![]() | | #81 | ![]() |
![]() Join Date: Nov 2010 Location: Reading, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 23,158
Groans: 731
| Neutral : -1 score tappy-tap-tappytalk
__________________ Mods: stock Eventually I'll pay for how I am....but it won't be by the hand of any of you faggot fucks here. |
![]() | | #82 | ![]() |
![]() Join Date: Nov 2011 Location: Minooka, IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 545
| Not Ranked : 0 score
Tapatalk LIKE A BOSS!
__________________ 2012 Mazdaspeed3 Black Mica HYPNOTIC TUNED, FREEK TUNED, HTP full 3" intake/TIP, HKS SSQV 4 full VTA, Corksport catless downpipe, Corksport catless Racepipe, Cobb AP V3, Autotech Fuel Pump Internals, JBR 88duro RMM, JBR 88duro TMM, JBR 80duro PMM, JBR cylindrical shift knob, Fidanza aluminum flywheel, EBC green brake pads, Centric high carbon rotors, Nitto NT555 tires, Gorilla spline lug nuts, DDM tuning HID's lows, Resonator Delete. | |
| The Following User Says Thank You to GODspeed7 For This Useful Post: | faeker (01-25-2013) |
![]() | | #83 | ![]() |
Groans: 731
| Not Ranked : 0 score Hahaha. Not yours. tappy-tap-tappytalk
![]() | | #84 | ![]() |
Groans: 136
| Not Ranked : 0 score I swapped my stock BPV with the small port plugged with a TurboSmart BPV, and I noticed no change in boost or response whatsoever. The TS unit is actually quieter than my stock unit was. Tapadatass
__________________ |
![]() | | #85 | ![]() |
Groans: 731
| Not Ranked : 0 score omg i hate playing nice. you may be using the wrong spring/shim setup for stock boost levels.
| The Following User Says Thank You to faeker For This Useful Post: | irishking03 (02-11-2013) |
![]() | | #86 | ![]() |
| Not Ranked : 0 score Posted in wrong thread Tapatalk LIKE A BOSS!
__________________ 2012 Mazdaspeed3 Black Mica HYPNOTIC TUNED, FREEK TUNED, HTP full 3" intake/TIP, HKS SSQV 4 full VTA, Corksport catless downpipe, Corksport catless Racepipe, Cobb AP V3, Autotech Fuel Pump Internals, JBR 88duro RMM, JBR 88duro TMM, JBR 80duro PMM, JBR cylindrical shift knob, Fidanza aluminum flywheel, EBC green brake pads, Centric high carbon rotors, Nitto NT555 tires, Gorilla spline lug nuts, DDM tuning HID's lows, Resonator Delete. Last edited by GODspeed7; 01-26-2013 at 08:49 PM. |
![]() | | #87 | ![]() |
![]() Join Date: Feb 2013
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2
| Not Ranked : 0 score Is a stock bov just as good as an aftermarket one if im not boosting over 20psi and I'm just gonna recurc the aftermarket one?? I don't care about the sound I want performance.
![]() | | #88 | ![]() |
![]() Join Date: Feb 2010 Location: Philadelphia, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 323
Razr-Maxx-Tapa-Talking-2
__________________ 2009 Metro Grey Numbers Fully Bolted. Nator Pa Dyno Day: 311HP 328TQ Pump 93 Nator Pa Dyno Day: 310HP 329TQ Pump 93 End of Drive 9/24/2013 2012 Liquid Silver Cobb AP | |
![]() | | #89 | ![]() |
Groans: 136
| Not Ranked : 0 score I went up to ~27 psi on the stock BPV with the K04 and E85 with no noticeable issues. I only put on a TurboSmart BPV because I got a great deal on it.
| The Following User Says Thank You to silvapain For This Useful Post: | btstarcher (05-05-2013) |
![]() | | #90 | ![]() |
![]() Join Date: Oct 2012 Location: Tulsa, OK
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10
| Not Ranked : 0 score I just through on a Greddy Type RS BPV with plans of increasing my boost in the future and it was cheap.
