Like Tree16Likes
 Old 03-24-2012, 08:35 PM   #41
silvapain's Avatar
Posts: 6,665   (View Stats)
Groans: 136
Here are some pics of the stock BPV.
It's hard to see, but the small port on the bottom of the BPV goes up to the middle chamber:
Tapadatass
rfinkle2 (01-11-2013)
 Old 05-03-2012, 06:26 PM   #42
Mazdazilla6's Avatar
Posts: 3,657   (View Stats)
BOV
Has anyone ever heard of this site? By no means do I intend to buy any of these but I found it fairly amusing to see an "HKS" bov for $50.
The Following User Says NO Thank You to Mazdazilla6 For This Un-useful Post:
Don06speed6 (05-08-2012)
 Old 05-08-2012, 08:15 PM   #43
Spectrum24x's Avatar
Posts: 276   (View Stats)
Spectrum24x has a reputation beyond reputeSpectrum24x has a reputation beyond reputeSpectrum24x has a reputation beyond reputeSpectrum24x has a reputation beyond reputeSpectrum24x has a reputation beyond reputeSpectrum24x has a reputation beyond reputeSpectrum24x has a reputation beyond reputeSpectrum24x has a reputation beyond reputeSpectrum24x has a reputation beyond reputeSpectrum24x has a reputation beyond reputeSpectrum24x has a reputation beyond repute
Something we did on rx7s.. Can the stock bpv be vented to the atmosphere? *flamesuit on*
2007 TRUE RED MS3 GT
RX-8 WHEELS/DRILLED & SLOTTED ROTORS
KONI YELLOW/COBB SPRINGS/JBR RSB/HOTCHKIS FSB
COBB OTS STAGE 2 MAP
RMM/COBB INTAKE/COBB TIH/ETS TMIC
OBX TEST PIPE/AUTOTECH INTERNALS/FORGE BPV V2
Spectrum24x is offline   Reply With Quote
The Following User Says NO Thank You to Spectrum24x For This Un-useful Post:
 Old 06-23-2012, 08:34 PM   #44
Don06speed6's Avatar
Posts: 2,492   (View Stats)
Don06speed6 is the leader of the worldDon06speed6 is the leader of the worldDon06speed6 is the leader of the worldDon06speed6 is the leader of the worldDon06speed6 is the leader of the worldDon06speed6 is the leader of the worldDon06speed6 is the leader of the worldDon06speed6 is the leader of the worldDon06speed6 is the leader of the worldDon06speed6 is the leader of the worldDon06speed6 is the leader of the world
Groans: 62
@Raider
Cobb AP(FREEK TUNED)/CS TBE/SURE AEROS/CPE TIH/ ITV 22/SU RMM/KMD INTERNALS/SURE DREADNAUGHT/JUGGERNAUGHT/WHITELINE RSB/SURE ANCHORS/SURE COUNTERWEIGHT/SURE SHORTCUT/JBR HEAVY KNOB/JBR EGR DELETE/SPC BALL JOINTS/CENTRIC BLANKS/HPS PADS/BNOON BOLT/ALTERED CUSTOMS FMIC/TURBO XS RFL
Don06speed6 is offline   Reply With Quote
 Old 08-05-2012, 10:45 AM   #45
Jin
Jin's Avatar
Posts: 68   (View Stats)
Jin is a jewel in the roughJin is a jewel in the roughJin is a jewel in the roughJin is a jewel in the rough
Groaned at 7 Times in 4 Posts
Originally Posted by irishking03 View Post
Actually waiting for him to add it.
Nice write up!
Get a question....will you still be able to have that "Qiu~Qiu~" sound after you convert your bov/bpv into 100% recirc mode?
