![]() | | #161 | ![]() |
![]() Join Date: Jun 2009
| Not Ranked : 0 score
Unless it is leaking, stick with stock BPV. And don't waste your money on noise makers that do not give you any more power, but can cause your engine to idle poorly and misfire when shifting. BOVs are for highly modified engines with much larger aftermarket turbos, manifolds, and for special tuning designed from the ground up to work in tandem with BOVs. They do nothing beneficial for the kind of mods you are describing, beyond shout "ricer." You are not driving a Honda. My Christmas gift to you is for you to save your money for mods that actually make power. A BOV will not.
__________________ 2017 Audi Q5 3.0 T (supercharged) Stage 2+ EPL tune, JHM overdrive crank pulley, EPL supercharger pulley, ZF8 TCU tune, aFe/034 intake, modified air box. 480 hp. Sunlight Silver '08 MS3 GT Mods: (Sold 1/25/2019 after 10+ years of ownership) BNR Stage 1 (to fix smoking K04 turbo), TurboXS 3" Catless DP/RP "Stealthback" into stock CBE, Vibrant 3 inch Ultra Quiet Resonator in RP section, Magnaflow 3 1/2" exhaust tip, Mazdaspeed CAI w/air straightener and K&N conical filter, NGK 6510 Iridium IX one step colder plugs, Hypertech tune, Autotech HPFP internals, Stock BPV (works perfectly), Yokohama Advan Neova AD08R's (stock size on stock rims); Hawk HPS pads; SURE RMM; Grimmspeed EBCS (2 port mode), Bilstein B6's, SPC rear camber arms. Last edited by MSMS3; 12-24-2016 at 12:34 PM. | |
![]() | | #162 | ![]() |
Groans: 438
Why do you need to replace your bpv? Because you want your car to make ricer sounds? If you haven't even started modding, there is no need to replace your stock valve unless it is not functioning properly. And you clearly haven't read much if you are asking about having to move the location of the BPV. Not to mention, you say nothing about getting HPFP internals, which are the first thing that should be on your list of parts to buy.
__________________ All good things must come to an end... | |
![]() | | #163 | ![]() |
![]() Join Date: Aug 2016 Location: Gatineau Quebec
| Not Ranked : 0 score Firstly you don't need to make me sound like a brainless goon. I'm asking about this. Not saying I'm moving ahead with it. I ask because I don't know. Also I said nothing about getting a bov for the sound. I could care less for the noise. I thought it would help with throttle response and boost lags. Obveously it's not worth it. Secondly I just started doing research oh hpfp. This site isn't the easiest to figure out and I don't have the time to spend hours every day as I have a busy work life. I'm doing the best I can. And I don't plan to install anything till I know exactly what the outcome will be. Be positive and a little less harsh. Thought this was a good communitie. |
![]() | | #164 | ![]() |
![]() Join Date: May 2014 Location: Bloomsburg PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 136
| Not Ranked : 0 score Off topic from this thread but, Cobb Accessport, Autotech HPFP internals, RMM to get you started. Make sure you really want to use a stock size intake, if you upgrade the turbo later you'll regret it, ask me how I know. Buy once, save money. Our sponsored forum vendors are fantastic. Also do yourself a favor and get an OTS tune from Freektune or Stratified, money well spent. My present to you, Merry Christmas!
__________________ BNR S3 - FREEKTUNED on E33 |
![]() | | #165 | ![]() |
![]() Join Date: May 2010 Location: Maryland
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 848
As for the seals... You have a stock car. The mods you're throwing at the car have minimal impact on power. So why are you buying CS seals? Save your money unless they're leaking... Understand that EVERY response that you've received so far was done with good intent. These folks are trying to prevent you from throwing your hard-earned money at needless mods and directing you towards the ones you DO need (HPFP) to operate safely. No need to get upset. | |
![]() | | #166 | ![]() |
![]() Join Date: Mar 2013 Location: North Brunswick, NJ
Rep Power: 1125 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,645
Groans: 143
| Not Ranked : 0 score Also, there's no requirement that the BPV be mounted 6" from the throttle body. You can mount it anywhere between the turbo outlet and the throttle body and it'll do its job. Just a question of running the air return piping back to the intake from wherever you mount it.