__________________ 2013 Mazdaspeed 3: Performance: Autotech Internals // COBB AP // COBB TIP // Cobb Intake & Air Box // COBB FMIC // UR Catted DP V1 // UR CBE // UR Testpipe // Go Fast Bits BPV // Stratified ECBS 2-Port Mode // NGK One Step Colder Plugs // JBR Coolant Bypass Kit // Rotella T6 5w-40 // CP-e Stage RMM // Cp-e PMM // CS Shifrer Plate // Sure Shift Anchors // Redline Plus Hood Struts VD: 304hp / 333tq Stage 2 91 Octane Freek Tune |
![]() | | #91 | ![]() |
![]() Join Date: Apr 2013 Location: California
Rep Power: 0 ![]() Thanks: 2
| Not Ranked : 0 score thank you so much for all of these threads. im about to purchase my MS3 soon and knowing all of this info ahead of time before i upgrade is a huge help |
![]() | | #92 | ![]() |
![]() Join Date: Mar 2013 Location: Morgantown WV
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 30,420
Groans: 40
| Not Ranked : 0 score It's almost time to add the soon-to-be-released CorkSport BPV to this. @irishking03;
__________________ 2010 CBM Mazdaspeed3 w/Tech Package 240 whp/282 ft-lb @ CP-e Mustang Dyno [8/3/13] 271 whp/314 ft-lb @ Moore Automotive DynoJet [10/19/13] Cobb AP // JBR Stage II PowerPath Intake // GFB Respons BOV // AutoTech Internals // Sure Race Pipe (Cullen Eats Penises) // CPe TMIC JBR 88a RMM // JBR 70a TMM // JBR EGR Block Off Plate // Damond OCC // NGK Iridium IX Spark Plugs // JBR Bypass Valve Hose // SU Boost Tubes JBR Spherical Heavy Shift Knob // CorkSport interior LEDs // JBR License Plate Frame Mod // G2 Black Caliper Paint // 35% tint On deck: VG Sharkfin Antenna ![]() Last edited by jk_ms3; 07-14-2013 at 10:24 AM. |
| The Following User Says Thank You to jk_ms3 For This Useful Post: | irishking03 (08-10-2013) |
![]() | | #93 | ![]() |
| Banned ![]() Join Date: Feb 2012
Rep Power: 0 ![]() Thanks: 1
| Not Ranked : 0 score I am planning on going VTA with the BOV and does anyone know what the plug size fit for the inlet tube? Torque solution is selling a plug but they offer it in 1" and 1.25" and im not sure which size would best fit in the intlet tube. Torque Solution Billet Aluminum 1" Bypass Plug: Universal |
![]() | | #94 | ![]() |
(Thread Starter) | Not Ranked : 0 score @jk_ms3; ill add it when its released keep me posted when it does if I dont see it. Sorry guys ive been busy with a new house just getting married and my new son. I am going to go over this whole thread tomorrow or Monday to see what I need to update. Appreciate everyone liking it and making me aware of what needs to be changed. Sent from my SCH-I605 using Tapatalk 2
![]() | | #95 | ![]() |
![]() Join Date: Aug 2013 Location: Chicago,IL
Groaned at 3 Times in 1 Post
| Not Ranked : 0 score So I just installed corksport stage 2 intake and hks bov. I ran it recirculated. Whenever I build boost it makes a flutter sound, but not that high pitch sound im used to hearing. Do u not get that sound when u run it recirc? OR is the woosh my intake and the bov doesn't make a sound because of the recirc and not atmospheric? |
![]() | | #96 | ![]() |
(Thread Starter) | Not Ranked : 0 score Sent from my SCH-I605 using Tapatalk 2
![]() | | #97 | ![]() |
| Not Ranked : 0 score Mine sounds exactly the same, you have an sri tho right? |
![]() | | #98 | ![]() |
(Thread Starter) | Not Ranked : 0 score Yes sir. Hks suction reloaded sri Sent from my SCH-I605 using Tapatalk 2
![]() | | #99 | ![]() |
| Not Ranked : 0 score So if I didn't install the hks would it make the same sound? |
![]() | | #100 | ![]() |
(Thread Starter) | Not Ranked : 0 score Its the blow off making the sound not the intake. I feel as though the intake and tip make more of a sucking sound and you can hear the turbo spool alot better without the oem tip tappin dat trigga
![]() | | #101 | ![]() |
| Not Ranked : 0 score I has a cobalt ss/tc and the k&n intake made the same sound with my stock blow off valve. |
![]() | | #102 | ![]() |
Groans: 731
| Not Ranked : 0 score I'm having a hard time not commenting here. Seriously..................................
