![]() | | #121 | ![]() |
![]() Join Date: Oct 2013 Location: Detroit, MI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 509
| Not Ranked : 0 score Also, you don't have the Synapse DV. Diverter Valve | Bov | smallest, lightest, fastest blow off valve on the market. and Mazdaspeed3 2007-2013 and Mazdapseed6 2005-2007 Synchronic DV Kit: Official Synapse Store | Buy our DV, BOV, and Wastegate with Synchronic Technology and more | Synapse Engineering ... among other places it can be purchased.
| The Following User Says Thank You to aackthpt For This Useful Post: | btstarcher (06-04-2015) |
![]() | | #122 | ![]() |
![]() Join Date: Nov 2010 Location: Reading, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 23,158
Groans: 731
| Not Ranked : 0 score Why would he remove it?
__________________ Mods: stock Eventually I'll pay for how I am....but it won't be by the hand of any of you faggot fucks here. |
![]() | | #123 | ![]() |
| Not Ranked : 0 score Because And because... is it true? I haven't found instructions for it but if you look up "HKS SSQV maintenance" or "HKS BO maintenance" on Google you get lots of hits. The manuals for every other one I've looked at, including the Cobb one that they claim minimizes maintenance, suggest periodic maintenance. Except the Synapse ones who don't address it in their product manual at all, only in the FAQs on the website. And they still sell a rebuild kit, which makes me not really believe the claim that it never needs maintenance or whatever (having a long maintenance interval is not the same as never needing maintenance, though there might be an interesting debate here between what counts as normal part breakage from use/wear vs. maintenance). But theoretically neither of the Synapse ones, including one that is already included, has that same advantage. At the very least, IF it is a claim made by HKS on their website, it should go in the section for the HKS with the rest of their marketing claims. These threads aren't intended to suggest or sway people to any given thing, just to show the options and duplicate their marketing claims. Speaking of which, it is actually one of my beefs with these threads that they reiterate the companies' marketing claims. Marketing claims are usually useless and often times just straight up incorrect.
![]() | | #124 | ![]() |
![]() Join Date: Sep 2011 Location: Cape Town, South Africa
Rep Power: 237 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 90
Remember that the order that I quote is based upon actual purchase volumes as seen in signatures / profiles. The OP quoted HKS first because that was his purchase choice / bias. HKS may require no or less maintenance, but it is typically more expensive and thus, I believe, not the first choice by this forum's members. I will update my post (Synapse DV, etc.) when I get back to South Africa. I am still travelling across the US at the moment.
__________________ MS3 Gen2: AT: HPFP Int; Cobb: AP V3/ATR; CS: SRI/TIP, Catless DP; DIY: Air-box; GS: EBCS; Hankook: V12; NGK: 1 step cooler; OTC: EGR Del, OCC with VTA, PCV Plate, TP Coolant Bypass | |
![]() | | #125 | ![]() |
I don't give a crap about the order in which they are presented. No fucks given. I'm simply suggesting that if you want to remove the OP's bias for this one product, you need to remove this statement. It sounded as though that was a goal based on your exchanges with Raider. If that's a no fucks given situation, then that's fine. Just pointing out errors and updates, as is requested for these threads.
__________________ 2013 'speed3, silver Stage Bro | |
![]() | | #126 | ![]() |
However, upon my return, I will remove, "Good thing about the HKS is that this minor maintenance isn't required."
![]() | | #127 | ![]() |
Groans: 731
| Not Ranked : 0 score He's just being an asshole cock bag
| The Following 2 Users Say Thank You to faeker For This Useful Post: | aackthpt (06-07-2015), Inquisitive (06-07-2015) |
![]() | | #128 | ![]() |
| The Following User Says Thank You to aackthpt For This Useful Post: | silvapain (06-07-2015) |
![]() | | #129 | ![]() |
| Not Ranked : 0 score lol - with a tinge of sarcasm on your part, but I applaud you for making light of it. There is a lot of aggression in this forum (many Type As), but then I assume that you race to win (Nator).
