Like Tree40Likes
 Old 02-13-2014, 11:44 PM   #1
sidekick's Avatar
Posts: 3,093   (View Stats)
Groans: 47
Originally Posted by afronese1 View Post
Where's the optimum position for the hi-flow cat? I was thinking of doing it the way cpe has its catted dp for ms6.
Putting it to close to the turbo outlet can cause premature failure, so the further back you can fit it, the better. IIRC, some people have had issues with the CP-E cats failing, most likely due to heat.
afronese1 (02-14-2014)
 Old 03-11-2014, 08:54 PM   #2
bguild's Avatar
Posts: 12   (View Stats)
bguild is on a distinguished road
Guys, I read this entire effin thread and there is one thing I need to confirm. Is the ATP downpipe for my MS6 I bought here
ATP Turbo 3-inch Downpipe for Mazdaspeed 6 #ATP-MS6-001 - Revolution Performance Motorsports!
a full length downpipe?
I noticed page 1 said ATP doesn't make a top/bottom section so I am assuming this is a full downpipe and will hook right up to the Magnaflow catback, correct?
bguild is offline   Reply With Quote
 Old 03-11-2014, 09:06 PM   #3
El Beaner's Avatar
Posts: 4,262   (View Stats)
The picture alone looks like a long/Full dp. If you go look at the ones that are just the dp they are much shorter / smaller
SOLD 2012 LSM Tech - 11/17/17
The Following User Says Thank You to El Beaner For This Useful Post:
jreiden1 (03-12-2014)
 Old 03-13-2014, 08:50 AM   #4
6ixof1's Avatar
Posts: 700   (View Stats)
I got my finger on the trigger for this DP... It's just the install...
Black Mica Mazdaspeed 6
The Mad Scientist Tunings
 Old 03-13-2014, 12:35 PM   #5
GODspeed7's Avatar
Posts: 3,456   (View Stats)
What about the install?
sent while failing
2012 Mazdaspeed3 Black Mica
 Old 03-14-2014, 10:05 AM   #6
Zoobie13's Avatar
Posts: 104   (View Stats)
Zoobie13 has a brilliant futureZoobie13 has a brilliant futureZoobie13 has a brilliant futureZoobie13 has a brilliant futureZoobie13 has a brilliant futureZoobie13 has a brilliant futureZoobie13 has a brilliant futureZoobie13 has a brilliant futureZoobie13 has a brilliant futureZoobie13 has a brilliant futureZoobie13 has a brilliant future
So the 2007 ms3 have the faulty turbo seals so does that mean it will cause a smoking turbo for everyone? Or has anyone successfully added dp successfully to the 07?
07 TRUE RED Mazdaspeed 3
// BNR S3 //
//Cobb ap (Freektune)//
//Cobb ebcs//
//Cobb sri//
//Cobb tip//
//Cobb DP//
//ETS TMIC //
// Corksport boost tubes //
// 3 BAR sensor //
//NGK LTR7IX//
//Forge bpv v1 PING//
//res delete//
// Cannon muffler Tip //
//Autotech interals //
//Sure RMM 70 duro //
//Rally armour mudflaps//
//Momo shift knob//
//DDM 8000k //
Zoobie13 is offline   Reply With Quote
 Old 03-16-2014, 06:35 PM   #7
TheBunk's Avatar
Posts: 18   (View Stats)
TheBunk will become famous soon enough
Groaned at 3 Times in 1 Post
I've had my M2 downpipe for almost a year now with no smoke except for at WOT. stock turbo 2007 ms3
2007 Mazdaspeed 3 Cosmic Blue
HPS CAI | SURE Turbo Inlet | CX Racing FMIC | Borla Catback | Cobb AP V3 | M2 DP | CP-E HPFP | Greddy Type RS BPV | SURE RMM | CS Springs/Struts | H&R Springs | TSW Donington 18s | NGK IX Iridium | JBR SSP and Bushings | SURE AGS 621g Knob | Yellow Lamin-X fog covers | MPT Dyno Tune with E85 | SURE OCC | AEM Meth Kit | Painted Roof, Grill, Front/Rear Bumpers, Scrape Pads, Side Mirrors, Calipers |
TheBunk is offline   Reply With Quote
 Old 03-20-2014, 08:37 PM   #8
bguild's Avatar
I installed the ATP downpipe on my MazdaSpeed6. Make no mistake, it's a bitch of a job. I followed the corksport instructions which require unbolting most of the top of the engine, the motor mounts, etc. Fun times.
