![]() | | #361 | ![]() |
![]() Join Date: Sep 2015 Location: Brick, NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,356
Groans: 50
| Not Ranked : 0 score
__________________ 2011 Mazdaspeed3 w/ tech package Totaled/ R.I.P. |
![]() | | #362 | ![]() |
![]() Join Date: Dec 2013 Location: Scranton, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5
| Not Ranked : 0 score you can also read the logs in excel as a spreadsheet.
__________________ 2006 Mazdaspeed 6 rebuilt with v6 rear end CPE TMIC || Cobb SRI + TIP || Grimmspeed 3 port EBCS || Forge BPV V1 || UR Test Pipe || CPE Single Exit Exhaust || JBR heavy shift knob and shifter bushings || JBR RMM || SU short throw || Corksport Stubby antenna || Glowshift boost and voltage gauges || CS Mudflaps |
![]() | | #363 | ![]() |
![]() Join Date: Oct 2015 Location: Hibbing, MN
Rep Power: 66 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 264
| Not Ranked : 0 score Ive been searching for information regarding the Mazda donut exhaust gasket. Haltech recommended it in his how-to thread and there was another thread where cpe was quoted to have said no gasket is required for the meet up between dp and cbe. Once again, Im asking here as to not make a new thread lol (as it is related to downpipes). any recommendations? |
![]() | | #364 | ![]() |
Groans: 50
__________________ 2011 Mazdaspeed3 w/ tech package Totaled/ R.I.P. | |
![]() | | #365 | ![]() |
![]() Join Date: Jan 2015 Location: Lincoln, NE
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 93
I have the Cp-e catless downpipe and I didn't use a donut gasket. Car runs fine and haven't heard any exhaust leaks yet.
__________________ 07 Black Mica MS3: Built motor- SP63 Pro Series 88mm 9.5CR pistons, Manley H-beam rods, Clevite Main/Rod bearings, ARP main studs, L19 head studs, ACT 6-puck sprung clutch w/ Prolite Flywheel, AP V3, Stratified E85 tune/EBCS, NGK plugs, Autotech internals, Corksport injector seals/short shift plate/shifter bushings/LED kit, Cp-e FMIC/catless down pipe, Damond RMM/TMM, Mazdaspeed CBE, JBR SRI/TIP/recirc hose/BSD/oil pan baffle/EGR delete/51r battery box, Forge V2 BPV, Koni yellows, and Cobb springs, Gold Enkei RPF1 w/ 245/45/17 sport comp 2's | |
![]() | | #366 | ![]() |
![]() Join Date: Dec 2014 Location: LODI, OHIO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() Thanks: 24
| Not Ranked : 0 score yeah I got an EBAY M2 catless downpipe and this flange end literally bolts into the stock CBE picture attached is also a CP-E downpipe
__________________ 2012 MS3 BM TECH - COBB SRI - COBB TIP - CORKSPORT TMIC - TURBOSMART KOMPACT BPV - M2 LONG CATLESS DP - AUTOTECH INTERNALS - ACCESSPORT V3 - COBB RMM PURPLE DRANK TUNED |
| The Following User Says Thank You to Rommel043 For This Useful Post: | Gitcherex (12-02-2015) |
![]() | | #367 | ![]() |
| Not Ranked : 0 score |
![]() | | #368 | ![]() |
Groans: 50
| Not Ranked : 0 score Oh. When I installed mine I had to use an adapter and the new donut gasket I bought didn't fit the catback side of the adapter some how. So I just put a good 40 ft lbs on the bolts and they don't leak one bit. So you can get away with not using it.
| The Following User Says Thank You to robbspeed For This Useful Post: | Gitcherex (12-02-2015) |
![]() | | #369 | ![]() |
| Not Ranked : 0 score sweet thanks guys! Now i dont gotta worry about having a leak lol. Upgrade next week! |
![]() | | #370 | ![]() |
![]() Join Date: Mar 2008 Location: W. Suffield, CT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 674
| Not Ranked : 0 score Ebay DP that was on car needed new flex pipe and wanted to install cat.
