  • 1 Post By Raider
 Old 10-25-2012, 09:01 AM   #1
jracer's Avatar
Posts: 1,706   (View Stats)
Groans: 89
Default Engine coolant
I know mazda uses some funky coolant..
can you mix it with other brands ? or does ALL mazda the coolant need to be flushed out ? before adding normal stuff...
116k miles on my speed on stock coolant.
any option other than the mazda coolant .
I know ford has a coolant that basically the same as mazdas......
H&R springs/H&R 15mm spacers
MAP catless testpipe
MAP UICP
Grimmspeed 3 port
Cosworth filter
SSP relay kit
TWM Desert Eagle shift knob
AEM wideband gauge
Prosport boost gauge
EvoX piller pod
30%Tint
Slowpoke Tuned 339hp/336tq
**** SOLD *****
2006 speed6
 Old 10-25-2012, 09:11 AM   #2
2k4_8's Avatar
Posts: 684   (View Stats)
2k4_8 is the leader of the world2k4_8 is the leader of the world2k4_8 is the leader of the world2k4_8 is the leader of the world2k4_8 is the leader of the world2k4_8 is the leader of the world2k4_8 is the leader of the world2k4_8 is the leader of the world2k4_8 is the leader of the world2k4_8 is the leader of the world2k4_8 is the leader of the world
Groans: 64
Groaned at 18 Times in 6 Posts
We use fl 22, Google its compatibility, I'm on my phone or I'd help more.
COBB AP, CPE STAGE 2 RMM, CS SRI/TIP, AT HPFP INTERNALS, CNT CATTED DP, CP-E TRITON, JBR RSB, SWIFT SPRINGS, CS CAMBER ARMS
2k4_8 is offline   Reply With Quote
 Old 10-25-2012, 09:12 AM   #3
TRex's Avatar
Posts: 3,139   (View Stats)
Mazda FL-22 Coolant Information - Mazda3Forums.com
tl/dr
go to http://ricartmazdaparts.com/
put in 0000-77-508E-20 in the parts search box and select mazda
and there you go
The Following 3 Users Say Thank You to TRex For This Useful Post:
jax ms3gt (08-30-2015), jracer (10-25-2012), Vader (10-25-2012)
 Old 10-25-2012, 09:17 AM   #4
deadlandxtreme's Avatar
Posts: 1,117   (View Stats)
deadlandxtreme is the leader of the worlddeadlandxtreme is the leader of the worlddeadlandxtreme is the leader of the worlddeadlandxtreme is the leader of the worlddeadlandxtreme is the leader of the worlddeadlandxtreme is the leader of the worlddeadlandxtreme is the leader of the worlddeadlandxtreme is the leader of the worlddeadlandxtreme is the leader of the worlddeadlandxtreme is the leader of the worlddeadlandxtreme is the leader of the world
Groans: 82
Unicorn jizz with a dash of leprechaun blood (for color of course).
Just make sure you use the right ratio on anything you use.
2010 Mazdaspeed3- Installed Mods:- GT 3071 (Ported,polished, and coated by Grimmspeed) Polished and coated throttle body (Grimmspeed)TWM Performance Full Replacement Short Shifter Kit, Corksport FMIC (Upgraded size and coated by Calico Coatings), HTP 4" SRI, Forge V2 BPV, Corksport coolant hoses, NGK Iridum, COBB AP, Full Race DP (ceramic coated), Corksport hangers,JBR EGR block off, Autotech HPFP internals. Glowshift triple gauge pod, Aeroforce Interceptor dual gauges, STRI Imperial boost gauge.Stratified EBCS.RSB and Rear Camber Arms ( JBR ). Tein EDFC kit - Tein Super Street Coilovers . Enkei Racing RPF1 .GTSPEC bracing (front to rear)Corksport FSB..StopTech SS Brake Lines-SportStop Cross Drilled and Slotted Rotors-StopTech Street Performance Brake Pads.. Stratified Boost dial and Guardian Angel. JMF Intake manifold. Full Race Exhaust Manifold (ceramic coated). Damond Motorsports CC. SSP CC. PERM PCV Plate. 3bar MAP. , CP-E Triton full exhaust(Tuning provided by Stratified Tuning)
deadlandxtreme is offline   Reply With Quote
The Following User Says Thank You to deadlandxtreme For This Useful Post:
Raider (10-25-2012)
 Old 10-25-2012, 09:21 AM   #5
v8 convert
p057's Avatar
Posts: 1,782   (View Stats)
p057 has disabled reputation
Groans: 220
John, if you need FL-22, i have like 3 jugs of it. you only need about 1 1/2 to fill your car up. let me know.
p057 is offline   Reply With Quote
 Old 10-25-2012, 09:23 AM   #6
UnknownSuperhero's Avatar
Posts: 2,462   (View Stats)
You haz FL22 badge on coolant tank?
