Like Tree40Likes
 Old 08-13-2013, 09:57 PM   #201
mikede5's Avatar
Posts: 82   (View Stats)
mikede5 has a brilliant futuremikede5 has a brilliant futuremikede5 has a brilliant futuremikede5 has a brilliant futuremikede5 has a brilliant futuremikede5 has a brilliant futuremikede5 has a brilliant futuremikede5 has a brilliant futuremikede5 has a brilliant futuremikede5 has a brilliant futuremikede5 has a brilliant future
Originally Posted by speedre View Post
Anyone have any dyno results showing gains with the Cobb dp? I'm deciding between Cobb and Corksport, I know the hp difference won't be much but I can't find any numbers on the Cobb one. Their website shows a graph but hp numbers aren't on it.
I never did a dyno run for my cobb dp, but I ran a log before and after and got a 7-9 g/s gain which I found to be about 17-20hp. It really depends on the car and the mods you have on it. Just go with what pipe you like is your best bet.
Sent from my Nexus 4 using Tapatalk 2
-2012 Pearl White MS3 - AEM CAI, Cobb TIP, Cobb AP ots stage 2, AT Internals, Corksport TMIC, H&R Springs, JBR Rear Camber Arm, Cobb downpipe, Evo X Wheels Painted Gold with Nitto Neo Gen 235/40-18
-2011 GSXR 750
-1999 Custom Long Travel Tacoma
mikede5 is offline   Reply With Quote
The Following User Says Thank You to mikede5 For This Useful Post:
speedre (08-14-2013)
 Old 08-14-2013, 01:59 PM   #202
speedre's Avatar
Posts: 103   (View Stats)
speedre is a splendid one to beholdspeedre is a splendid one to beholdspeedre is a splendid one to beholdspeedre is a splendid one to beholdspeedre is a splendid one to beholdspeedre is a splendid one to beholdspeedre is a splendid one to behold
Groaned at 7 Times in 3 Posts
cool thanks for the info mikede, can't wait to install it
speedre is offline   Reply With Quote
 Old 09-15-2013, 10:43 AM   #203
evolizzee's Avatar
Posts: 601   (View Stats)
evolizzee is the leader of the worldevolizzee is the leader of the worldevolizzee is the leader of the worldevolizzee is the leader of the worldevolizzee is the leader of the worldevolizzee is the leader of the worldevolizzee is the leader of the worldevolizzee is the leader of the worldevolizzee is the leader of the worldevolizzee is the leader of the worldevolizzee is the leader of the world
Are there any benefits from goin to an M2 catless DP from a Cobb DP with a high flow cat?
2011 Blue Mica 50% E85
COBB: AP, DP, SRI, TIP, OCC // Blitz Steel Mesh Filter // SURE: RMM, Boost Tubes, Counter Weight, Shift Anchors, AGS Knob // JBR: Tranny Mount, Passenger Mount// PT-P: HPFP, Rail Valve // PCV Vent // Forge BPV V1 // ETS 3.5" TMIC // NGK IXs // EGR Delete // Resonator Delete // FoMoCo Gear Oil // Castrol Syn Power 5w-40 // Koni Yellows // H&R Sport Springs // SPC Camber Arms// Spec: Stage 3+ SR Clutch, 12lb Flywheel
13.2@113mph
evolizzee is offline   Reply With Quote
 Old 09-15-2013, 11:04 AM   #204
TiGraySpeed6's Avatar
Posts: 3,981   (View Stats)
If you've been fighting overspool issues or smoking issues with the K04, or if you live in a state with inspections, adding the cat in may help by providing some back pressure or for inspections.
Adding a cat can also help remove the fuel smell from your exhaust if that's in issue for you.
Oh, and tree hugger.
If none of those points are relevant to your needs, I'd consider the budget better applied elsewhere.
