| Not Ranked : 0 score i expect you would need to be 2 of course or try to inspect it from the floor by using your hands to press it as best as you can..... i never experiences it myself but i did saw some pictures of broken pedal mechanism in this forum after installing harder pressure plate on speed6...
| Oem clutch/Fidanza Flywheel, Causing sticky clutch pedal? | Douggievee | MazdaSpeed 6 - Engine, Transmission & Driveline | 14 | 05-14-2015 10:44 AM |
| Clutch Masters Twin Disc Clutch Kit now Available at EdgeAutosport! | EdgeAutosport.com | EdgeAutosport.com | 67 | 03-17-2015 03:39 PM |
| New OEM Clutch with Fidanza Flywheel Soft Clutch Feel | zer010gic | MazdaSpeed 3 - Engine, Transmission & Driveline | 3 | 03-15-2014 11:12 PM |
| Clutch disc snapped - new CM clutch experience | Absolut1l | MazdaSpeed 6 - Engine, Transmission & Driveline | 4 | 05-08-2013 05:07 AM |
| Will a DIY clutch adjustment help a slipping clutch? | Greekfreak | MazdaSpeed 6 - Engine, Transmission & Driveline | 1 | 09-20-2012 05:53 PM |
