 Old 05-24-2018, 10:04 AM   #1
Speed6speed6's Avatar
Posts: 1   (View Stats)
Speed6speed6 is an unknown quantity at this point
Default Does my PTO or transfer case "valve" need replacing?
Took my bone-stock 2006 MS6 to the dealer for the 100k maintenance. The dealer states that my PTO or transfer case “valve” needs replacing. What does this valve do? Is there any outward sign of this valve failure e.g., a noise, the car throwing a code (with or without CEL), a noise when hard turning one direction, drips of tranny fluid where I park the car? The dealer is asking $1700 which is okay because I know it's a lot of labor but I feel they’re being dishonest with me and this might not need replacing. How can I confirm the PTO valve does need replacing?
Speed6speed6 is offline   Reply With Quote
 Old 05-24-2018, 12:50 PM   #2
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
What the fuck. No.
Ask them what exact part they're trying to replace - get a part number.
-06 MS6
-Corn fed 07 MS3 - Sold
Vansquish (05-24-2018)
 Old 05-24-2018, 01:31 PM   #3
Police - Grammarhead
Vansquish's Avatar
^^^ What he said. ^^^
It sounds like they're trying to take you for a ride. There are no valves in our PTO of which I am aware that need regular maintenance or replacement. So...
Ask them what they're talking about and make sure you get a part number IN WRITING.
That said, it IS quite common for the PTO to leak. I've had to have mine resealed 3 times at this juncture, and I never launch the car. If the PTO is leaking, the service to reseal it at my local Mazda dealer was about $860.
MazdaspeedKills (05-25-2018)
 Old 05-25-2018, 05:40 AM   #4
GroceryGtr's Avatar
Posts: 472   (View Stats)
are they talking about the vent maybe? Those CAN get clogged up, but its not exactly a common replacement item.
 Old 05-25-2018, 08:02 AM   #5
MazdaspeedKills's Avatar
Posts: 443   (View Stats)
MazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the world
Groaned at 7 Times in 4 Posts
Sounds like another flux capacitor replacement. Just say "no thanks". The only thing you'd ever should have to do at the 100k mile service is a fluid change in PTO. Anything else is case seal or axle seal related and completely up to you if you want to have it done. If your undertray or PTO case has fluid on it, its likely the PTO case seal. To reseal properly you need to pull from the car. The $860 quote from Vanquish sounds about right for the job.
'06 MS6: BNR S3//CP-E FMIC//Forge V3/CP-E Nano Intake//TIP//DNP Swain Tech Coated Exhaust Mani//CP-E Catted Swain Tech Coated DP//Magnaflow CBE//CP-E RMM & TT Rear Diff Mount//PnP & Coated Intake Mani// VCTS and EGR delete//GS EBCS//3 Bar MAP//RMM//SafeSeals//PT-P FP Internals//TWM Stage II STS//SSP//Saikou Michi OCC//Snow Stage 2 WMI w/ D07 nozzle//Cobb AP V3//RICH TUNE!//Stoptech Slotted Rotors and EBC RedStuff Pads//H&R springs w/spacers//Bilsteins//SPC Balljoints//AeroForce ScanGauge & WideBand//Snow Performance WMI Failsafe & Guardian Angel//Morimoto HID Projector Upgrade//Hella HID Fogs
MazdaspeedKills is offline   Reply With Quote
MPS6 Transfer Case "loud clunk" in reverse after new clutch stavros99 MazdaSpeed 6 - Engine, Transmission & Driveline 5 01-15-2018 06:41 PM
VIDEO: Chrysler's Nardelli makes case for "Why Fiat Works" Haltech Automotive News 0 03-20-2009 06:50 AM
Page generated in 0.26002 seconds with 24 queries