340hp / 371tq
 Old 10-01-2013, 01:16 PM   #205
Raider YOLO'd my mom
spdandpwr's Avatar
Posts: 965   (View Stats)
spdandpwr is the leader of the worldspdandpwr is the leader of the worldspdandpwr is the leader of the worldspdandpwr is the leader of the worldspdandpwr is the leader of the worldspdandpwr is the leader of the worldspdandpwr is the leader of the worldspdandpwr is the leader of the worldspdandpwr is the leader of the worldspdandpwr is the leader of the worldspdandpwr is the leader of the world
I hear that our turbos require backpressure to prevent messing with the seals. My question is, can if I upgrade to a high flow cat setup, which core do I go with? i want whichever provides the best performance under high heat loads. I've seen highflow cats melt and I don't want that on my car, lol.
spdandpwr is offline   Reply With Quote
 Old 10-01-2013, 09:23 PM   #206
Esteban123toro's Avatar
Posts: 245   (View Stats)
Esteban123toro is the leader of the worldEsteban123toro is the leader of the worldEsteban123toro is the leader of the worldEsteban123toro is the leader of the worldEsteban123toro is the leader of the worldEsteban123toro is the leader of the worldEsteban123toro is the leader of the worldEsteban123toro is the leader of the worldEsteban123toro is the leader of the worldEsteban123toro is the leader of the worldEsteban123toro is the leader of the world
Groaned at 6 Times in 4 Posts
ive been looking everywhere reviews from the dnp turbo manifold... what you guys think?
Esteban123toro is offline   Reply With Quote
The Following 2 Users Say NO Thank You to Esteban123toro For This Un-useful Post:
captain slow (10-02-2013), doubleflusher (10-02-2013)
 Old 10-02-2013, 09:07 AM   #207
captain slow's Avatar
Posts: 5,559   (View Stats)
Groans: 398
This thread is for down pipes, not exhaust manifolds. Take your question elsewhere, there's plenty of people with reviews/comments on the DNP manifold.
The Following User Says Thank You to captain slow For This Useful Post:
Esteban123toro (10-02-2013)
 Old 10-02-2013, 11:59 AM   #208
Koke382's Avatar
Posts: 4,361   (View Stats)
Groans: 32
Every time I read your post I read it in captain slows voice.
sent from my peepee
Westbound likes this.
2007 Mazdaspeed 3 GT
18x8.75 XXR 527 225/40/18r
New fucken miata build:
1993 Red Na6
Some suspension modz yo
Coilovers// Other shit
 Old 10-11-2013, 02:14 AM   #209
Remichell's Avatar
Posts: 2   (View Stats)
Remichell is an unknown quantity at this point
Ok im noob but i read the entire thread, but didn't find an answer to my question and since this is the DP thread i assume its here where it need to be ask. There are no options out there for a DP meant for a top mount turbo other than custom?? Just want to know if there is or was a company that make or made them. I read in another build thread where they were using top mount manifold but they just mention they adapt a downpipe from another kit or something, just though it was gonna be mention here.
Remichell is offline   Reply With Quote
 Old 10-11-2013, 08:18 AM   #210
GODspeed7's Avatar
Posts: 3,456   (View Stats)
You are correct and the reason is their are too many variables as far as turbo/manifold location for a downpipe to be mass produced like that.
2012 Mazdaspeed3 Black Mica
 Old 10-11-2013, 05:36 PM   #211
Remichell's Avatar
Yeah i kind of figure it out after reading a lot of treads... But i found out in this thread that there is a person on the forum that sell the downpipe for the top mount with, Intake, Custom Oil Lines, & Screamer Pipe that goes for the name of Dustin. Can some one tell me how can i contact him so i can get a quote from him for the package, so later on when i have everything else just buy that form him. Thanks
 Old 10-11-2013, 06:40 PM   #212
jreiden1's Avatar
Posts: 237   (View Stats)
jreiden1 is the leader of the worldjreiden1 is the leader of the worldjreiden1 is the leader of the worldjreiden1 is the leader of the worldjreiden1 is the leader of the worldjreiden1 is the leader of the worldjreiden1 is the leader of the worldjreiden1 is the leader of the worldjreiden1 is the leader of the worldjreiden1 is the leader of the worldjreiden1 is the leader of the world
Permtuning.com is his website but his focus I believe are on other things right now. And he has a full time job! So you can try there who knows, he might!
