 Old 07-17-2018, 06:16 PM   #1
Pro60modman's Avatar
Posts: 5   (View Stats)
Pro60modman is an unknown quantity at this point
Default High rpm misfire, tried everything.
06 MS6.
Got it with cheap parts store coils and it ran poorly with random misfires everywhere. Swapped to new OEM coils and all was well except 5500+ where it would misfire. Put new NGK 6510 plugs in gapped .026 all the way to .019 and no change. There are no boost or load tables influencing a fuel cut. Stretched the springs, nothing. Replaced the springs with proper length 4 gauge copper grounding wire, no dice. At this point I'm at a loss. The tune is solid. BNR S4 on E50 at 24psi with a Treadstone FMIC, fuel pump internals and HTP 3" intake. AFR's are perfect and timing is a 4 degrees under MBT up top for now.
I haven't gone into leak down, cylinder leakage or EGR leak tests yet but it looks like I'm heading that way if I haven't missed some sort of ignition fault.
Pro60modman is offline   Reply With Quote
 Old 07-17-2018, 08:11 PM   #2
JakeMS3's Avatar
Posts: 1,164   (View Stats)
Groaned at 7 Times in 5 Posts
Why multiple threads on same issue bruh?
2013 LSM w/tech
Cobb AP V3, CBE
CS Turbo tuned by PD
JBR FMIC Pipe Kit w/TR8
CP-E TIP/3.5" Intake
DM OCC/TMM
Forge V2 BPV
Bilstein B8 w/Swift springs
Wilwood 6 pot BBK
EBC RedStuff rear pads
Konig Hypergram 18x8.5"
The Following User Says Thank You to JakeMS3 For This Useful Post:
Thor Hammer (07-18-2018)
P0302 Cylinder 2 Misfire.. But no misfire. AredMS3 MazdaSpeed 3 - Engine, Transmission & Driveline 4 10-20-2016 06:45 AM
High KR WOT-high boost, high load c_bye MazdaSpeed 3 - Engine, Transmission & Driveline 13 06-28-2016 09:11 PM
Stutter/misfire/breakup at medium to high loads Dano MazdaSpeed 3/6 - Troubleshoot/Diagnostics 64 06-07-2015 11:33 AM
Cylinder 4 Misfire, Fuel Pressure too high Kaidao MazdaSpeed 3/6 - Troubleshoot/Diagnostics 6 09-20-2011 02:00 PM
Geneva 2010: Citroen DS High Rider rides in on its high horse Haltech Automotive News 0 03-03-2010 07:30 AM
Page generated in 0.23557 seconds with 21 queries