If not does it get hot?
if so Engine Ice High Performance Coolant - 64oz. 1/2 GAL
 Old 10-25-2012, 09:36 AM   #7
Prestone pre-mix and done. Got it on sale. It's great stuff for the lazy.
mikie likes this.
beachshoer (10-26-2012), jracer (10-25-2012), TRex (10-25-2012)
 Old 10-25-2012, 09:41 AM   #8
v8 convert
p057's Avatar
Groans: 220
From @TiGraySpeed6 on the mazda6club forums
MS6 Fluid Notes & DIY Pictures - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
> Coolant
'06 MS6 Manual - 8.5 us qts (2.25 us gallons)
Type- Mazda FL22
Mazda OEM - part# 0000-77-508E-20
Ford Specialty Green Coolant - Motorcraft part # VC-10-A or VC-10-A2 - $27.59 gallon 50/50 mix
Zerex Asian Vehicle Coolant - NAPA Part # ZRX 675130 - $13.99 gallon of 50/50 mix
It seems that only Mazda has coolant called "FL22"
- - Well, OK then, just WTF is FL22, and is this going to be a PITA?
Some clarity, compliments of the BobIsTheOilGuy forums, and a poster named ponderosaTX:
"...Mazda automotive coolants are green but they have almost NOTHING in common with conventional North American green coolant. Prior to the 2005 model year, Mazdas were equipped with a first generation P-OAT (phosphated organic acid technology) coolant developed and manufactured by CCI, the leading Japanese coolant company. P-OAT coolants rely on a combination of phosphates and organic acids to prevent corrosion; they contain no silicates or borates. In the 2005 model year, Mazda started using a second generation P-OAT coolant which has a lower concentration of phosphates and an improved organic acid additive package. The other major Japanese auto manufacturers, namely Toyota, Honda, and Nissan all use essentially the same coolant technology.
The only aftermarket P-OAT coolants are Japanese OEM coolants from Mazda, Toyota, Honda, and Nissan, Zerex Asian Vehicle coolant, and Motorcraft Specialty Green Engine Coolant (which reportedly is identical to the second generation Mazda FL22 OEM P-OAT coolant). For the record, Ford started using Japanese P-OAT coolant technology in many of its 2009 models (those sharing engine technology with Mazda) instead of G-05. Ford evidently found the performance of Japanese P-OAT coolants was superior to G-05 in Mazda engineered engines.
Using conventional North American green coolant in a Mazda is a bad idea. Even German (BASF) coolant technology as embodied in G-05, which contains silicates and no phosphates, is a much better choice than conventional North American green for vehicles with aluminum blocks and aluminum radiators. But a genuine P-OAT coolant, particularly a second generation P-OAT coolant like Mazda FL22 or Motorcraft Specialty Green, is the best choice."
It now looks like Ford Specialty Green Coolant may be the cost-effective alternative to Mazda FL22. Zerex Asian Vehicle Coolant is another option.
Originally Posted by IHeartGroceries
Just got off the phone with the Ford house.
Their Mazda equivalent fluid is now identified as VC10A2.
It was priced 27.59/gal...
The Following 2 Users Say Thank You to p057 For This Useful Post:
jracer (10-25-2012), TiGraySpeed6 (10-25-2012)
 Old 10-25-2012, 11:34 AM   #9
TRex's Avatar
hahaha thats what i did, engine is an engine, coolant is a coolant
Originally Posted by jracer View Post
so does coolant ever wear out ?? not cool as well as new coolant ?
so i guess if i just drain it ALL out and flush it a few times i should be good adding Prestone or some other normal coolant ..
yes, just like engine oil, it gets dirty over time and loses its effectiveness
 Old 10-25-2012, 09:59 AM   #10
jracer's Avatar
Groans: 89
MAP UICP
Grimmspeed 3 port
Cosworth filter
SSP relay kit
AEM wideband gauge
EvoX piller pod
30%Tint
**** SOLD *****
2006 speed6
 Old 10-25-2012, 11:34 AM   #11
v8 convert
p057's Avatar
Groans: 220
Yeah it does, but it really does seem to last for a while. The first time I "inadvertently" drained my coolant a year ago it came out looking pretty much the same as the stuff I had in there, HOWEVER I used to have my ECTs constantly at 180ish. never ever got it any lower.