__________________ 2007 Mazdaspeed3 GT |
![]() | | #167 | ![]() |
![]() Join Date: Dec 2014 Location: Puerto Rico
Rep Power: 73 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 26
I don't think the car will misfire with a BOV. You will run very rich when the BOV vents which can cause your engine to drown in fuel which in turn shuts it down or you could also get afterfire(not to be confused with backfire), which is a flame or loud pop coming out your exhaust due to all the unburnt fuel. What the OP... -well not really, -but the guy who is being attacked because BOV, should do is remove and plug the recic hose on the stock BPV, and then see how the car runs. You will have turned the stock BPV into a BOV so to speak. Just make sure the re-circulation hose is plugged well or you will have on hell of a leak that will run you lean and cause your engine to blow! ^ Yes this is stupid, but it's worth testing for those who want to see what the difference is. | |
![]() | | #168 | ![]() |
The high pressure fuel pump internal upgrade is absolutely essential. Without that, increased boost and increased air flow or exhaust side flow = zoom, zoom, boom on our engines, as the stock pump is marginal to begin with.
![]() | | #169 | ![]() |
![]() Join Date: Feb 2018
Rep Power: 0 ![]() Thanks: 0
Groaned at 6 Times in 3 Posts
| Not Ranked : 0 score Is the cobb bpv worth it? Thinking of that being my next mod |
| The Following User Says NO Thank You to KooshaS For This Un-useful Post: | Db09ms3 (03-02-2018) |
![]() | | #170 | ![]() |
![]() Join Date: Nov 2016 Location: AZ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 550
Groans: 105
| Not Ranked : 0 score |
![]() | | #171 | ![]() |
![]() Join Date: Jan 2017 Location: Phoenix, AZ
| Not Ranked : 0 score Can I install a BOV while running the COBB stage 2 tune? Just checking because I'd rather not damage my engine, turbo, etc. |
![]() | | #172 | ![]() |
| Not Ranked : 0 score Shouldn't make a difference as long as it is recirculating. If you have the hose to the Turbo Inlet Pipe disconnected(and blocked off hopefully), then you are Venting To Atmosphere and will run rich every time you let off the gas. I think a tune can help make it not so bad or fit it, not sure, by leaning out the AFR after letting off the gas, not really sure how to tune that in. I recommend you recirculate. |
![]() | | #173 | ![]() |
![]() Join Date: Nov 2010 Location: Reading, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 23,158
Groans: 731
*ahem* Blue spring 2 shims. Sent from my SM-G950U using Tapatalk
__________________ Mods: stock Eventually I'll pay for how I am....but it won't be by the hand of any of you faggot fucks here. | |
![]() | | #174 | ![]() |
Dead thread and multiple prior answers notwithstanding, why in the world would you want an aftermarket BOV at all? Is there anything wrong with your stock valve?
![]() | | #175 | ![]() |
![]() Join Date: Dec 2009
Rep Power: 0 ![]() ![]() ![]() Thanks: 20
Groaned at 74 Times in 53 Posts
| Not Ranked : 0 score Fuck off, moron. BEat it
__________________ ------------------------------------------------------- |
| The Following User Says NO Thank You to allservice For This Un-useful Post: | MSMS3 (06-20-2019) |
![]() | | #176 | ![]() |
Rep Power: 3747 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,744
| Chill out, dudebro. You're not as cool as you think you are.
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f505/bov-boost-bypass-valve-thread-99892/ | ||||
| ?????? | This thread | Refback | 11-08-2013 09:22 AM | |
| Blow off valve 2010 ms3 | This thread | Refback | 06-13-2012 12:09 AM | |
| Turbosmart dual port bov? - 2010 Mazda 3/Mazdaspeed 3 Forums | This thread | Pingback | 02-14-2012 08:35 AM | |
| Display Modes | |
