![]() Join Date: Nov 2015
Rep Power: 0 ![]() ![]() Thanks: 3
(Thread Starter) | Not Ranked : 0 score Had an oil change 3 weeks ago and just added 3.5 qts of oil to get it back to the normal level. Has never been the case before except right before this change, so it seems like the oil consumption increase is new. Had the oil tested at blackstone about a year ago and everything was normal. Tested cylinder compression this fall (while replacing the spark plugs) and all 4 were in mid-70's psi. Did notice (I think unless it's phantom) a bit of a power loss maybe 6 months ago or so. The tail pipe is black, so it's burning through the oil. The oil is Castrol 03111 GTX High Mileage 10W-40 Synthetic Blend Motor Oil. Any ideas of what this could be? A turbo on its way out? The car is 2008 MS3 GT with 168k. thanks much. |
![]() Join Date: Jun 2009
| Not Ranked : 0 score You are allowing your car to get 3.5 quarts low on oil and are wondering what’s wrong? If static compression is only 70 psi across the board, you are way below the minimum. You are not going to fix this with a turbo. And, black exhaust is normal for direct injection engines. Sorry, but you need a new or rebuilt short block, or a low mileage used engine.
| The Following User Says Thank You to Roman-dude For This Useful Post: | MSMS3 (02-10-2020) |
As to why the loss, begin with a cylinder leak down test. Are you parking in the same place? Any oil on the floor or in the under tray? What does the bottom of the engine look like? Any visible signs of leaks? If no engine leaks and cylinder leak down is acceptable, then check for PCV valve function. Is there oil inside the intercooler and coupler hoses? Look there too. That might help isolate the cause. If the engine is not smoking and compression is good, your issue is likely minor.
Did not see any signs of oil previously but I'll take a closer look soon. As for not letting it get that far - totally with you. Checked oil 3 weeks after an oil change - never expected this to be the case. thanks again | |
| Not Ranked : 0 score have you checked if the oil filter isn't leaking or the pan plug ? something doesn'T start to act strangely without any direct action....If nothing else happened but an oil change and it start using oil, i would start looking there.... If you still have the creepy oem filter that driven many 2.3 engine (turbo and non turbo) to run out of oil, i would at least get a brand new plastic cap each 2-3 change and check around for oil leaks... If everything is ok there, i would then check turbo but....
On a related note, before I start searching - any way to test turbo without taking it off? | |
| Not Ranked : 0 score 3-4hr seem a bit high for the leak down....it is like replacing the spark plugs but with the added time to push air into each cylinders and rotating the crank pulley for each... I don't have exact numbers but i imagine it could be done in less than 2 hours...
https://www.pegasusautoracing.com/do...ocID=TECH00137 Considering that the leak down is a more precise version of the compression test, and my compression was ok, it seems I may not need to do the leak one. | |
You would do well to have that test done. It will help diagnose the possible source of your oil consumption.
| The Following User Says Thank You to MSMS3 For This Useful Post: | Jeff23spl (02-11-2020) |
| Not Ranked : 0 score both are similar. leakdown call for a little more work by getting access to crank pulley to set piston position and held it....you use a little more complex gage and use compressor air instead of cranking... but, overall, work remain basic. Maybe there is some with more complex way of doing it??? Anyway, yes if compression is good, leak down should usually not return bad results but sometimes oil can increase compression reading while leakdown will point out problems....And also with low compression, leakdown will help figure out where the leak is coming from... that would be much different from cars models. if you have a V engine with hidden plugs, it would get a lot longer to reach than on a dohc 4cyl engine with plugs right on top....
__________________ Mazda for life...or until i can afford something better... 2007 rusted Speed6... Forged with meth and a 3076 in progress... 1993 Ford Probe KLZE 143dB 2012 Mazda3 Gs-sky 6.5l/100 when transporting speed parts 1989 GM 6.2 diesel pickup Wife drive 2010 CX7 2007 speed3 burned (i'm proud to ran 12.7s with it) ...Because French Canadian... If you check for leaks and you didn't made a test under compressor pressure, you aren't done checking for leaks.... Last edited by Jeff23spl; 02-11-2020 at 10:34 AM. Reason: MSF Database - Automerged Doublepost |
| Not Ranked : 0 score Listening to where the compressed air escapes can be very useful in locating the source of a leak - cylinder head valves or seals versus the piston rings. Your oil is going somewhere. Did you check to see if you had oil in your intercooler or the couplers? It’s normal for there to be a little, but it should not be pooling up.