![]() | | #130 | ![]() |
Anyway I didn't want an argument in the first place and considered anything I posted more a logical discussion. And BTW, I'm still OK with the statement, just not where and how it was presented. If you want to put it into the HKS section, and put a similar statement on the Synapse products (for example), and/or any others to which it applies, I'd be fine with keeping it. I just want to keep things as truthful and non-confusing as possible. Modifying this car, and making one's way around this forum, is difficult enough as it is. BTW, I wasn't intending to complain about your work @Inquisitive;. I've enjoyed your updates and contributions to the forum. Also I knew about your travel from other threads in which I've made suggestions so I wasn't expecting fast action (nor was it needed in any way).
| The Following User Says Thank You to aackthpt For This Useful Post: | Inquisitive (06-10-2015) |
![]() | | #131 | ![]() |
![]() Join Date: Jun 2015
Rep Power: 0 ![]() Thanks: 0
| Not Ranked : 0 score Hey im looking for a bov for My protege and im Not a big online buyer, wheres the best place to get one? Its an 03 but not having much luck. |
![]() | | #132 | ![]() |
| Not Ranked : 0 score Call these guys up. Current sale on now for em. EdgeAutosport Weekly Sale! |
| The Following User Says Thank You to Raider For This Useful Post: | Castillo817 (06-23-2015) |
![]() | | #133 | ![]() |
| Not Ranked : 0 score Hey i checked that site the only thing they ha for my car was coilovers lol |
![]() | | #134 | ![]() |
| Not Ranked : 0 score Did you try calling? They can get it. |
![]() | | #135 | ![]() |
| Not Ranked : 0 score @aackthpt; I don’t think that I was the culprit in "tu quoque" or didn’t intend to be anyway. Keep up with the additions. After driving 4,100 miles through 17 states and visiting two other states, I could finally return to my own much missed bed and even update this thread. If you are satisfied, then Raider can update the OP.
| The Following User Says Thank You to Inquisitive For This Useful Post: | aackthpt (06-30-2015) |
![]() | | #136 | ![]() |
| Not Ranked : 0 score I will update the OP and the KB. |
| The Following 2 Users Say Thank You to Raider For This Useful Post: | aackthpt (06-30-2015), Inquisitive (07-01-2015) |
![]() | | #137 | ![]() |
__________________ 2013 'speed3, silver Stage Bro | ||
![]() | | #138 | ![]() |
![]() Join Date: Mar 2015
Rep Power: 0 ![]() Thanks: 2
| Not Ranked : 0 score I have not read through everyone else's comments on here, but I just put on my HKS SSQ BOV and I have to say, the Torque Solutions flange is a POS! Could not get my snap ring on and I had two others helping me. Thankfully I had ordered a 3P Perfomance one as well and it worked like a charm! Also the Recirc hose plug from Torque is super tight. Does not fit well at all and I think that is because they decided to put a lip on either side of the plug. wtf?!? Im going to eventually just remove that recirc hose since I'm VTA now and just plug from the other end. Anyway, just a little advice on the adapter flange if anyone runs into the problem Great write up btw!
