 Old 02-25-2019, 03:22 PM   #1
arvint123's Avatar
Posts: 10   (View Stats)
arvint123 has a little shameless behaviour in the past
Default ETC TMIC question
Hey guys, just got my ETS top mount intercooler and everything seems simple to install, just one question to those who have had this, do you guys re-use the rubber grommets that go on the three bolts that attack to the engine? When i put the grommets in the ETS one the bushing doesnt really fit in and the design of the bracket itself is a open circle instead of a closed circle like the OEM TMIC so im assuming we just use the bolts and bushings and no rubber grommets correct? (Probably a stupid question but i'm new to all this so be gentle on me haha)
appreciate it!
arvint123 is offline   Reply With Quote
 Old 02-26-2019, 05:42 AM   #2
danb's Avatar
Posts: 176   (View Stats)
danb has much to be proud ofdanb has much to be proud ofdanb has much to be proud ofdanb has much to be proud ofdanb has much to be proud ofdanb has much to be proud ofdanb has much to be proud ofdanb has much to be proud ofdanb has much to be proud ofdanb has much to be proud of
Mine just kept popping out. I ended up not using them
2007 speed3 GT. cobb rmm, JbR pmm, Corksport adjustable shifter, twm solid shifter bushings, Sure shift knob, AP3, Autotech, CS turbo, CS occ, HTP 3.5, Depo catless dp, TS Kompact bpv, CS 3port, cpe BlockD, GA V3, DO DVC-30, Cx racing piping, tr1035.. Freektuned
2011 mazda 6
danb is offline   Reply With Quote
 Old 02-26-2019, 12:47 PM   #3
Fstrnyou's Avatar
Posts: 2,498   (View Stats)
I have a CP-e TMIC hard mounted to the intake/brackets.
Even though the grommets work fine with it. However, the added vibes on the TMIC is working the bolts loose that hold the mounting tabs onto the intercooler. Time to throw on some blue stuff.
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
 Old 02-26-2019, 01:11 PM   #4
Loophole35's Avatar
Posts: 59   (View Stats)
Loophole35 is just really niceLoophole35 is just really niceLoophole35 is just really niceLoophole35 is just really nice
I'm using them on my Corksport TMIC.
2008 True Red Mazdaspeed 3
Mod list:
Cobb RMM, TIP, SRI w air box, CBE and AP3
Corksport Short throw plate w/ shifter bushings, TMIC and BPV
CPE catted DP
Tune done by Will at PD-Tuning (still slow need BT)
150k miles on original motor and turbo
H&R sport springs w/ Koni yellows
17x9 +48 6UL with 245/45R17 Flaken Azenis
Loophole35 is offline   Reply With Quote
 Old 02-27-2019, 06:17 PM   #5
Thor Hammer's Avatar
Posts: 1,847   (View Stats)
Groans: 211
appreciate it!
I have an ETS and had no issues using the rubber grommets in the mounting tabs. They're there for a reason. Use them.
 Old 02-27-2019, 06:36 PM   #6
kosti365's Avatar
Posts: 15   (View Stats)
kosti365 is an unknown quantity at this point
^ This. I also have the ETS and reused mine. I guess over time they get worn/loose but they are necessary for some vibration isolation. I would also use some locktite on the tabs that attach to the intercooler.
2013 MS3 Liquid Silver Metallic with Tech
Power: CS HPFP Internals, JBR SRI\TIP, UR Race Pipe, CPE TMIC, TB TIG\Coolant Bypass, Cobb AP, Denso ITV22's, E33 Freektune
Handling: CorkSport RSB, CPE RMM, Bilstein B12 Prokit, Konig Rennform 18x8 w\Indy Firehawks, Stoptech Front Slotted Rotors\Pads\SS Lines, Damond SSP, JBR Shifter Bushings, CS TMM insert
Misc: Damond OCC & EGR Delete, CS BPV, Borla Axle Back, BaysonR Front Lip, LED everything
kosti365 is offline   Reply With Quote
 Old 02-28-2019, 01:42 PM   #7
Jonwalls's Avatar
Posts: 14   (View Stats)
Jonwalls will become famous soon enough
Double nut it.
Jonwalls is offline   Reply With Quote
 Old 03-01-2019, 03:28 PM   #8
Groans: 211
Originally Posted by Jonwalls View Post
Double nut it.
I can double nut it some nights, but not all. GF loves it.
The Following 2 Users Say Thank You to Thor Hammer For This Useful Post:
Jonwalls (03-05-2019), monkey.bones.007 (03-02-2019)
 Old 02-28-2019, 01:44 PM   #9
arvint123's Avatar
Thanks for the replies, i figured you had to re-use them, didnt seem right to have metal bolted down to metal for the intercooler and thankfully i got some new grommets and everything snug'd up super nice!
TMIC Question Tru3 2010 MS3 - Turbo Induction 9 09-02-2018 10:31 PM
question about tmic? contreras MazdaSpeed 3/6 - Turbo Induction 45 12-14-2011 05:57 PM
ETS TMIC question Whiteboy MazdaSpeed 3/6 - Turbo Induction 13 07-27-2011 08:56 PM
TMIC the BIG Question (Where, How, Why) ganque MazdaSpeed 3/6 - Turbo Induction 11 11-15-2010 03:19 PM
Page generated in 0.30341 seconds with 26 queries