__________________ MS6 - BNRs3 - Cobb AP - JBR Tru-3.0 - Spearco FMIC - MAC EBCS - Synapse BOV - DNP - CPE DP->MF - SU RRM - TTFMM - TT + CPE Diff Mounts - Mrlilguy HPFP - Projector HID fogs - TSX projector retrofit - LI jammers - Advan RZs w/ 245 PSSs - Koni - WL RSB |
![]() | | #371 | ![]() |
![]() Join Date: Apr 2015 Location: Fort myers, Florida
Rep Power: 0 ![]() ![]() ![]() Thanks: 6
Groaned at 12 Times in 3 Posts
| Not Ranked : 0 score Not too sure what to get. What will give me th most gains, a OBX turbo back exhaust or just a CNT long Catless downpipe with OEM cat back? |
![]() | | #372 | ![]() |
Rep Power: 6573 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10,956
Groans: 122
Just as an FYI, several people have had fitment issues with the speed daddy catless DP; myself included. Its made a bit short. The DP still fit, but it pulled my entire exhaust forward to mate up with the DP. Had to use C clamps to install it the first time. Oh, and an extended rear o2 causes a CEL on the Pus. So if you can, one without an extended bung would be preferred. If you have the funds, have someone either cut it or weld in a normal one altogether, before you have it installed. Or do what I do, install it and shut the check engine lights off. lol
__________________ CP-e S2 RMM // TurbineTech FMM // Ghetto SRI // 3" ATP MAF housing // Ultimate Racing CBE // Ebay Downpipe // Cobb AP // Autotechs // PG TIP // HKS V4 BOV // NGK Iridiums // ACT Street Disc // JBR Trans Mount Rich Tuned 330WHP and 363TQ 10-19-13 Moore Automotive ![]() | |
![]() | | #373 | ![]() |
![]() Join Date: May 2015
Rep Power: 0 ![]() Thanks: 1
| Not Ranked : 0 score I've done some searching and haven't really found an answer, but I have a 09 ms3 and the catback and the tail say mazdaspeed. I assume this is an upgrade over stock but I can't find anything about it. Will I be better off getting another catback or is the mazdaspeed version as good as the others. |
![]() | | #374 | ![]() |
Groans: 122
| A catback is purely sound, so go with whatever tingles your sack.
| The Following User Says Thank You to CWP_MS3 For This Useful Post: | PapaBone (02-12-2016) |
![]() | | #375 | ![]() |
| Not Ranked : 0 score I just bought a CNT catless Downpipe and wanted to use a O2 sensor extender but can't seem to find where to buy one. I'm not sure if the Downpipe already comes with one but does anyone know where I can get an O2 sensor extender? in case mine doesn't come with one |
![]() | | #376 | ![]() |
Groans: 122
| You don't want one. Read my post a few posts up about the extenders.
![]() | | #377 | ![]() |
| Not Ranked : 0 score Ok I see. But arnt O2 sensor extenders made to prevent CEL. How would it cause it to have a CEL? |
![]() | | #378 | ![]() |
Groans: 122
I have read of people not even getting a CEL on a catless DP that had a standard bung. With that said, I personally have CELs from the extended bung on my DP. It thinks my o2 sensor is shot, and its probably right these days, after running e85 for like 3 straight years.
| The Following User Says Thank You to CWP_MS3 For This Useful Post: | Richys10 (02-13-2016) |
![]() | | #379 | ![]() |
| Not Ranked : 0 score Ohh ok I see . Makes sense. Thanks man! |
![]() | | #380 | ![]() |
![]() Join Date: Mar 2016 Location: Minnesota
Rep Power: 0 ![]() Thanks: 10
| Not Ranked : 0 score How do you guys feel about ebay downpipes?? Crap? Or descent? |
![]() | | #381 | ![]() |
| Neutral : +1 score Ive had mine for about 3 months and no problems. I have heard people having cracks at the welds. Speed daddy seems to be the way to go for the ebay DPs. |
| The Following User Says Thank You to T_DUBL_U For This Useful Post: | Khang88 (05-10-2016) |
![]() | | #382 | ![]() |
Groans: 122
| Ebay is fine. Some on the pus have been short, and it still fits, but as far as I know the 6 its always been fine.
| The Following User Says Thank You to CWP_MS3 For This Useful Post: | Khang88 (05-11-2016) |
![]() | | #383 | ![]() |
| Not Ranked : 0 score Ive had my m2 catless downpipe (ebay) for almost 6-7 months now. Only issues I've had is their crappy ass gaskets. Mine burnt to a crisp lol |
| The Following User Says Thank You to Gitcherex For This Useful Post: | Khang88 (05-11-2016) |
![]() | | #384 | ![]() |
Groans: 122
| I reused my stock gasket. Fuck their shit.