| The Following User Says Thank You to faeker For This Useful Post: | Schrocko (04-05-2014) |
![]() | | #103 | ![]() |
tappin dat trigga
| The Following User Says Thank You to irishking03 For This Useful Post: | faeker (09-09-2013) |
![]() | | #104 | ![]() |
| Not Ranked : 0 score Is there a sticky on this then I should read? |
![]() | | #105 | ![]() |
Groans: 40
| Not Ranked : 0 score Here you go: BOV/BPV Thread
__________________ 2010 CBM Mazdaspeed3 w/Tech Package 240 whp/282 ft-lb @ CP-e Mustang Dyno [8/3/13] 271 whp/314 ft-lb @ Moore Automotive DynoJet [10/19/13] Cobb AP // JBR Stage II PowerPath Intake // GFB Respons BOV // AutoTech Internals // Sure Race Pipe (Cullen Eats Penises) // CPe TMIC JBR 88a RMM // JBR 70a TMM // JBR EGR Block Off Plate // Damond OCC // NGK Iridium IX Spark Plugs // JBR Bypass Valve Hose // SU Boost Tubes JBR Spherical Heavy Shift Knob // CorkSport interior LEDs // JBR License Plate Frame Mod // G2 Black Caliper Paint // 35% tint On deck: VG Sharkfin Antenna ![]() |
![]() | | #106 | ![]() |
Groans: 731
__________________ Mods: stock Eventually I'll pay for how I am....but it won't be by the hand of any of you faggot fucks here. | |
![]() | | #107 | ![]() |
(Thread Starter) | Not Ranked : 0 score I hope so to tappin dat trigga
![]() | | #108 | ![]() |
Groans: 40
![]() | | #109 | ![]() |
![]() Join Date: Jan 2013 Location: MIAMI, FL -- MIAMI LAKES 33015
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 276
Groaned at 6 Times in 4 Posts
| Not Ranked : 0 score my hks super sequential broke, like that internals fall apart, so i was wondering which bov will be healthier for my car i have a gt3076r, i dont understand much about the vta and the other i really dont care about sound, just want to do it right.. thanks |
![]() | | #110 | ![]() |
![]() Join Date: Oct 2012 Location: Monroe township, New Jersey
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 612
Tap
__________________ Coming Soon: 5 speed 4x4 12v Cummins turbo diesel Gone: 2012 LSM Mazdaspeed3 w/tech Hypnotic Tuned Installed Cobb AP, Autotech Internals,Cobb SRI/TIP, JBR 88 Duro Trilogy, HKS SSQV4 vta, m2 full downpipe,Ultimate Racing CBE, NJSPEED3 pnp intake manifold, ETS 3.23" TMIC, TWM Full Replacement Short Shifter + SSP, JBR Heavy Knob, JBR EGR block off + TB TIG + Coolant Bypass, Koni Sport Yellows w/ corksport springs, Enkei Evo X GSR's on 245/40/18's Rice gloss black wrapped roof and side mirrors, Hella Supertones, 5% Rear half tints, lamin-x fogs, defi racer boost guage w/block8head pod, corksport interior LED kit | |
| The Following 3 Users Say Thank You to Ziggylittles For This Useful Post: |
![]() | | #111 | ![]() |
(Thread Starter) | Not Ranked : 0 score If you are bt you might want something like a tiaol bpv not the hks. Sent from my SCH-I605 using Tapatalk 2
![]() | | #112 | ![]() |
![]() Join Date: Oct 2013
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 16
Groaned at 60 Times in 22 Posts
| Not Ranked : 0 score When I had my speed 6 a few years back the craziest thing was when I installed my HKS SQV III then went back to a SQV II. I literally blew the BOV off the charge pipe because I had installed the ring it in backwards that hold it in the flange. But what was crazy is the car ran fine it just wouldn't build any boost. And it didn't throw a SINGLE cel/Code the entire time with the BOV blown off the pipe. Which I thought was pretty weird. |
![]() | | #113 | ![]() |
Groans: 731
| Not Ranked : 0 score ![]() now with three times the hate
