(Thread Starter) | Not Ranked : 0 score A few weeks ago I was on a Gayata forum searching for parts and I saw power steering stuff for sale: This is what caught my attention: The seller e-mailed me another picture: and I had this thought that maybe, maybe we could use it on the block side for the oil return line. The part arrived Saturday and here is what the flange looks like superimposed on my earlier sketch: Now, onto some measurements and comparisons. The stock oil return line's orifice is 0.5856", the Miata's one is 0.5120", the third flange, same as Treadstone here sans the integrated o-ring, is 0.505". I am not concerned about the smaller than stock diameter as virtually all aftermarket flanges are 1/2" ID. The bolt holes on the Miata flange are a bit too close and will have to be elongated, should be easily doable. The flange is super thin compared to the stock line, I have no idea if this is a problem, most likely shorter bolts will have to be used. The line should clear the TC easily, but it is still possible that it would run too close to the block. A -10an line with a clamp fits very snugly and there should be no leaks. I do have a spare block and a spare stock EM, maybe one of these days I will grab another turbo and test my theory. Or perhaps someone who is in the middle of a build will jump on it. The Miata part # is 32-5M0 and goes for $21.95. As you can see in the diagram, there is an o-ring if needed -- it is an extra $17.70 as part of a seal kit -- but I am sure we can source just an o-ring at a cheaper price. Another possibility is to shave the flange so it is perfectly flat but I am not sure if there is enough material. To complete the line on the turbo end, we can use the above mentioned Treadstone flange, or, if an angle is required, a combination of this and this, as such: @phate; @Tomas; @torquemaniac;
| The Following 8 Users Say Thank You to Code Monkey For This Useful Post: | Easter Bunny (11-17-2014), Hargarbl (11-16-2014), ItsNox (11-17-2014), Mazdazilla6 (11-17-2014), mxlplx71 (11-17-2014), rob ms6gt (11-22-2014), torquemaniac (11-17-2014), WetzMS3 (01-28-2015) |
![]() Join Date: Jun 2012 Location: Montreal, QC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 927
| Not Ranked : 0 score Dustin make (or used to make) nice custom oil return line from the OEM line...see here : HOW TO: TOP MOUNT TURBO SET UP!! This is the easiest option in my opinionm, unless you are crazy like me and want full custom shit
__________________ 2011 CX-7 AWD 2.3 turbo Ported Holset HY35 // Custom top mount EM // Tial MV-S 38mm // Custom DP and catback // L2A intercooler with AMG CWA-100 pump// Perrin MBC // 3.25 Blow-thru MAF // Aquamist HFS-4 v.2 direct port injection // Eagle rods // Supertech 4032 pistons // Forge BPV v.2 // Perrin air/oil separator // Autotech HPFP // Custom RMM insert // TB coolant bypass // Full EGR delete // 3.5 bar MAP // Launch control with anti-lag // Derale remote transmission cooler // Upgraded transmission boost valve // Shimmed transmission accumulators // Adjusted transmission clutch control valve // Digital overboost protection system // Custom firewall heatshield // JKS rear spoiler // Painted VC and IM // BSD // Custom vent pod with boost and meth gauge // Tuned with Versatuner"When the turbo spins the bull$hit ends" BOOST the replacement for displacement |
| The Following User Says Thank You to torquemaniac For This Useful Post: | Code Monkey (11-17-2014) |
![]() Join Date: Aug 2012 Location: Mundelein, IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 322
| Not Ranked : 0 score And this guy from a subaru fits the turbo. Could be a match made in heaven.
__________________ The Car - 08.5 True Red MS3 GT - MODS -Cp-e nano sri, HTP 3" tip, Autotech internals, Custom fmic 28x8x3.5 cx core, Cobb ap, Autolite XP5263, Turbo_Steve SHIFT HAMMER SSP, TRZ rear mount. Atp Downpipe and custom catted mid pipe. JBR TIG, tb gasket & egr delete, XS POWER V2 turbo manifold, Aem 30-3000 WMI Kit, Ported intake By Turbo_Steve. ADAPTED PERFORMANCE SHIFT HAMMER SSP - ADAPTED PERFORMANCE ENGINE COVERS Soon to come. WHO KNOWS? A.D.D. FTW! |
| The Following 5 Users Say Thank You to Turbo_Steve For This Useful Post: | Code Monkey (11-17-2014), Easter Bunny (11-17-2014), ItsNox (11-17-2014), mxlplx71 (11-17-2014), torquemaniac (11-17-2014) |
| Not Ranked : 0 score Nice option, but the real deal killer is the section that bolt to the block (low profile 80 degree bend)!
| Not Ranked : 0 score That really is a killer idea! I'll definitely keep it in mind when I build my engine this coming year.
![]() Join Date: Dec 2010 Location: Delanco, NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 897
| Not Ranked : 0 score Nice find! You may have something there. I noticed the flanges on our egr tube match as well. I couldn't do anything with it tho. Right now I am using this on the turbo side mated to the factory block fitting. It's not perfect but it works.Also, the newer ATP housings have the boss for the EWG cast into the housing, it just is not machined out. This interferes now as well. What I don't understand is WHY WONT CP-E JUST SELL US THEIR FUCKING LINE? I am sorry, but I am not starting over with an entire $7K turbo kit just to get the fucking oil return line. I'm sure a lot of folks feel the same way. They must hate money over there.
