  • 1 Post By mateo
 Old 11-22-2019, 09:56 PM   #1
mateo's Avatar
Posts: 11   (View Stats)
mateo is an unknown quantity at this point
Default BLOWN ENGINE ON MY DD!!
gas pedal slipped under weather tech mats while doing a pull and caused an unintended redline hold. I'm almost positive my engine exploded and is toast. had to walk my ass home with no phone and on the way back walking I found chunks on the road looks like cast aluminum. when I get back to where the car is I check it out and the top looks normal but there's obviously something busted on the bottom of the engine and oil everywhere. this an accidental zzb? this is my daily driver. I only have RMM, 3in intake, and an AP with a freektune map. I really don't know how to go about this and honestly any help would really be great. also if anyone has the stock map to a first gen thatd be really helpful incase I have to put the stock intake and airbox back on to sell. thanks everyone.
mateo is offline   Reply With Quote
 Old 11-22-2019, 09:58 PM   #2
Wcdfmt510's Avatar
Posts: 40   (View Stats)
Wcdfmt510 will become famous soon enoughWcdfmt510 will become famous soon enough
The stock(factory), map should be stored on the AP
Sent from my Moto Z (2) using Tapatalk
Wcdfmt510 is offline   Reply With Quote
 Old 11-22-2019, 10:00 PM   #3
mateo's Avatar
yeah it should be but my stupid ass didn't back it up when I had the option
 Old 11-22-2019, 10:27 PM   #4
Tres3's Avatar
Posts: 61   (View Stats)
Tres3 is a splendid one to beholdTres3 is a splendid one to beholdTres3 is a splendid one to beholdTres3 is a splendid one to beholdTres3 is a splendid one to beholdTres3 is a splendid one to beholdTres3 is a splendid one to behold
It's toast. I'm sorry for your loss.ask me how I know.
$4k-ish for someone else (that you trust) to put in a used long block. Maybe a little less. If you un-marry the AP, it'll put it back to stock, and you can sell it and the mods separately, if that's the way you go.
3 or 6 and what year and miles? Where are you located?
_____________
2006 Platinum MS6 GT
zzb at 156k - stock 2013 gen2 replacement - Cobb APv3, Fidanza LW Flywheel/Luk clutch, CorkSport BPV, Cobb SRI
Last edited by Tres3; 11-22-2019 at 10:27 PM. Reason: MSF Database - Automerged Doublepost
Tres3 is offline   Reply With Quote
 Old 11-23-2019, 12:09 AM   #5
mateo's Avatar
07 speed 3. I'm in Eugene, Oregon man. I'm trying to even think about where to start if I'm gonna get a new engine. it seems like such an expensive process. the mileage is around 126k
I have a powertrain warranty through my credit union since this is my dd im trying to see if it'll cover my ass if not then ... fuck
 Old 11-23-2019, 07:09 AM   #6
Rose City Speed6's Avatar
Posts: 55   (View Stats)
Rose City Speed6 is a name known to allRose City Speed6 is a name known to allRose City Speed6 is a name known to allRose City Speed6 is a name known to allRose City Speed6 is a name known to allRose City Speed6 is a name known to all
Groaned at 3 Times in 1 Post
I hope the warranty claim works out.
Rose City Speed6 is offline   Reply With Quote
 Old 11-23-2019, 07:16 AM   #7
Tres3's Avatar
If it helps, my MS6 went almost 5 years ago at 156k. Got a Gen 2 engine transplanted and should roll over 300k miles in the next month or two.
Mods and warranties don't mix, but hopefully they'll cover it. Good luck.
_____________
 Old 11-23-2019, 07:28 AM   #8
mateo's Avatar
it seems like stocking out for now is the way to go before taking it anywhere then. I need to switch out the intake put my ecu back in place and change the RMM back if that will make a difference.. when your engine blew how did you go about it as far as actually getting a new motor and getting it installed? I appreciate your replies very much
me too. it says engine included. we'll see how much of it tho.
