![]() Join Date: Nov 2015
Rep Power: 0 ![]() ![]() Thanks: 3
(Thread Starter) | Not Ranked : 0 score Thanks! |
![]() Join Date: Aug 2011 Location: Boerne, TX
Rep Power: 112 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 39
| Not Ranked : 0 score Switch the bulbs from side to side. If the issue follows, it's the bulb. If not, may be ballast. Also check connectors for corrosion while you're at it.
__________________ _____________ 2006 Platinum MS6 GT zzb at 156k - stock 2013 gen2 replacement - Cobb APv3, Fidanza LW Flywheel/Luk clutch, CorkSport BPV, Cobb SRI Last edited by Tres3; 02-01-2020 at 04:33 PM. Reason: MSF Database - Automerged Doublepost |
![]() Join Date: Jun 2009
| Not Ranked : 0 score Also, 3 or 6?
__________________ _____________ 2006 Platinum MS6 GT zzb at 156k - stock 2013 gen2 replacement - Cobb APv3, Fidanza LW Flywheel/Luk clutch, CorkSport BPV, Cobb SRI |
| The Following User Says Thank You to Tres3 For This Useful Post: | MSMS3 (02-03-2020) |
| Not Ranked : 0 score get 2 brand new bulb first as old bulbs gives less output and could be harder on the ballast start circuit... then a ballast
| The Following User Says Thank You to Jeff23spl For This Useful Post: | MSMS3 (02-03-2020) |
| Not Ranked : 0 score Maybe OP will tell us what car he has if we are to help him. MS3? Gen 1 or Gen2? Year model? Sport or GT or MS6?
OP?
__________________ _____________ 2006 Platinum MS6 GT zzb at 156k - stock 2013 gen2 replacement - Cobb APv3, Fidanza LW Flywheel/Luk clutch, CorkSport BPV, Cobb SRI | |
| Not Ranked : 0 score i did the same but then, figured out there is 2 different person with same question.
(Thread Starter) | Not Ranked : 0 score Apologies for the delayed response - somehow did not get the email notifications. To the point - the car is 08 MS3 with a GT trim (HID lights). Interestingly, the headlight started to come on more often - if I turn the switch several times, fair odds it would come on and stay for a bit. Obviously, this is not sustainable. Thinking of picking up a ballast that I could return just so that I would have it on hand in case it's not the bulb (and to avoid having to remove the bumper twice). thanks again. |
| Not Ranked : 0 score OEM ballast from Amazon. Fully returnable.Ask me how I know.
| Not Ranked : 0 score i was able to replace bulb without removing the bumper cover but needed for the ballast....
| Not Ranked : 0 score Oh, yes. Bumper can stay on for bulbs, as long as your hands are thin and wrists are flexible.
| Not Ranked : 0 score Oh yeah, I forgot is a 3. On a 6 it's tight, but doable.
| Not Ranked : 0 score was ok for my speed6 d2s and i had h11 socket on the speed3 converted to hid...maybe it is harder with d2s...but i also have tiny hands...
| HID ballast/bulb install tips? | SkippyScallop | MazdaSpeed 3 - How-To's | 0 | 10-12-2016 07:40 AM |
| Headlight Bulb | Tiner | Mazdaspeed3/6 General Discussion | 8 | 07-26-2015 08:26 PM |
| Why is my low beam a 9003 bulb? | kylejenson | MazdaSpeed 3/6 - Car Audio & Electronics | 8 | 06-24-2014 11:31 PM |
| low-beam bulb burned out | bzwyatt | CX-7 > General Lounge + New Member Welcome | 14 | 06-05-2011 09:47 PM |
| Headlight out... it's not the bulb | Eazy | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 5 | 02-11-2009 12:57 AM |