Unfortunately, in my case, almost every bolt was rusted and I needed a bunch of new bolts including downpipe to turbo bolts, and some new heat shields.
Question for ATP downpipe owners: is your primary O2 like a single millimeter away from the turbo housing once installed? I am so worried that it is too close and will rub. I will try to send a picture tomorrow.
Thanks.
 Old 04-20-2014, 07:21 AM   #9
Dark Lightning's Avatar
Posts: 170   (View Stats)
Dark Lightning is the leader of the worldDark Lightning is the leader of the worldDark Lightning is the leader of the worldDark Lightning is the leader of the worldDark Lightning is the leader of the worldDark Lightning is the leader of the worldDark Lightning is the leader of the worldDark Lightning is the leader of the worldDark Lightning is the leader of the worldDark Lightning is the leader of the worldDark Lightning is the leader of the world
Groaned at 6 Times in 2 Posts
Yes. Might be two millimeters.
2012 BMW 135i M-Sport
Dark Lightning is offline   Reply With Quote
 Old 04-09-2014, 09:38 PM   #10
maas173's Avatar
Posts: 9   (View Stats)
maas173 is on a distinguished road
Default need help!
I bought a 3 inch catless downpipe without the test pipe with it..will this connect to the stock cbe or am I going to need an adapter to get it down to 2.5 inches so it will connect with the stock midpipe??
maas173 is offline   Reply With Quote
 Old 04-09-2014, 09:43 PM   #11
theurgy's Avatar
Posts: 2,580   (View Stats)
Depends, which downpipe did you get?
 Old 04-25-2014, 08:32 AM   #12
Zoobie13's Avatar
Question, would the gen 2 cs dp + rp fit gen 1s?
// BNR S3 //
//Cobb ebcs//
//Cobb sri//
//Cobb tip//
//Cobb DP//
//ETS TMIC //
// 3 BAR sensor //
//NGK LTR7IX//
//res delete//
//Momo shift knob//
//DDM 8000k //
 Old 04-25-2014, 08:42 AM   #13
Raiders Bitch
Shampu's Avatar
Posts: 803   (View Stats)
Did you read the first post?
Look for some giant red text in caps and you will find your answer
Instagram: Genpu_Drew
235/40 Pilot Super Sports
Tuned by Nishan
25% E85
SnowWhiteMs3 (05-17-2014)
 Old 04-25-2014, 08:52 AM   #14
Zoobie13's Avatar
Hahah shat my bad I read it a couple times but skimmed it. Thanks for the smack in the head lol
// BNR S3 //
//Cobb ebcs//
//Cobb sri//
//Cobb tip//
//Cobb DP//
//ETS TMIC //
// 3 BAR sensor //
//NGK LTR7IX//
//res delete//
//Momo shift knob//
//DDM 8000k //
The Following User Says Thank You to Zoobie13 For This Useful Post:
 Old 05-21-2014, 01:13 PM   #15
thuglife2334's Avatar
Posts: 117   (View Stats)
thuglife2334 has much to be proud ofthuglife2334 has much to be proud ofthuglife2334 has much to be proud ofthuglife2334 has much to be proud ofthuglife2334 has much to be proud ofthuglife2334 has much to be proud ofthuglife2334 has much to be proud ofthuglife2334 has much to be proud ofthuglife2334 has much to be proud ofthuglife2334 has much to be proud of
so i have notice that theres not alot of talk about the speed6 Corksport dp . i take it there not any good. i was planning on getting one with a cat. but i am not seeing to many ppl running them. why is that. just looking for a little insight.
2006 wwp MS6 -Cobb AP v2, Cobb SRI, Cs tih, SU TMIC, Autotech HPFP
custom test pipe, JBR RMM,
thuglife2334 is offline   Reply With Quote
 Old 05-21-2014, 08:01 PM   #16
trdaltezza's Avatar
Posts: 34   (View Stats)
trdaltezza will become famous soon enough
Thanks for that little nugget about the o2 bung extension...Now Im thinking catless downpipe, since I know I can get past the CEL's
trdaltezza is offline   Reply With Quote
 Old 06-21-2014, 06:02 PM   #17
570msp's Avatar
Posts: 102   (View Stats)
570msp is a splendid one to behold570msp is a splendid one to behold570msp is a splendid one to behold570msp is a splendid one to behold570msp is a splendid one to behold570msp is a splendid one to behold570msp is a splendid one to behold
Noob here with a MS6 and I'm still trying to learn this car. Came from a MSP so it's pretty different, anyways... Anyone have any good power gains with a specific short DP that keeps the second cat? I'd like the keep the second cat for back pressure because I'm worried about the infamous smoking turbo problem and would want to keep a cat to help with the issue.
