  • 1 Post By Carskick
 Old 12-12-2018, 01:35 AM   #1
Hunts_ms3's Avatar
Posts: 15   (View Stats)
Hunts_ms3 can only hope to improve
Groaned at 4 Times in 1 Post
Default Mazdaspeed3 (08) built bottom end
Car starts up then dies after the rpms just drop and only way you can catch them is putting the gas in all the way anything less and nothing happens, anyone have any solutions, everything on the motor has been replaced everything is basically brand new ,wiring, fuses, relays everything
Hunts_ms3 is offline   Reply With Quote
 Old 12-12-2018, 09:12 PM   #2
Varomnia's Avatar
Posts: 459   (View Stats)
What mods are you toting? And other than a built bottom end, was any mods added to the mix?
Assuming you upgraded to a different intake during this conversion, try unplugging the MAF sensor and see if it'll run without too much issue. If that's the case, and you haven't gotten the new intake tuned, get a tune. We got lots of good e-tuners here who can tune on either Accessport or Versatuner.
 Old 12-12-2018, 09:22 PM   #3
Hunts_ms3's Avatar
Running big turbo, st intake mani, 3.5” intake, fullrace manifold, 3” DP , 3.5 bar map sensor, 3Port BC , DW300c In tank pump, HPFP internals,fmic , corksport big Throttle body.Car will start up and can sometimes idle for little with pedal 3/4 in but if you lift of it dies
 Old 12-12-2018, 09:24 PM   #4
Varomnia's Avatar
Were any of those mods you just listed put on before or after you noticed this issue?
 Old 12-12-2018, 09:28 PM   #5
Hunts_ms3's Avatar
All on , Car been in out for while trying to solve a fuel pressure issue which took roughly 4 months. Now that the pressure is good the car just won’t stay alive
It’s been a battle to get this car running
Last edited by Hunts_ms3; 12-12-2018 at 09:28 PM. Reason: MSF Database - Automerged Doublepost
 Old 12-13-2018, 06:04 AM   #6
Posts: 2,235   (View Stats)
There is another thread beside yours with similar problems and good tips.
You may take a look
 Old 12-13-2018, 11:03 AM   #7
Carskick's Avatar
Posts: 315   (View Stats)
Carskick has a reputation beyond reputeCarskick has a reputation beyond reputeCarskick has a reputation beyond reputeCarskick has a reputation beyond reputeCarskick has a reputation beyond reputeCarskick has a reputation beyond reputeCarskick has a reputation beyond reputeCarskick has a reputation beyond reputeCarskick has a reputation beyond reputeCarskick has a reputation beyond reputeCarskick has a reputation beyond repute
Is the MAF calibration correct for your mods?
As Varomnia mentioned, the tune needs to know how big the intake is.
2009 Mazdaspeed 3 Sport (Original Owner) - 95k miles on original Motor & Turbo and counting
Current Performance Mods: APv3 Freektune 93 & E-30 | JBR 3.0 SRI | ETS TMIC w/JBR Red Tubes | SpeedDaddy TP | AT HPFP | Damond Triple Mounted | Southbend S2 Endurance Clutch/Fly | Stoptech Slotted Rotors | EBC RedStuff Pads | Enkei PF01 18x8.5 +48 | Continental EC Sport 245/40R18 | KWv2 Coilovers | Whiteline LCA Bushings, Anti-Lift, & Bump Steer | Whiteline Endlinks | JBR .125 FSB & RSB w/billet bushings/mounts | CS Lower Tie Bar | DM OCC w/VTA | JBR Shifter Bushings
Stereo Mods: Pioneer AVH4100NEX | Phoenix Gold 6.5" Comps Front | Focal 6.5 Coax Rears | Polk 12" in Trunk Floor Enclosure | PPI 4x125W amp driving Fronts & Sub
Other Mods: FIAMM 72112 Low Note Horn alongside stock
Mods Awaitting Install: Redline Leather Center Armrest & Handbrake Boot
Future Mods: Injector Seals | Built Block & BNR S3v2 if ZZB
Removed Mods: JBR 70A RMM | Koni STR.T Orange Shocks
Carskick is offline   Reply With Quote
 Old 12-13-2018, 11:14 AM   #8
Hunts_ms3's Avatar
Engine hasn’t even been broken in yet, every time the cars starts, it’s starts up like cold start for about 6 seconds then dies.
 Old 12-13-2018, 11:54 AM   #9
Carskick's Avatar
If that MAF tune is not correct for your intake, it likely won't run at all or will just die after starting. Has your computer been tuned for your mods? Whether or not the engine is broken in doesn't matter. in fact, if you're not tuned, you can't break in your engine, cause it won't run.
Jeff23spl likes this.
 Old 12-13-2018, 12:55 PM   #10
Hunts_ms3's Avatar
Ok what do you suggest I do
 Old 12-13-2018, 02:36 PM   #11
Good point, you can't run a stock tune with different sensors range.
Usually when you get extanded range sensors is because you understand the need and how it works. The 0-5v signal remain 0-5 but 5v means a lot more than before and the ecu need to know it.
The MAF would peg on positive LTFT/STFT but cannot compensate for a huge change like that. when it read 100g/s it pass about 175g/s....It probably get even worst at iddle speed...
Similar for the map
You either need a special maps for your mods that will need to be made again after break-in (Etuner usually help for this)
Or you can switch back to oem map and maf hosing for the break in period but make sure to stay low boost to avoid pegging the sensors.
 Old 12-13-2018, 09:32 PM   #12
Carskick's Avatar
You need to get a tune for your size intake, preferably for your particular one, or return to a stock size. Diameter is the primary variable, but there are others.
 Old 12-13-2018, 09:37 PM   #13
Hunts_ms3's Avatar
MAF is all good not the problem, thinking of pulling the motor and again
 Old 12-13-2018, 09:42 PM   #14
Hunts_ms3's Avatar
By passed the whole maf and still having same problems
 Old 12-13-2018, 10:47 PM   #15
SSinstaller's Avatar
Posts: 3,989   (View Stats)
Groans: 60
Your new MAF housing means that for a given voltage you're actually flowing almost 62% more air. Without a proper tune the ecm will not be injecting enough fuel for it to stay running.
Getting the idle calibration close enough to run isnt very hard at all. Multiply the original maf calibration by 1.619, and you'll be close enough for it to idle. Then you just do a normal maf calibation to fine tune it.
 Old 12-17-2018, 07:06 AM   #16
This + map scalar, but as long as he possess ATR or Versatune...
What do you mean by bypassing the maf ???
You MAF and MAP need to be addressed together. Even if you find a way to keep the car idling, it won't be safe to drive it this way.
Last edited by Jeff23spl; 12-17-2018 at 07:07 AM. Reason: MSF Database - Automerged Doublepost
 Old 12-24-2018, 09:52 PM   #17
Hunts_ms3's Avatar
Pulled motor back out , reassembling it. The that built motor was stupid so hopefully when valve cover comes off we can see the issue right away.
Build my engine or built longblock? Built trans? Mustangkr500 Mazdaspeed3/6 General Discussion 24 07-22-2016 12:17 PM
Best Places to have bottom end built? onetechyguy MazdaSpeed 3 - Engine, Transmission & Driveline 1 05-05-2012 08:24 AM
Page generated in 0.36627 seconds with 24 queries
