 Old 07-24-2012, 10:12 AM   #1
Lurkers
eksces's Avatar
Posts: 35   (View Stats)
eksces has a spectacular aura abouteksces has a spectacular aura about
Groaned at 16 Times in 8 Posts
Default Mod path for me
Hi guys!
I bought a SRI+TIP from Corcksport, Cp-e RMM, Cobb AP, Denso itv20 and TurboXs race pipe.
What should I do with this setup? RMM and plugs are already on the car. What about the rest?
Is it ok to put it all on with OTS map for Stage 1 sri+tip tune?
Or maybe I should leave the race pipe for later when I buy hpfp and then put stage 2 map already? (which will take few months).
I have no idea if the RP will help or hurt or maybe make no difference on OTS Stage 1 AP tune.
The spark plugs should be ok with these mods? I don't want go one step colder if I don't have to. I would like to stay "Stage 1" for a while and work on reliability of the car. In this scenario I should probably delete the EGR asap and clean the valves. what next? Any suggestions?
eksces is offline   Reply With Quote
 Old 07-24-2012, 12:54 PM   #2
Design's Avatar
Posts: 1,887   (View Stats)
Groaned at 9 Times in 5 Posts
Since you're relatively new I find it only fair to give you a freebie. Grab a beverage and enjoy:
http://www.mazdaspeedforum.org/forum/foru...st-read-99499/
Regardless of your experience level, all related information can be extracted from that thread. If there's something you don't understand, post your specific question in one of the linked tech threads. GL.
09 CWP MS3 GT
Ownership & Build Thread
The Following 2 Users Say Thank You to Design For This Useful Post:
motherfnmonsta (07-25-2012), Raider (07-24-2012)
 Old 07-24-2012, 02:15 PM   #3
Lurkers
eksces's Avatar
Thanks. Went thru almost all what is in that thread, but still have no idea what to do with my race pipe.
 Old 07-24-2012, 02:28 PM   #4
chuckms6's Avatar
Posts: 1,618   (View Stats)
chuckms6 is the leader of the worldchuckms6 is the leader of the worldchuckms6 is the leader of the worldchuckms6 is the leader of the worldchuckms6 is the leader of the worldchuckms6 is the leader of the worldchuckms6 is the leader of the worldchuckms6 is the leader of the worldchuckms6 is the leader of the worldchuckms6 is the leader of the worldchuckms6 is the leader of the world
Put it on, get an e-tune.
Tapatalking
DIY SRI, DIY WAIC, VCTS Mod, Gutted Stock DP, Cobb AP, SURE TIG, KMD Internals, Denso ITV22's
SURE Dreadnaught, DSS Left Rear Axle, Custom in car SSP, JBR SSP, Powered by Max Shift Knob
Megan Racing Coilovers
13.7@ 96 w/1.8 60ft (SRI, AP)
13.4@ 102 w/1.9 60ft (SRI,AP,WAIC,TIG, Internals, ITV22's)
chuckms6 is offline   Reply With Quote
 Old 07-24-2012, 02:37 PM   #5
Lurkers
eksces's Avatar
So with the rp and e-tune (i saw few tuners at the forum) I can get better results even without hpfp?
Or this is just something to check if my pump holds the pressure or not?
Anyway, e-tune is few hundred bucks, right? so i would like to avoid costs for a while
 Old 07-24-2012, 02:39 PM   #6
mczimer's Avatar
Posts: 1,249   (View Stats)
mczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the world
You should be running ITV22 plugs (1 step colder) on any tune with the AP, so that is your next step. The race pipe can stress your stock pump to the limits, so you *can* run it on a stage 1, just monitor the pressure during WOT.
I also think you should read this completely:
http://www.accessecu.com/accessport/...in%20v1.00.pdf
mczimer is offline   Reply With Quote
The Following User Says Thank You to mczimer For This Useful Post:
Design (07-24-2012)
 Old 07-24-2012, 02:41 PM   #7
08cosmic3's Avatar
Posts: 2,920   (View Stats)
You need the colder plugs with the AP per Cobbs recomendations. You can get by running the TP with stock fuel pump with a tune but you should have spent money on the FP internals first.
Design (07-24-2012)
 Old 07-24-2012, 03:25 PM   #8
I will quote this again today as a recommended power mod path:
Blog : The modification path in a MazdaSpeed/MPS vehicle : Stratified Automotive Controls
chuckms6 (07-24-2012), Dumyz (07-29-2012)
 Old 07-24-2012, 03:28 PM   #9
MS3-a(sore)ASS-rex's Avatar
Posts: 7,012   (View Stats)
Groans: 224
Go NO further until you upgrade your HPFP.
NATOR PA
The Following 2 Users Say Thank You to MS3-a(sore)ASS-rex For This Useful Post:
DiGi Faggot (07-30-2012), Raider (07-24-2012)
 Old 07-24-2012, 04:31 PM   #10
Lurkers
eksces's Avatar
Thanks all!
I should get one step colder plugs even if my power gains would be around 40-50whp ??
Why would AP need to change the plugs? Are the stock ones already too hot for a stock setup? Anyone tried to run AP stage one on itv20 plugs?
The pressure on the rail should be above 1600psi at WOT, right? I'll probably put intake first and a tune and see how it goes. Last thing I want is a boom!
