you will be able to approach 300whp and you should be able to achieve significantly above 300lb-ft at the wheels. If you use an E85 mixture, you'll get above 300whp fairly easily, but that's an additional tuning and usage burden. If you switch to a BNR S3, you'll be significantly into the 300whp range with pretty good spool and transient response. The CST4 will provide very similar results. The CST5 and BNR S4 are for aiming closer to 400whp, and can achieve more in some instances.
__________________ Having trouble finding something on MSF? Use MS3Shadow's search tool:SEARCH MSF HERE! | |
| The Following 2 Users Say Thank You to Vansquish For This Useful Post: | joefromkocomo (01-07-2020), MSMS3 (01-07-2020) |
It’s a great, fast spooling, fat torque turbo, well suited for a daily driven MS3. Go bigger and you get more power at the expense of rubber band slingshot like turbo lag and then need to think about how to use more power on a fwd platform. It’s very easy to overpower the tires at 300 whp, and higher torque down low is not usable and may bend rods. Once you go big turbo and cross 350 whp, you need to be thinking built engine and stronger clutch. Pay to play or break stuff.
(Thread Starter) | Not Ranked : 0 score I was flipping through the DP/TP stickied thread to look for the answer, can't seem to find it. Is there a significant difference between a divorced DP like the Corksport and a bellmouth DP in terms of performance? The reading I've done pretty much tells me there's a decrease in turbulence when using a divorced pipe, but I'm not clear on the performance benefit, if any, between the two types. I've pretty much gotten it narrowed down to the ATP, Ultimate Racing, and the Corksport for the DP. I know I like the sound of the HKS CBE, so that's already decided.
| The Following User Says Thank You to joefromkocomo For This Useful Post: | MSMS3 (01-08-2020) |
Do you recommend getting the extra O2 bung? I live in SC, so it's not a requirement for me to be Catted, but I'm still undecided on whether I'm going catted or catless. My wife's a big Eco head and I try to be conscious too, so I'm leaning toward going catted unless there's a significant difference. It seems like there's really only ~5hp to gain from going catless. If that's the case, I think catted will be the way to go so I can tell her in confidence I'm being environmentally conscious. #marriedlife
__________________ '07 Mazdaspeed3 Mostly Stock... for now. Last edited by joefromkocomo; 01-08-2020 at 11:53 AM. Reason: MSF Database - Automerged Doublepost | ||
| The Following 2 Users Say Thank You to Vansquish For This Useful Post: | joefromkocomo (01-08-2020), MSMS3 (01-08-2020) |
Exactly. And, if the bungs are properly designed and located, you can run catless with no check engine light. Not suggesting you spend the extra on something like my TurboXS, but they really engineered the rear bung location and height so that I almost never had a check engine light, maybe only once or twice a year, usually after some really abrupt change in weather and ambient temperature. Maybe the cheap e-Bay copies have the same raised secondary 02 bung now.
Divorced dp is not likely to make any difference, either, except on a built engine with big turbo, custom tune and supporting mods. If you truly plan to ditch the K04 in favor of a big turbo, what follows in this post may not matter. But if you plan to run the K04 now, or for a while: Like I said earlier, the limiting factor is the flow of the stock K04. Once you hit that wall at 300-310 whp on pump gas with upgraded hpfp internals, good intake flow and a good 3” downpipe, throwing other or different power mods will not change that. Also know that the stock CBE is well-matched to the turbo. The exhaust side restrictions are upstream of the CBE, in the stock catted downpipe and catted midpipe. Once you have a good 3” dp/rp you’ve solved exhaust side flow for maxing out the K04 on pump gas. Changing the CBE only changes sound unless you also install a larger turbo and tune for it. Look at my mods. Stock CBE downstream from the catless 3” dp/rp. 300-310 whp. There is very little, if anything, left on the table. Maybe another 5 whp with a very good tweaked custom tune. The K04 (now equivalent flow BNR 1), is maxed out. You can make more torque down low (350 ft.lbs.) but you just bend connecting rods and shred tires (fwd). A MS6 with AWD might benefit from higher low ind torque, but at the risk of bent rods. It’s not usable on the MS3 in the real world. Better tunes for the MS3 soften torque down low and bring it on strong after 3,500-4,000 rpm to redline. We’ve traveled this road for years. There is no magic to make a K04 make more power than what it’s efficiency map will allow. I’ve always been happy at the level where it is maxed out on a safe tune.
