 Old 04-22-2012, 05:15 PM   #1
Mizzle's Avatar
Posts: 2,829   (View Stats)
Groans: 324
Default Spend My Money For Me
Soooo I'm indecisive, lazy, fearful & ocd. These things cause problems when it comes to spending money. I'm making a list here with links to help myself, but I also want your suggestions if necessary. I'm set on the wheels, tho, since I want to try and keep the negative scrub radius.
If you know of a better price, part, have another suggestion or are a vendor looking to deal, hit me up and/or post in here.
As far as parts I'm not decided on yet, I'm fine with DIY so if another OCC will work but doesn't have a check valve, I'll get a check valve ya know?
Wheels:
_Enkei PF01 17x8 ET50 (silver) with centers
_~ $1,100
_TireRack
Tires:
_Continental ExtremeContact DW 245/45ZR17 Purchased @ $620
_Tire Details - Discount Tire Direct
Lugs:
_McGard 65557BK SplineDrive Wheel Installation Kit Purchased @ $81.35
_Amazon
STS:
_Ralco RZ 914950 Purchased @ $116.61
_Ralco RZ Short Shifter MAZDA 3 2007 - 2009 914950
Programmer:
_AP AP-MAZ-002
_$535.00
_07-11 Mazdaspeed3 Cobb Tuning Accessport
Side Mounts:
_JBR obv.
_$350.00
Springs:
_Swift
_$319.00
_Swift Spec R Springs Mazdaspeed 3 MS3 2010+
Fuel Pump Internals:
_$349.96
_Autotech Hi Volume Fuel Pump Upgrade HPFP Internals Mazdaspeed 3 6 MS3 MS6
Help:
Spark Plugs:
_?
Strut Mounts:
_What adjustable mounts are out there?
Rear camber arms:
_Brand loyalty aside, which ones are a.) awesome & b.) adjustable on the car?
BSD Kit:
_Which would you recommend?
OCC:
_Which would you recommend? Easiest to drain?
EGR Blockoff:
_I'm thinking JBR?
FSB:
_Stiffest?
RSB:
_Stiffest?
Is the Whiteline bumpsteer thing worth it?
Is the Whiteline caster kit worth it?
Should I get rear toe adjuster thingies?
What else am I missing? I don't (yet,) want a FMIC/TMIC, dp, etc.
I don't have the money for internals or the AP yet, hence why it's mostly the stuff at the beginning of the list.
How are we so far/what do you think?
:edit:
Please include links.
 Old 04-22-2012, 05:18 PM   #2
mazdafreak's Avatar
Posts: 2,610   (View Stats)
Groans: 124
Md occ.....(Matt Damond oil catch can)
Rsb-jbr.
713whp/569wtq!
10.72 @ 139.44! (10/1/2015)
10.43 @ 140.95! 10/9/2015
10.35 @ 140.86 (10/30/2015)
 Old 04-22-2012, 05:24 PM   #3
Mizzle's Avatar
Groans: 324
Rsb-jbr.
Links?
I heard TriPoint's race bar was the stiffest. No?
 Old 04-22-2012, 05:27 PM   #4
Police - Grammarhead
Vansquish's Avatar
I seem to recall having heard some not-so-great things about the Ralco RZ short shifters. I think if you look around a little bit, you'll find some mentions of it being "weak" or "rattly" or something along those lines.
I think I'd go with the TWM kit instead, though it is significantly pricier.
 Old 04-22-2012, 05:32 PM   #5
TWOptSL0W's Avatar
Posts: 3,289   (View Stats)
Groans: 125
i got my rpf1's for 1k shipped, pm me
 Old 04-22-2012, 05:32 PM   #6
predapio's Avatar
Posts: 8,939   (View Stats)
Groans: 309
From what I've read, the Conti's are okay at everything, great at nothing.
I still say a summer setup and a winter setup.
What a lovable bunch we are!!
The Following User Says Thank You to predapio For This Useful Post:
CWP_MS3 (05-09-2012)
 Old 04-22-2012, 05:33 PM   #7
mazdafreak's Avatar
Groans: 124
Links?
I hear front sway bar isn't worth it since u will get way too much oversteer or understeer, one of those.
Umm but for rear sway bar......I'd just go jbr
Mazdaspeed 3 (07' - 2012) : James Barone Racing, Custom Fabrication
And the oil catch can you can get from Matt damond.
http://www.mazdaspeedforum.org/forum/foru...-thread-36097/
713whp/569wtq!
 Old 04-22-2012, 05:47 PM   #8
Mizzle's Avatar
Groans: 324
DW, not DWS. They're second only to 2x expensive Michelins.
The Following 2 Users Say Thank You to Mizzle For This Useful Post:
predapio (04-22-2012), SLOWHATCH (05-07-2012)
 Old 04-22-2012, 05:53 PM   #9
Vansquish's Avatar
If you want to know about the Ralco RZ for sure, I suggest you chat with Daddy Chinkus. I think he's got one in his car.
