  • 1 Post By Vansquish
 Old 04-06-2016, 05:33 PM   #1
Ms6ownersblike's Avatar
Posts: 9   (View Stats)
Ms6ownersblike can only hope to improve
Groaned at 9 Times in 9 Posts
Default Any wastegate options that will fit ms6 stock turbo!?
Is there any options for a different wastegate for a stock ms6 turbo?
May be a dumb question. Just looking for answers
Thanks
Ms6ownersblike is offline   Reply With Quote
The Following User Says NO Thank You to Ms6ownersblike For This Un-useful Post:
Vansquish (05-23-2016)
 Old 04-06-2016, 05:48 PM   #2
Omega's Avatar
Posts: 441   (View Stats)
searching google brings up pretty viable results.... just saying...
Forge Motorsport Piston Turbo Actuator Kit Mazdaspeed 3 6 MS3 MS6
2006 Super Clean BCM MS6
 Old 04-06-2016, 06:50 PM   #3
Is this going to give me the beautiful vband sound like a 44mm tial would?
Vansquish (04-06-2016)
 Old 04-06-2016, 07:14 PM   #4
Omega's Avatar
No I assumed you were talking wastegate actuator because the stock turbo has an internal wastegate..... You would need to get a manifold and block the wastegate.... Makes no sense on stock...
There are plenty of options for EWG on big turbos
 Old 04-06-2016, 07:17 PM   #5
gdawg25's Avatar
Posts: 248   (View Stats)
gdawg25 is the leader of the worldgdawg25 is the leader of the worldgdawg25 is the leader of the worldgdawg25 is the leader of the worldgdawg25 is the leader of the worldgdawg25 is the leader of the worldgdawg25 is the leader of the worldgdawg25 is the leader of the worldgdawg25 is the leader of the worldgdawg25 is the leader of the worldgdawg25 is the leader of the world
That would require an external wastegate. Keep searching. It is possible with the stock turbo, but requires an after market exhaust manifold with the ewg port and you would need a means of closing the stock iwg.
@Omega; you beat me to it.
'08 MS3 // Corksport Turbo // JBR 3.5" WP // CNT Racing Turbo-Back // CX Racing FMIC // COBB AP // SURE Ventus // SURE Return // Damond Motorsports PMM & TMM // SURE Torq R3 // Stratified Guardian Angel // Autotech HPFP Internals // JBR EBCS // Corksport 3.5bar MAP // JBR S2 OCC // JBR EGR Delete // JBR TIG's // CP-e Safe Seals // SURE Shortcut // Corksport Swaybars // Bilstein Sports // H&R Springs // Tenzo R Type M 18"x8" // Michelin PSS
Last edited by gdawg25; 04-06-2016 at 07:17 PM. Reason: MSF Database - Automerged Doublepost
gdawg25 is offline   Reply With Quote
The Following User Says Thank You to gdawg25 For This Useful Post:
 Old 04-06-2016, 07:51 PM   #6
Police - Grammarhead
Vansquish's Avatar
The OP is strong with the rice side of the force...
 Old 04-06-2016, 08:00 PM   #7
Omega's Avatar
Haha, I saw your post right after mine. I seriously thought he meant actuator because who the hell would ask about a replacement "wastegate" on stock turbo. As soon as I saw the second post I just had to go in, a lot of time and money to waste just for sound.
Might as well make a boost actuated exhaust cutout if that's what you want...
The Following 2 Users Say Thank You to Omega For This Useful Post:
MS3Shadow (04-06-2016), Vansquish (04-06-2016)
 Old 04-06-2016, 08:21 PM   #8
jtday's Avatar
Posts: 650   (View Stats)
Just need one of these bad boys.
2009 MS3 GT
For You BT/Turbo Noobs - I haz Wastegate? helmetface MazdaSpeed 3/6 - Turbo Induction 9 09-20-2011 06:20 PM
How to connect the stock wastegate solenoid to an external wastegate cageyvet MazdaSpeed 3/6 - Turbo Induction 0 03-17-2010 05:02 PM
Modded stock turbo options, yes that is a 3" bellmouth.... ptperformance Mazdaspeed3/6 General Discussion 128 05-09-2009 04:53 PM
Page generated in 0.28316 seconds with 24 queries