| The Following 2 Users Say Thank You to faeker For This Useful Post: | Don06speed6 (01-24-2014), KusteLokal (01-24-2014) |
![]() | | #114 | ![]() |
(Thread Starter) | Not Ranked : 0 score @faeker; you kill me with the comments you make. I'm cracking up from that picture tappin dat trigga
![]() | | #115 | ![]() |
![]() Join Date: Jun 2014
| Not Ranked : 0 score This is great. I'm a newb at modding and I have been reading up like crazy for the past 3 weeks! Pure gold I tell ya! Thanks dude |
![]() | | #116 | ![]() |
![]() Join Date: Sep 2011 Location: Cape Town, South Africa
Rep Power: 237 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 90
| Not Ranked : 0 score BPV / BOV A Blow-off Valve (BOV) or Bypass Valve (BPV) is a pressure release system present in most turbocharged engines. Its purpose is to prevent compressor surge, and reduce wear on the turbocharger and engine. Blow-off valves relieve the damaging effects of compressor "surge loading" by allowing the compressed air to vent to atmosphere, making a distinct hissing sound, or recirculated into the intake upstream of the compressor inlet. They provide improved / quicker throttle response, better boost handling capacity / higher clamping load to maintain boost pressure more reliably and quicker spool recovery. A compressor bypass valve (CBV), also known as a pressure relief valve or diverter valve, is a manifold vacuum-actuated valve designed to release pressure in the intake system of a turbocharged vehicle when the throttle is lifted or closed. This air pressure is re-circulated back into the non-pressurized end of the intake (before the turbo) but after the mass airflow sensor. A blow-off valve, (sometimes "hooter valve", not to be confused with a bypass valve) performs the same task but releases the air into the atmosphere instead of recirculating it. The blow-off action produces a range of distinctive hissing sounds, depending on the exit design. Some blow-off valves are sold with a trumpet-shaped exit that intentionally amplifies the sound. Some turbocharged vehicle owners may purchase a blow-off valve solely for the auditory effect even when the function is not required by normal engine operation. Motor sports governed by the FIA have made it illegal to vent un-muffled blow-off valves to the atmosphere.[citation needed] Blow-off valves are used to prevent compressor surge, a phenomenon that readily occurs when lifting off the throttle of an unvented, turbocharged engine. When the throttle plate on a turbocharged engine closes, the high pressure air in the intake system is trapped by the throttle and a pressure wave is forced back into the compressor. The compressor wheel slows rapidly and may even stall, and the driver will notice a fluttering air sound. The rapid slowing or stalling stresses the turbo and imparts severe turbo lag if the driver accelerates immediately after the surge event. Disadvantages In the case where a mass airflow sensor (MAF) is used and is located upstream from the blow-off valve, the engine control unit (ECU) will meter out excess fuel because the atmospherically vented air is not subtracted from the intake charge measurements. The engine then briefly operates with a fuel-rich mixture after each valve actuation. The rich mixing can lead to hesitation or even stalling of the engine when the throttle is closed, a situation that worsens with higher boost pressures. Occasional events of this type may be only a nuisance, but frequent events can eventually foul the spark plugs and destroy the catalytic converter, as