PS I already have HPFP internals and AP with idle turned up.
Thanks for the advice in advance
570msp is offline   Reply With Quote
 Old 02-03-2015, 05:13 AM   #18
Inquisitive's Avatar
Posts: 220   (View Stats)
Inquisitive is the leader of the worldInquisitive is the leader of the worldInquisitive is the leader of the worldInquisitive is the leader of the worldInquisitive is the leader of the worldInquisitive is the leader of the worldInquisitive is the leader of the worldInquisitive is the leader of the worldInquisitive is the leader of the worldInquisitive is the leader of the worldInquisitive is the leader of the world
Default 2015 Update
You should take care of the HPFP limitations before considering the removal of a cat or going completely cat-less.
The DP is the most restrictive section of your exhaust system. The bell housing is so crimped; it is hard to imagine the waste-gate having enough room to open. It contains cat-1, which is heavy, but not as heavy as cat-2. If required for emissions control, if you do not have the software to cancel the CEL (in AP un-tick codes: P0038 and P0420 (if rear spark plug de-fouler does not work)) or if you are allowed to disable two codes only for emissions testing, you will need a fast cat with following oxygen sensor bung for the second sensor. A DP provides faster turbo response times and power gains across the rev range. The transition from decelerating to accelerating is much smoother. The engine just seems to breathe easier, probably due to the increased VE.
Divorce pipes reduce the turbulence caused by the opening and closing of the waste-gate. Also, the nature of bell housing designs creates turbulence as the chamber is expanded to cater for the turbo outlet and waste-gate. Having dedicated pipes respectively allows for same size pipes and thus, a smoother flow. By joining further down, they help to speed up the extraction resulting in faster opening of the waste-gate.
Descending Genpu purchased popularity order:
DownPipe (DP) and Full / Long DP
• UR DP
• Corksport DP
• CP-E DP & Long DP
• Cobb DP
• ATP Long DP
• eBay DP
• CNT Long DP
• M2 Long DP
• Gutted DP
• Kozmic DP
• Speed Daddy DP
• M2 DP
• TurboXS DP
• Full Race DP
• XForce DP
• AQ Motorsports Long DP
• QAS Long DP
• CES Racing Long DP
• Protuning Lab DP
• Best Mufflers DP
• Magnaflow DP
Test / Race / Track Pipe (cat-less) (TP / RP)
• Ultimate Racing (UR)
• CorkSport (CS)
• OBX
• CP-E
• TurboXS
• Street Unit (See Warning)
• Sure (See Warning)
• Cobb
2015 prices and availability:
First Section of Pipe Post Turbo
3” Ultimate Racing (UR) DP
Available from: 3” Ultimate Racing (UR) DP
MS6 (Not found), MS3 Gen1 (Yes), MS3 Gen2 (Yes) cat-less Version 1 $295, cat-less Version 2 $345, Long DP Ceramic Cat $395, Long DP Metal Substrate Cat $445, extra wideband bung $25)
Corksport (CS) DP
MS6 DP
MS6 Long DP
MS3 DP
MS3 Long DP
Available from:
MS6
CS 6 DP
MS3
CS 3 DP
MS6 (Yes: cat-less $349.99, +$281 for cat (long DP)), MS3 Gen1 (Yes) $299.99 + $281 for cat (long DP) with 65mm or 80mm option, MS3 Gen2 (Yes) $299.99 + $281 for cat (long DP) with 65mm or 80mm option