Do these diagnostics in whatever order you want, but you are going to need that leak down test. You lost 3.5 quarts of oil in only three weeks. It’s going somewhere. I did not ever get a clear answer about physical leaks. I know you don’t see any. Can you remove the bottom tray or apron and look under there. A bad leak should find its way to the ground, but that treat/apron can hold a lot of oil. I also don’t recall you saying whether the car is smoking and what color the smoke is, if present. That would help.
As for smoking, had a coworker follow me for a few minutes. Supposedly there was a bit of a plume (but not dark) right after I took off but not much after. He's not a car guy, though, so this may be less than very accurate. Will have someone who knows trail me on Sat. thanks! | |
| Not Ranked : 0 score checking charge pipe is pretty easy, It could be a bit sticky on the side like dirty and this is about normal with a k04 but if you have liquids dripping out, it isn't. And looking 3.5quart for 5000 miles is enough to drip out if going there... but then, if there is oil there, you will still have to narrow out the source...
(Thread Starter) | Not Ranked : 0 score Also, still no visible leaks and no oil in the coolant reservoir. Also, not sure if it's related but P0300 started popping up. Used to happen on occasion in the past but has not since I swapped out the plugs. |
![]() Join Date: Sep 2018 Location: Bonney Lake, WA
Rep Power: 0 ![]() Thanks: 1
| Not Ranked : 0 score Sorry to thread jack but this sounds identical to my situation. Random misfit code, and oil consumption . My compression test was 180/180/160/180. Not great, but also not terrible. No smoking at idle, no oil in intercooler running 5w-40 with a Damond banjo bolt. I just changed my PCV too. Pretty frustrated tbh |
Rep Power: 3745 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,744
__________________ Having trouble finding something on MSF? Use MS3Shadow's search tool:SEARCH MSF HERE! | |
| Not Ranked : 0 score |
(Thread Starter) | Not Ranked : 0 score So the compression test came back with near 190 on 3 and mid-180 on the other one, so the engine is fine. There was oil in the hose leading into the intercooler, so looks like the turbo. Additionally, the gaps increased on the plugs since I put in the new ones 10k or so ago, which is probably why it kept throwing the P0300 misfire last few days and then also p2177 and p2187 "too lean" codes yesterday. With the gaps tightened, the codes are off and no more rougher idle. But I do need to have a new turbo put in. A quick look on ebay showed one for $380, or the bnr for 425 + core and shipping. Honestly, don't know if BNR is worth it since I will be looking to sell the car anyway, just don't want to sell one with an issue. Also, there are some for under $200 but my gut is telling me to stay away from those. Tried a quick search for some turbo list on the forum but no dice. Anyway, sorry for rambling on, any advice etc is welcome. Thanks. |
![]() | | #24 | ![]() |
(Thread Starter) | Not Ranked : 0 score oh, I am looking to have the shop do it, what else do I need to buy besides the turbo? I mean, I am going to look into that but it would be great to hear from those who know. thx |
| Oil Consumption, No Smoke - Rings? Thoughts? | BBSpeed26 | 2010 MS3 - Troubleshoot/Diagnostics | 4 | 05-02-2018 09:51 PM |
| Oil consumption PLEASE HELP | ms6tats | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 15 | 12-27-2016 10:56 PM |
| Serious oil consumption | Tiner | MazdaSpeed 3 - Engine, Transmission & Driveline | 3 | 07-31-2016 07:50 PM |
| Oil Consumption | Big Dog | Mazdaspeed3/6 General Discussion | 0 | 01-21-2015 11:47 AM |
| oil consumption?? | MS6Blaze | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 6 | 02-13-2014 07:19 PM |