Jin is offline   Reply With Quote
 Old 08-05-2012, 11:15 AM   #46
irishking03's Avatar
Posts: 2,136   (View Stats)
irishking03 is the leader of the worldirishking03 is the leader of the worldirishking03 is the leader of the worldirishking03 is the leader of the worldirishking03 is the leader of the worldirishking03 is the leader of the worldirishking03 is the leader of the worldirishking03 is the leader of the worldirishking03 is the leader of the worldirishking03 is the leader of the worldirishking03 is the leader of the world
Originally Posted by Jin View Post
Nice write up!
I think it sounds alot better in Recirc mode if you have the HKS.. I havent tried any of the others..
2009 Metro Grey Numbers Fully Bolted.
Nator Pa Dyno Day: 311HP 328TQ Pump 93
Nator Pa Dyno Day: 310HP 329TQ Pump 93
End of Drive 9/24/2013
2012 Liquid Silver
Cobb AP
irishking03 is offline   Reply With Quote
 Old 08-05-2012, 11:55 AM   #47
weakdog85's Avatar
Posts: 493   (View Stats)
weakdog85 is the leader of the worldweakdog85 is the leader of the worldweakdog85 is the leader of the worldweakdog85 is the leader of the worldweakdog85 is the leader of the worldweakdog85 is the leader of the worldweakdog85 is the leader of the worldweakdog85 is the leader of the worldweakdog85 is the leader of the worldweakdog85 is the leader of the worldweakdog85 is the leader of the world
i think yes, just disconnect the recirc hose, block it off. i'm really just guessing. lol
07 MS6 Sport.............
JBR Shifter Bushings * JBR RMM * JBR PMM * SURE SRI * VG Sharkfin Antenna * 20% Tint * Cobb AP * Grimmspeed EBCS * Coolant Bypass * PG TIP * Autotech Internals *
weakdog85 is offline   Reply With Quote
 Old 08-06-2012, 12:10 AM   #48
Jin
Jin's Avatar
Thanks.
Still get some questions....how do you turn your hks bov into recirc mode? Any other kit needed? How to install?
Thanks!!!!
 Old 08-06-2012, 09:20 AM   #49
Thanks.
Thanks!!!!
There are 8 allen keys i think around the hks that unscrew. you need to remove every other bolt and the front slides off. The fin thats gold or purple i think comes out and you have to buy the recirc kit so you can put the part in. Screw the BOV back together and than you just need to hook up the tube and boom, Recirculated BPV. I have the HKS and love it.. I think it sounds alot better than the VTA option..
2012 Liquid Silver
Cobb AP
 Old 08-13-2012, 08:04 PM   #50
KillerSaiyan's Avatar
Posts: 22   (View Stats)
KillerSaiyan will become famous soon enough
+1 on full recirc HKS.. I had Forge v2 and now I have the HKS SS v4 on full recirc and I LOVE the shit out of it
COBB AccessPort | HKS SSQ v4 | INJEN Cold Air Intake | CORKSPORT Turbo Inlet Pipe | EBAY (m2) Catless Long Downpipe | HKS Hi-Power Catback Exhaust | PTP Fuel Pump Internals | Grimmspeed EBCS | TWM Short Shifter | JBR 815 gram knob| SURE Short Shift Plate/Counterweight | STREETUNIT Shifter Bushings | STREETUNIT Rear Motor Mount | CORKSPORT SuperWhite interior LED Kit | HALO Angeleyes 7000k | DDM 6000k 35w (switching to 55w) HID Headlights | DDM 3000k 35w HID Fogs | Flat Black Evil M | Side Door Guard Removal | Evo Mod Grille| Tenzo-R dc-10 wheels| BC COILS| KENWOOD eXcelon Headunit (4v preouts) | ALPINE MRP-M500 Mono Amp (500w RMS) | ALPINE MRP-F300 4-way Amp (75w RMS x4) | ALPINE Type-R 12" Woofer | ALPINE Type-R 6.5 Door Speakersru
KillerSaiyan is offline   Reply With Quote
 Old 11-13-2012, 02:37 AM   #51
EPTSpeed3's Avatar
Posts: 67   (View Stats)
EPTSpeed3 has much to be proud ofEPTSpeed3 has much to be proud ofEPTSpeed3 has much to be proud ofEPTSpeed3 has much to be proud ofEPTSpeed3 has much to be proud ofEPTSpeed3 has much to be proud ofEPTSpeed3 has much to be proud ofEPTSpeed3 has much to be proud ofEPTSpeed3 has much to be proud ofEPTSpeed3 has much to be proud of
Anyone know if the WRX 08+ BPV or BOV work on the MS3? There are a ton of them for sale locally for pretty cheap on CL. Seen some Turboxs and Turbo Smart for as low as $70 for the hybrids.
