  • 1 Post By Jeff23spl
 Old 05-27-2019, 09:00 AM   #1
Spence's Avatar
Posts: 15   (View Stats)
Spence is an unknown quantity at this point
Default How to rebuild a K04?
Hi guys, I think its quite obvious now my turbo is done lol... I bought a rebuild kit for it, but I was curious if you guys know of any good videos on how to do so... I do have the proper tools most likely to do this...
Thanks
-Spence
Spence is offline   Reply With Quote
 Old 05-27-2019, 09:28 AM   #2
Posts: 2,235   (View Stats)
The key is cleaning the turbine shaft where the sealing ring seat. sometimes it is so well baked that it looks like real metal...and if the ring groove is worn out, you won't get good results.
Look at your blades also, if it is damaged, just throw it to garbage...especialy the cold side.
If you find a trick to open the cold side back plate that is silicone glued, let me know....i did succeeded but sometimes i break it in 2-3 parts....
VW also use k series so you shouldn't have problem to find videos....
at the end of the day, a complete assembled CHRA can be found for 250$, it is a better option than the time it takes to risk a 100$ rebuild kit in it.
and any other turbo swap could be better than a k04....but our Mazda flange limit the options if you don't plan to change manifold and DP
Spence likes this.
K04 rebuild I<3Groceries MazdaSpeed 3/6 - Turbo Induction 17 06-02-2013 02:10 AM
Would you buy a used MS6/rebuild it? Silver Ecstasy MazdaSpeed 6 - Engine, Transmission & Driveline 44 08-19-2012 06:56 AM
My MS6 Rebuild spiker98 MazdaSpeed 3/6 - Big Turbo Builds 15 12-08-2010 10:17 PM
Page generated in 0.23370 seconds with 21 queries
