![]() Join Date: Jun 2016
Rep Power: 0 ![]() Thanks: 0
Groaned at 5 Times in 1 Post
(Thread Starter) | Not Ranked : 0 score Last edited by Jmachete; 06-05-2016 at 01:22 PM. |
| The Following 5 Users Say NO Thank You to Jmachete For This Un-useful Post: | InkedInspector (06-05-2016), jtday (06-05-2016), MD1032 (06-06-2016), Vansquish (06-05-2016), WetzMS3 (06-06-2016) |
![]() Join Date: Nov 2015 Location: Australia
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14
| Not Ranked : 0 score Few reasons, read up there are huge info from this forum. My guess is, its coming from your turbo oil seals. common problem with a K04. |
![]() Join Date: Mar 2011 Location: Dallas, Texas
| Not Ranked : 0 score Yes, read up. Blue smoke is oil, most likely like @MRR; said, black soot is fuel, not that regular would do that either? Maybe if it caused you to run richer due to knock.... Several solutions to the smoking turbo.... search for that :-)
__________________ Max Bolted and Built Stock K04 |
| The Following User Says Thank You to sheston For This Useful Post: | InkedInspector (06-05-2016) |
| Police ![]() Join Date: Jul 2013 Location: Louisville, KY
Rep Power: 2719 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,545
Groans: 312
| 07 on a K04, I would assume blue smoke is turbo, as others said. Time to bigger! Wouldn't hurt to go ahead and compression and leak down check the motor though.
__________________ |
![]() Join Date: Mar 2013 Location: North Brunswick, NJ
Rep Power: 1125 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,645
Groans: 143
| Not Ranked : 0 score I would definitely run a leak down test just in case. Probably the turbo, though.
__________________ 2007 Mazdaspeed3 GT |
![]() Join Date: Jun 2009
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,505
| Not Ranked : 0 score Does it smoke at idle or just when you "take off"? Either way it is oil. Could you be more descriptive of the conditions in which this occurs. Range of possibilities run from relatively benign turbo seal leak to serious engine ring blow by or worse. I agree that you need to at least do a static cylinder compression check on a warm engine. Have to pull the IC off the top, remove the plugs and test each cylinder individually. Write down the numbers and post them. Also look at each plug and take a photo of the tip. If it is oily, that is not good news. If you haven't done this already, you need to do it periodically on an older engine, anyway.
| Blue smoke | DC2 | 2010 MS3 - Troubleshoot/Diagnostics | 20 | 03-04-2016 11:12 AM |
| blue smoke | Xlude | 2010 MS3 - Engine, Transmission & Driveline | 6 | 12-17-2013 10:25 AM |
| Blue smoke under acceleration | Dsmer4ever | Mazdaspeed3/6 General Discussion | 7 | 04-17-2011 04:22 PM |
| Blue Smoke | johnnyspeed6 | MazdaSpeed 6 - Engine, Transmission & Driveline | 9 | 03-04-2010 08:31 PM |
| Blue Exhaust Smoke | JCMS07 | MazdaSpeed 3 - Engine, Transmission & Driveline | 16 | 12-02-2008 11:56 PM |