EPTSpeed3 is offline   Reply With Quote
The Following User Says NO Thank You to EPTSpeed3 For This Un-useful Post:
faeker (11-16-2012)
 Old 11-13-2012, 03:05 AM   #52
GODspeed7's Avatar
Posts: 3,456   (View Stats)
You need to search a bit more. I know you just joined but please browse the sit a little bit and with almost 2 million posts on this site, your question will surely be answered already.
Tapatalk LIKE A BOSS!
2012 Mazdaspeed3 Black Mica
 Old 11-13-2012, 03:06 AM   #53
EPTSpeed3's Avatar
Tried searching but the search function isnt all that great. Found the BOV-BPV thread which was great so thats why i posted here.
 Old 11-13-2012, 03:16 AM   #54
GODspeed7's Avatar
3 letter shit is hard to search for. Try google as well. I am not interested in BPV's (stay away from BOV's) but now that I actually looked, looks like turbosmart is dual compatible. Who would have thought?
 Old 11-16-2012, 06:19 PM   #55
R.I.P speed6's Avatar
Posts: 5   (View Stats)
R.I.P speed6 has a little shameless behaviour in the past
ok i searched and i cant find an answer is the MAF sensor in the right spot for a BOV or do i need a convertion kit
excuse/reason for everything.... IT'S GOT AWD
R.I.P speed6 is offline   Reply With Quote
The Following User Says NO Thank You to R.I.P speed6 For This Un-useful Post:
faeker (01-06-2013)
 Old 11-16-2012, 07:02 PM   #56
faeker's Avatar
Posts: 5,091   (View Stats)
Groans: 731
what the fuck is with the brownies today?
Mods: stock
 Old 11-16-2012, 07:06 PM   #57
Rainmens's Avatar
Posts: 129   (View Stats)
Rainmens is the leader of the worldRainmens is the leader of the worldRainmens is the leader of the worldRainmens is the leader of the worldRainmens is the leader of the worldRainmens is the leader of the worldRainmens is the leader of the worldRainmens is the leader of the worldRainmens is the leader of the worldRainmens is the leader of the worldRainmens is the leader of the world
Originally Posted by RhoadBlock View Post
Doesn't Synapse have a BOV for the DISI? Or was there a fallout I missed back in the day?
Official Synapse Store | Buy our DV, BOV, and Wastegate with Synchronic Technology and more | Synapse Engineering
Yes sir, Synapse FTW! Self tuned (no shims) BPV.
304whp/360tq Vdyno 1.01 CF
Cobb AP, Sure 3" Full3 Aeros Intake, Autotech Internals, M2 DP, 3" CP-E Single Exit (w/resonator), 3.25" ETS, PnP'ed IM w/VTCS removed, 1/16"Sure TIG spacer Synapse BPV, AWR 70 Duro RMM, JBR 70 Duro TMM, Denso 1-Step Colder Plugs, TWM Shifter Bushings, SM OCC, Custom Shift Knob, Custom Shifter Weight, SURE Shorcut, H&R Springs, Tenzo DC-6 Wheels
Rainmens is offline   Reply With Quote
The Following 2 Users Say Thank You to Rainmens For This Useful Post:
mig02 (12-26-2012), rfinkle2 (01-11-2013)
 Old 11-16-2012, 07:23 PM   #58
ASHMS3's Avatar
Posts: 1,362   (View Stats)
Groans: 126
You should know the answer to this question if you have ever opened your hood. bpv is post Maf.If you vta, you are releasing metered air. You will run rich on shifts and probably have some after fires. Plenty of people around here do it anyway with no real bad side effects. some people vta and block off the recirculation tube. Some use hybrid valves like the dual port or the Cobb. really up to you, there are multiple ways to skin this cat. By the way this was all covered in the thread if you had bothered to read it.
