 Old 08-13-2016, 06:57 AM   #1
mrQQ's Avatar
Posts: 1,164   (View Stats)
Default anyone did the foglight mod on MS6? HID flickers?
Hi,
I wanted to do the foglight mod on my MS6. I found the foglight relay, I found the wire which gets ground when headlights come on. I connected the wire to ground permanently, so now I can switch on foglights whenever I want, but once I do that, HID's (low beam) start to flicker.
What am I doing wrong?
mrQQ is offline   Reply With Quote
 Old 08-31-2016, 05:11 PM   #2
Givemhell's Avatar
Posts: 27   (View Stats)
Givemhell is a glorious beacon of lightGivemhell is a glorious beacon of lightGivemhell is a glorious beacon of lightGivemhell is a glorious beacon of lightGivemhell is a glorious beacon of light
Originally Posted by mrQQ View Post
Hi,
You need to find a anti-flicker relay. should be able to find one on amazon or ebay
Givemhell is offline   Reply With Quote
 Old 09-01-2016, 02:48 PM   #3
SSinstaller's Avatar
Posts: 3,989   (View Stats)
Groans: 60
Disconnect whatever you did asap.
If you have drls you need to cut two wires at the auto light off control module, and then connect them togeather.
If you dont have drls you cut one wire at the fog relay and connect the relay side to 12v constant.
 Old 09-05-2016, 12:41 PM   #4
mrQQ's Avatar
when I say DRLs I mean custom leds I have installed, they are not connected to anything except battery, and turn on once generator starts charging (eg voltage gets >13v).
Not sure how this should impact HIDs though..
 Old 09-05-2016, 06:00 PM   #5
white devil's Avatar
Posts: 126   (View Stats)
white devil is a splendid one to beholdwhite devil is a splendid one to beholdwhite devil is a splendid one to beholdwhite devil is a splendid one to beholdwhite devil is a splendid one to beholdwhite devil is a splendid one to beholdwhite devil is a splendid one to beholdwhite devil is a splendid one to behold
By DRLs, I believe he is just referring to the manner in which your lights turn on. Meaning, as soon as you turn on the car, they turn on automatically. Here in the states, they dont and we physically have to turn them on.
white devil is offline   Reply With Quote
How to: CX-7 Standalone Foglight Mod Raider CX-7 > How-To's 6 07-21-2017 09:14 AM
rear foglight maxed_out_saloon MazdaSpeed 3/6 - Appearance 0 04-26-2011 09:50 AM
Hid Foglight Coversion Rican219 MazdaSpeed 6 - How-To's 53 03-22-2011 10:32 PM
Page generated in 0.26265 seconds with 23 queries