 Old 04-22-2012, 06:16 PM   #10
Mizzle's Avatar
Groans: 324
I want more of a "If it were my car and I could do it again, I'd buy ____ because ____."
rfinkle2 (04-22-2012), SLOWHATCH (05-07-2012)
 Old 04-22-2012, 07:28 PM   #11
Mizzle's Avatar
Groans: 324
OP updated. Easiest to drain OCC that'll work with a CAI.
 Old 04-22-2012, 07:53 PM   #12
MS3-a(sore)ASS-rex's Avatar
Posts: 7,012   (View Stats)
Groans: 224
OCC=matt damond or JBR
EGR delete=JBR
RSB=no clue
Plugs=Denso ITV22's
BSD=I personally like the SURE BSD
Rear Camber Arms=Megan or SPC. Both adjust on the car
NATOR PA
 Old 04-22-2012, 09:38 PM   #13
Mizzle's Avatar
Groans: 324
Is there a bsd walk-through?
Any less expensive occ's or would making a cheaper one work negate the savings?
Link to Megan camber arms?
@jbarone - does yours adjust when installed?
What is the consensus on rear toe adjusters?
 Old 04-22-2012, 09:58 PM   #14
mazdafreak's Avatar
Groans: 124
No, his arent adjustable once on the car.
713whp/569wtq!
 Old 04-22-2012, 10:00 PM   #15
Mizzle's Avatar
Groans: 324
Thanks. Do Megan arms have stiffer bushings?
 Old 04-23-2012, 05:15 AM   #16
Groans: 224
Edgeautosport.com has them and @eric@edgeautosport can get you some good prices on mist of these parts
NATOR PA
 Old 04-24-2012, 05:49 PM   #17
Constantin's Avatar
Posts: 3,907   (View Stats)
Constantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the world
Groaned at 18 Times in 16 Posts
Really? I didn't do a detailed search yet. Can you post the link to the thread? I in the market for sway bars. Original plan was to go get front and rear...
Constantin is offline   Reply With Quote
 Old 04-24-2012, 05:58 PM   #18
Constantin's Avatar
STS:
_Ralco RZ 914950
_$118.99
_Ralco RZ Short Shifter MAZDA 3 2007 - 2009 914950 (unless I can bid one down on Ebay.)
I heard that with aggressive shifting with short shifters you are highly increasing the chance to ruin your tranny. To be more specific you are putting a lot of pressure on synchronizers.
I have heard it from reputable source, but I am NO EXPERT! May somebody who know about the possible problems that short shifter can bring can comment here...it will be nice to know for sure.
 Old 04-24-2012, 09:27 PM   #19
Mizzle's Avatar
Groans: 324
Whoever said a STS ruins your synchros is retarded.
That said, I'm just buying that to replace my stock unit. I'm going to add a 2" extension to bring it back to stock height anyways.
 Old 04-27-2012, 04:56 PM   #20
Constantin's Avatar
Default FSB = no oversteer
Hey, found this thread by @Tomas:
Hotchkis FSB Install
@Tomas sais (post #5) that he does not experience oversteer. In fact he highly recommends Hotchkis FSB.
The Following User Says Thank You to Constantin For This Useful Post:
Mizzle (04-27-2012)
 Old 05-05-2012, 02:31 AM   #21
Mizzle's Avatar
Groans: 324
Ralco STS ordered from THMotorsports: $116.61 shipped.
Hubcentric rings ordered from EBay - $9.
McGard lug kit ordered - $38 after using AMEX points (from ~$85)
Question:
Why are the spark plug part numbers for 2010 MS3's and 2008 MS3's different?
@Daddy Chinkus - is the shifter a STS because they cut the shaft down or because the linkage connection is longer?
NGK 2008: ILTR6A-8G .032"
NGK 2010: SILTR6A-7G .027"
Obviously the gap, but what else?
 Old 05-05-2012, 09:32 AM   #22
mczimer's Avatar
Posts: 1,249   (View Stats)
mczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the world
If you are getting an AP, you might as well invest in one step colder plugs. For the OCC....yes, MC's is a great setup, but it isn't anything you can't do yourself. You can install the OCC by the horn bracket, which lets you drain the easiest, or by the CAI (should still fit). When you do install the OCC, you should also clean your valves and do the EGR blockoff at the same time, since it is a seriously big PITA without the I off.
mczimer is offline   Reply With Quote
 Old 05-06-2012, 01:28 AM   #23
2zz mr-s
dooderek's Avatar
Posts: 5,119   (View Stats)
Groans: 239
linkage is but the shifter itself is also shorter
 Old 05-06-2012, 05:50 PM   #24
Mizzle's Avatar
Groans: 324
Any knowledge on the plug part numbers?
 Old 05-06-2012, 06:25 PM   #25
grantmm's Avatar
Posts: 826   (View Stats)
Groaned at 8 Times in 5 Posts
+1 for TriPoint Rear Swaybar. Their customer service is better than amazing. I'd rather support them then someone who's an ass to anyone who questions their products (JBR).
 Old 05-06-2012, 06:51 PM   #26
Mizzle's Avatar
Groans: 324
A.) @jbarone is one of the best vendors we've ever had.
B.) My thread is not for bickering.
