Like Tree3Likes
  • 1 Post By Code Monkey
  • 1 Post By Justin@Freektune
 Old 07-20-2014, 09:56 AM   #1
Default Evap system delete?
In a never ending quest for weight reduction and simplification I wonder how hard it would be to remove the evap system.
Here is a diagram of the evap system on the fuel tank side:
I was thinking about yanking #3 (charcoal canister) and #4 (evap system leak detection pump) and leaving the air filter like this:
On the engine side, I would remove the purge solenoid valve and the line that goes to the intake manifold and plug the hole. Hopefully I can disable whatever codes pop out with the AP.
Doable?
derek13p likes this.
derek13p (08-17-2014)
 Old 07-21-2014, 02:21 PM   #2
ispypsi's Avatar
Posts: 303   (View Stats)
ispypsi is the leader of the worldispypsi is the leader of the worldispypsi is the leader of the worldispypsi is the leader of the worldispypsi is the leader of the worldispypsi is the leader of the worldispypsi is the leader of the worldispypsi is the leader of the worldispypsi is the leader of the worldispypsi is the leader of the worldispypsi is the leader of the world
Have done it on past cars. Pulled a good 5-7 lbs off my 240sx years ago ripping out the various sensors and giant charcoal canister. Make sure you check the level of the open hose so that it has no ability to leak out any fuel, I had to tuck one up in a hole in the frame, and that worked well. It never really smelled like gas either and it was just open ended - still is actually.
Definitely will need the AP because I can only imagine the slew of codes you'll get. I got 4-5 and that was from 1997 levels of OBD2 technology.
Edit - ps you loaded the fuel tank diagram twice. Would like to see the engine side diagram for giggles.
Dan - '08 MS3, some kinda silver
ispypsi is offline   Reply With Quote
The Following User Says Thank You to ispypsi For This Useful Post:
Code Monkey (07-21-2014)
 Old 07-21-2014, 03:33 PM   #3
I posted two pictures to clearly show the before and after.
On the engine side, there is nothing special going on, just remove #1 and #2 , and cap the IM with something. I think a vacuum cap with a ziptie should do, this is what I have on the TB.
ispypsi (08-13-2014)
 Old 07-23-2014, 08:19 PM   #4
motherfnmonsta's Avatar
Posts: 2,308   (View Stats)
Groans: 106
only issue I see is passing state inspections from a visual stand point if the tech is actually paying attention. Also not sure in your state how many not readys montitors you are allowed to have either. In NC we are only allowed one not ready so gotta pick your poison.
My next concern is you will still need a form of venting for the fuel tank to allow pressure out of the tank so that it will not possible go boom boom or something else.
Code Monkey (07-23-2014)
 Old 07-23-2014, 08:27 PM   #5
It is a racecar so 0 fucks given about engine codes, etc. There are no visual or OBDII inspections where I live, and in a year or two I will most likely take the car off the streets anyway. The tank would still be vented via the stock air filter where I drew the red line.
 Old 07-24-2014, 05:20 AM   #6
Justin@Freektune's Avatar
Posts: 954   (View Stats)
Definitely doable as long as the tank still has some sort of vent. Which it will. So you will be good. And yes we can delete every code associated with te evap system
Code Monkey likes this.
PTE 6062
633HP/523TQ
Quickest/Fastest Mazdaspeed
4/22/2017 New England Dragway
Code Monkey (07-24-2014)
 Old 08-10-2014, 08:56 PM   #7
Ok, it is done.
The proposed routing above is not possible without dropping the tank so I did it this way:
The 1/2" (?) part is on the right side next to the diff and behind the axle and is a bitch to get to. There was no space to reach and clamp that green pain in the ass quick release connector so I just obliterated it (bottom of picture below). The hardline on that side is, I think, 1/2" -- I only had a 5/8" hose and a 5/8" to 3/4" heater hose adapter so I used them (top of picture below). The hardline you will connect to has no bead on the very edge, only like 3/4" down (for that green connector to hook) -- so I slid the 5/8" hose as far as I could so it went beyond the bead and put a constant pressure clamp hopefully right on the bead.
The rest was simple, I ran a 3/4" heater hose from the hose adapter all the way to the air filter, clamps everywhere.
Here is all the shit I pulled out, although the two brackets under the charcoal canister and the plastic shields went back in. I put electrical tape on the electrical connector and the thin evap line that runs all the way into the engine bay.
I kept the brackets for now as I thought I could have a water-meth pump installed under the spare tire space, but looking at how dusty shit gets there I will be ripping the spare tire "inverted cup" piece out (could not remove it today, shit is spot welded) and we will weld a flat piece of metal there -- I am taking here about the stuff inside the trunk.
On the engine bay side, I removed the purge solenoid valve and hose and capped the line with vacuum caps.
This is how I have it on the IM now (with the loose end cut out), I have no idea if the cap will pop off at +20 psi of boost, the ones I have on the throttle body never gave me problems, I guess I will have to try it to see if it works.
Last but not least, I got a P0443 code which I promptly disabled in the AP.
For the record, the charcoal canister, evap system leak detection pump, and all the hoses I pulled on both the engine and rear side weigh 7 lbs.
The Following 4 Users Say Thank You to Code Monkey For This Useful Post:
Mauro_Penguin (08-12-2014), mxlplx71 (08-10-2014), theschrum (09-11-2014), WetzMS3 (01-22-2016)
 Old 08-11-2014, 07:00 AM   #8
Voltwings's Avatar
Posts: 3,713   (View Stats)
Rafal, assuming you mean the section on the throttle body i have circled here, No pressure actually goes through that, its just a water jacket to heat up the air to aid cold start. However, in messing around with OCC set ups, we have capped off the main 5/8" bung on the front side of the manifold with a Vacuum cap and zip tie and not had any issues thus far. I imagine you will be fine as long as you got that zip tie snug on there.