Tappin'
 Old 12-21-2012, 09:27 AM   #59
cmatiazzo's Avatar
Posts: 7   (View Stats)
cmatiazzo is on a distinguished road
I have a 2010 and everything is Stock!!, You said "Get more mods first that matter" and Can you list them??
I really want to buy the K&N Short Intake and upgrade the stock valve to either a 50/50 BPV, I know its silly, but this is my First Turbo car and I love the idea to hear the BOV Noise, If I can have that on the 50/50 BPV, even better.
I dont race anyone or anything, But trying to decide the best for my car since I drive about 400 miles/week.
any suggestion will be more than welcome
cmatiazzo is offline   Reply With Quote
The Following 3 Users Say NO Thank You to cmatiazzo For This Un-useful Post:
faeker (01-06-2013), Raider (12-21-2012), STI_LOL (02-14-2013)
 Old 12-21-2012, 09:38 AM   #60
GODspeed7's Avatar
You need to get better at quoting people before you talk shit...
 Old 12-21-2012, 09:44 AM   #61
cmatiazzo's Avatar
[QUOTE=DaDoctor;1230318]Can anyone confirm that the cobb tuning xle bpv Model#771650 for the mazdaspeed 3 is the same as the cobb tuning xle bpv Model#724650 for the Subaru Impreza WRX 2008-2012? They look identical on cobb's website. I would save almost $50 online if I purchase the wrx one from here:
Cobb tuning 08-10+ WRX and 05-09 LGT , Engine Performance, Subaru 2008+ WRX / STI performance parts, Subaru Performance
Hi There!
I have a 2010, all Stock, I am planning to do some upgrades like, Intake and the BOV/BPV valve. Can you please let me know your suggestions and if the valve you saw on that site (cheaper than any place else) will fit my car?, since its all stock, do I need to replace anything else? plastic to metal flanges or hoses?, I will really appreciate some help. This is my first turbo car and I love it
The Following User Says NO Thank You to cmatiazzo For This Un-useful Post:
Raider (12-21-2012)
 Old 12-21-2012, 09:48 AM   #62
A BOV is not an upgrade. You suck at quoting.
Stop posting, Read your welcome PM, and the links in my sig. Then go to the Knowlegebase and read everything.
jtt (12-21-2012)
 Old 12-21-2012, 09:49 AM   #63
cmatiazzo's Avatar
Sorry, I think it was a mistake to look for help at Forums, I forgot that people like you, would flame any type of posts or questions, Am I talking shit about anything or just asking noob questions? Like I said THIS is my 1ST Turbo car and I am learning about it, If you cant help on anything, just dont answer!! See, because of people like you that I will probably not pay to be a VIP member, This is my 4th post and I am already getting all Flamed!!!
VaporOnly likes this.
Raider (12-21-2012)
 Old 12-21-2012, 09:51 AM   #64
You are getting flamed for not reading and you were already warned when you joined. Here is a link to the welcome PM and email you got, and IGNORED.
http://www.mazdaspeedforum.org/forum/foru...-email-132737/
You not going VIP is only hurting YOU, not us, junior.
silvapain (12-21-2012)
 Old 12-21-2012, 10:02 AM   #65
faeker's Avatar
Groans: 731
Neutral  -1 score
You dumb piece of living abortion; people have already answered your question. You do not need to replace your bpv. Get the fuck over that. Do not come in here, ask a question, have the answer be what you did not want to hear, and then go on to say you still want a bov without expecting to get burnt. All of the answers you will ever ask about this car have been answered on this forum. Knowledge the fuck up asshole.
tappy-tap-tappytalk
Mods: stock
 Old 12-21-2012, 01:36 PM   #66
silvapain's Avatar
Groans: 136
You already are "all flamed". We're just telling you to shut your pie hole and search.
