![]() Join Date: Dec 2008
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 238
(Thread Starter) | Not Ranked : 0 score Right? Having owned higher hp V8's when I needed to pass or go up a hill, I just left it in the gear it was in and relied on the lower range torque to get me through it, I never had a problem doing that. Am I correct that this is a bad idea with this car? I've read things such as "May God have mercy on those that boost in 5th gear"...when raking through the gears it's common for me to push it in 3d, 4th and then into 5th pulling strong boost the entire time. Is that a bad thing? Or is it boosting in low RPMs that's bad, say in 5th or 6th gear cruising on the highway. I'm just trying to clear this up for my peace of mind. Please forgive my ignorance, I'm just not accustomed to having a high rev engine...hell, most of my cars in the past had a 6K redline and pushing it above 5K was useless. My GTO would cruise at 1500 RPM in 6th through town. I've made a habit of keeping the RPM's higher on my MS3 by downshifting more often that I have in the past (passing/uphill)...I have to keep telling myself it's ok, I'm not used to that sound yet I guess.
__________________ I swear I can smell your stinky hands from here... |
Groans: 60
| Not Ranked : 0 score There are really only two rules and they're pretty simple. 1) Part throttle boost is VERY bad. Don't do it! Downshift, or go WOT. 2) Don't go WOT below 3000 rpm. If you don't have a full throttle flash, there is no need to take this motor past 5500rpms, but your not going to hurt anything, you just won't make more power.. I ran fully bolted for two years with no upgraded HPFP, and my motor was running perfect before I pulled it for the build..
| The Following User Says Thank You to SSinstaller For This Useful Post: | Smokehouse (03-17-2009) |
And as for the 3K thing...You're saying never dump the pedal in lower than 3K RPM's? Interesting. If your in a situation where downshifting is not an option (say in second and 1st is no good) will you just ease on the throttle and then let it rip at around 3K? Again...sorry if this stuff seems stupid, this really is new territory for me.
__________________ I swear I can smell your stinky hands from here... | |
| Banned ![]() Join Date: Jun 2008 Location: misery
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 11,510
Groans: 1,940
| Not Ranked : 0 score well duh, you drive it up, on, and OVER the ramps |
| The Following 3 Users Say Thank You to phillyb For This Useful Post: |
Groans: 1,940
| Not Ranked : 0 score jesus christ i just couldn't resist that one. there is too much load put on the engine at low rpm and wot. |
Groans: 60
If your in a situation where downshifting is not an option going WOT is probably safer than easing in to the throttle(this causes part throttle boost). IMO, part throttle boost on this motor is far more dangerous than the momentary lean spot(caused by the HPFP) you might get going WOT below ~3K rpms.
__________________ Fully Built : Arias Pistons: Pauter Rods : ARP bolts: Ported Head: Cosworth BSD : Spec 3+ Clutch : Fidanza Flywheel : AWR Engine mounts 90duro : Custom TIP/Intake : Custom Blow Through 3.5" MAF : Custom FMIC : HKS SSQV VTA : Ported IM : Custom DP : Custom Exhaust : CPBoost Top Mount EM : Garrett GT3582R : PTP Turbo Blanket: Tial V44 EWG : Perrin EBCS : MrLilGuy/PTP HPFP : Ported fuel line : Ported Fuel Rail : Custom Ported Fuel Injectors : Kenny Bell Boost-a-Pump : HKS Twin Power DLI II : HKS M-Series Plugs : Cobb AP : AEM 3.5bar MAP :Koni Sport shocks : RPM Kspec Springs : TWM STS : TT Front Diff Mount : CPE Upper Diff Mount : Whiteline RSB : AWR Endlinks | |
![]() Join Date: Jan 2009
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 21
Groaned at 227 Times in 193 Posts
| Not Ranked : 0 score I'm kinda questioning this too... I always go part throttle into low boost while driving down the highway in 5th and 6th gear? The only problem Ive notice with that is the wastegate is extremely touchy... |
| The Following User Says NO Thank You to Bigbody250 For This Un-useful Post: |
Groans: 60
| Not Ranked : 0 score Search some of the blown motor threads and you'll see that alot of them let go during that same type of driving...
| Banned ![]() Join Date: Jul 2008 Location: AVON LAKE , OHIO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 18
| Not Ranked : 0 score Just keep your foot in it |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 51
| Not Ranked : 0 score really ive never had a single problem with my engine its the damn transmission that keeps f-ing with me . 43,000 miles so far If your worried don't go WOT in the dead heat of the summer and if its slow downshift and drive it hard . Heavy mods I'd look into getting built . Or another car . Like an STI drool . Fist mods no questions asked Motor mounts !! Im on my second transmission and it has 2nd and and the shifting fork replaced at the same time the passenger motor mount got replaced . Oil was leaking out of it . when I pulled the tranny mount off it had a crack in it . If you listen to anyone on here listen to me !!! update you motor mounts should be the first thing you do . I actually had a police officer come up to me one day and ask me if I was having trouble with my motor mounts. Seems to be a common mazda problem . |
| The Following User Says Thank You to ccann26 For This Useful Post: | fyrecrotch (03-18-2009) |
| The Angry Goose ![]() Join Date: Jun 2008 Location: Villa Park, IL
Rep Power: 701 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,192
Groaned at 9 Times in 6 Posts
| Not Ranked : 0 score I drive it everyday, anyway it suits my needs. 21k with no issues in the year I have had my 08. I feel the blown motor "issue" is literally blown out of proportion. This is the internet....a lot of important factors can be left out to make he/she like they are not at fault. Just enjoy your car.