After i put brand new fluid in, i can get it down to 169 on a cold day, mid 170's in the evening with 70ish degree weather on the interstate cruising at 60-75 mph 6th gear.
Those few degrees Fahrenheit may not sound like much, but it's proof there is a difference.
 Old 10-25-2012, 11:42 AM   #12
TiGraySpeed6's Avatar
Posts: 3,981   (View Stats)
Thanks @p057 - that one is here on MSF too -
Coolant does/can wear out- that is the protective additives will lose their effectiveness.
The big trick, really, is how the coolant's additive package behaves with an all aluminum engine over an extended period of time. Bad reactions can cause build up and block passages or not properly lubricate bits like the coolant impeller, or even cause the thermostat to seize open or closed.
Mazda blocks work well with Zerex Asian Vehicle Coolant. 50/50 mix jugs available at the local parts joint for about $13 a gallon, you need 2 of em. Distilled water for any balance needed. Remember to set heater as hot as it'll go to cycle that core too.
Winter at least 50/50.
Summer a lot of folks run a jug of 50/50, and the rest distilled water- plain water cools the best.
340hp / 371tq
jracer (10-25-2012), rfinkle2 (10-25-2012)
 Old 10-25-2012, 12:00 PM   #13
silvapain's Avatar
Posts: 6,665   (View Stats)
Groans: 136
It doesn't really get "dirty"; it becomes acidic over time and will corrode metal parts it contacts. The new 'long life' coolants like FL22 are designed to be more stable for longer.
I didn't read closely through the thread, so I apologize if it has already been said, but FL22 comes premixed and should not be diluted.
Tapadatass
Also, straight distiller water is very corrosive and will quickly eat away at the Aluminum block. Part of the additives in antifreeze are chemicals to reduce the reactivity of water.
Tapadatass
Last edited by silvapain; 10-25-2012 at 12:00 PM. Reason: MSF Database - Automerged Doublepost
 Old 10-25-2012, 12:52 PM   #14
itg3rl's Avatar
Posts: 381   (View Stats)
itg3rl has disabled reputation
Shouldn't need to do a coolant flush until about 30k miles BTW. Along with that manual flush. Do them both at the same time so its easier to remember for the next service/time.
JBR SSP . Turbosmart BOV . Autotech Internals . 88d JBR RMM . JBR Spherical Shift knob . H & R springs . JBR rear sway bar
itg3rl is offline   Reply With Quote
 Old 10-25-2012, 12:53 PM   #15
v8 convert
p057's Avatar
Groans: 220
jracer has an 07 ms6 at 110k+ miles, it's a bit overdue for him.
 Old 10-25-2012, 12:58 PM   #16
itg3rl's Avatar
Oh shit! I had tea in my mouth when I read that, bout spit it out.
Just a wee bit overdue is right.
 Old 10-25-2012, 01:46 PM   #17
silvapain's Avatar
Groans: 136
FL22 requires replacement at 100K miles if I remember correctly.
Tapadatass
jracer (10-25-2012)
 Old 10-25-2012, 04:13 PM   #18
itg3rl's Avatar
Noted. Still overdue regardless.
 Old 10-25-2012, 06:47 PM   #19
btstarcher's Avatar
Posts: 4,852   (View Stats)
Tapadatass
None of my engines last long enough for a flush...