2006 WWP Mazdaspeed 6
KILLAH BUILT 700+ AWHP TUNED BY NISHAN
jreiden1 is offline   Reply With Quote
 Old 10-13-2013, 01:58 PM   #213
jeopardy98's Avatar
Posts: 1,920   (View Stats)
jeopardy98 is the leader of the worldjeopardy98 is the leader of the worldjeopardy98 is the leader of the worldjeopardy98 is the leader of the worldjeopardy98 is the leader of the worldjeopardy98 is the leader of the worldjeopardy98 is the leader of the worldjeopardy98 is the leader of the worldjeopardy98 is the leader of the worldjeopardy98 is the leader of the worldjeopardy98 is the leader of the world
@djuosnteisn;
Bone Stock 2012 BM Non-Tech for 2500 miles. (250 whp/265 wtq Moore Auto). Currently: K04/Cobb AP/AT internals/Magnaflow CBE/M2 DP/Cobb SRI/HTP TIP/CS boost tubes/CS recirc hose/TS BPV/SU TMIC/GS EBCS/JBR EGR delete/Coolant bypass/Thermal TB gasket/NGK 6510's/JBR SSP/JBR Knob/JBR 88 RMM/JBR SSB/DDM 35w 5000k HIDs/PAC Gateway iPod integration and Sirius. (301whp/360wtq Moore Auto). Finklefied Hypnotic tune. 14.1@106 Mason Dixon- Driver mod needed.
jeopardy98 is offline   Reply With Quote
 Old 11-10-2013, 06:55 PM   #214
mlamp89's Avatar
Posts: 101   (View Stats)
mlamp89 will become famous soon enoughmlamp89 will become famous soon enough
Mother of God...I've got the stock down pipe removed but just sitting down in the engine bay. What's the easiest way t up get the stupid thing up and out. I'd prefer to remove as few parts as possible....
2007 Red MS6 AEM CAI, Custum exhaust, AP, HPFP internals, catless DP.
2005 Red Hyundai Tiburon SE V6 6MT, K&N CAI, Borla Full exhaust, Headers-Sold
mlamp89 is offline   Reply With Quote
 Old 11-10-2013, 07:00 PM   #215
Pull RMM and rock engine forward while lifting the DP up & out.
It takes a few tries to get the angle right, but when you do it will lift right out. Also, if you haven't already, separate the lower section and drop it out the bottom so you're only pulling up the primary cat section.
Once the stocker is out you can put the RMM back- the aftermarket DP has plenty of room to go in easy as can be.
340hp / 371tq
ABOSWORTH (04-02-2014), mlamp89 (11-10-2013)
 Old 11-10-2013, 07:05 PM   #216
DP install instructions from CPE, but the technique to remove the stock DP will apply to any
340hp / 371tq
 Old 11-10-2013, 07:33 PM   #217
mlamp89's Avatar
Thanks. I got the lower part out. But it's the upper part that's making me rethink ever upgrading anything again.
 Old 11-11-2013, 12:31 PM   #218
mlamp89's Avatar
Got the rear motor mount out. Put the Jack next to the mount and started lifting. Got to the point that the car itself was also lifting. Still can't wiggle the dp out. What's the special angle? I've tried spinning, pulling cursing and yanking. It's still really tight with the alternator and turbo and exhaust manifold.
rdguindon likes this.
