![]() Join Date: Nov 2018 Location: Ukraine, Odessa
Rep Power: 0 ![]() Thanks: 0
(Thread Starter) | Not Ranked : 0 score Hello. I am from Ukraine, please forgive me for my English. I ran into a problem with my Mazda 3 MPS 2007. When I get overclocked, I get boost surges. No errors on the dashboard does not issue. I own the car since 2013. This problem was from the very beginning of my ownership. I bought a standard car. At the moment there is a tuning kit COBB STAGE 3. Diagnostics "Turbogarage" PAT pointed out that the torque limit signal is on. During the attempt to fix the problem, the engine control unit changed. In addition, when removing the fuses on the ABS / DSC unit, the problem falls. |
(Thread Starter) | Not Ranked : 0 score I incomprehensibly described the problem? |
Rep Power: 3747 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,744
| I am not sure I understand the problem that you are having. You mentioned that you have a Cobb Stage 3 tuning kit. That makes me wonder two things in particular. 1. Do you have a custom tune for the car? 2. Are you using an off-the-shelf (OTS) tune instead? The datalog that you uploaded does not really tell us very much. Because you do not maintain a constant or gradually increasing accelerator pedal position, the data is very inconsistent. As a result, it is very difficult to tell if movement of your foot on the accelerator pedal is causing the fluctuations in throttle position, boost, mass airflow, and so forth.
The accelerator pedal is at the same level of depression. | |
What aftermarket parts are installed on the car?
__________________ Having trouble finding something on MSF? Use MS3Shadow's search tool:SEARCH MSF HERE! | |
At the moment, the standard enumerated engine, past G2, the new original turbocharger. | |
(Thread Starter) | Not Ranked : 0 score I'll try to describe it differently. If you go by car, 4th gear is included. With an average acceleration, the accelerator pedal ~ 40%, engine 2000-3000 rpm. Boost 0 Psi. It is not clear where the kick comes from and the boost starts to jump 0-0.7-0-0.7 psi. This continues until you release the accelerator pedal. https://youtu.be/_v0m7FgKu2U |
Groans: 211
__________________ 2007 MS6- H&R Coilovers/ C-PE Catted DP/Corksport HPFP Internals/ AEM CAI/ ETS TMIC/ CPE Austenite Dual CBE/ CPE TIH/ Synapse Synchronic/ Freektuned/ AP Short Shifter/ AWR RMM and OEM TMM with CS Inserts/ Southbend Stage 2 Endurance/Stop Tech Slotted Rear and DBA T3 4000 Series Front with EBC Reds/CPE xFlex Rear Diff Mount/ Whiteline Rear Sway Bar/DSS Level 2.9 Rear Axles | |
(Thread Starter) | Not Ranked : 0 score This problem comes from the DSC block, it gives the command to limit the torque. because of this, these jumps of supercharging appear. With a mechanical system shutdown - removing the fuses on the ABS / DSC problem disappears. I changed the ABS / DSC unit, the combined sensor and the steering position sensor did not help. |
(Thread Starter) | Not Ranked : 0 score Mileage on my car is currently 80,000 kilometers. In connection with the fall of compression in the third cylinder, I did an overhaul of the engine. During the repairs, the main and connecting rod bushings, connecting rods and piston G2, rings, oil pump, new original turbocharger, flywheel, clutch were replaced. Before this repair, the car was standard, without tuning. After the repair was installed The Stage 3 Power Package COBB. I repeat that the problem is not in the motor and its software. I went to Kiev to Sasha PAT (this is our local tuner of the Ministry of Railways, maybe you heard about him), unfortunately he didn’t have enough days to sort out the problem completely. The only thing he said is that the engine control unit receives a signal to limit the torque on the CHAN bus, it seems that the car seems to be skidding, and programmatically by temporarily turning off the perception of the singal by the engine control unit to limit traction. This signal most likely comes from the DSC block. Changed both the DSC unit itself, and the combined sensor and rudder position sensor did not help. There is a possibility that a failure occurs in the ABS sensors, but at that time, does not it show an error on the instrument panel? |
Groans: 211
Put the stock tune back on the car. Or Stage 1 OTS tune.
| SWAS strikes again?
| Car jerks when turning left all the way? | Vex | MazdaSpeed 3/6 - Suspension & Brakes | 19 | 03-20-2015 12:31 PM |
| Car Jerks at WOT: Fueling Issue??? | Stew | MazdaSpeed 3/6 - ECU Computer Tuning | 16 | 08-30-2013 10:12 AM |
| car jerks when im in the bottom of a 3 or 4 or 5 | Palms | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 4 | 03-04-2011 07:33 PM |
| Car Jerks when starting up | zpele | Mazdaspeed3/6 General Discussion | 19 | 01-23-2011 02:20 PM |
