![]() Join Date: Sep 2019 Location: PNW
Rep Power: 0 ![]() Thanks: 0
![]() Join Date: Apr 2016 Location: TRACY CA
| Not Ranked : 0 score The stock(factory), map should be stored on the AP Sent from my Moto Z (2) using Tapatalk |
![]() Join Date: Aug 2011 Location: Boerne, TX
Rep Power: 112 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 39
| Not Ranked : 0 score It's toast. I'm sorry for your loss.ask me how I know. $4k-ish for someone else (that you trust) to put in a used long block. Maybe a little less. If you un-marry the AP, it'll put it back to stock, and you can sell it and the mods separately, if that's the way you go. 3 or 6 and what year and miles? Where are you located?
__________________ _____________ 2006 Platinum MS6 GT zzb at 156k - stock 2013 gen2 replacement - Cobb APv3, Fidanza LW Flywheel/Luk clutch, CorkSport BPV, Cobb SRI Last edited by Tres3; 11-22-2019 at 10:27 PM. Reason: MSF Database - Automerged Doublepost |
I have a powertrain warranty through my credit union since this is my dd im trying to see if it'll cover my ass if not then ... fuck | |
![]() Join Date: Jan 2016
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 24
Groaned at 3 Times in 1 Post
| Not Ranked : 0 score I hope the warranty claim works out. |
Mods and warranties don't mix, but hopefully they'll cover it. Good luck.
__________________ _____________ 2006 Platinum MS6 GT zzb at 156k - stock 2013 gen2 replacement - Cobb APv3, Fidanza LW Flywheel/Luk clutch, CorkSport BPV, Cobb SRI | |
me too. it says engine included. we'll see how much of it tho. Last edited by mateo; 11-26-2019 at 03:26 PM. Reason: MSF Database - Automerged Doublepost | |
| Not Ranked : 0 score Do you have a shop you trust -really trust- to do it? If so, talk with them first. I sourced my engine myself and had it drop shipped to my shop. (I'm in Texas). Post in Mazdaspeed Owners on FB. There are several salvage guys there who are pretty reputable. I like Salvage Performance, and they ship anywhere, but three are other good ones that may be closer to you. Look at their FB or their eBay store just to see what they have and to get an idea on cost. After you have a better feel for what it will take, make a decision.
would it be stupid to have my local Mazda do the swap? I've tried reaching out to a few people that I've seen are in the area and just requested to join the nator OR Facebook page so maybe I can find a trusted local shop by Monday when I have to make a move. | |
| Not Ranked : 0 score Trust your Nator. The dealer would do it right, but with a new crate and will cost way more.
| The Following User Says Thank You to Tres3 For This Useful Post: | cyclist20 (11-26-2019) |
| Not Ranked : 0 score time for another engine, your bloc is likely destroyed and could probably not be rebuild check speed and also cx7 used engine...The best is probably to get one with a warranty and best if the install job goes with it. You will have like 3months or more to check if the engine is ok Usually it doesn't blow because of redline but because of being loaded below 3000rpm with knock....this can break or weaken a rod or the rod bearing...But i know it won't help for now but maybe if you keep the car....
![]() Join Date: Sep 2017 Location: Western Mass
Rep Power: 43 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9
| Not Ranked : 0 score welcome to the zzb club.
__________________ 06 Speed6 White/Black interior Sure Diff Mounts, JBR Intake, JBR I/C Hoses, Wiesco pistons .5mm over, Molnar H-Beam Rods, King bearings, New to me Cylinder Block, CS turbo, CS catted turbo back exhaust, CS HPFP, CS EBCS, CS injector seals, AP v3, FREEKTUNE, rebuilt clutch from Falcon Clutch with kevlar lining, DM PCV plate, DM stage 1 OCC, EcoBoost oil pump, vented oil cap with baffle, Speed Solutions PTO bearing caps, All Damond mounts To think... this is suppose to be my winter car... because, '72 AMC Javelin AMX 366 CI, 4speed 13.13 quickest 1/4 mile et so far '12 1/2 Triumph Daytona 675R stock some how '79 AMC Spirit AMX, 4.6L stroker I6 |
| Not Ranked : 0 score Good luck.
| Not Ranked : 0 score If it is really a genuine and new engine this, it is way better than most of any other options.
| Not Ranked : 0 score That's the best way long term. Glad you are staying in the fam.
![]() Join Date: Jan 2019
Rep Power: 20 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14
| Not Ranked : 0 score Sorry to hear of your misfortune. A new engine is much cheaper than a new car though. Good luck with the process.
__________________ 2010 Black MazdaSpeed 3 80k+ miles CS RMM Damond PMM Autotech HPFP JBR solid shift bushing DM short shift plate HPS SRI G-plus TIP CP-e TMIC AP V3 Stage 1 +SF |
| Display Modes | |
| Blown Engine??? | MaleJadeLy | Mazdaspeed3/6 General Discussion | 42 | 02-20-2016 10:19 PM |
| Blown engine... | C9H13NO3_rush | MazdaSpeed 6 - Engine, Transmission & Driveline | 27 | 06-06-2014 08:54 PM |
| blown engine... | Val | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 32 | 02-03-2012 08:56 AM |
| Blown engine | stupidslow_ms3 | Mazdaspeed3/6 General Discussion | 53 | 05-06-2011 07:40 PM |
