 Old 10-07-2012, 08:57 PM   #1
itsstock02's Avatar
Posts: 132   (View Stats)
itsstock02 has a reputation beyond reputeitsstock02 has a reputation beyond reputeitsstock02 has a reputation beyond reputeitsstock02 has a reputation beyond reputeitsstock02 has a reputation beyond reputeitsstock02 has a reputation beyond reputeitsstock02 has a reputation beyond reputeitsstock02 has a reputation beyond reputeitsstock02 has a reputation beyond reputeitsstock02 has a reputation beyond reputeitsstock02 has a reputation beyond repute
Default OTS AP tune with catless DP?
Will an OTS Stage 2 tune work fine with an catless DP? I just dont want to have a CEL on.
MS6 GT, TWM shifter, 5% tint
2002 Mustang GT, Saleen Series IV supercharger
1995 Saturn SL2, turbo, MS1, shit getter
itsstock02 is offline   Reply With Quote
 Old 10-07-2012, 09:00 PM   #2
Dmurray06's Avatar
Posts: 3,279   (View Stats)
Groans: 189
Yes
 Old 12-15-2012, 01:53 PM   #3
Spectrum24x's Avatar
Posts: 276   (View Stats)
Spectrum24x has a reputation beyond reputeSpectrum24x has a reputation beyond reputeSpectrum24x has a reputation beyond reputeSpectrum24x has a reputation beyond reputeSpectrum24x has a reputation beyond reputeSpectrum24x has a reputation beyond reputeSpectrum24x has a reputation beyond reputeSpectrum24x has a reputation beyond reputeSpectrum24x has a reputation beyond reputeSpectrum24x has a reputation beyond reputeSpectrum24x has a reputation beyond repute
I'm about to run the same, any concern of boost creep?
2007 TRUE RED MS3 GT
RX-8 WHEELS/DRILLED & SLOTTED ROTORS
KONI YELLOW/COBB SPRINGS/JBR RSB/HOTCHKIS FSB
COBB OTS STAGE 2 MAP
RMM/COBB INTAKE/COBB TIH/ETS TMIC
OBX TEST PIPE/AUTOTECH INTERNALS/FORGE BPV V2
Spectrum24x is offline   Reply With Quote
 Old 12-15-2012, 01:55 PM   #4
boostdmazda3's Avatar
Posts: 1,177   (View Stats)
boostdmazda3 is the leader of the worldboostdmazda3 is the leader of the worldboostdmazda3 is the leader of the worldboostdmazda3 is the leader of the worldboostdmazda3 is the leader of the worldboostdmazda3 is the leader of the worldboostdmazda3 is the leader of the worldboostdmazda3 is the leader of the worldboostdmazda3 is the leader of the worldboostdmazda3 is the leader of the worldboostdmazda3 is the leader of the world
with a downpipe always get a custom tune.
Bnr s3/Act 6 puck/sure full 3inch intake/cobb fmic/cobb downpipe/grimmspeed ebc/3 bar map/hks catback/autotech hpfp internals/turbosmart bpv/bc coilovers/jbr trilogy mounts/ngk one step colder plugs/ms6 rims on nt-01 tires. 24 psi E85 freektuned.
Freektuned e85 Focus st as the daily.
boostdmazda3 is offline   Reply With Quote
 Old 12-15-2012, 02:15 PM   #5
ms3rick's Avatar
Posts: 2,959   (View Stats)
you can disable the cel in ATR, google msf search for the correct codes to uncheck =)
Sold:
2010 MS3 siLver.
Official 60-100mph Times
Official Video battles
Official Youtube Channels
The Following User Says Thank You to ms3rick For This Useful Post:
simply_pandora (12-16-2012)
 Old 12-15-2012, 02:21 PM   #6
Don't most downpipes have the extra o2 bung further back to avoid the CEL?