__________________ 2017 Audi Q5 3.0 T (supercharged) Stage 2+ EPL tune, JHM overdrive crank pulley, EPL supercharger pulley, ZF8 TCU tune, aFe/034 intake, modified air box. 480 hp. Sunlight Silver '08 MS3 GT Mods: (Sold 1/25/2019 after 10+ years of ownership) BNR Stage 1 (to fix smoking K04 turbo), TurboXS 3" Catless DP/RP "Stealthback" into stock CBE, Vibrant 3 inch Ultra Quiet Resonator in RP section, Magnaflow 3 1/2" exhaust tip, Mazdaspeed CAI w/air straightener and K&N conical filter, NGK 6510 Iridium IX one step colder plugs, Hypertech tune, Autotech HPFP internals, Stock BPV (works perfectly), Yokohama Advan Neova AD08R's (stock size on stock rims); Hawk HPS pads; SURE RMM; Grimmspeed EBCS (2 port mode), Bilstein B6's, SPC rear camber arms. Last edited by MSMS3; 01-08-2020 at 11:32 AM. | |
| The Following User Says Thank You to MSMS3 For This Useful Post: | Db09ms3 (01-08-2020) |
![]() | | #24 | ![]() |
| Not Ranked : 0 score catless also came with more fuel smell so it would be hard to convince her that you are eco friendly with it... but just ask here to take a step backward and look at everything overall to weight the impact of your small hatch over the world and it won't make any difference....Most of the bike allowed to use reserved lane among the electric cars don't have any cat installed either... the difference won't be much important in hp but in spool and torque response.
| The Following User Says Thank You to Jeff23spl For This Useful Post: | joefromkocomo (01-08-2020) |
![]() | | #25 | ![]() |
| Not Ranked : 0 score dyno numbers are 1 thing but more powerband is what will let you win a race. And dyno numbers are scaled differently from place to place so if you have the place to test run and log, a proper etune is similar or sometimes better than a dyno tune because you run in real conditions... Ps i mention French Canadian in my sign just in case someone would think i'm retarded or never went to school because of my grammar... but if you compare our French or behaviors, it would be similar to comparing Texan English to British...Btw if one would like to learn some or our expressions, he could search for french and piper blush on youtube...
![]() | | #26 | ![]() |
![]() | | #27 | ![]() |
back to cars, i would agree our specialized tuners know pretty well the k04 and probably have tune ready for each intake and exaust setup but because our engine get old, worn and could have been repaired, it may not react exactly like another one with the same setup...(valves lash, shifted crank sensor, loose timing chain vs tight one, clogged valves vs clean ones etc etc...) You would better get the full etune process from them with dataloging and finetune for your specific install for the best results...
__________________ Mazda for life...or until i can afford something better... 2007 rusted Speed6... Forged with meth and a 3076 in progress... 1993 Ford Probe KLZE 143dB 2012 Mazda3 Gs-sky 6.5l/100 when transporting speed parts 1989 GM 6.2 diesel pickup Wife drive 2010 CX7 2007 speed3 burned (i'm proud to ran 12.7s with it) ...Because French Canadian... If you check for leaks and you didn't made a test under compressor pressure, you aren't done checking for leaks.... | |
![]() | | #28 | ![]() |
![]() | | #29 | ![]() |
| Not Ranked : 0 score Our cars and engine are relatively rare. The experienced e-Tuners mentioned above have vast experience accumulated over many years tuning this engine safely and powerfully for each of the many different combinations of turbos, intakes, exhausts, intercoolers and other mods. The chances of a local hometown tuner having tuned even one MS3 or MS6 is very low, and involving the same turbo/intake/exhaust combination or doing 3 port EBCS tuning will be just about zero. One mistake on one false tuning assumption will blow this engine in a heartbeat. This is not a one size fits all tuning solution when going big turbo.
![]() | | #30 | ![]() |
I do have a specific question about tuning with exhaust though. Say I install and aftermarket downpipe and keep the stock CBE on it and get it tuned. If I change over to the HKS catback will I need to retune? My research is telling me that the CBE has very little to do with power gain, and more to do with sound production. Or am I mistaken and will this change the back pressure of the exhaust system such that I will need to have it retuned? I'm leaning towards just waiting until I have the full exhaust system that I want to put on it to install it anyway, but if the answer is that changing the CBE has no effect whatsoever... I might change the order of how I do it.