CP-E Long DP
MS6
MS3
Available from:
MS6
http://cp-e.com/webstore/product/maz...kspl-downpipe/ / MS6 long catted
MS3
http://cp-e.com/webstore/product/maz...kspl-downpipe/ / MS3 long catted
MS6 (Yes, catted) $621.40, MS3 Gen1 (Yes, catted) $504.40, MS3 Gen2 (Yes, catted) $504.40
Cobb Long DP
Available from: Mazdaspeed3 SS 3" Downpipe with High Flow Cat / Long catted MS3 Gen 1&2
MS6 (Not found), MS3 Gen1 (Yes, catted) $695, MS3 Gen2 (Yes, catted) $695
ATP DP
MS6 Long DP
MS3 Long DP
MS3 DP
Available from:
MS6 Long DP MS6 ATP Long DP
MS3 Long DP MS3 ATP Long DP
Much less popular: ATP DP MS3 ATP DP
MS6 (Yes, V-band) $439 + Mazda 5-bolt to V-band $95, MS3 Gen1 (Yes), MS3 Gen2 (Yes) cat-less, no donut, 3”, Long DP $299, DP $259
CNT Long DP
MS3 cat-less
MS3 catted
Available from: CNT Long DP
MS6 (Not found), MS3 Gen1 (Yes), MS3 Gen2 (Yes) 76mm cat-less $259, catted $399
M2 Long DP
MS6
MS3
Available from:
MS6
 MS6 long cat-less MS6 long cat-less
MS3
MS3 long cat-less
MS6 (Yes, cat-less) $140, MS3 Gen1 (Yes, cat-less) $171, MS3 Gen2 (Yes, cat-less) $171
Kozmic DP
Available from:
MS6
Kozmic MS6 DP
Kozmic MS3 DP
MS6 (Yes), MS3 Gen1 (Yes), MS3 Gen2 (Yes) V-band for use with CP-E EM only $539.99
Speed Daddy DP
MS6
MS3
Available from: Speed Daddy DP
MS6 (Yes) $318.99 out-of-stock, MS3 Gen1 (Yes) $148.99, MS3 Gen2 (Not found)
TurboXS DP
Available from: http://turboxs.com/shop/mazda/153-ma...-downpipe.html / 3 long cat-less
MS6 (Not found), MS3 Gen1 (Yes, cat-less) $299, MS3 Gen2 (Yes, cat-less) $299
Full Race DP
MS3 Prostock
MS3 EFR
Available from:
MS3 Prostock
Full Race Prostock DP
Full Race EFR DP
MS6 (Yes), MS3 Gen1 (Yes), MS3 Gen2 (Yes) Prostock $748.99 V-band + $75.34 for MS3, optional $120 silver or black coating on EFR
XForce Full TBE only
Available from: XForce DP
MS6 (Not found), MS3 Gen1 (Not found), MS3 Gen2 (Yes) Australian $1600
Available from: http://www.aqmotorsports.com/product...roducts_id=590
MS6 (Not found), MS3 Gen1 (Yes, catted) $499, MS3 Gen2 (Not found)
QAS Full Exhaust System
Available from:
QAS Full Exhaust System (German)
Translated into English
MS6 (Not found), MS3 Gen1 (Yes), MS3 Gen2 (Not found) €899 + shipping from Germany
CES Racing Long DP
Available from: CES Racing Long DP
MS6 (Not found), MS3 Gen1 (Yes), MS3 Gen2 (Yes) Australian $1,299
Protuning Lab
MS6 DP
MS3 DP
MS3 Long DP
Available from: http://www.protuninglab.com/j220ma6madit.html / MS6
http://www.protuninglab.com/dp-ms3-t.html / MS3 Gen 1 Long
http://www.protuninglab.com/doma3tu.html / MS3 Gen 1 & 2 Short
MS6 (Yes, catted) $191.99, MS3 Gen1 (Yes) $181.99, MS3 Gen2 (Yes) $173.99
Magnaflow Catted DP
MS3 DP
Two-year warranty
Available from: Magnaflow Catted DP
MS6 (No), MS3 Gen1 (Yes) $490, MS3 Gen2 (Yes) $490
A Long or Full DP includes the DP and TP / RP. The TP / RP always removes cat-2 and can be purchased with or without resonator delete for use with the OEM / stock DP or aftermarket DP.