Tapadatass
 Old 12-21-2012, 02:53 PM   #67
GODspeed7's Avatar
@Raider; how come when i tell him he sucks at quoting he goes off on me but when you groan him AND tell him he sucks at quoting he says nothing to you?! on my computer i can tell what he was trying to say but on tapatalk it was one huge run on paragraph with no spaces between sentences.
 Old 12-21-2012, 02:55 PM   #68
Because he knows you promised pics and did not deliver.
GODspeed7 (12-21-2012)
 Old 12-21-2012, 03:06 PM   #69
GODspeed7's Avatar
i honestly couldnt tell if you were talking shit or not because your sentence was a quote/comment run on jumbled mess! you were talking about mods that matter and what not. so dont get all butt hurt, just laugh it off and continue on. getting an attitude and popping off at the mouth isn't going to help you or hurt us. it was an honest mistake on both our parts. (that is as close to an apology as you will get from me so deal with it) welcome to the forum and i still advise searching. a BPV/BOVisn't going to help you completely stock. yes it may sound cooler but whats the point if you are still stock and have no AP to tune for it if you need to? not to mention the stock BPV holds boost pretty well.
wife just had a baby so she is still in her "i hate my body" mode and wont even let me touch her half the time let alone stand naked in front of me to get pics. lol i never said i wouldnt i said i would get them as soon as i got the chance.
Last edited by GODspeed7; 12-21-2012 at 03:06 PM. Reason: MSF Database - Automerged Doublepost
 Old 12-21-2012, 03:25 PM   #70
cmatiazzo's Avatar
a BPV/BOV isn't going to help you completely stock. yes it may sound cooler but whats the point if you are still stock and have no AP to tune for it if you need to? not to mention the stock BPV holds boost pretty well.
Thanks for the apology!!!!
Now We are getting somewhere, I know it sounds Dummy and everything but I have to be Honest with you and say that I really dont plan to upgrade anything for now, because of Money and few other reasons, Like I said before, this is my very first Turbo car and since I was a teenager, I liked the BOV sound and I thought would be "cool" to have that option in my car right now!, I understand that the Factory BPV holds the boost and everything else, but that dont give you the sound I was aiming for , I looked into the Short Intakes options for now and maybe later some new exhaust setup!!. I am reading everything on the "guide" and will get myself educated into these new "Turbo World".
I dont plan to go any faster, Wife is already complaining that the car is to fast!!!! lol.
BTW
MERRY XMAS TO YOU ALL
 Old 01-06-2013, 09:09 PM   #71
Evan002's Avatar
Posts: 69   (View Stats)
Evan002 has much to be proud ofEvan002 has much to be proud ofEvan002 has much to be proud ofEvan002 has much to be proud ofEvan002 has much to be proud ofEvan002 has much to be proud ofEvan002 has much to be proud ofEvan002 has much to be proud of
Groaned at 12 Times in 2 Posts
Is the HKS SSQV really worth it...
Evan002 is offline   Reply With Quote
 Old 01-06-2013, 09:27 PM   #72
faeker's Avatar
Groans: 731
Fuck right the fuck off
tappy-tap-tappytalk
Mods: stock
 Old 01-06-2013, 09:38 PM   #73
GODspeed7's Avatar
Neutral  +1 score
Ummmm yes. It's pretty much the only dedicated VTA BOV that can keep closed at idle but still give complete drivability without all of the post shift rich conditions and afterfire. Not to mention HKS has been making products for almost 30 years. Do I personally LOVE the sound? Not really. But to have a valve that is this reliable, well made, and care free is worth it to me.