__________________ Hector 2014 Mazda 3 2008 Mazdaspeed3-SOLD 1979 Mazda Rx7 |
| The Following 5 Users Say Thank You to Hectik1 For This Useful Post: | ChrisK (03-18-2009), fuji27 (03-22-2009), fyrecrotch (03-18-2009), mouse0330 (03-18-2009), zoom1&zoom2 (03-18-2009) |
| Banned ![]() Join Date: Mar 2008 Location: Winter springs
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,251
Groans: 974
Groaned at 738 Times in 373 Posts
| Not Ranked : 0 score Yeah, I part throttle boost in upper gears all the f'n time. Never had a single problem with it..I think that some are getting cars with bad factory tunes or some shit because it's not everyone having this problem. |
![]() Join Date: Feb 2009
Rep Power: 151849 ![]() Thanks: 55,993
Groans: 1,443
| Not Ranked : 0 score OK, so what needs to be done/added to make this motor do anything productive past 5,500 RPMs? I've hit that wall a few times. It just falls flat on it's face.
__________________ Evo VIII - 9.93 @ 150.05 - CAI and LEDs Beanfab / Tuned by Nishan |
![]() Join Date: Aug 2008 Location: Michigan
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 438
Groaned at 81 Times in 33 Posts
| Not Ranked : 0 score 5500rpm is the literally the safe limit of the stock K04 turbo. Any other tunes would be sorta unsafe for the sake of the stock turbine. I part throttle boost all the time, and I don't have any issues. IMO..if I have to go gentle or WOT only...wtf kind of car do we own then? Sounds like the car needs ridilin or something, and i'm not prescribing shit!
__________________ Mike 2008.5 CWP Mazda CX-7 Sport FWD - hers 2008.5 CWP Mazdaspeed 3 GT - traded 2011 LSM Mazdaspeed 3 Sport w/tech pkg - sold |
![]() ![]() Join Date: Jul 2008 Location: Old Bridge NJ
Rep Power: 22834 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 31,276
Groans: 309
| Not Ranked : 0 score I drive 7 miles to work everyday. One way has lights every half mile. The other way is all highway. I don't stoplight race (well...maybe sometimes...lol). So just by driving either on the streets or highway; I part throttle boost alot. 7600 miles and no problems.....yet...we'll see in the future...only mods are intake and mm.
__________________ Dash08: I don't see the whole pedophile thing, But Predapio is a dirty old bastard. So, I wouldn't rule it out entirely. That's also why he fits in here. We're all a bunch of filthy, perverted, arrogant, pessimistic, self-righteous assholes who find entertainment at other peoples expense. What a lovable bunch we are!! |
![]() Join Date: Feb 2009 Location: Coronado ca.
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 101
__________________ 2007 mazdaspeed6 & 2007 mazda 6 wagon gt 3.0 | |
| Not Ranked : 0 score Im right there with ya buddy... my other cars are a 2000 dakota r/t 5.9 v8 modded, 67 barracuda 372 v8 heavily built, 05 ram cummins with banks tuner/exhaust etc. I too am used to big 400+ ft lb torque monsters... so going to my MS6, my first 4cyl car turbo car too. It has taken some getting used to but it sure if a fun car, I really love how quickly these cars get into boost and the great torque numbers. I bought mine used with 15K miles on it, it now has 30K miles on it and basically this is what I have found. Part throttle boosting.. I do this every single day, alot of the time I never get a chance to get the car to wide open throttle. For the most part I am used to easing into the throttle, in my dakota and barracuda if you floor it below 20 mph the tires just fry...but when I ease into the throttle on the MS6 it gets into boost and to 5500 rpm before I get the peddle to the floor. I have been doing this for 15K miles now without a hitch. I have noticed while cruising the freeway if you downshift to 5th and give it part throttle sometimes it will knock for a split second. It has happened to me about 4 or 5 times.So I try not to do that... dont run her up over 5500 rpms because the HP and tq just disappears after that..car falls on its face, so dont bother. Clutch peddle and engagement is like a pickup truck manual trans, takes a little getting used to. You'll find your style with it, just have fun and dont worry, the internet is your friend, but if your worried about anything with any car, the internet can be your worst enemy... LOL
![]() Join Date: Jan 2009 Location: Fort Worth, TX
Rep Power: 794 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 771
| Not Ranked : 0 score I've recently noted SS's comments on my own. I've been paying close attention to my AFR lately, and I've noticed it stays stoich under part throttle and under moderate boost. The threshold is just...wrong. It scares me everytime. I try to stay under 5lbs usually, under part throttle.