 Old 11-11-2013, 12:43 PM   #219
grab the cpe guide I posted & have a look at the stock dp removal steps-
That's the process I used to remove mine as well- I'd forgotten, but need to have jack under the engine with block of wood to support the oil pan, then remove the connection to the PMM, then you can shift the engine as needed.
340hp / 371tq
 Old 11-11-2013, 12:48 PM   #220
dale_gribble's Avatar
Posts: 4,720   (View Stats)
Don't jack the motor up, lower it for clearance to get the upper piece out. Remove the PMM top section, remove the RMM, use a jack to carefully drop the motor down to get the clearance you need. I just did it this weekend.
MINI H1 6.0 - CAR LED TAILS
mlamp89 (11-11-2013)
 Old 11-11-2013, 12:56 PM   #221
Posts: 2,827   (View Stats)
^ This.
LOWER the motor, not raise it. Lowering the motor will make more room.
 Old 11-11-2013, 04:20 PM   #222
mlamp89's Avatar
Good Lord....Finally got it out. I had to cut the heat shield off.(rusted and stuck screws) I've got the motor mounts back on and now working on getting bolts from the down pipe flange to the turbo all tightened. But there's one that a socket can't get on. So it'll be interesting. Thanks for your help!
 Old 11-11-2013, 07:03 PM   #223
jeopardy98's Avatar
That one you can't get a socket on requires a wobble extension and a swivel socket plus a narrow ratchet. You can get a socket on it but you need the right combination.
 Old 11-12-2013, 11:50 AM   #224
mlamp89's Avatar
Thanks. I have a swivel socket. But I don't think i have a wobble extension. and I dont know if my ratchet is narrow enough. I guess I will try. need attachments for my attachments..
 Old 11-19-2013, 05:51 PM   #225
Sandman88's Avatar
Posts: 9   (View Stats)
Sandman88 has a little shameless behaviour in the past
very good, informative thread. I'm having the problems mentioned in this thread. got a downpipe and my CEL came on. maaad backfire. was running too lean. so I re-installed my stock recirc BOV. I had a VTA BOV installed. helped out a little. guess I gotta get an O2 sensor extender.
Sandman88 is offline   Reply With Quote
 Old 11-20-2013, 07:24 AM   #226
Putting the stock BPV back on is an excellent beginning. It works extremely well until you get well above 20 psi which is not going to happen on the stock turbo on pump gas.
What downpipe did you get? If it hasa raised sensor bung, adding an extender will probably not help and could make matters worse. If no raised bung, then try the extender. I only get a CEL a couple times per year, usually with a cold snap in late fall and on the first warm day in the spring. I just clear the light and roll on.
 Old 11-20-2013, 09:49 AM   #227
Sandman88's Avatar
I'm thinking of getting a recirc BOV eventually. I believe it's an ATP downpipe. and it did have an extended sensor bung which I assumed was a built-in O2 sensor extender.
MAZDASPEED 4 LIFE!!!
 Old 11-20-2013, 10:20 AM   #228
Great. Run like you are. Clear the light. It may stay off a long time and is easily cleared with most cheap cel readers. I assume you have some sort of tuning device to safely run a downpipe. That device will clear codes. And I assume you have upgraded your fuel pump internals to handle the extra flow demands. What other mods do you have? Sounds like you may need to do more reading and study before you go zoom, zoom, boom.
Why a "recirc BOV"? There is no such thing. If it recirculates, by definition it is a BPV. Changing to a different one will not improve performance. If you just want to make noise, get a duck call or make armpit fart sounds. If you simply want to know that the valve is releasing, the stock valve is plenty loud enough to hear inside the car, even if you have the windows up if you have an SRI or CAI intake, which I assume if you are running a downpipe. Running vent to air on stock tune is a really stupid idea, and generally not desirable on this engine on any tune. Your MAF sensor has "read" that air and matched the fuel to go with it. If you then far that air to atmosphere, the engine runs rich, not lean during that event. It afterfires during shifts, stumbles and generally runs crappy at idle.