![]() | | #385 | ![]() |
| Not Ranked : 0 score I went back in 2 weeks ago and put the oem dp gasket back on. Tried using some 800* gasket maker to fix the gasket on the vband-3inch pipe (dont recall what its actually called), seems to have worked but idk lol |
![]() | | #386 | ![]() |
| Not Ranked : 0 score So as far as quality with the downpipe itself and power gains, it good? |
![]() | | #387 | ![]() |
Groans: 122
When it comes to BT, you will need the DP. Personally, an ebay DP and TP are relative in price. Might as well get the m2 DP and do it right to begin with.
![]() | | #388 | ![]() |
Ive had mine for about 30k no issues. get rid of the junk gasket they give you and reuse the stock one. The DP came up a little short on my genpu but thats nothing longer bolts cant fix. if you have a genpu, please cut the secondary bung down to half size and/or drill a new hole with a shorter bung. the secondary NEEDS to be close to exhaust stream otherwise youll run rich as fuck AFR's and throw two codes. I think its the best bang for your buck. Hell, I think it sounds pretty damn good with jsut this DP and the stock catback.
__________________ 2012 MS3 BM TECH - COBB SRI - COBB TIP - CORKSPORT TMIC - TURBOSMART KOMPACT BPV - M2 LONG CATLESS DP - AUTOTECH INTERNALS - ACCESSPORT V3 - COBB RMM PURPLE DRANK TUNED | |
| The Following User Says Thank You to Rommel043 For This Useful Post: | Khang88 (05-11-2016) |
![]() | | #389 | ![]() |
| Not Ranked : 0 score Thanks guys. Im really considering an ebay dp. Everything else is just too pricey. |
![]() | | #390 | ![]() |
Groans: 122
| I don't think the MS6 DP has the extended rear o2 bung on it. If it does, have a shop weld a standard in before you install it.
![]() | | #391 | ![]() |
![]() | | #392 | ![]() |
![]() Join Date: Jan 2014 Location: Kissimmee FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 191
| The Following User Says Thank You to Nel Mazdaspeed For This Useful Post: | Khang88 (05-13-2016) |
![]() | | #393 | ![]() |
| Not Ranked : 0 score Cool. How's the power gains on the m2? |
![]() | | #394 | ![]() |
| Not Ranked : 0 score i honestly dont have a diff DP to make comparisons, but according to my tuner they are similar if not the same in gains. the only diff is the quality and workmanship and price.. imo Sent from my SAMSUNG-SM-N910A using Tapatalk |
![]() | | #395 | ![]() |
![]() Join Date: May 2016
Rep Power: 0 ![]() Thanks: 0
| Not Ranked : 0 score If anyone can give me opinions on which exhaust is best for the MS3 I'd greatly appreciate it. I just bought my 2012 speed 3 about a month ago. |
| The Following User Says NO Thank You to Lambo0311 For This Un-useful Post: | robbspeed (05-31-2016) |
![]() | | #396 | ![]() |
Groans: 50
![]() | | #397 | ![]() |
![]() Join Date: Apr 2014 Location: Lansdowne, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 11
| Not Ranked : 0 score So I don't post often on here. Hell I haven't even been searching forums much lately. But I just got my CNT 3" catless downpipe in and installed. It was on back order and I waited for months to get it in. I figured for the price and what I have heard and read I couldn't go wrong. In the end I think I'm in love with the feel and sounds. However I cannot recommend this downpipe because of a major issue I had with their product. If you look at the pictures of the downpipe you will see it looks like a decent piece, until you look at the last few pictures when i went to go and install it. The holes on the bellmouth to mount on the turbo no only are a bitch to get to the studs, but they did not line up correctly and had to be filed out larger in order to make the bolts line up correctly. If I was not in the right place doing this it would have been a long day of hell just to go back to stock. Luckily we were able to file the holes larger and put this thing up and down on the lift repeatedly until the holes lined up correctly again. Now it is time to play with tune and i will try to keep you guys updated on that somewhere else on the forums. Then next on list is to cut out the 2.5 inch flange on the Magnaflow 15557 exhaust and put on a flat 3 inch flange to match this downpipe (just threw on a flat gasket for now knowing its getting done soon.