__________________ Meet a giant fish. Fuck his brains out. |
![]() Join Date: Mar 2008 Location: Navarre, FL
Rep Power: 4956 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,585
Groans: 370
| Not Ranked : 0 score I really don't freak out or worry about the part throttle stuff or low rpm boosting... and I'm basically fully bolted and have 40k miles on the car...no real issues. I usually don't go WOT below 3k in gears 4-6, but 1-3 they are short enough if you do go WOT below 3k you're out of the low rpm range before you know it. But on the highway if I am going to pass someone, I go WOT/part throttle all the time in 6th gear. only time i might be worried about low rpm boost/power is if you had lots of boltons done and were still on the stock FP or on the limits of the stock FP... I have meth also so that probably helps supply some low end fuel too Sometimes I will see some KR at low rpm in boost, but I will let off and instantly go back into it and there's no KR, it seems to be some weird ECU issue than an actual issue itself? Overall I say don't worry about it too much! especially if you only have basic mods like intake, bpv, test pipe blah blah |
![]() Join Date: Aug 2008 Location: jersey
Rep Power: 609 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 388
| Not Ranked : 0 score i drive religiously out of boost, try to never go more than 10vacum And i never floor it unless im above 3000 now i feel like ive been wasting my time |
| Driver ![]() Join Date: May 2008 Location: Toronto
Rep Power: 1986 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,158
Groans: 44
| Not Ranked : 0 score nothing wrong with babying the car...just do it for the right reason. I can't see any of us consistently puonding in 15PSI @ 2000RPM in 5th all the time. Just drive the car like you normally do. I've done some unholy things to the car...nasty disgusting, locked doors in a dank basement perversion...she loves it.
__________________ ![]() DONE . Cobb AP 22-psi Self-Tuned . ATP GT3071 . CP-e 3.25" MAF+4" inlet . Denso ITV-24 . CP-e HPFP . CP-e FMIC . Turbosmart Ultimate BPV . 50/50 Meth w/ M5 nozzle . PTP IM Spacer+EGR delete . GrimmSpeed EBCS 3-port . SteedSpeed Mani . CP-e TBE . Greddy OCC w/ 2nd PCV valve . F2 BSD + oil-pan baffle . Hawk HP+ pads . Goodridge SS brake lines w/ Ford Super Dot 4 . Cobb Springs+FSB . Tri-Point RSB+Endlinks . Koni Yellows . KMAC Camber Plates . 60mm Boost Gauge . TWM Complete Shifter w/ JBR SSP+weight . CP-e RMM+PTP trans+kicker mount . Sparco Harness Bar w/ MOMO 4-pt harness . Rays/Volks 57F 18x8.5" +45mm 235/40/18 Hankook V12 . BBS RK 17x8" +45mm 235/45/17 RA1/R6 . OEM Snowflakes w/ 215/50/17 Nitto NT-SN1 . 3rd in CSCS 2009 Time Attack Championship - Super Street FWD . 360whp/390wtrq . SOON . 3-bar MAP sensor . MSpeed Tuning & Diagnostics - The Street Lab is ALWAYS OPEN FOR BUSINESS "It is amazing how many drivers, even at the Formula One Level, think that the brakes are for slowing the car down." -- Mario Andretti -- |
![]() Join Date: Apr 2008 Location: MS
Rep Power: 845 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 360
Groans: 56
![]() Join Date: Jul 2008 Location: Oklahoma
Rep Power: 0 ![]() Thanks: 0
![]() | | #24 | ![]() |
![]() | | #25 | ![]() |
![]() Join Date: Mar 2008 Location: Miami, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 61
| Not Ranked : 0 score Worry about boost and a blown engine when you're modded. If you're stock, just drive the car. There is no right or wrong way. I pass in 6th all the time, usually on the highway. If you're going up a hill, it should be fairly obvious when the engine is being overworked, simply downshift. The gears are so short (and the turbo spools pretty quickly) that it's harder to bog the engine compared to some other cars.
__________________ Cobb SRI // Cobb Shifter Weight // TWM Bushings // TWM STS // TWM type R weighted shift knob // Medieval Rear Mount // Darkstar Passenger Mount |
| Incentives aimed at clearing 'mess' of leftover '08 models | Haltech | Automotive News | 0 | 02-07-2009 05:10 AM |
| Incentives aimed at clearing 'mess' of leftover '08 models | Haltech | Automotive News | 0 | 02-06-2009 04:30 PM |
| checking / clearing codes? | GPMS3 | MazdaSpeed 3/6 - ECU Computer Tuning | 11 | 01-15-2009 12:31 PM |