the inefficiently combusted fuel produces soot (excess carbon) and unburned fuel in the exhaust flow can produce soot in the converter and drive the converter beyond its normal operating temperature range. An alternative method for utilizing both a MAF and a blow-off valve is to have the MAF located down stream between the intercooler and the throttle plate. This is known as Blow-through rather than the traditional Draw-through set up. Care must be taken as to the position of the MAF to prevent damage to the sensitive element. (I.E. on a SR20DE motor, the MAF must be at least 12" from the throttle plate, and the blow-off valve must be 6" from the MAF sensor). By using a draw-through method, the MAF won't be affected by the blow-off valve opening as the pressure is vented before the air reaches the MAF. One approach used to mitigate the problem has been to reduce the boost pressure, which reduces the required venting volume and yields less charge over-calculation by the ECU. The air can also be recirculated back into the intake, a typical stock setup for cars with an upstream MAF sensor. The situation can also be corrected by switching the fuel metering system over to a manifold absolute pressure sensor, a conversion that usually requires a compatible aftermarket ECU or piggy-back fuel controller. The MAP sensor monitors the absolute pressure in the manifold at all times and will correctly detect the change that occurs when the valve vents, allowing the ECU to reduce fuel metering accordingly. Operation A blow-off valve is connected by a vacuum hose to the intake manifold after the throttle plate. When the throttle is closed, the relative manifold pressure drops to below zero bar and the resulting pressure differential operates the blow-off valve's piston. The excess pressure from the turbocharger is then vented into the atmosphere or recirculated into the intake upstream of the compressor inlet. FYI Most BOV/BPV will need some maintenance through the years. Basically they need to be re-oiled. The following list will be discussed below with images: • Forge (both V1, V2 and unknown versions purchased) BPV • Turbosmart Dual Port BPV / BOV Combination • Go Fast Bits (GFB) Respons BPV / BOV Combination • Forge V2 BPV • Forge V1 BPV • HKS SSQV BOV • CorkSport (CS) MZR BPV • Cobb XLE BPV / BOV Combination • Synapse Synchronic BOV • Forge V? BPV • TurboXS BPV • Tial QR BPV • Turbosmart Kompact Plumb Back BPV • GReddy RZ BOV • CX Racing BOV (comes with their FMIC) • JBR DISI Bypass Valve Return Hose • Synapse Synchronic DV Turbosmart Dual Port Maz Type 5 BPV / BOV Combination Billet aluminium; Holds boost more efficiently over stock valve; BPV spring rate is tuneable to the vacuum of your car; Choice of high pressure and low pressure springs; Gain Top End Horsepower; vents to intake, atmosphere becoming a blow off valve or adjustable mixture of both, while the Sleeper version is quiet during mild boost; note: both are taller, therefore, will not work with stock air-box Available from: Turbosmart Dual Port Maz Type 5 BPV / BOV Combination MS6 (Yes), MS3 Gen1 (Yes), MS3 Gen2 (Yes) $482.96 Go Fast Bits (GFB) Respons BPV / BOV Combination Dual action, twist BPV to BOV adjustable Available from: Go Fast Bits (GFB) Respons BPV / BOV Combination MS6 (Yes), MS3 Gen1 (Yes), MS3 Gen2 (Yes) $268.68 Forge BPV Made from billet aluminium V1: Makes a ping / swords clashing noise V2: stealth Available from: Forge BPV MS6 (Yes), MS3 Gen1 (Yes), MS3 Gen2 (Yes) $169.95 HKS SSQV BOV Info: http://www.hksusa.com/ Nickel-plated, die-cast metal secondary valve, which is swaged to the primary valve, a stainless steel C-Clip and spring to increase sealing and durability; First Sequential Blow-Off Valve featuring a unique, pull-type, sequential valve structure and a differential pressure control system allowing for stable operating ranges from low to high boost pressures. Note that a separate flange must be purchased and fitted to the BOV before installing on your car; comes with inline filter on the vacuum line; can keep closed at idle. The recirculating kit is an optional extra (additional expense), but note that 100% VTA can damage your CAT. Requires a separate (extra cost) mounting flange kit which is difficult to install properly (ex. CP-E, Jay Racing / JSC Speed, etc.) Available from: Hasegawa, Kitagawa, and Sigma (HKS) SSQV BOV MS6 (Yes), MS3 Gen1 (Yes), MS3 Gen2 (Yes) $331.95 CorkSport (CS) MZR BPV Half the spring height, 30% larger piston, 33% faster to vent Available from: CorkSport (CS) MZR MS6 (Yes), MS3 Gen1 (Yes), MS3 Gen2 (Yes) $188.99 Cobb XLE BPV / BOV Combination Different vent modes, pre-load adjustable, compatible with alcohol / water mix, reliably holds high levels of boost without leaks, fast venting, Teflon coated, hard anodized piston providing low sliding friction, reduces surface wear and minimizes maintenance requirements, can hold up to 60 psi Available from: Cobb Tuning XLE BPV / BOV Combination MS6 (Yes), MS3 Gen1 (Yes), MS3 Gen2 (Yes) $295 Synapse Synchronic BOV Eliminates the need for diaphragms by using a piston actuator that does not require frequent lubrication; can hold 60 psi yet still prevent compressor surge; can install as pull or push type valve Available from: Synapse Synchronic BOV MS6 (Yes), MS3 Gen1 (Yes), MS3 Gen2 (Yes) $289.95 TurboXS BPV Each flange is beefy to keep it from warping and allowing you to have the best mating surface possible Available from: TurboXS BPV MS6 (Yes), MS3 Gen1 (Yes), MS3 Gen2 (Yes) $239 Tial QR BPV 6 spring options (3 PSI to 12 PSI) Available from: Tial QR BPV MS6 (Yes), MS3 Gen1 (Yes), MS3 Gen2 (Yes) $259 silver, black, red, purple, blue Turbosmart Kompact Plumb Back BPV Available from: Turbosmart Kompact Plumb Back BPV MS6 (Yes), MS3 Gen1 (Yes), MS3 Gen2 (Yes) $184.49 GReddy RZ BOV Easily adjustable to eliminate compressor surge and preventing premature boost leakage while increasing boost response between shifts; made of durable cast and billet aluminium frame; valve to diaphragm ratio provides performance that cheap piston types cannot offer; spring stiffness adjustment screw; three models Available from: GReddy RZ BOV MS6 (?), MS3 Gen1 (?), MS3 Gen2 (? Although several Genpu owners have installed this) $360 for Type FV for RX-7 CX Racing BOV (comes with their FMIC) Available from: CX Racing BOV (comes with their FMIC) MS6 (Yes), MS3 Gen1 (Yes), MS3 Gen2 (Yes) $399 JBR DISI Bypass Valve Return Hose Direct (5 layers silicone & 4 layers of reinforcement) replacement for OEM, which will show signs of deterioration and cracking within a year degrading performance to eventually throwing a CEL. Available from: JBR DISI Bypass Valve Return Hose MS6 (Yes), MS3 Gen1 (Yes), MS3 Gen2 (Yes) $35 in red, blue, black or white CP-E Helihose 4-ply reinforced silicone hose, helical cut throughout for flexibility, steel wire routed through the hose to prevent kinking, while maintaining extreme flex, two SS liner clamps are included, providing clamping pressure without tearing silicone, gloss silicone finish with CP-E logo, 