MS6 Resonated
MS3
Available from:
MS6
UR MS6
MS3
UR Gen1
1.44 HP, 1.74 more Torque, 3” 304 SS, TIG welded, includes donut gasket, cat-less with resonator option
MS6 (Yes) $125 +$100 Resonated or +$100 Ceramic Cat or +$150 Metal Cat, MS3 Gen1 (Yes), MS3 Gen2 (Yes) $150 +$100 Resonated or +$100 Ceramic Cat or +$150 Metal Cat
CorkSport Power Series Racepipe
MS6 Resonated
MS3
Available from:
MS6
CorkSport Power Series Racepipe MS6 Resonated
MS3
CorkSport Power Series Racepipe MS3
12 WHP by deleting cat-2 (80mm)
MS6 (Yes) $178.99, MS3 Gen1 (Yes) $167.99 (Resonated available), MS3 Gen2 (Yes) $167.99
OBX (Amazon)
MS3
Available from:
MS6
OBX (Amazon) MS6
MS3
OBX (Amazon) MS3
SUS T-304, CNC machined flanges, DUAL-TIG welded
MS6 (Yes) $79, MS3 Gen1 (Yes), MS3 Gen2 (Yes) $not known as out-of-stock
eBay
MS6
MS3
Available from:
MS6
eBay MS6
MS3
eBay MS3
MS6 (Yes) $70, MS3 Gen1 (Yes), MS3 Gen2 (Yes) $85
CP-E Nexus Resonator Delete
Available from: CP-E Nexus Resonator Delete MS3
MS6 (Not found), MS3 Gen1 (Yes), MS3 Gen2 (Yes) $259.69
TurboXS
Available from: TurboXS
3” T304 SS; with TurboXS CBE got 22-26 WHP, 17-30 ft-lbs
MS6 (Not found), MS3 Gen1 (Yes), MS3 Gen2 (Yes) $177.95
Street Unit (SU)
WARNING: read http://www.mazdaspeedforum.org/forum/foru...3/#post1927730
3” 304 SS cat-less (weight saving) CNC machined flanges, reuses the stock donut flange system to allow for necessary movement. The removal of the 2nd cat will NOT trigger any check engine lights. The test pipe will bolt right up to both the stock and aftermarket cat-back exhaust systems.
Sure Flow M3 Track Pipe
removes 2nd cat, 3”, 304 SS, CNC machined flanges, TIG welded, re-uses stock donut flange for flex movements, will not trigger CEL
MS3 Gen2: AT: HPFP Int; Cobb: AP V3/ATR; CS: SRI/TIP, Catless DP; DIY: Air-box; GS: EBCS;
Hankook: V12; NGK: 1 step cooler; OTC: EGR Del, OCC with VTA, PCV Plate, TP Coolant Bypass
Last edited by Inquisitive; 07-07-2015 at 09:27 AM. Reason: Added Magnaflow Catted DP
Inquisitive is offline   Reply With Quote
 Old 02-03-2015, 06:17 AM   #19
Dude, you are kicking ass at the refresh!
All this update needs is more pics of products, and links. A lot do not work (oddly, it is the ones with no pics. Keep revising, and once ready, I will update it.
Good to see that South Africa is doing good on MSF these days!
chaser27 (02-03-2015), Koke382 (02-03-2015), Mauro_Penguin (02-05-2015), Nel Mazdaspeed (02-03-2015)
 Old 02-03-2015, 10:28 PM   #20
^^ Hey, thanks man - imagine what I could do with a faster line. I keep having to reload images, get timed out... So, I save often.
Today's Bing shows a fishing village I pass by on the way to work. You can imagine these waves from the Cape of Storms hitting the second story windows in the restaurant overlooking the little lighthouse at the end of the pier.
 Old 02-04-2015, 03:16 AM   #21
Well, keep updating, and let me know when it's done, ok?
 Old 02-04-2015, 04:06 AM   #22
OK - I think it's ready for the rigours of MSF testing (no broken images, correctly identified manufacturers, etc.) Perhaps we should wait for comments first.
I haven't addressed TPs, just the overlap with Long DPs.
I think we should say a bit more about going cat-less, being: the purposes are to reduce backpressure, increase exhaust flow, decrease turbo spool time, increase horsepower, broaden the torque band and produce a more aggressive sound.
Eliminate one catalytic converter (cat) by either replacing the DP which contains cat-1 or cat-2 and resonator delete, called a test pipe and then add a free flow exhaust. The latter also being called cat-back, but expect complaints from the neighbours with this second option. The increased exhaust flow will move the detonation threshold up and creates enough VE to allow for slightly higher boost targets. (Cobb) However, running completely cat-less can create severe boost spikes as well as over boost conditions. Fast cats are expensive. Remember to lower your WGDC a few percent in the 2500 to 3500 RPMs range @phate; ) when deleting a cat as the turbo will spool quicker or you will see boost spikes. Also, lower the requested load to less than actual load in the spike area. @Speed3eak; ) With a DP, you should see 1-2 better mpg @wolly6973; ) and get two more psi @MSMS3; ). Replacing the DP reduces the back pressure and may allow oil to pass by the turbo seals. This was more a problem with the GenWans and remedied by raising the idle to 900 RPMs and / or swapping to a smaller diameter oil feed bolt “pill” sold by bnoon. @MS3-a(sore)ASS-rex; )
The first oxygen (O2) sensor is essential for the ECU’s AFR tuning. The second O2 sensor is after cat-1 just to ensure that there is a functioning catalytic converter in the system. The ECU is expecting to see a difference between the two sensors. Otherwise, it will trip a CEL and can put the vehicle in “Null” / “Valet” / “Dealer” mode limiting speed, etc. An extension on the second O2 bung is also called a spark plug de-fouler or mechanical O2 fix. It lifts the second O2 sensor out of the exhaust flow and “usually” fools the ECU into thinking that cat-1 is still there restricting the exhaust flow. These can be purchased separately or comes with the pipe. Note that they do not come with a guarantee to not trip a CEL.
