 Old 02-15-2012, 12:25 PM   #1
sacredmonkey's Avatar
Posts: 12   (View Stats)
sacredmonkey will become famous soon enough
Default Blown Turbo?????
Hey all, back with another question. I'm new to turbo induction and the sounds a turbo and the bypass valve makes. Since I just bought the car I have been listening to any and every noise this car makes. And every time the turbo spools up and i shift (let off the gas) I hear the let off of the pressure through the bypass valve...but, as i was jumping on the highway today to get to school I realized that while I was shifting I wasn't hearing any bypass valve shwoosh that i usually hear. Maybe I'm just freaking out over nothing, but it sounds weird to me.
thanks for any advice.
sacredmonkey is offline   Reply With Quote
 Old 02-15-2012, 12:27 PM   #2
What are your modifications.
If not modified, then it is fine, and you need to read some stickies, like in my sig.
 Old 02-15-2012, 12:34 PM   #3
ms6forthewin's Avatar
Posts: 525   (View Stats)
ms6forthewin is the leader of the worldms6forthewin is the leader of the worldms6forthewin is the leader of the worldms6forthewin is the leader of the worldms6forthewin is the leader of the worldms6forthewin is the leader of the worldms6forthewin is the leader of the worldms6forthewin is the leader of the worldms6forthewin is the leader of the worldms6forthewin is the leader of the worldms6forthewin is the leader of the world
If your car is stock it should barely make any sound, you'll her the woosh sound if you get a after market bpv/bov or a intake.
Donate
-2014 Evo X GSR
-2007 MAZDASPEED 6 (SOLD)
BNR S3// ALL-SUPPORTING MODS
ms6forthewin is offline   Reply With Quote
 Old 02-15-2012, 12:40 PM   #4
ABSpeed3's Avatar
Posts: 698   (View Stats)
ABSpeed3 is the leader of the worldABSpeed3 is the leader of the worldABSpeed3 is the leader of the worldABSpeed3 is the leader of the worldABSpeed3 is the leader of the worldABSpeed3 is the leader of the worldABSpeed3 is the leader of the worldABSpeed3 is the leader of the worldABSpeed3 is the leader of the worldABSpeed3 is the leader of the worldABSpeed3 is the leader of the world
Groans: 133
Groaned at 7 Times in 4 Posts
Did you feel a noticeable reduction in power? How hard were you accelerating?
08.5 CWP MS3 GT
PG Intake, TIP | Forge BPV | M2 Catless DP | HKS Catback | Cp-e FMIC| Autotech Internals | Self Tune | Bilstein Shocks | SPC Camber Arms | H&R Springs | Progress RSB | JBR SSP, Bushings, PMM | TWM Shift Knob | TRZ RMM, TMM | TRM C3 17x9| Dunlop Star Spec ZII (245/40) | Matt Damon OCC
ABSpeed3 is offline   Reply With Quote
 Old 02-15-2012, 12:53 PM   #5
No mods. But ms6ftw, I could definitely still hear the turbo and bpv noise quite well when the radio isn't on. and ABSpeed3 i was in 4th gear around 4k rpm still accelerating at probably 65% throttle. its on a on-ramp that I do this frequently because it goes from the ramp to a straight where I like to get on it.
Slight reduction of power. I didn't get the surge of power that I usually do, it felt like I was driving my old mazda 2.3 N/A
 Old 02-15-2012, 12:55 PM   #6
TRex's Avatar
Posts: 3,139   (View Stats)
if you are stock and you havent built up a lot of pressure then you will not hear it most of the time
on an unrelated note how the hell are you not being flamed to holy hell?
The Following 3 Users Say Thank You to TRex For This Useful Post:
dereeek (02-15-2012), karl-hungus (02-15-2012), Worbit (02-15-2012)
 Old 02-15-2012, 01:27 PM   #7
patrick failman
karl-hungus's Avatar
Posts: 4,635   (View Stats)
Groans: 74
possible efop (evo friend of phil).
 Old 02-15-2012, 12:59 PM   #8
weakdog85's Avatar
Posts: 493   (View Stats)
weakdog85 is the leader of the worldweakdog85 is the leader of the worldweakdog85 is the leader of the worldweakdog85 is the leader of the worldweakdog85 is the leader of the worldweakdog85 is the leader of the worldweakdog85 is the leader of the worldweakdog85 is the leader of the worldweakdog85 is the leader of the worldweakdog85 is the leader of the worldweakdog85 is the leader of the world
correct me if i'm wrong but wouldn't a little heat soak change the sounds a bit. i feel like when my car is cold i hear tubro/bpv a little more than when it's warmed up.
07 MS6 Sport.............
JBR Shifter Bushings * JBR RMM * JBR PMM * SURE SRI * VG Sharkfin Antenna * 20% Tint * Cobb AP * Grimmspeed EBCS * Coolant Bypass * PG TIP * Autotech Internals *
weakdog85 is offline   Reply With Quote
 Old 02-15-2012, 01:06 PM   #9
Ahhhhh, heat soak, I was in traffic before I hit the highway. That could be it, I totally forgot about that. I'll see if it does it again when I go to work tonight.
Thanks for the quick responses.
 Old 02-15-2012, 01:42 PM   #10
TRex's Avatar
ahh efop i c....well.....boo....
 Old 02-15-2012, 01:56 PM   #11
pebenito's Avatar
Posts: 249   (View Stats)
pebenito is the leader of the worldpebenito is the leader of the worldpebenito is the leader of the worldpebenito is the leader of the worldpebenito is the leader of the worldpebenito is the leader of the worldpebenito is the leader of the worldpebenito is the leader of the worldpebenito is the leader of the worldpebenito is the leader of the worldpebenito is the leader of the world
Is it cold where you are? Could it be you're hitting load targets w/less boost?
2008.5 MGM Mazdaspeed 3 GT
Cobb AP | cp-e SRI | cp-e TMIC | UR TP | cp-e RMM | JBR SSP | JBR Spherical Shift Knob | JBR RSB | Autotech HPFP | Spin-on
pebenito is offline   Reply With Quote
Another Blown Turbo... dcamp2 Gen2 MS3 General Discussion 75 06-29-2012 11:35 AM
Blown Turbo JD80 Gen2 MS3 General Discussion 23 07-27-2011 09:23 PM
blown turbo h0rsies MazdaSpeed 3/6 - Turbo Induction 1 07-07-2010 06:42 AM
missfire? and also blown turbo? wisniaPl MazdaSpeed 3/6 - Troubleshoot/Diagnostics 28 05-04-2009 03:55 PM
Page generated in 0.31652 seconds with 27 queries