14.5” in length, made in the U.S.A., lifetime warranty Available from: CP-E Helihose MS6 (Yes), MS3 Gen1 (Yes), MS3 Gen2 (Yes) $64.48 CorkSport (CS) DISI Silicon Bypass Valve Hose Made from long lasting, four-ply reinforced, high quality, molded silicone for a strong flexible connection for ideal flow from the bypass valve to the turbo inlet pipe, comes in black, red, blue or white with two T-Bolt clamps Available from: CorkSport (CS) DISI Silicon Bypass Valve Hose MS6 (Yes), MS3 Gen1 (Yes), MS3 Gen2 (Yes) $39.99 in black, red, blue or white Synapse Synchronic DV Eliminates the need for diaphragms by using a piston actuator that does not require frequent lubrication; can hold 60 psi yet still prevent compressor surge; extremely fast response (< 25 msec) to eliminate compressor surge, 6061 aluminium, use a bolt on adaptor or weld Al or SS flange Available from: Synapse Synchronic DV Caps for Synapse Synchronic DV MS6 (Yes), MS3 Gen1 (Yes), MS3 Gen2 (Yes) $282.95; standard black cap (or colours: blue, red, orange, raw - add $29.99)
__________________ MS3 Gen2: AT: HPFP Int; Cobb: AP V3/ATR; CS: SRI/TIP, Catless DP; DIY: Air-box; GS: EBCS; Hankook: V12; NGK: 1 step cooler; OTC: EGR Del, OCC with VTA, PCV Plate, TP Coolant Bypass Last edited by Raider; 06-29-2015 at 08:13 AM. Reason: Added Synchronic DV & removed OP's "Good thing about the HKS is that this minor maintenance isn't required." |
![]() | | #117 | ![]() |
| Not Ranked : 0 score I think the lists should not be by popularity. Just lists. I would just remove that wording. I like the refresh overall. Can you include details from the OP in your revision? I know CPE and Corkssport also have recirc hoses, too. |
| The Following User Says Thank You to Raider For This Useful Post: | PapaBruno (02-18-2015) |
![]() | | #118 | ![]() |
| Not Ranked : 0 score Updated Of course I disagree on mentioning popularity. If I was a manufacturer, I would pay for this valuable information as a useful tool in deciding on which price inflection point to use to increase sales and yet, we are offering it free and unbiased here. Paying for market research can be subject to conflicts of interest, competitors’ larger marketing budget, etc. ex. Google ads. Some manufacturers are conducting their own research on this forum. Certainly vendors have looked at my public profile. However, in deference to your wish, I have removed this wording. The OP was biased by his choice for HKS over TS. I have dropped the huge wiki images, which are really too large to be displayed properly in a thread and thus, are of questionable value. I have moved the HKS flange example to immediately follow HKS. You are a fountain of knowledge. I have added the CP-E and CS recircs.
__________________ MS3 Gen2: AT: HPFP Int; Cobb: AP V3/ATR; CS: SRI/TIP, Catless DP; DIY: Air-box; GS: EBCS; Hankook: V12; NGK: 1 step cooler; OTC: EGR Del, OCC with VTA, PCV Plate, TP Coolant Bypass |
![]() | | #119 | ![]() |
![]() Join Date: Mar 2015 Location: Chesapeake
Rep Power: 0 ![]() Thanks: 0
| Not Ranked : 0 score Will the JBR recirculating hose fit on a Cobb TIH and a SSQV? |
![]() | | #120 | ![]() |
| Not Ranked : 0 score Yes. |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f505/bov-boost-bypass-valve-thread-99892/ | ||||
| ?????? | This thread | Refback | 11-08-2013 09:22 AM | |
| Blow off valve 2010 ms3 | This thread | Refback | 06-13-2012 12:09 AM | |
| Turbosmart dual port bov? - 2010 Mazda 3/Mazdaspeed 3 Forums | This thread | Pingback | 02-14-2012 08:35 AM | |
| Display Modes | |