The Following User Says Thank You to Inquisitive For This Useful Post:
MSMS3 (02-04-2015)
 Old 02-04-2015, 10:55 AM   #23
Posts: 2,826   (View Stats)
Excellent summary of available DPs, features, benefits and risks. I would add the following caveat, which concurs with your post:
1. I ran catless dp/rp in my sig below for a short while without either a high pressure fuel pump upgrade or a tune. That proved dangerous, in retrospect. I reported at the time about a 2 psi boost gain on the stock tune. But, there was also a pretty nasty boost spike in the 3,500 rpm range, running up to about 21 psi.
2. I did install the Hypertech tune based on "back channel" info from another trusted MS3 user on this board that it would actually eliminate the spikes while raising load limits, increasing timing, etc. It did, in fact, remove those spikes and proved to be a very effective tune if you are staying on the stock K04 turbo and running ordinary premium pump gas.
3. I learned later, fortunately before it was too late, that the high pressure fuel pump upgrade is essential to safety if running an exhaust this free flowing. I began monitoring (ScanXL Pro software and laptop) with the HT tune and discovered that fuel pressure was close to becoming unsafe and then did drop under load on a couple datalogs to unsafe levels. Of course this is well-known now, but perhaps not so back then. So, pump internals were installed.
Thanks, again for the excellent summary. Running a 3" catless dp and rp really wakes this engine up. But, for those who may be new to the issue and considering this exhaust upgrade, it is unsafe without both some sort of tune to kill the spikes and a high pressure pump internals upgrade.
The Following 2 Users Say Thank You to MSMS3 For This Useful Post:
Inquisitive (02-04-2015), Raider (02-05-2015)
 Old 02-05-2015, 06:55 AM   #24
Bumping this. Is this finished/ready to update to 2015 standards? People please check and give input, too
 Old 02-06-2015, 12:04 PM   #25
OP updated!
 Old 03-17-2015, 09:54 AM   #26
okspeed's Avatar
Posts: 127   (View Stats)
okspeed has a reputation beyond reputeokspeed has a reputation beyond reputeokspeed has a reputation beyond reputeokspeed has a reputation beyond reputeokspeed has a reputation beyond reputeokspeed has a reputation beyond reputeokspeed has a reputation beyond reputeokspeed has a reputation beyond reputeokspeed has a reputation beyond reputeokspeed has a reputation beyond reputeokspeed has a reputation beyond repute
Is there a consensus on the best catted downpipe ie: best value/performance/build quality? Maybe Cobb quality but better price/value? Have internals and intake, looking for best all around downpipe setup with cat.
okspeed is offline   Reply With Quote
The Following User Says NO Thank You to okspeed For This Un-useful Post:
chaser27 (03-17-2015)
 Old 03-18-2015, 12:06 AM   #27
I have now included the TPs / RPs.
Like the Wiki and my other threads, the order is given in descending Genpu purchase order with the UR DP being the most popular choice and the others less so. I think this is the closest to a broad consensus as one will find. Whether one wants to argue that Genpus have learned from their predecessors is up to you.
With threads like this it is often asked, “Which is the best?” This is difficult to answer as some consider best quality at any price, personal preference / bragging rights / street cred (popular brand), best value (quality at a good price), popularity (local Nator), cheapest price, etc.
It may not give you a competitive edge choosing the most popular option, but it should allow you to compete.
 Old 03-17-2015, 01:39 PM   #28
theurgy's Avatar
My shortlist has always been Cobb, CP-e, and UR. But that's just me.
 Old 03-22-2015, 08:03 PM   #29
okspeed's Avatar
Anyone have any luck with the ebay/Amazon test pipes?