 Old 07-24-2012, 04:40 PM   #11
ricknm's Avatar
Posts: 1,102   (View Stats)
ricknm is the leader of the worldricknm is the leader of the worldricknm is the leader of the worldricknm is the leader of the worldricknm is the leader of the worldricknm is the leader of the worldricknm is the leader of the worldricknm is the leader of the worldricknm is the leader of the worldricknm is the leader of the worldricknm is the leader of the world
fuel pressure at WOT needs to be over 1600psi.
Get colder plugs
DEF. get FP internals.
I personally would wait installing the race pipe until you get internals. After all, the last thing you want is zoom zoom boom. You said it yourself. Why even risk it.
last but not least, E-tunes are 100% more effective then an OTS map.
BNR s3 w/ some other stuff. Hypnotic tuned.
ricknm is offline   Reply With Quote
 Old 07-24-2012, 05:25 PM   #12
sidekick's Avatar
Posts: 3,093   (View Stats)
Groans: 47
This should be stickied somewhere.
 Old 07-27-2012, 05:30 PM   #13
Forsworn71's Avatar
Posts: 107   (View Stats)
Forsworn71 has a brilliant futureForsworn71 has a brilliant futureForsworn71 has a brilliant futureForsworn71 has a brilliant futureForsworn71 has a brilliant futureForsworn71 has a brilliant futureForsworn71 has a brilliant futureForsworn71 has a brilliant futureForsworn71 has a brilliant futureForsworn71 has a brilliant futureForsworn71 has a brilliant future
This is fucking amazing. Just saying. I was searching all around for a suggested order and this was absolutely everything I was looking for.
+1 STICKY please
Forsworn71 is offline   Reply With Quote
The Following User Says Thank You to Forsworn71 For This Useful Post:
Lex (07-29-2012)
 Old 07-28-2012, 03:34 PM   #14
Lurkers
eksces's Avatar
So, after reading your advices and few online articles I think I'll go as follows:
I'll put the intake + cobb's stage 1 maps first and play with it till hpfp upgrade.
After upgrade I'll put itv22 with the test pipe and try the stage 2 maps with custom tune.
Thanks guys!
The Following 2 Users Say Thank You to eksces For This Useful Post:
DiGi Faggot (07-30-2012), Lex (07-29-2012)
 Old 07-29-2012, 10:09 PM   #15
Dumyz's Avatar
Posts: 402   (View Stats)
Dumyz is the leader of the worldDumyz is the leader of the worldDumyz is the leader of the worldDumyz is the leader of the worldDumyz is the leader of the worldDumyz is the leader of the worldDumyz is the leader of the worldDumyz is the leader of the worldDumyz is the leader of the worldDumyz is the leader of the worldDumyz is the leader of the world
Groans: 27
Groaned at 6 Times in 2 Posts
Thanks guys!
Throw on the TIP while you're at it. Just sayin...
2010 Mazdaspeed 3 - Sold
New: 2008 Toyota Tundra
Dumyz is offline   Reply With Quote
 Old 07-29-2012, 11:57 PM   #16
theurgy's Avatar
Posts: 2,580   (View Stats)
Then spend the $200 and get a custom tune (with Lex perhaps).
That's probably your safest bet.
Lex (07-30-2012)
 Old 07-30-2012, 04:43 AM   #17
Lurkers
eksces's Avatar
by intake I mean both sri + tip from CS i've mentioned in the first post.
 Old 07-30-2012, 02:58 PM   #18
LilGator's Avatar
Posts: 136   (View Stats)
LilGator has a reputation beyond reputeLilGator has a reputation beyond reputeLilGator has a reputation beyond reputeLilGator has a reputation beyond reputeLilGator has a reputation beyond reputeLilGator has a reputation beyond reputeLilGator has a reputation beyond reputeLilGator has a reputation beyond reputeLilGator has a reputation beyond reputeLilGator has a reputation beyond reputeLilGator has a reputation beyond repute
Groaned at 6 Times in 3 Posts
What's the reasoning for custom tuning with a test pipe instead of downpipe, considering the HPFP is upgraded at this point?
This upgrade path makes it sound like downpipe/IC upgrades are only worth it after BT?
LilGator is offline   Reply With Quote
 Old 07-30-2012, 04:10 PM   #19
Cost alone. That path is bang for the buck sensitive.
 Old 07-31-2012, 03:26 PM   #20
Lurkers
eksces's Avatar
With the test pipe alone you can still pass the emissions test (what I've heard).
Stage 2 -Mod Path Dilemma J_Logik Gen2 MS3 General Discussion 40 02-14-2012 05:31 PM
What's next in my upgrade path? ABSpeed3 Mazdaspeed3/6 General Discussion 17 11-29-2011 09:38 AM
My Mod Path - Some questions Nachtsturm MazdaSpeed 3/6 - ECU Computer Tuning 51 07-22-2010 03:47 PM
whats the right path? LiEast MazdaSpeed 3 - Engine, Transmission & Driveline 9 08-12-2009 11:30 PM
As UAW fades, so does a path to U.S. prosperity Haltech Automotive News 0 05-31-2009 01:10 PM
Page generated in 0.40926 seconds with 32 queries