The Following User Says Thank You to GODspeed7 For This Useful Post:
Evan002 (01-11-2013)
 Old 01-06-2013, 09:50 PM   #74
Evan002's Avatar
Cool then I think I will buy this week, thanks for the input
 Old 01-06-2013, 11:02 PM   #75
GODspeed7's Avatar
Unless you have at least an AP, fuel pump internals, intake, and RMM, a BOV should be the least of your worries and could be money best spent on one of those other mods.
The Following 2 Users Say Thank You to GODspeed7 For This Useful Post:
Evan002 (01-07-2013), nycMS3 (01-06-2013)
 Old 01-07-2013, 12:25 AM   #76
Evan002's Avatar
I agree completely with you, but I really want the sound. I have a CS SRI with TIP and RMM. When I get my next profit sharing I'm going to buy the HPFP and AP, if I have enough money left over I'm going to get a DP also.
 Old 01-11-2013, 06:49 AM   #77
Dr. Speed's Avatar
Posts: 610   (View Stats)
Dr. Speed is the leader of the worldDr. Speed is the leader of the worldDr. Speed is the leader of the worldDr. Speed is the leader of the worldDr. Speed is the leader of the worldDr. Speed is the leader of the worldDr. Speed is the leader of the worldDr. Speed is the leader of the worldDr. Speed is the leader of the worldDr. Speed is the leader of the worldDr. Speed is the leader of the world
Could someone add the GFB BPV to the list here? I know it's talked about elsewhere, but it would be nice to have everything consolidated here since the Go Fast Bits part is a very good and relatively newly-discovered option.
On another note, it's interesting how it is now 2013 and there are still so many damn people who just don't have a clue when it comes to proper forum etiquette. There's never a shortage of brownies wasting space and getting butthurt in otherwise useful threads is there?
| 2012 CWP | Cobb AP + AT Internals | HTP 3" Intake | 91oct + DO WMI (D07, 50/50) + 3gal E85 | UR Test Pipe | cp-e TMIC | JBR Trilogy, OCC, EGR Block, SSB | TBC Bypass |
Freektuned - 313/351 - Stock DP
Dr. Speed is offline   Reply With Quote
The Following User Says Thank You to Dr. Speed For This Useful Post:
 Old 01-11-2013, 07:01 AM   #78
I'll add it this weekend. Thanks
Razr-Maxx-Tapa-Talking-2
2012 Liquid Silver
Cobb AP
The Following 2 Users Say Thank You to irishking03 For This Useful Post:
Dr. Speed (01-11-2013), rfinkle2 (01-11-2013)
 Old 01-25-2013, 03:06 PM   #79
esestak's Avatar
Posts: 119   (View Stats)
esestak has a reputation beyond reputeesestak has a reputation beyond reputeesestak has a reputation beyond reputeesestak has a reputation beyond reputeesestak has a reputation beyond reputeesestak has a reputation beyond reputeesestak has a reputation beyond reputeesestak has a reputation beyond reputeesestak has a reputation beyond reputeesestak has a reputation beyond reputeesestak has a reputation beyond repute
I saw someone ask this but they didn't get a definitive answer. Can u set the stock bpv to vta?
2012 Silver MS3
Cobb AP l Autotech HPFP l Cobb SF SRI l Corksport TIP l Turbosmart Dual Port BPV l OBX CBE l Ultimate Racing TP l Custom DP l Protege Garage PMM l JBR 88 RMM l JBR SSP/weight/bushings/knob l CXRacing FMIC l NGK plugs l Eibach Springs
esestak is offline   Reply With Quote
 Old 01-25-2013, 03:36 PM   #80
GODspeed7's Avatar
Yes but only with a guardian angel. Otherwise you will run like shit
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f505/bov-boost-bypass-valve-thread-99892/
?????? This thread Refback 11-08-2013 09:22 AM
Blow off valve 2010 ms3 This thread Refback 06-13-2012 12:09 AM
Turbosmart dual port bov? - 2010 Mazda 3/Mazdaspeed 3 Forums This thread Pingback 02-14-2012 08:35 AM
Page generated in 0.60502 seconds with 39 queries