C.) Anyone that says shit like the following doesn't get to speak unless spoken to:
I upshift and downshift without the clutch all the time...
Soo any input on the plugs?
 Old 05-06-2012, 06:57 PM   #27
grantmm's Avatar
JBR is also one of the cockiest people ever on the forum.
Shifting a car without using the clutch says nothing about someone's knowledge oor experience with car setup.
I'm also not the one who can't use the search function for one of the most commonly discussed maintenance upgrades.
 Old 05-06-2012, 07:04 PM   #28
lulz @Raider
burn813's Avatar
Posts: 3,171   (View Stats)
I have the ralco and I have had it on ye car for about a year...... I am pretty happy with it..... Only thing I don't like is I think it is about 1/2 an inch shorter than the twm and when you put the car in reverse it rubs on the shifter boot.... I am on my second shifter boot
2008 MS3 gt
470hp/463tq on GT35r at 29psi
burn813 is offline   Reply With Quote
 Old 05-06-2012, 07:39 PM   #29
Mizzle's Avatar
Groans: 324
First off, no one mentions the SILTRA6A-7G.
Second, get off your soap box and fuck off / gtfo.
Do you have a shortened boot? I assume it's where the washer is that retains the boot?
 Old 05-06-2012, 08:01 PM   #30
lulz @Raider
burn813's Avatar
Right there
2008 MS3 gt
 Old 05-06-2012, 08:04 PM   #31
lulz @Raider
burn813's Avatar
And yes that is the short boot
2008 MS3 gt
 Old 05-06-2012, 09:08 PM   #32
Mizzle's Avatar
Groans: 324
Weird.
Is it something on the inside? I ask because I have a grinder... and mine is already purchased
 Old 05-06-2012, 10:02 PM   #33
lulz @Raider
burn813's Avatar
Yeah there is a plastic piece that you could prolly trim down..... I am just to fucking lazy
2008 MS3 gt
 Old 05-06-2012, 11:30 PM   #34
Mizzle's Avatar
Groans: 324
So lazy, in fact, that you can't type two "o's," in "too."
<3
 Old 05-07-2012, 12:22 AM   #35
Bosox's Avatar
Posts: 328   (View Stats)
Bosox is the leader of the worldBosox is the leader of the worldBosox is the leader of the worldBosox is the leader of the worldBosox is the leader of the worldBosox is the leader of the worldBosox is the leader of the worldBosox is the leader of the worldBosox is the leader of the worldBosox is the leader of the worldBosox is the leader of the world
Groaned at 33 Times in 13 Posts
All these mentions of Matt Damond.. I don't think the guy exists. I think he is made up. Either that or he has been on location with Ben for the last 6 months. The guy reminds me of the R.O.U.S.es or Keyser Söze.
2010 Liquid Silver MS3 - COBB SRI/TIH, AP, JBR 88 Duro RMM, JBR Bushings, JBR SSP, AT Internals, CP-e Catted DP/RP, Michelin Pilot Super Sports 235/40 18, Motorcraft MT Fluid, Step Colder NGK's
Wife's Car: 2013 CX5 AWD Grand Touring (It's slow but handles nice)
OBAMA SUCKS
Stratified Tune by Lex
Bosox is offline   Reply With Quote
 Old 05-07-2012, 06:27 AM   #36
lulz @Raider
burn813's Avatar
<3
Shit, fuck ..... You are right
2008 MS3 gt
 Old 05-07-2012, 06:27 AM   #37
lulz @Raider
burn813's Avatar
He is there, he just hides well @Bosox
2008 MS3 gt
 Old 05-07-2012, 08:00 AM   #38
Mizzle's Avatar
Groans: 324
Hello,
They are very similar, but have different part numbers. The SILTR6A-7G is dealer only. The ILTR6A-8G is the option available for purchase in the aftermarket.
Best Regards,
Andrew Hauenstein Technical & Training Specialist NGK Spark Plugs (USA), Inc
rfinkle2 (05-07-2012)
 Old 05-07-2012, 08:57 PM   #39
Mizzle's Avatar
Groans: 324
Note:
Holy crap, I got my hubcentric rings already.
I bought them on 5.3.2012 for $8.90 with free shipping on they're here... cray.
I highly recommend "aaiautomotiveaccessories," on EBay.
 Old 05-08-2012, 08:15 PM   #40
Mizzle's Avatar
Groans: 324
McGards came in.
One point of contention: The spline-drive nuts have rotating seats so they don't fuck your wheels up.
The locks that came with it do not.
I'm happy because they'll protect my shit, but still... wtf?
Looking for a shop in NYC bigx5murf Mazdaspeed3/6 General Discussion 0 02-16-2011 06:56 PM
Car is in the shop desertrat MazdaSpeed 3/6 - Turbo Induction 2 11-15-2010 10:15 PM
The Shop crbalch Mazdaspeed3/6 General Discussion 4 11-08-2010 06:37 PM
08 In the Shop Shanems3 MazdaSpeed 6 - Engine, Transmission & Driveline 6 04-24-2010 08:46 AM
Page generated in 0.57441 seconds with 32 queries
