 Old 04-12-2011, 05:18 PM   #1
kizner00's Avatar
Posts: 14   (View Stats)
kizner00 will become famous soon enough
Default engine igniion fuse blows when key is turned on
any help would be great for this newbie to Mazda,
my car died this morning, just stalled.
i have found that the engine ignition fuse blows as soon as i turn on the key, this is the fuse inside the cabin at your feet.
any thoughts?
kizner00 is offline   Reply With Quote
 Old 04-12-2011, 11:46 PM   #2
Whiteboy's Avatar
Posts: 2,032   (View Stats)
Whiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the world
Groans: 142
Stop making double posts brownie...if you didn't get your answer in the previous section you def won't get it here.
stalled out and now wont turn over at all
~My Mod List: ETS TMIC; CP-E SRI; COBB TIP; CP-E DP; CP-E RMM; CP-E Safe Seals; ITV-22's; GHL SS CBE; TWM STS w/bushings; Autotech HPFP Internals; AP (Stratified by Lex); Matt Damond OCC; CP-E Triple Gauge Pod w/ Prosport Premium Boost, AFR, and Oil Pressure Gauges; JBR Eliminator Shift Knob~
Whiteboy is offline   Reply With Quote
 Old 04-12-2011, 11:47 PM   #3
Fuck sushi rolls
rodrigo's Avatar
Posts: 18,719   (View Stats)
Groans: 356
if your fuse blows out when u turn the key on u have a short circuit somewhere along the line of the ignition.... time to trace it niggah.
Eng Bar fuse keeps blowing after water splashed into engine bay Dawey1 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 14 03-28-2011 01:19 PM
MS6 Engine Blows Up.....Options to replace?? jamgt MazdaSpeed 6 - Engine, Transmission & Driveline 8 12-12-2010 12:41 PM
Problem with fuse of PCM Yarrus MazdaSpeed 3 - Engine, Transmission & Driveline 3 10-02-2009 12:27 AM
Sunroof fuse? SpdFreak MazdaSpeed 3/6 - Car Audio & Electronics 3 06-11-2009 01:10 AM
Page generated in 0.24482 seconds with 22 queries