 Old 03-22-2015, 08:23 PM   #30
TurboSix's Avatar
Posts: 186   (View Stats)
TurboSix has a reputation beyond reputeTurboSix has a reputation beyond reputeTurboSix has a reputation beyond reputeTurboSix has a reputation beyond reputeTurboSix has a reputation beyond reputeTurboSix has a reputation beyond reputeTurboSix has a reputation beyond reputeTurboSix has a reputation beyond reputeTurboSix has a reputation beyond reputeTurboSix has a reputation beyond reputeTurboSix has a reputation beyond repute
Some people have better success than other with ebay. Guess its luck of the draw. But go do some research. You can find a lot of information by spending a little bit of time
2006 TGM MS6
HTP 3" | Corksport TBE | CP-E TMIC | JBR Boost Tubes | Autotech Internals | Freektuned | CP-E Rear Diff Mount | SURE Juggernaught | JBR RMM | CS TMM Insert | Damond SSP | JBR Shifter Bushings | Damond OCC | Damond Banjo Bolt | Block8head Vent Pod with Defi Red Racer Boost Gauge[/I]
TurboSix is offline   Reply With Quote
 Old 04-28-2015, 06:29 PM   #31
Porterhouse07's Avatar
Posts: 221   (View Stats)
Porterhouse07 has a reputation beyond reputePorterhouse07 has a reputation beyond reputePorterhouse07 has a reputation beyond reputePorterhouse07 has a reputation beyond reputePorterhouse07 has a reputation beyond reputePorterhouse07 has a reputation beyond reputePorterhouse07 has a reputation beyond reputePorterhouse07 has a reputation beyond reputePorterhouse07 has a reputation beyond reputePorterhouse07 has a reputation beyond reputePorterhouse07 has a reputation beyond repute
Groaned at 6 Times in 4 Posts
I just read all 8 pages and couldn't find what I'm looking for. Maybe my mind went numb from reading so much but....
I just got a deal on a CS catted DP with an 80mm flange. Is there any way to use this with the stock exhaust or do I need to leave the DP off until i can get an aftermarket CBE?
GT3071R | HTP 3" Intake | Magnaflow CBE | Grimmspeed EBCS | Bosch 3 Bar MAP | AP v3
CS HPFP Internals | CS Catted DP | CS RMM | TR6 FMIC w/ JBR Piping | HKS SSQV4 BPV
CS SSP | Swift Springs | DM Stage 3 OCC and PCV Plate | EBC Slotted Rotors w/ Yellowstuff Pads | NGK Iridium
Freektuned 350/365
Porterhouse07 is offline   Reply With Quote
 Old 04-28-2015, 11:29 PM   #32
I see you got a response to this question posed at: The Official Gen 1/2 Mazdaspeed 3 Intercooler Thread. Firstly, I assume that you are not talking about a full / long CS DP. Therefore, you need to transition from 80 to 65 to hook-up to the OEM. Most members buy a TP / RP for this purpose. You could stay with CS to ensure fit or have a local shop make this and at the same time look at a custom resonated version depending upon your taste (and neighbours or your empathy to your neighbours - lol). With CBE, most recommend a minimum of 73 throughout to not limit future BT installation.
 Old 04-29-2015, 04:27 AM   #33
That was a one off question that was off topic in that thread. Thought I'd put it where it needs to go. I just realized I put it in Gen 1 thread also but from what I understand, there is no difference. But I am talking about the long catted DP. Just trying to figure out what I need to do to go ahead and install the 80mm DP before I get a CBE
Freektuned 350/365
 Old 04-28-2015, 11:28 PM   #34
CleanMS3's Avatar
Posts: 27   (View Stats)
CleanMS3 has a reputation beyond reputeCleanMS3 has a reputation beyond reputeCleanMS3 has a reputation beyond reputeCleanMS3 has a reputation beyond reputeCleanMS3 has a reputation beyond reputeCleanMS3 has a reputation beyond reputeCleanMS3 has a reputation beyond reputeCleanMS3 has a reputation beyond reputeCleanMS3 has a reputation beyond reputeCleanMS3 has a reputation beyond reputeCleanMS3 has a reputation beyond repute
You can get a gasket that tapers down from 3" to oem
Sent from my SM-G925T using Tapatalk
CleanMS3 is offline   Reply With Quote
The Following User Says Thank You to CleanMS3 For This Useful Post:
SpencerC (04-29-2015)
 Old 04-29-2015, 02:49 PM   #35
SpencerC's Avatar
Posts: 2,159   (View Stats)
All you need is a gasket that fills the extra space from 80mm to 65mm. A donut gasket might work. It is difficult though to prevent it from leaking since it is a bottleneck there so the potential for air leaks is much higher.
jomatthe (02-02-2016)
 Old 04-29-2015, 03:29 PM   #36
Thanks for the input. Is that something I can pick up at a parts store or do I need to order it? I've seen it on your website But if I can get one locally, it would obviously be faster. I was contemplating having a shop fabricate a resonator delete pipe from the DP to the stock muffler.