Last edited by mateo; 11-26-2019 at 03:26 PM. Reason: MSF Database - Automerged Doublepost
 Old 11-23-2019, 05:04 PM   #9
Tres3's Avatar
Do you have a shop you trust -really trust- to do it? If so, talk with them first. I sourced my engine myself and had it drop shipped to my shop. (I'm in Texas).
Post in Mazdaspeed Owners on FB. There are several salvage guys there who are pretty reputable. I like Salvage Performance, and they ship anywhere, but three are other good ones that may be closer to you. Look at their FB or their eBay store just to see what they have and to get an idea on cost.
After you have a better feel for what it will take, make a decision.
_____________
 Old 11-23-2019, 05:13 PM   #10
mateo's Avatar
I see they have a gen 2 engine with 41k..
would it be stupid to have my local Mazda do the swap? I've tried reaching out to a few people that I've seen are in the area and just requested to join the nator OR Facebook page so maybe I can find a trusted local shop by Monday when I have to make a move.
 Old 11-23-2019, 06:57 PM   #11
Tres3's Avatar
Trust your Nator. The dealer would do it right, but with a new crate and will cost way more.
_____________
The Following User Says Thank You to Tres3 For This Useful Post:
cyclist20 (11-26-2019)
 Old 11-25-2019, 06:22 AM   #12
Posts: 2,235   (View Stats)
time for another engine, your bloc is likely destroyed and could probably not be rebuild
check speed and also cx7 used engine...The best is probably to get one with a warranty and best if the install job goes with it. You will have like 3months or more to check if the engine is ok
Usually it doesn't blow because of redline but because of being loaded below 3000rpm with knock....this can break or weaken a rod or the rod bearing...But i know it won't help for now but maybe if you keep the car....
 Old 11-25-2019, 06:35 AM   #13
LenSpeed6's Avatar
Posts: 164   (View Stats)
welcome to the zzb club.
06 Speed6
White/Black interior
 Old 11-26-2019, 10:30 AM   #14
mateo's Avatar
ended up ordering a new block and turbo under partial 3rd party warranty, Mazda price matched a local shop and that saved me a little but still fucked in the ass
Db09ms3 likes this.
 Old 11-26-2019, 11:10 AM   #15
Tres3's Avatar
Good luck.
_____________
 Old 11-26-2019, 11:31 AM   #16
If it is really a genuine and new engine this, it is way better than most of any other options.
 Old 11-26-2019, 03:33 PM   #17
mateo's Avatar
remanufactured block with 0 miles and a new turbo, 100k warranty. I'm glad to hear that it's probably the way to go from someone other than myself
 Old 11-26-2019, 05:01 PM   #18
Tres3's Avatar
That's the best way long term. Glad you are staying in the fam.
_____________
 Old 11-26-2019, 08:07 PM   #19
tripppleP's Avatar
Posts: 97   (View Stats)
Sorry to hear of your misfortune. A new engine is much cheaper than a new car though. Good luck with the process.
2010 Black MazdaSpeed 3
80k+ miles
CS RMM
Damond PMM
Autotech HPFP
JBR solid shift bushing
DM short shift plate
HPS SRI
G-plus TIP
CP-e TMIC
AP V3 Stage 1 +SF
Blown Engine??? MaleJadeLy Mazdaspeed3/6 General Discussion 42 02-20-2016 10:19 PM
Blown engine... C9H13NO3_rush MazdaSpeed 6 - Engine, Transmission & Driveline 27 06-06-2014 08:54 PM
blown engine... Val MazdaSpeed 3/6 - Troubleshoot/Diagnostics 32 02-03-2012 08:56 AM
Blown engine stupidslow_ms3 Mazdaspeed3/6 General Discussion 53 05-06-2011 07:40 PM
Page generated in 0.37463 seconds with 26 queries