 Old 12-16-2012, 03:54 PM   #7
Chicagospeed6's Avatar
Posts: 445   (View Stats)
Chicagospeed6 is the leader of the worldChicagospeed6 is the leader of the worldChicagospeed6 is the leader of the worldChicagospeed6 is the leader of the worldChicagospeed6 is the leader of the worldChicagospeed6 is the leader of the worldChicagospeed6 is the leader of the worldChicagospeed6 is the leader of the worldChicagospeed6 is the leader of the worldChicagospeed6 is the leader of the worldChicagospeed6 is the leader of the world
I have a m2 downpipe and never got a check engine light. I did overboost with the stage 2 ots. I believe it targets 17.5 lbs and I was getting 19.5. I contacted tuner and he gave me a base map until I got fully tuned.
Tapatalk
Some dude has my car!
Chicagospeed6 is offline   Reply With Quote
 Old 12-16-2012, 07:39 PM   #8
Coaststarlight's Avatar
Posts: 296   (View Stats)
Coaststarlight is the leader of the worldCoaststarlight is the leader of the worldCoaststarlight is the leader of the worldCoaststarlight is the leader of the worldCoaststarlight is the leader of the worldCoaststarlight is the leader of the worldCoaststarlight is the leader of the worldCoaststarlight is the leader of the worldCoaststarlight is the leader of the worldCoaststarlight is the leader of the worldCoaststarlight is the leader of the world
Just remember to Log your data and keep an eye on your car's motor, thats you biggest respons ability
Long Block Built by GPwerks and Loose Screw Motor Sports
https://www.gp-werks.com/
http://www.crossoverauto.com
^Any Parts, Great Prices^
Coaststarlight is offline   Reply With Quote
 Old 12-16-2012, 08:29 PM   #9
BlueDmnSpeed's Avatar
Posts: 1,129   (View Stats)
yes that map will be fine to begin with. but you will need to get a custom tune as the OTS maps are just baselines and should be more customized to your setup. @RichieRichness refer to him or one of the other e-tune guru's on here
RichTuned
BlueDmnSpeed is offline   Reply With Quote
The Following User Says Thank You to BlueDmnSpeed For This Useful Post:
RichieRichness (12-17-2012)
 Old 12-17-2012, 08:22 AM   #10
RichieRichness's Avatar
Posts: 3,314   (View Stats)
Groans: 35
CEL's are just a fact of life once you start modding. We can't promise that you won't get a CEL from a DP however, AS @ms3rick said, just turn the CEL off in ATR. Or get a tune and your tuner will work through this.
RichieRichness is offline   Reply With Quote
The Following User Says Thank You to RichieRichness For This Useful Post:
ms3rick (12-17-2012)
 Old 12-17-2012, 05:04 PM   #11
So with the CEL turned off in atr will the car pass inspection?
 Old 12-17-2012, 05:22 PM   #12
ms3rick's Avatar
^ no
Sent from my dizzLe using RaWr powers!
Sold:
2010 MS3 siLver.
 Old 12-18-2012, 09:10 PM   #13
Originally Posted by ms3rick View Post
^ no
Hmm. Then I may have a catless downpipe to put up for sale bc I don't want to have to change it every year for inspection...
 Old 12-18-2012, 09:12 PM   #14
senor blanco ms3's Avatar
Posts: 1,353   (View Stats)
senor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the world
yes, it will. my code has been disabled since last july.
2008.5 Crystal White Pearl MS3
A lot of mods
Check out my big turbo build!
senor blanco ms3 is offline   Reply With Quote
 Old 12-18-2012, 09:31 PM   #15
faeker's Avatar
Posts: 5,091   (View Stats)
Groans: 731
turning off the cel in atr doesn't make the cel magically disappear. it just keeps our light from turning on. It's still being set off as far as the ecu can read. most emission tests will allow 1 fail of 3. I always let my DP one go because fuck laying on my back to change it out. The other two, egr and evap, should be fine to pass. having said that part; please search the forums. This question has been asked multiple times and the answer has yet to change.