__________________ 2012 Gen2 Velocity Red Mica Cobb: AP, RMM, SF Intake and Inlet Hose; AT Internals; CNT Catless 3" downpipe; Magnaflow CBE 1557 ![]() ![]() ![]() |
| The Following User Says Thank You to IT GUY For This Useful Post: | robbspeed (07-02-2016) |
![]() | | #398 | ![]() |
![]() Join Date: May 2013 Location: Ponce, Puerto Rico
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 40
| Not Ranked : 0 score I know this thread is old but im getting ready to purchase a catted downpipe but im still debating on whether to get divorce or bellmouth due to many different opinions. Justin recommended me corksport or cobb. One is divorce and one is bellmouth. I was reading on other subaru forums that divorce was the way to go, having separate tubes avoiding turbulence, boost spikes and the same time exhaust flow is smoother, giving the car the chance to produce hp and tq efficiently. Others think that bellmouth is the way to go when you have high boost applications and that this model is best suited for the mazdaspeed 3. Normally drag race cars have separate tubes, the wastegate comes out the side of the car or the bottom while the turbo tube out the hood in some cases(divorce way) With what model do you guys recommend I should go? Ive been inclined towards the divorce but you guys tell me what is your thought
__________________ Forge BPV V2//COBB AP V3// COBB DP //ETS TMIC//AUTOTECH HPFP//JBR SRI//JBR TIP//JBR COOLANT BYPASS KIT//JBR DISI HOSES//JBR BYPASS HOSE//JBR THROTTLE BODY THERMAL GASKETS//JBR SHIFTER BUSHINGS// //RACING BEAT CBE//DAMOND MOTORSPORTS OCC//COBB RMM//CS LED KIT//CS LED FOGS//CBI OSRAM HID BULBS//CONTI EXTREME CONTACT 235/40 R18//RACESENG SHIFT KNOB//FREEKTUNED ON 93 PUMP GAS |
![]() | | #399 | ![]() |
| Not Ranked : 0 score I don't have any professional or mathematical advice on this matter. All I can say is mine has treated me great since it's been in. Surprising amount of power being pushed out of my stock ko4. Sent from my SAMSUNG-SM-G930A using Tapatalk
![]() | | #400 | ![]() |
![]() Join Date: Mar 2014 Location: Sedalia,MO
Drag racing cars have external wastegates thats why they have a downpipe and and dump pipe for the wastegate. Outr k04 is internally wastegated, so just get a bellmouth and be done with it. Thats what the majority of the people here including me have and no issues. Sent from my iPhone using Tapatalk | |
| The Following User Says Thank You to Dennisms3 For This Useful Post: | robbspeed (12-18-2016) |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f505/official-downpipe-test-pipe-race-pipe-thread-99627/ | ||||
| catless downpipes cause turbo to blow seals?? - Page 4 | This thread | Pingback | 11-10-2014 11:55 AM | |
| Tuner/garage in Brampton/Mississauga area | This thread | Refback | 08-02-2014 08:51 AM | |
| Downpipe options - 2004 to 2014 Mazda 3 Forum and Mazdaspeed 3 Forums | This thread | Pingback | 07-22-2014 10:53 AM | |
| ?????????? ?? ??????? 6 mps | This thread | Refback | 02-15-2014 02:51 PM | |
| Aide pour choisir downpipe - Mazda 3 Quebec | This thread | Refback | 08-06-2013 07:10 AM | |
| Mazdaspeed stage 2 downpipe vs racepipe | This thread | Refback | 06-19-2013 09:31 AM | |
| Cat'd DP? - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum | This thread | Refback | 04-21-2012 07:39 PM | |
| I HATE heat shielding. MPS 6 | Post #6 | Pingback | 12-23-2011 02:44 PM | |
| Which Race Pipe/Test Pipe is the best for a Mazdaspeed 6? | ItalianSA | MazdaSpeed 6 - Engine, Transmission & Driveline | 6 | 04-20-2009 12:14 PM |