The Following 2 Users Say Thank You to MSMS3 For This Useful Post:
Notorious AMA (01-07-2014), Sandman88 (11-20-2013)
 Old 11-20-2013, 06:29 PM   #229
Sandman88's Avatar
I don't have any tuning device yet. I would love a COBB Access Port but it's too expensive for me right now. I haven't gotten fuel pump internals yet. I was under the impression that BOVs are recirc and BPVs are VTA. I found a recirc BOV made by HKS. I do love the sounds they make but I've heard that they somewhat improve performance too. My stock BOV makes slight, barely noticeable blowoff sounds. I just realized before I signed up on this forum that it's not good to run VTA with such a stock car. And when my friend scanned my car, the device said it was running lean. I'm getting so many different opinions from so many people so that's why I registered on this forum. Not only did I want to meet other Mazdaspeed enthusiasts like myself, but I wanted to learn about my car with the best information I can get.
 Old 11-21-2013, 07:18 AM   #230
Welcome. You have much to learn, Grasshopper. You are in the right place, but starting off the wrong way. Please begin reading the stickies in the threads related to engine, forced induction and tuning. It's all here. Nobody is going to spoon feed you and you will get flamed for asking stupid shit or making stupid comments on things that have been the subject of multiple threads. So, search before posting.
Running an aftermarket downpipe on the stock fuel pump and stock tune is asking for trouble. I'll bet you don't even have a boost gauge, let alone any monitoring software. The downpipe alone will cause the ECU to raise boost by about 2 psi. It is running VTA that causes you to run rich during shifts and causing unburned fuel to ignite in your exhaust. That's afterfire, NOT backfire which is on the intake side. And yes, your understanding of BPV and BOV is backward. You need a recirc tube in place. Did you even plug the intake port for that tube when trying to run VTA?
I asked about other mods. You may be fucked up there. Improper intake choice or setup could produce a lean condition. Maybe we should take this to PM and not hijack this downpipe thread further. So much newbie fail, so much to learn.
jeopardy98 (11-24-2013)
 Old 11-24-2013, 11:17 AM   #231
jeopardy98's Avatar
I would highly suggesting removing that dp until you upgrade your fuel pump internals and even then without some kind of monitoring you are playing with fire. MSMS3 have given you good advice. You have a lot to learn and days worth of reading.
 Old 11-24-2013, 06:36 PM   #232
jk_ms3's Avatar
Posts: 1,390   (View Stats)
Groans: 40
This is not good! I appreciate your willingness to learn, so here's lesson #1 : don't run a dp without internals. Swap that dp out, or at least stay out of boost. Then get an AP and internals ASAP. It's way cheaper to get them now than if your car goes zzb.
You're welcome.
On deck: VG Sharkfin Antenna
 Old 12-05-2013, 10:48 PM   #233
speed34win's Avatar
Posts: 21   (View Stats)
speed34win will become famous soon enough
Hey does anyone know of a company or someone that sells or can make me an adapter for a v-band turbo to stock 5 bolt downpipe??