Edit: saw this was my 1000th post and i'll be damned if it's too nice.
hey asshole, fucking search the god damn forums harder. if you think you searched and couldn't find an answer, you didn't fucking search enough threads. downpipe questions are as common as fucking bpv questions and sri questions. seeing these threads every 2 days is getting old really god damn fast.
now, if you're butt hurt from that just read the first part of my post and ignore the last part. fag.
Mods: stock
Pointless (12-19-2012), rolanblack (12-22-2012)
 Old 12-18-2012, 09:41 PM   #16
not sure if there's a difference but mine was disabled by a tuner with atr pro
A lot of mods
 Old 12-18-2012, 09:42 PM   #17
Karmat's Avatar
Posts: 1,179   (View Stats)
I run some anti-foulers on my 2nd O2 sensor with the M2 catless pipe and have no CEL.
2002 Corvette Z06 (Black)
 Old 12-19-2012, 09:40 AM   #18
SparkySparks's Avatar
Posts: 1,314   (View Stats)
Gen1 you can run the anti-foulers but Gen2 you will get a CEL for the second O2. I've had my catless CNT DP for about a month and no CEL for not having cats.
On Order:
Coming Soon:
DIY Projects:
 Old 12-22-2012, 08:09 PM   #19
rolanblack's Avatar
Posts: 2,110   (View Stats)
You have a gen1 ms6, i doubt you will pull a cel. If you do, reset it with the AP and if it comes on then go to a muffler shop and get a longer bung made for you 02 sensor. Worked for others
The Following User Says Thank You to rolanblack For This Useful Post:
BrianB6 (12-22-2012)
 Old 09-19-2017, 04:58 AM   #20
louis's Avatar
Posts: 3   (View Stats)
louis has a little shameless behaviour in the past
Do i need a map to not have problems with a down pipe? Cobb tells me I need a cat or else
Sent from my SM-G930W8 using Tapatalk
louis is offline   Reply With Quote
The Following 2 Users Say NO Thank You to louis For This Un-useful Post:
mituc (09-21-2017), Vansquish (09-19-2017)
 Old 09-19-2017, 06:33 AM   #21
Police - Grammarhead
Vansquish's Avatar
This question has been answered many times in the five years since this thread was last updated.
Try searching a little more.
You also need HPFP internals to safely use an aftermarket downpipe without risking blowing your motor.
 Old 09-19-2017, 06:48 AM   #22
louis's Avatar
My concern is I have all of that but the only thing different that I have is a catleas down pipe. Cobb said I might to damage if I don't add a cat
 Old 09-19-2017, 07:04 AM   #23
danb's Avatar
Posts: 176   (View Stats)
danb has much to be proud ofdanb has much to be proud ofdanb has much to be proud ofdanb has much to be proud ofdanb has much to be proud ofdanb has much to be proud ofdanb has much to be proud ofdanb has much to be proud ofdanb has much to be proud ofdanb has much to be proud of
before anything check and get HPFP. Youd be best off getting a pro tune... an ots+ tune thru Freektune is only around 100$. other tuners have them too.
Start researching more, contact a e tuner and do it right before you blow it up.
use this to search---
https://cse.google.com/cse/publicurl...1oxu#gsc.tab=0
good luck
2007 speed3 GT. cobb rmm, JbR pmm, Corksport adjustable shifter, twm solid shifter bushings, Sure shift knob, AP3, Autotech, CS turbo, CS occ, HTP 3.5, Depo catless dp, TS Kompact bpv, CS 3port, cpe BlockD, GA V3, DO DVC-30, Cx racing piping, tr1035.. Freektuned
2011 mazda 6
danb is offline   Reply With Quote
The Following User Says Thank You to danb For This Useful Post:
 Old 09-19-2017, 07:56 PM   #24
louis's Avatar
good luck
Thanks. There to many mixed messages. Some say it will be fine some say don't do it just a cat
Problem. Without meth tune is great. On Meth tune shits the bed. dsmluck MazdaSpeed 3/6 - ECU Computer Tuning 16 09-06-2011 06:58 PM
Page generated in 0.42566 seconds with 36 queries
