Groans: 60
| Not Ranked : 0 score Depends on how bad it's rusted. I'd start with just a microfiber cloth and some wd40 or atf. If that doesn't work you could try some fine stainless steel wool. Much more than that and you probably should tear it down..
| The Following 2 Users Say Thank You to SSinstaller For This Useful Post: | phate (12-19-2018), qtrmile beast (12-17-2018) |
| Supplier testing 3-cylinder engines with cylinder deactivation | Haltech | Automotive News | 0 | 07-14-2014 03:50 PM |
| Where is the Rust? | OttoSpeed | Exterior | 11 | 04-29-2013 11:52 AM |
| Rust already? | Cambelious | 2010 MS3 - Troubleshoot/Diagnostics | 6 | 06-30-2010 11:10 AM |
| Rust | RUMBLEFISH | MazdaSpeed 6 - How-To's | 1 | 06-17-2010 07:25 PM |