__________________ CS Stage II Intake \\ CS Fuel Pump Internals \\ CS Racepipe \\ HKS SSQ BOV \\ CS Short Shift Plate \\ Damond OCC \\ Torque Motor Mount \\ Cobb V2 AP \\ FreekTune |
![]() | | #139 | ![]() |
![]() Join Date: Apr 2016 Location: TRACY CA
| Not Ranked : 0 score I cannot find any info on what I tried. So I took the stock bpv house off and it throws cel for lean at idle. Also Capped off bpv hose...Now what I don't get is why and how when u put a actual bov you don't get cel? Sent from my XT1585 using Tapatalk |
![]() | | #140 | ![]() |
Groans: 731
| Not Ranked : 0 score 10 month rez. Wasn't really needed
![]() | | #141 | ![]() |
![]() Join Date: Feb 2016
Rep Power: 0 ![]() ![]() ![]() Thanks: 3
| Not Ranked : 0 score Okay, so I have been searching all over this forum as well as online in general and cant find an answer or post about what I did. I was purchased the Turbosmart Dual Port Maz Type 5 BPV / BOV Combination as a present from my brother. I see in the list of of BOV that this does not work with stock air box because the BOV is big and will not fit. I got it to fit by unbolting the screw that holds the stock air box upright really close to the original BOV. how bad is this to do? I don't really see an issue because all hoses are fine and the air intake box is just sitting a little lower than normal. My car is running fine and I plan on upgrading the CAI, but is this okay to run in the mean time? My car is stock other than the BOV and I know people say not to get a BOV on a stock car, but it was a gift and I've always wanted a BOV. Any help or suggestions are much appreciated. |
![]() | | #142 | ![]() |
![]() Join Date: May 2011 Location: Valdosta GA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,861
Groans: 126
Sent from my SM-G920V using Tapatalk
__________________ '09 Red MS3 - AP self tuned, CS HPFP, JBR 3.5 WP, CP-e S2 RMM, M2 Catless DP, CX FMIC, CNT CBE | |
| The Following User Says Thank You to ASHMS3 For This Useful Post: | Esandman93 (05-22-2016) |
![]() | | #143 | ![]() |
![]() Join Date: Jun 2016
| Not Ranked : 0 score hey guys, I just bought a 2013 MS3 and it had a turbosmart BOV on it. I've been driving it for 2 days and kept hearing a "pigeon" type noise aka flutter. I thought oh shit compressor surge. I looked at the BOV and noticed it wasnt opening! So long story short I took it off and the piston had a little corrosion and wouldnt open and hasn't been this whole time. I got it all lubed up and am finally getting that psssssssh noise, yay! Any advice on tuning it harder or softer or where that sweet spot might be? |
![]() | | #144 | ![]() |
![]() Join Date: Jun 2009
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,507
![]() | | #145 | ![]() |
| Not Ranked : 0 score Okay guys may be a dumb question, I have an 08 Speed3 its literally stock except for resonator delete... I would like to get a bov or bpv, do I need any sort of tuning for either of them? |
| The Following User Says NO Thank You to PatRoell For This Un-useful Post: | g00s3y (07-23-2016) |
![]() | | #146 | ![]() |
Groans: 731
| Not Ranked : 0 score how about no to both.
| The Following User Says Thank You to faeker For This Useful Post: | g00s3y (07-23-2016) |
![]() | | #147 | ![]() |
Groans: 438
Don't get either. Fucking ricer.
__________________ All good things must come to an end... | |
![]() | | #148 | ![]() |
| Not Ranked : 0 score Idk why this website is filled with nothing but douchebags... Having a forum and posting is to get help and all anyone does is talk shit. Your speed already has a BPV and is not meant for a BOV. I have a BOV on my 2011 speed cause it was a gift and I see no harm done. I am already over the psshhht noise so I would advice against and put the money towards something else that will add power. Eventually a BOV has the possibility of damaging your car so all and all not worth it. I also did not get a tune done when I installed my BOV. |
![]() | | #149 | ![]() |
Groans: 438
And the first mod of his was deleting the resonator (sound mod), and now he wants to change the BPV (because sound). So in a "performance" based car, he cares more about sound , instead of performance. To each his own, but calling him a ricer isn't incorrect.
![]() | | #150 | ![]() |
Groans: 731
| Not Ranked : 0 score this thread itself has the answer of "you really shouldn't do this" in regards to a bov. fuck off with your brownie faggot logic.
