 Old 01-16-2017, 05:44 PM   #1
mazduhz's Avatar
Posts: 9   (View Stats)
mazduhz will become famous soon enoughmazduhz will become famous soon enough
Default My clutch is fused to the FLYWHEEL!
So, upon starting my car for the first time after the rebuild, the brand new Fidanza flywheel + brand new Luk OEM clutch disk have somehow managed to fuse together. It engaged and disengaged at first, then I backed it out of the garage, when I went to put it into 1st, the clutch no longer disengaged.
(even installed a brand new clutch master cylinder)
SUGGESTIONS PLEASE =D
mazduhz is offline   Reply With Quote
Which Clutch / Flywheel? BuddySpeed3 MazdaSpeed 3 - Engine, Transmission & Driveline 27 05-29-2016 03:33 PM
Oem clutch/Fidanza Flywheel, Causing sticky clutch pedal? Douggievee MazdaSpeed 6 - Engine, Transmission & Driveline 14 05-14-2015 10:44 AM
New OEM Clutch with Fidanza Flywheel Soft Clutch Feel zer010gic MazdaSpeed 3 - Engine, Transmission & Driveline 3 03-15-2014 11:12 PM
clutch/flywheel bad??? stonecold0469 MazdaSpeed 6 - Engine, Transmission & Driveline 0 03-17-2013 10:01 PM
Page generated in 0.38780 seconds with 29 queries
