 Old 12-18-2009, 07:59 PM   #1
Race Roots's Avatar
Posts: 885   (View Stats)
Race Roots is the leader of the worldRace Roots is the leader of the worldRace Roots is the leader of the worldRace Roots is the leader of the worldRace Roots is the leader of the worldRace Roots is the leader of the worldRace Roots is the leader of the worldRace Roots is the leader of the worldRace Roots is the leader of the worldRace Roots is the leader of the worldRace Roots is the leader of the world
Groaned at 18 Times in 18 Posts
Default MS3: Brake Rotors, Pads, Lines and Fluid!
Here at Race Roots we have everything you need to complete your required brake maintenance!!
First Up we are very proud to introduce the new Racing Brake One Piece Slotted Rotors that are 3.75 lbs lighter PER ROTOR!!! So that is a weight savings of almost 8lbs per axle!
These Rotors are made out of alloyed gray iron and are a straight slot vane rotor with EDP coating and cross cut grinding on friction surface.
For a complete set Front and Rear you can get them for $390 shipped!!!
Orders can be placed here: Mazdaspeed 3: Brakes and Accessories
We are also stocked up and ready to ship Hawk Ceramics, HPS, and HP+ pads. To help some of you on deciding which pad is best for you I will try to describe the characteristics of each pad.
*First off these pads are street pads, so they are legal to drive on the streets.*
I will go in order of luxury to straight performance, so to start off:
1.Hawk Ceramics – These pads will have better braking bite then OEM, and have low dust and noise output. This is perfect pad for daily driving in the city, and emergency braking situations. These pads are popular among show cars as they prevent wheels from getting layers of hard to remove brake dust. These pads can also be used during autocross events, but they might suffer from overheating (brake fade) over long term continuous braking and will wear fast under spirited driving.
2.Hawk HPS – These pads are also great for daily driving with their carbon/metallic compound. From customer reviews these pads tend to have a little less initial bite than Ceramics, but these pads also have much better braking over OEM. The reason why Carbon/metallic compound is used is because they wear slower, and last longer. These pads have low noise and low dust output, but not as low as the ceramics. These pads can also be used for autocross events, and they should hold up rather well. These pads might not hold up in racing conditions that exceed autocross speeds.
3.Hawk HP+ (plus) – The HP+ pad is the ultimate performance street pad. This pad is made to stop you and do it reliably. The HP+ has an aggressive carbon/metallic compound that gives you race level braking, but comes with consequences with higher dust and noise output. These pads will most likely squeal occasionally, but that’s just the characteristics of performance brake pads. Lastly these pads are meant for continuous hard braking, and will hold up at higher temperatures (brake fade prevention)
Racing Brake SS lines – With your pad change we highly recommend changing out the spongy rubber brake lines and getting some DOT Certified Stainless Steel Brake Lines. We have Racing Brake SS lines that will meet your needs in increasing pedal feel!
Here are the links to the pads and lines on Race-Roots. (As always FREE SHIPPING on all orders over $100)
Hawk Ceramnics (Front) - $85
Hawk Ceramnics (Rear) - $65
Hawk HPS (Front) - $75
Hawk HPS (Rear) - $60
Hawk HP+ (Front) - $105
Hawk HP+ (Rear) - $89
Mazdaspeed 3: Stainless Steel Lines (racing brake) - $95
Lastly we also stock ATE Super Blue and Typ200 Amber Brake Fluid for all of your regular brake fluid flushes. The idea behind using either of these is that one is blue and the other is amber so you can do alternating flushed to ensure a complete flush every time without having to drain the complete system!!
We now also have our Staged Upgrades and Combos available for easy purchase off our site!
Hawk HPS Stage 1 Brake Upgrade
Hawk Performance Ceramics Stage 1 Brake Upgrade
Hawk HP Plus Stage 1 Brake Upgrade
PM us if you have any questions
www.raceroots.com[/B]
Race Roots is offline   Reply With Quote
The Following User Says Thank You to Race Roots For This Useful Post:
802MS3 (12-20-2009)
 Old 12-18-2009, 09:37 PM   #2
MadOzodi's Avatar
Posts: 686   (View Stats)
Sweet, I may pick up a pair of fronts since my DBA 4000s are on backorder till next month!