Past:
-Sold-
-Sold-
Current:
2012 Loaded Speed3 - Stock
2001 Miata - Basically stock
Code Monkey (08-11-2014)
 Old 08-11-2014, 07:06 AM   #9
Yeah, that's what I meant. When I get my new radiator, hopefully in the next 2 weeks, the front end will come out and I will tighten the zip tie as much as I can, now it is tight but I suspect it could be tighter, it is a pain to reach there.
Voltwings (08-11-2014)
 Old 08-12-2014, 01:52 PM   #10
Downmented's Avatar
Posts: 3,040   (View Stats)
Groans: 493
So @Code Monkey; I dont know if this is your most recent weight reduction project, but without the approximate weight of your cage, what would be your rough guesstimate of the current weight of the vehicle, as well as total weight lost thus far?
700HP CLUB
11.479@124mph
#DIX
 Old 08-12-2014, 02:03 PM   #11
Look at this post, assuming the 3,252 is correct, we have
Code:
 . di 3252-7-161
3084
with a full tank of gas. The 161 is from here -- weight of cage and spreader plates but not seat brackets. If you were running only one seat, subtract another 25 lbs or so.
Total weight lost so far would be then
Code:
. di 3589-3084
505
You can bring that 3,084 below 3,000 for sure.
Downmented (08-12-2014)
 Old 08-12-2014, 02:08 PM   #12
Downmented's Avatar
Groans: 493
Where would you say the largest loss of weight came from?
700HP CLUB
11.479@124mph
#DIX
 Old 08-12-2014, 02:43 PM   #13
Mazdazilla6's Avatar
Posts: 3,657   (View Stats)
Have you looked into lighter crash bars?
VersaTuner = Versatune
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Autotech = HPFP Internals
Grimmspeed = EBCS
 Old 08-12-2014, 03:36 PM   #14
Mauro_Penguin's Avatar
Posts: 1,997   (View Stats)
Groans: 171
Very nice job! Not just the weight reduction, but one step closer towards simplifying the car!
Code Monkey (08-12-2014)
 Old 08-17-2014, 08:31 PM   #15
derek13p's Avatar
Posts: 1,195   (View Stats)
derek13p is the leader of the worldderek13p is the leader of the worldderek13p is the leader of the worldderek13p is the leader of the worldderek13p is the leader of the worldderek13p is the leader of the worldderek13p is the leader of the worldderek13p is the leader of the worldderek13p is the leader of the worldderek13p is the leader of the worldderek13p is the leader of the world
Groans: 38
This inspired an idea for my build today, thank you!
06 MS6 & 06 MS6
The beauty is the beast
Daily driven
derek13p is offline   Reply With Quote
The Following User Says Thank You to derek13p For This Useful Post:
Code Monkey (08-17-2014)
 Old 08-17-2014, 09:04 PM   #16
I got the car re-fueled first time today since I pulled the evap system, the tank is still vented so no problems with pumping gas in.
Mauro_Penguin (08-18-2014)
 Old 06-21-2015, 10:18 AM   #17
I have no idea if the cap will pop off at +20 psi of boost...
Just to update, a ziptied rubber cap on the IM will not work in the long run. The rubber will crack sooner or later from boost. Use JBWeld or some other permanent solution.
ItsNox (06-21-2015), Voltwings (06-21-2015)
 Old 01-22-2016, 07:28 AM   #18
aviator79's Avatar
Posts: 3,934   (View Stats)
So im sure you get the EVAP not ready from this right? No CEL but never comes ready.
 Old 01-22-2016, 07:34 AM   #19
You will get a CEL, I just turned it off with the AP.
And here's the latest picture of the IM, I had the shop remove the whole evap fitting, tap, and plug the hole.
Vansquish (01-22-2016)
 Old 04-21-2019, 04:57 PM   #20
Tazilla's Avatar
Posts: 1   (View Stats)
Tazilla is an unknown quantity at this point
Ok, it is done.
I have a Mazda 6 2.3 does anyone know if i could use the same instructions? I want to get rid of the evap system, the pump is bad, keeps popping fuses so instead of replacing i want to remove the system. I removed the pump and just plugged the two hoses but i don't have any power what so ever if i go up a steep hill i would be in trouble.
Tazilla is offline   Reply With Quote
 Old 04-21-2019, 06:00 PM   #21
rgurleyjr's Avatar
Posts: 21   (View Stats)
rgurleyjr has a spectacular aura aboutrgurleyjr has a spectacular aura aboutrgurleyjr has a spectacular aura about
Pretty sure an evap issue will not cause a lack of engine power at all. Like it has nothing to do with it.
Not sure, I am having evap problems on my 08 speed 3 and the canister and pump are behind the rear subframe. And I ain't messing with that anytime soon.
rgurleyjr is offline   Reply With Quote
 Old 04-22-2019, 07:14 AM   #22
How to: AC System Delete and Alternator Relocation ABQ Speed6 MazdaSpeed 6 - How-To's 68 03-13-2018 01:24 PM
EVAP not ready and P0455 EVAP CEL issue aviator79 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 35 03-04-2016 07:12 AM
Failed emiisions due to EVAP system not ready aviator79 Mazdaspeed3/6 General Discussion 59 12-12-2014 11:46 AM
Evap system not complete? ms6ms6 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 4 02-20-2014 04:34 PM
evap system delete mrkdspd MazdaSpeed 6 - Engine, Transmission & Driveline 1 02-17-2011 10:22 PM
Page generated in 0.44531 seconds with 32 queries
