 Old 04-22-2018, 02:19 PM   #1
jmwatts's Avatar
Posts: 2   (View Stats)
jmwatts will become famous soon enough
Default P0113 after intake clean
I just finished an intake port cleaning and put everything back together (or so I thought). It starts but will die at idle, but will keep running (roughly) if I keep revs above 2k. The code it throws is P0113. Interestingly, at first I had forgotten to plug in the MAF sensor, however it seems to run better with that disconnected. I figure I must have forgotten a hose or sensor somewhere, any clue where to start looking?
thanks
mike
jmwatts is offline   Reply With Quote
 Old 04-22-2018, 04:15 PM   #2
JSmith's Avatar
Posts: 707   (View Stats)
Groans: 106
A bit of light reading for you. LMGTFY
 Old 04-22-2018, 07:22 PM   #3
jmwatts's Avatar
Sorry, should have mentioned I had already checked all the obvious. Turns out I had forgotten the little rubber gasket under the inlet manifold vacuum chamber.
The Following User Says Thank You to jmwatts For This Useful Post:
JSmith (04-23-2018)
Getting P0113 code after removing intake, help please fultobt MazdaSpeed 3/6 - Troubleshoot/Diagnostics 4 09-09-2016 10:46 AM
Valve clean, showing P0113, P0328, P2119, P0193 and more Mattyhawk1 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 10 08-10-2015 10:38 PM
Using heat to clean intake valves? sidekick Mazdaspeed3/6 General Discussion 7 10-02-2014 09:46 PM
HELP!!!! P0113 CEL chintastic 2010 MS3 - Troubleshoot/Diagnostics 1 12-01-2011 03:12 PM
How The Fuck To Clean The Valve Intake the_rolex_guy MazdaSpeed 3/6 - ECU Computer Tuning 7 07-21-2011 05:28 PM
Page generated in 0.24317 seconds with 21 queries