Freektuned 350/365
 Old 04-29-2015, 05:16 PM   #37
SpencerC's Avatar
Some autoparts stores might have it, or an exhaust shop. Not sure what you mean fabricate a resonater delete pipe from DP to stock muffler... the DP if it is ours and 80mm has no resonater just a high-flow catalyst. If you delete that you are wasting the whole point of getting a high-flow cat in the first place, those reasons being no CEL, no smell, and backpressure acting how it is supposed to.
 Old 06-05-2015, 09:17 AM   #38
Rommel043's Avatar
Rommel043 is just really niceRommel043 is just really niceRommel043 is just really niceRommel043 is just really niceRommel043 is just really nice
my question is, will any 3" long downpipe mate right up to the stock catback exhaust or will i have to get a donut adapter?
Thanks fellas
Rommel043 is offline   Reply With Quote
 Old 06-05-2015, 04:52 PM   #39
aromig's Avatar
Posts: 289   (View Stats)
aromig is the leader of the worldaromig is the leader of the worldaromig is the leader of the worldaromig is the leader of the worldaromig is the leader of the worldaromig is the leader of the worldaromig is the leader of the worldaromig is the leader of the worldaromig is the leader of the worldaromig is the leader of the worldaromig is the leader of the world
Thanks fellas
If the catback side flange tapers to 65mm, you're good. If it stays 80mm/3inch all the way, it won't work unless you can rig it somehow. Personally recommend against that though.
"I apologize for nothing!" - Hedonismbot
aromig is offline   Reply With Quote
 Old 07-02-2015, 10:36 AM   #40
GregScuba's Avatar
Posts: 96   (View Stats)
GregScuba is the leader of the worldGregScuba is the leader of the worldGregScuba is the leader of the worldGregScuba is the leader of the worldGregScuba is the leader of the worldGregScuba is the leader of the worldGregScuba is the leader of the worldGregScuba is the leader of the worldGregScuba is the leader of the worldGregScuba is the leader of the worldGregScuba is the leader of the world
Not sure if this has already been mentioned, but I just stumbled upon this, and thought I'd throw it in the mix. Apparently Magnaflow makes a DP. No idea how it performs though.
Magnaflow/Catalytic Converter 51545 at AutoZone.com
nomorecivic! likes this.
2010 Liquid Silver Mazdaspeed 3
Cobb AP v3, tuning by Stratified Automotive Controls, Autotech HPFP internals, one step colder NGK Iridium plugs, Cobb DP, Magnaflow 3" CBE, Corksport SRI/TIP, Corksport Race RMM 80A, Synapse Synchronic DV in push mode A+B, Treadstone TR6 FMIC, JBR FMIC piping kit, JBR Silicone recirc hose, JBR rear sway bar, Bilstein B14 coilovers, SPC adjustable rear camber arms, Stoptech SS brake lines and brake pads, 17x9" et+45mm Enkei Racing RPF1's, 245/40/17 Hankook RS3's, JBR 5mm hub/wheel spacers in front.
GregScuba is offline   Reply With Quote
The Following 3 Users Say Thank You to GregScuba For This Useful Post:
Gitcherex (12-03-2015), Koke382 (07-02-2015), littleloogy (07-02-2015)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f505/official-downpipe-test-pipe-race-pipe-thread-99627/
catless downpipes cause turbo to blow seals?? - Page 4 This thread Pingback 11-10-2014 11:55 AM
Tuner/garage in Brampton/Mississauga area This thread Refback 08-02-2014 08:51 AM
Downpipe options - 2004 to 2014 Mazda 3 Forum and Mazdaspeed 3 Forums This thread Pingback 07-22-2014 10:53 AM
?????????? ?? ??????? 6 mps This thread Refback 02-15-2014 02:51 PM
Aide pour choisir downpipe - Mazda 3 Quebec This thread Refback 08-06-2013 07:10 AM
Mazdaspeed stage 2 downpipe vs racepipe This thread Refback 06-19-2013 09:31 AM
Cat'd DP? - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Refback 04-21-2012 07:39 PM
I HATE heat shielding. MPS 6 Post #6 Pingback 12-23-2011 02:44 PM
Which Race Pipe/Test Pipe is the best for a Mazdaspeed 6? ItalianSA MazdaSpeed 6 - Engine, Transmission & Driveline 6 04-20-2009 12:14 PM
Page generated in 0.95061 seconds with 45 queries
