![]() Join Date: Aug 2014 Location: Monroe, Mi
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 16
![]() Join Date: Mar 2011 Location: Dallas, Texas
| Not Ranked : 0 score If it is leaking, you should be able to take the plastic tray off the bottom and see that amount. Folks have had problems finding leaks in the past, because the tray catches it fairly well, but empties at speed. If the motor was burning it, seems you would see some white smoke. I'm going with something not connected good enough when replacing the new block. Good luck finding it. Hope you fix it before damage occurs
__________________ Max Bolted and Built Stock K04 |
(Thread Starter) | Not Ranked : 0 score Thanks, it's easier knowing that there is an issue now so that I can keep track of it, ya know? On the other hand it's drinking coolant almost as fast as the gas that goes through it, 3/4 gallon of coolant for 80 miles worth of driving. Dried the reservoir and had a bunch out of the radiator. Getting to the meat of the issue though, I'm assuming you're talking about the tray under the radiator, which is the skid plate? The car, unfortunately, doesn't have one lol and no drips around the bottom of the radiator. Top of the engine is dry as well. For the sake of not ruling anything out I did a a compression test and it came out well (165, 170, 171 and 172), also I put 30 psi into the cylinders to see if there's leaking past the head gasket and it seems to be okay, as far as I can tell. Didn't think it was relevant but there is white smoke at start up but it seems to clear up after it warms up, it's slightly more than normal, but nothing you'd see and get alarmed about. Also, for anyone who sees ECT temps at that level, chances are you'll be fine, it was just a different pair of shoes |
![]() Join Date: Dec 2009
Rep Power: 0 ![]() ![]() ![]() Thanks: 20
Groaned at 74 Times in 53 Posts
| Not Ranked : 0 score Well, I am facing a similar problem. Have you find the cause of the coolant leak in your car?
__________________ ------------------------------------------------------- |
| Not Ranked : 0 score pressurize your radiator, there is some pump that can connect at the place of the filling radiator cap and you should quickly see where it leaks.... Or make a temporary cardboard engine tray to see if some fluid can be going to the ground while driving and you don't see it. It could be a cracked hose, a clamp not tightened properly....a rotten transfert hose etc...I had issues with the one between TB and just at the end of the TIH. I had a factory battery but a flexible 3'' TIH that force that small hose to cut against the elbow. it was leaking just a little and wasn't seen anywhere unless i remove some parts....
| The case of the mysterious door lock | Pseudonym | MazdaSpeed 3/6 - Car Audio & Electronics | 6 | 01-18-2014 06:59 AM |
| Disappearing oil | Tokay444 | MSP - Engine, Transmission & Driveline | 16 | 05-26-2013 05:39 PM |
| A case of the mysterious noise... | spied | 2010 MS3 - Engine, Transmission & Driveline | 13 | 05-15-2013 08:07 PM |