SnailTune in progress
The Following 3 Users Say Thank You to btstarcher For This Useful Post:
86AmishMs3 (10-28-2012), jm211 (10-26-2012), silvapain (10-25-2012)
 Old 10-25-2012, 06:39 PM   #20
Coaststarlight's Avatar
Posts: 296   (View Stats)
Coaststarlight is the leader of the worldCoaststarlight is the leader of the worldCoaststarlight is the leader of the worldCoaststarlight is the leader of the worldCoaststarlight is the leader of the worldCoaststarlight is the leader of the worldCoaststarlight is the leader of the worldCoaststarlight is the leader of the worldCoaststarlight is the leader of the worldCoaststarlight is the leader of the worldCoaststarlight is the leader of the world
80% Steam Distilled water(70 cents a gallon @ Walmart), a bottle of water wetter and topped off with 50/50
Runs cooler, cools quiker
Just make sure the bottle says no minerals added on it
Long Block Built by GPwerks and Loose Screw Motor Sports
https://www.gp-werks.com/
http://www.crossoverauto.com
^Any Parts, Great Prices^
Coaststarlight is offline   Reply With Quote
 Old 10-25-2012, 06:41 PM   #21
jm211's Avatar
Posts: 943   (View Stats)
Yea, Fl-22 is good for about 100k.
I flushed it when i bought my car this january just because i didn't know. I'm at 55k miles.
the fl-22 is premixed and is not cheap. about $30 a gallon!
Based on what TI said, I went with mazda's shit instead of anything else.
 Old 10-25-2012, 06:43 PM   #22
Our cars are not good with water wetter. I've read 2 cases here it ended in head gasket issues.
 Old 10-25-2012, 07:16 PM   #23
easy's Avatar
Posts: 539   (View Stats)
easy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the world
Groans: 27
i tired water wetter and it stains the hell out of the overflow tank and when i replaced a hose it had residue left inside ... never going to use it again, 70%distilled/30% coolant is what im using now ...
08 MS3
() Arias Pistons & Pauter Rods, P&P Head, Port match IM, DCR VVT, ARP Head Studs, Autotech CDFP internals, F2 BSD & Baffle, Cobb AP, Cobb SRI, PG TIP, CS Test Pipe, FMIC, Tial QR, JBR RMM/TMM, Oil spin-on Conversion, NGK iridiums IX
() Koni Yellows, Roadmagnet springs(6.5k Front, 6.4k Rear), Cobb RSB, TB trunk brace, AWR Rear Endlinks, SPC rear camber arms
() Centric Slotted Rotors/ Posi-Quiet pad
() Fidanza 11lbs. Flywheel, E4P STS, Cobb Shifter Weight, TWM Bushings, Redline MT-90
easy is offline   Reply With Quote
 Old 10-25-2012, 08:38 PM   #24
WW was designed to be used with little to no coolant, which is why it's used at tracks when antifreeze is not allowed. They make a version for mixing with greater than 33% coolant blends labelled for diesel use.
look it up on redline's site, and references all over, including the bobistheoilguy site
340hp / 371tq
 Old 10-26-2012, 12:46 PM   #25
easy's Avatar
Groans: 27
i remember seeing on the bottle that it said you can add it to your existing coolant and being that majority of people will have a 50/50 mix, that shouldn't have been an issue.
08 MS3
 Old 10-26-2012, 01:05 PM   #26
Below is just one of many similar bits that are out there.
Running just Redline Water Wetter and H20 summer - Bob Is The Oil Guy
Redline Water Wetter was designed for use in pure water cooling systems, as required by racing applications.
Coolant, when spilled onto a track, causes a slippery condition.....not good for drive fast turn left applications.
If you read the chart on the bottle, it shows a major increase in temperature transfer between the water and metal in the water only application.
The same chart shows a slight improvement when used with coolant.
Unless you are running beyond the capacity of your cooling system (design or some problem that has developed), you will not see your motor running cooler with/without this product as the thermostat will regulate the coolant temperature.
Actual head temperature might differ, but that would take some advanced measuring that is not built into passenger vehicles (temperature monitoring is of coolant temperature).
I recall reading the Redline indicated that the stuff you see separate out of the Redline Water Wetter in systems with coolant is not harmful to the system....and will re-mix when the coolant gets hot.
What we tend to see is this stuff that separates out.....building up in the overflow bottle.....and it does look nasty.
At the same time I read this (someplace on THIS website) the recommendation to avoid this separation was to use the Water Wetter that is for Diesel engines.....as it is designed to be used in coolant, not pure water.
The Diesel Water Wetter was purple in color.......and harder to locate.
However, my advice would be to contact Redline through their website and see what they have to say.
They seem to be very responsive to questions and they would be a better source of information than I am.