__________________ [SIGPIC][/SIGPIC] ROB MS6GT 2006 Liquid Platinum Metallic Mazdaspeed 6 Stratified Tune, Stratified GA V2, Cobb AP V2, GTX3071R, HTP 4" Intake, Synchronic Diverter Valve, 3 bar MAP, Stratified Boost Dial, Corksport Injector Seals, Autotech Internals, Ebay DP, Custom TR8 FMIC, DevilsOwn Meth, Damond Catch Can, JBR 70 Duro Trilogy, TT front diff mount, Penis Eater top diff mount, Cut OEM Springs, Koni Yellows |
(Thread Starter) | Not Ranked : 0 score The EGR line will not work as it angles back into the block, this is documented in my fail thread. Kozmic could make a kill if they come up with a solution that fits many turbos.
| Not Ranked : 0 score Any updates?
| The Following User Says Thank You to rob ms6gt For This Useful Post: | Code Monkey (01-25-2015) |
| Not Ranked : 0 score Some kind of corrugated stainless steel line could be your ticket...here is some examples : Falcon Stainless, Inc. :: Price List for all Water Connectors This kind of line is really nice...its flexible yet strong, will keep the bends you give it and can withstand high temp
| The Following 2 Users Say Thank You to torquemaniac For This Useful Post: | Code Monkey (01-25-2015), ItsNox (01-25-2015) |
(Thread Starter) | Not Ranked : 0 score No updates so far. A couple months ago, I started bugging my shop about putting my spare engine on a stand so that I could snag Thanksgiving or Christmas deals on rods/pistons. They missed the Thanksgiving and then Bill, my mechanic, got burned and hospitalized after his race car caught on fire so I did not want to push the matter any further. I am taking my speed6 to the shop this week and will ask them about the engine again, I think Bill may be already back working.
__________________ 2006 Mazdaspeed6 EFR 7163|FMIC|South Bend|FCM coilovers|Powerbrake BBK|RPF1 18x10.5|Nitto NT01 stripped|caged|freektuned 2017 Subaru BRZ MCS TT1 coilovers|Brembo BBK|6UL 17x9|RE-71R|ACE 350|flex fuel|Delicious tuned | |
Just pay shipping!
__________________ 2011 CX-7 AWD 2.3 turbo Ported Holset HY35 // Custom top mount EM // Tial MV-S 38mm // Custom DP and catback // L2A intercooler with AMG CWA-100 pump// Perrin MBC // 3.25 Blow-thru MAF // Aquamist HFS-4 v.2 direct port injection // Eagle rods // Supertech 4032 pistons // Forge BPV v.2 // Perrin air/oil separator // Autotech HPFP // Custom RMM insert // TB coolant bypass // Full EGR delete // 3.5 bar MAP // Launch control with anti-lag // Derale remote transmission cooler // Upgraded transmission boost valve // Shimmed transmission accumulators // Adjusted transmission clutch control valve // Digital overboost protection system // Custom firewall heatshield // JKS rear spoiler // Painted VC and IM // BSD // Custom vent pod with boost and meth gauge // Tuned with Versatuner"When the turbo spins the bull$hit ends" BOOST the replacement for displacement | |
| The Following User Says Thank You to torquemaniac For This Useful Post: | Code Monkey (01-25-2015) |
![]() Join Date: May 2012 Location: Orlando, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 127
Groaned at 17 Times in 8 Posts
| Not Ranked : 0 score Lol you used all of my pictures! I don't think this is a great solution. Prone to leakage. You could weld a AN fitting onto the end of that and call it a day. ![]() I never had an issue with this set up. ![]() That's a picture my uncle took a long time ago. That's a gt28 IWG. The problem on the speed 6 becomes even more of a pain with an ewg housing on the turbo itself. Like in my picture above.
__________________ Fuck MSF |
| The Following 2 Users Say Thank You to avesfan101 For This Useful Post: | Code Monkey (01-27-2015), ttgeoff (06-02-2015) |
| Not Ranked : 0 score With the right clamps and hose, I dont think there will be leakage...the oil drain line is a low-pressure ''system''
| The Following 2 Users Say Thank You to torquemaniac For This Useful Post: | Code Monkey (01-28-2015), rob ms6gt (01-31-2015) |
Better bet is AN fittings. Even push lock fittings would be better.
__________________ Fuck MSF Last edited by avesfan101; 01-28-2015 at 08:21 AM. Reason: MSF Database - Automerged Doublepost | |
| The Following 2 Users Say Thank You to avesfan101 For This Useful Post: | Code Monkey (01-28-2015), TiGraySpeed6 (01-31-2015) |
| Not Ranked : 0 score Here is my oil drain fitting solution (block side) : a nice and shiny custom stainless elbow fitting ![]()
| The Following 4 Users Say Thank You to torquemaniac For This Useful Post: |
(Thread Starter) | Not Ranked : 0 score ^ Dude, assuming the angles work, you should seriously run some sort of a group buy. Edit: If you could make the flange a tad thinner, that would help with getting to that cursed lower bolt....
| The Following 2 Users Say Thank You to Code Monkey For This Useful Post: | rob ms6gt (01-31-2015), TiGraySpeed6 (01-31-2015) |
| bt oil drain line for MS6 | ryein7 | MazdaSpeed 3/6 - Turbo Induction | 17 | 03-14-2012 10:42 AM |
| How often do you drain your OCC? | Oswald | MazdaSpeed 3 - Engine, Transmission & Driveline | 2 | 12-31-2010 11:54 PM |
| K04 oil feed line & oil drain line | NJSPEED3 | MazdaSpeed 3/6 - Turbo Induction | 12 | 09-14-2009 10:46 AM |