speed34win is offline   Reply With Quote
 Old 12-05-2013, 11:31 PM   #234
theurgy's Avatar
Posts: 2,580   (View Stats)
Maybe:
http://www.mazdaspeedstore.com/mazda...ed6-p-353.html
 Old 12-05-2013, 11:41 PM   #235
speed34win's Avatar
No that's for stock turbo to v band I need the other way
 Old 12-06-2013, 01:41 PM   #236
chuckms6's Avatar
Posts: 1,618   (View Stats)
chuckms6 is the leader of the worldchuckms6 is the leader of the worldchuckms6 is the leader of the worldchuckms6 is the leader of the worldchuckms6 is the leader of the worldchuckms6 is the leader of the worldchuckms6 is the leader of the worldchuckms6 is the leader of the worldchuckms6 is the leader of the worldchuckms6 is the leader of the worldchuckms6 is the leader of the world
just get a vband downpipe
DIY SRI, DIY WAIC, VCTS Mod, Gutted Stock DP, Cobb AP, SURE TIG, KMD Internals, Denso ITV22's
SURE Dreadnaught, DSS Left Rear Axle, Custom in car SSP, JBR SSP, Powered by Max Shift Knob
Megan Racing Coilovers
13.7@ 96 w/1.8 60ft (SRI, AP)
13.4@ 102 w/1.9 60ft (SRI,AP,WAIC,TIG, Internals, ITV22's)
chuckms6 is offline   Reply With Quote
The Following User Says Thank You to chuckms6 For This Useful Post:
theurgy (12-06-2013)
 Old 12-06-2013, 02:56 PM   #237
2012FailWheelDrive's Avatar
Posts: 327   (View Stats)
2012FailWheelDrive is the leader of the world2012FailWheelDrive is the leader of the world2012FailWheelDrive is the leader of the world2012FailWheelDrive is the leader of the world2012FailWheelDrive is the leader of the world2012FailWheelDrive is the leader of the world2012FailWheelDrive is the leader of the world2012FailWheelDrive is the leader of the world2012FailWheelDrive is the leader of the world2012FailWheelDrive is the leader of the world2012FailWheelDrive is the leader of the world
Any idea where? I am looking for a vband downpipe at the moment and local shops want an arm and leg haha.
"under construction"
2012FailWheelDrive is offline   Reply With Quote
 Old 12-06-2013, 03:04 PM   #238
nortigid's Avatar
Posts: 503   (View Stats)
nortigid is the leader of the worldnortigid is the leader of the worldnortigid is the leader of the worldnortigid is the leader of the worldnortigid is the leader of the worldnortigid is the leader of the worldnortigid is the leader of the worldnortigid is the leader of the worldnortigid is the leader of the worldnortigid is the leader of the worldnortigid is the leader of the world
Long Downpipe for Mazdaspeed3 : atpturbo.com
ATP sells one (DP) with an optional vband. You can also find vband to 5-bolt adapters all over ebay. I did only see ones for GT2x turbos, but I really didn't dig that deep.
nortigid is offline   Reply With Quote
The Following User Says Thank You to nortigid For This Useful Post:
2012FailWheelDrive (12-06-2013)
 Old 12-06-2013, 03:12 PM   #239
theurgy's Avatar
Even if you don't find any of the adapter, you can always buy the flanges separately and get a custom shop to weld it up for you.
Might afford you some flexibility for placement and such.
 Old 12-06-2013, 05:01 PM   #240
chuckms6's Avatar
the $140 ebay downpipes are all 3" v band
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f505/official-downpipe-test-pipe-race-pipe-thread-99627/
catless downpipes cause turbo to blow seals?? - Page 4 This thread Pingback 11-10-2014 11:55 AM
Tuner/garage in Brampton/Mississauga area This thread Refback 08-02-2014 08:51 AM
Downpipe options - 2004 to 2014 Mazda 3 Forum and Mazdaspeed 3 Forums This thread Pingback 07-22-2014 10:53 AM
?????????? ?? ??????? 6 mps This thread Refback 02-15-2014 02:51 PM
Aide pour choisir downpipe - Mazda 3 Quebec This thread Refback 08-06-2013 07:10 AM
Mazdaspeed stage 2 downpipe vs racepipe This thread Refback 06-19-2013 09:31 AM
Cat'd DP? - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Refback 04-21-2012 07:39 PM
I HATE heat shielding. MPS 6 Post #6 Pingback 12-23-2011 02:44 PM
Which Race Pipe/Test Pipe is the best for a Mazdaspeed 6? ItalianSA MazdaSpeed 6 - Engine, Transmission & Driveline 6 04-20-2009 12:14 PM
Page generated in 0.86800 seconds with 42 queries