340hp / 371tq
easy (10-26-2012)
 Old 10-26-2012, 07:09 PM   #27
easy's Avatar
Groans: 27
good info, that is exactly what happened with me
08 MS3
 Old 07-31-2015, 10:01 AM   #28
Lex2007's Avatar
Posts: 574   (View Stats)
Default Zerex coolant and FL-22 coolant compatibility
For whatever its worth, I asked ZEREZ customer support, and they stated:
"...thank you for contacting Zerex Product Support. Valvoline would recommend Valvoline Maxlife Anti-freeze/Coolant, Zerex Asian Vehicle Anti-freeze/Coolant or Zerex Dex-Cool Anti-freeze/Coolant. All are compatible with your 2007 Mazda 3."
Then I asked "Are any of your coolants Type FL-22 compatible?" and the answer was:
"Thank you for contacting Zerex Product Support. Unfortunately, we do not rate our products against other product, rather we rate them based on the OEM specifications of the vehicle which the previously mentioned meet for your 2007 Mazda 3."
"The 2007 Mazda Speed3 & 3 have the same OEM Coolant specification. If FL-22 is the OEM recommendation for this vehicle and Valvoline Maxlife Anti-freeze/Coolant, Zerex Asian Vehicle Anti-freeze/Coolant or Zerex Dex-Cool Anti-freeze/Coolant all meet the OEM specification for your vehicle, then they would have to be compatible."
 Old 07-31-2015, 01:37 PM   #29
Lex2007's Avatar
Default PRE-MIXED LONG-LIFE "FL22" ENGINE COOLANT Service Bulletin
The Following 2 Users Say Thank You to Lex2007 For This Useful Post:
jax ms3gt (08-30-2015), ZetaDrift (10-02-2015)
 Old 11-06-2019, 08:12 AM   #30
Lex2007's Avatar
According to Mazda parts counter (Dan at Ourisman Mazda in MD) any Speed3 produced *after* December 17, 2007 uses FL-22. Before that it *does *not use FL22. AllData contradicts this, and states I need FL-22.
AllData isnt incorrect but there is a caveat. As per the TSB 01-033/07 in the above post, you CAN use FL-22 on older Speed3 but dont mix it with orange coolant because it will turn black.
Dan sent me this Mazda Fluids Chart updated March 16 2019 is as follows:
Pentonsin PENTOFROST A2 (GREEN) Antifreeze Specially Formulated For Asian Vehicles — CONCENTRATE- HOAT technology but does not have FL-22 according to the rep I spoke to at PENTOSIN but it does cross reference with Mazda 0000-77-501E-02.
http://www.pentosin.net/specsheets/Pentofrost_A2.pdf
Pentofrost A3 (BLUE) does have FL-22, according to the same guy at Pentosin but is only available in 50/50 mix but does NOT cross reference with Mazda 0000-77-501E-02 (confusing).
http://www.pentosin.net/specsheets/Pentofrost_A3.pdf
I had little trust in the expertise of the guy at Pentosin...he knew nothing about what FL-22 specs included, only that MAZDA had no cut off date for the need to use FL-22 or not. He was wrong about the cut off date.
Pentofrost A1 (RED) is FOR ASIAN vehicles, CONCENTRATED, HOAT technology but isnt listed for MAZDA.
http://www.pentosin.net/specsheets/Pentofrost_A1.pdf
An inexpensive FL-22 coolant CONCENTRATE is RAVENOL J4D2092 Coolant Antifreeze - HJC Hybrid Japanese Coolant Protect FL22 Concentrate (5 Liter. $27 on Amazon.
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f505/engine-coolant-128395/
Mazda FL-22 Coolant Cross-Reference_Wiki Searcher This thread Refback 04-26-2015 08:19 PM
Coolant in engine bay KillerAngel MazdaSpeed 3/6 - Troubleshoot/Diagnostics 21 05-23-2011 05:03 PM
Coolant boiling over exhaust in coolant bcmurphy87 MazdaSpeed 6 - Engine, Transmission & Driveline 12 12-15-2010 02:39 PM
Video: Prestone melts GM 3.6-liter engine block with blowtorches to show importance of coolant Haltech Automotive News 1 06-30-2010 11:13 AM
coolant phillyb MazdaSpeed 3 - Engine, Transmission & Driveline 26 03-13-2010 06:24 PM
Page generated in 0.51729 seconds with 34 queries