07 COSMIC BLUE MS3 GT
MadOzodi is offline   Reply With Quote
 Old 12-20-2009, 06:55 PM   #3
mr_mazda329's Avatar
Posts: 798   (View Stats)
mr_mazda329 is the leader of the worldmr_mazda329 is the leader of the worldmr_mazda329 is the leader of the worldmr_mazda329 is the leader of the worldmr_mazda329 is the leader of the worldmr_mazda329 is the leader of the worldmr_mazda329 is the leader of the worldmr_mazda329 is the leader of the worldmr_mazda329 is the leader of the worldmr_mazda329 is the leader of the worldmr_mazda329 is the leader of the world
Groans: 55
Nice..whenever my factory shit finally wears out, I am going this route.
09 MS3 CWP BNR-S3 GFB Respons BPV, HTP 3.5in whalepenis , CXRacing/TR8L Core FMIC CorkSport CBE CNT Catless long DP, NGK Plugs, DM Trilogy, Cobb AP VEGA Tuned, CP-e HPFP CP-e Injector Seals
97 Miata Daily Driver
04' Mazdaspeed Miata Track Car
Road Racing > Autocross > Spirited Driving > Sitting in Traffic > Mowing Lawns > Drag Racing
mr_mazda329 is offline   Reply With Quote
 Old 12-20-2009, 08:02 PM   #4
rabble rabble
802MS3's Avatar
Posts: 5,318   (View Stats)
Groans: 221
this is pretty awesome. does anyone know the price of the OEM rotors?
'08 CWP MS3 w/ T3 3071r
 Old 01-14-2010, 04:20 PM   #5
Race Roots's Avatar
Bump for some sexy Stainless steel lines!
Instock and ready to ship!
 Old 01-22-2010, 05:46 PM   #6
speed23's Avatar
Posts: 1,480   (View Stats)
Does free shipping on the front and rear rotors apply to canada too? (i would buy pads too)
Thanks.
 Old 01-22-2010, 06:19 PM   #7
Funky's Avatar
Posts: 319   (View Stats)
Funky has a reputation beyond reputeFunky has a reputation beyond reputeFunky has a reputation beyond reputeFunky has a reputation beyond reputeFunky has a reputation beyond reputeFunky has a reputation beyond reputeFunky has a reputation beyond reputeFunky has a reputation beyond reputeFunky has a reputation beyond reputeFunky has a reputation beyond reputeFunky has a reputation beyond repute
Groaned at 7 Times in 5 Posts
Do you also make those rotors not slotted? I'd be interested in yours for weight savings and better ventilation.
Also, do you offer any warranty against warping?
Funky is offline   Reply With Quote
 Old 01-23-2010, 07:06 AM   #8
Race Roots's Avatar
Thanks.
It unfortunately does not. We will do a combo discount plus shipping.
Currently these rotors only come slotted, there were talks of making a non slotted version but there would need to be a demand to make this happen.
Here is Racing Brakes policy for warranty's: Warranty Information - RacingBrake.com
I have done tons of research about this company you can search their review section and they are a track/Autocross oriented company. They also make specifically made Club SCCA Rotors for club racing.
Hawk Pads, Racing Brake Lines, and ATE Brake Fluid! Race Roots Mazdaspeed3/6 General Discussion 11 09-25-2009 02:04 PM
Racing Brake BBK's, Rotors, Pads and lines! Race Roots Mazdaspeed3/6 General Discussion 4 07-27-2009 07:04 AM
Centric rotors/pads speed6frk MazdaSpeed 3/6 - Suspension & Brakes 11 02-19-2009 07:58 PM
Choose The Right Tractor Battery, Poor Brake Pressure, Rusting Brake Rotors, Pick Up Truck Stalling, How To Find Car Man Haltech Automotive News 0 06-10-2008 02:12 AM
Ordered Stoptech Rotors, Pads, SS Lines, Fluids.. Performance Racing MazdaSpeed 3/6 - Suspension & Brakes 10 04-02-2008 06:42 AM
Page generated in 0.33749 seconds with 25 queries