![]() | | #151 | ![]() |
I just don't understand why people take the time out to read the post, type out a response, and the response is just shit talking. Yes it was a noob question and yes a BOV is rice as fuck and I'm saying that with one in my car right now, but like I said. I'm over the noise already and I'm gonna make it recirculating soon. And the search system for this site blows chodes. But yea. He should've at least tried looking. | |
| The Following User Says Thank You to Esandman93 For This Useful Post: | allservice (06-20-2019) |
![]() | | #152 | ![]() |
| That's why we always suggest using the search tool in my sig, it'll always work better than this site search. sent from my Nexus 6P
![]() | | #153 | ![]() |
But fact of the matter is that people on here don't help for shit. I'm not a noob anymore, but I'm sure as hell no expert and I could use advice from people on here that know more, but id rather figure it out on my own than ask and get nothing but "learn how to search you fucking idiot" when I've done nothing but research since I got my damn car. | |
![]() | | #154 | ![]() |
Groans: 731
| Not Ranked : 0 score when you ask the same fucking question that's been asked a thousand fucking times in an actual fucking thread based around that dumb fucking question and you still don't know the fucking answer.........people like me get to give you a fucking reply like this. fucker.
| The Following User Says Thank You to faeker For This Useful Post: | g00s3y (07-24-2016) |
![]() | | #155 | ![]() |
I do see where you're coming from though. Last edited by Esandman93; 07-24-2016 at 11:27 AM. Reason: MSF Database - Automerged Doublepost | |
| The Following 2 Users Say Thank You to Esandman93 For This Useful Post: | allservice (06-20-2019), krimsonviper (11-21-2017) |
![]() | | #156 | ![]() |
Groans: 731
| Not Ranked : 0 score we can't ignore it because that fucking question pops up everywhere. if you're really interested to on learning anything, read the God damn stickies in your gens forum. they give more than the first few steps towards treating your fucking car right. trust me, the stickies are chock full of great info that we children have amassed over years of ownership.
![]() | | #157 | ![]() |
Groans: 438
| Not Ranked : 0 score Angry post I now edited... Still mean it, but shouldn't be cluttering up this thread. Carry on folks... fucking noobs
__________________ All good things must come to an end... Last edited by g00s3y; 08-26-2016 at 02:43 PM. |
![]() | | #158 | ![]() |
![]() Join Date: Jun 2016 Location: Lancaster, Pennsylvania and Tuscaloosa, Alabama
Rep Power: 0 ![]() Thanks: 5
Groaned at 12 Times in 3 Posts
| Not Ranked : 0 score Anybody have experience with the Turbo By Cobb BPV? |
![]() | | #159 | ![]() |
![]() Join Date: Sep 2016 Location: Lebanon Me
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() Thanks: 0
| Not Ranked : 0 score For people driving a mazdaspeed 6 I have a dual port bov on my car I set it up 2 ways 1st way was VTA and block off the recirculation the car drove great and still does then yesterday I set it to recirculation only connected the hose and block off the other end of the valve and runs really good minus cant heat it boosting up but I figured ill share what I experienced with. comments from other would be great |
![]() | | #160 | ![]() |
![]() Join Date: Aug 2016 Location: Gatineau Quebec
| Not Ranked : 0 score so I've been doing so much research on building my mazdaspeed 3 safely. i want some nice gains but i don't want to run into any issues. motor mounts, transmission mount already bought. cobb sri, cobb tip, corksport fuel injector seals. nothing has been mounted on yet. gov has been my next approach including cobb ap. great write up on this thread. been thinking of the his bov. but as you were writing about bov's with maf. bov has to be mounted 12'' from the throttle plate and maf 6'' from bov. my question is are there any additional parts id need to make the install with those specs. or should i get rid of the maf. thanks in advance. I'm still new to this site. jay |
| The Following User Says NO Thank You to Jaysspeeed3 For This Un-useful Post: | MD1032 (12-25-2016) |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f505/bov-boost-bypass-valve-thread-99892/ | ||||
| ?????? | This thread | Refback | 11-08-2013 09:22 AM | |
| Blow off valve 2010 ms3 | This thread | Refback | 06-13-2012 12:09 AM | |
| Turbosmart dual port bov? - 2010 Mazda 3/Mazdaspeed 3 Forums | This thread | Pingback | 02-14-2012 08:35 AM | |