![]() | | #31 | ![]() |
Groans: 87
__________________ 2018 Audi RS3 2013 CWP Mazdaspeed3 - CS Turbo 2007 Acura TSX 6MT | |
| The Following User Says Thank You to tegxsi For This Useful Post: | joefromkocomo (01-14-2020) |
![]() | | #32 | ![]() |
| Not Ranked : 0 score I agree with this. In theory, if you’ve addressed the serious upstream exhaust restrictions (dp and midpipe low flow cats), both exhausts will then be outflowing the turbo. You probably would not need to retune. But, only by data logging would you know. If you change exhaust flow you want to watch AFR under load to make sure you stay safely on the rich side, look to see that you are not pulling timing and that you do not start seeing any boost creep. I don’t think you will on a good tune, but log with any change.
| The Following User Says Thank You to MSMS3 For This Useful Post: | joefromkocomo (01-14-2020) |
![]() | | #33 | ![]() |
__________________ '07 Mazdaspeed3 Mostly Stock... for now. | ||
![]() | | #34 | ![]() |
(Thread Starter) | Not Ranked : 0 score Jesus. So last night I was driving and giving it a little gas from 3k in 3rd gear, still on the Cobb Stage 0 which is allegedly a simulated stock map. I look down at my AP after a quick pull from 30-60 and see that the upper bound of my boost number was ~17.6 lbs. I know for damn sure a stock map should be tuned with a boost target of 15.5-15.6 lbs. I started logging so I could take a look at home to see what was going on, and sure enough I had one cell of boost spike. Shifting from 3rd to 4th, as soon as the turbo spooled in 4th it spiked to 17.68 lbs. I know the K04 is capable of 18-19 lbs safely, but if I'm 2 lbs over target that doesn't seem too great. No KR reading at all. I'm really just thinking of uninstalling the AP until it's time for tuning at this point. Am I thinking correctly, or am I just paranoid? Datalog attached.
![]() | | #35 | ![]() |
Please re-take some datalogs and include the following logging parameters (some things were missing in your log, and other unnecessary parameters were present). Note that a proper WOT datalog should be taken on a flat, smooth, straight road and it should begin just under 3000rpm and run to at least 6000rpm in a single gear (preferably 3rd or 4th). Accelerator Pedal Position Actual AFR Boost (psi) Boost Air Temp Calculated Load Coolant Temp HPFP Actual Pressure Inj. Duty Cycle Intake Temp Intake Valve Adv. Knock Retard Long Term Fuel Trims (LTFT) MAF Voltage MAF Airflow RPM Short Term Fuel Trim (STFT) Spark Advance Throttle Position (not throttle duty cycle) Vehicle Speed Wastegate Duty
| The Following User Says Thank You to Vansquish For This Useful Post: | joefromkocomo (01-18-2020) |
![]() | | #36 | ![]() |
tegxsi: I don't think what I was doing there would be considered true WOT. I wasn't on a stretch of road where I felt good really laying into it for a true WOT pull. More like I saw something I didn't like and wanted to take a quick log to see if it did it again and was something I needed to look further into. Of course this is all speculation, I'll just get a proper datalog and post again with real data instead of speculative bullshit.
![]() | | #37 | ![]() |
Groans: 87
Log looks ok. Looks very lean for stage 0. Was the pedal to the floor at WOT? I don't see the pedal and throttle% in the log. Stock/Stage 0 tune is actually a load targeting map so the amount of boost you see can vary based on intake temperatures. You will see a bit of overshoot on this map since the wastegate tables are aggressive.
| The Following User Says Thank You to tegxsi For This Useful Post: | MSMS3 (01-18-2020) |
![]() | | #38 | ![]() |
| Not Ranked : 0 score don't worry much if it happen just for 1 cell, everything electronically controlled remain mechanic with some kind of latency on the response. Especially in third gear and winter time, it is where your turbo spool the quickest...
| The Following User Says Thank You to Jeff23spl For This Useful Post: | MSMS3 (01-18-2020) |
![]() | | #39 | ![]() |
One cell of 17 psi is not harmful and might be pure anomaly, since it never recurred. OP might want to consider VersaTune as an option. Their stock maps are held in high regard. He can still use his AP for datalogging.
| The Following User Says Thank You to MSMS3 For This Useful Post: | joefromkocomo (01-18-2020) |
![]() | | #40 | ![]() |
(Thread Starter) | Not Ranked : 0 score Alright, 2 logs. First one in 3rd, second one in 4th. Had to cut it off a little before 6k on the 4th log, didn't want to be hooning it up somebodies butt and I was little closer to them than I felt comfortable with.
| Need help with spike | Zak | MazdaSpeed 3/6 - ECU Computer Tuning | 4 | 02-09-2011 07:59 PM |
| WTF is this spike? | Jarods7920 | Cobb ATR Support | 1 | 12-14-2010 05:19 PM |
| Spike of KR only happens sometimes at WOT | Lex | MazdaSpeed 3 - Engine, Transmission & Driveline | 26 | 07-08-2009 09:37 AM |
| Strage KR Spike | badams118 | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 3 | 01-31-2009 05:38 PM |
