 Old 05-17-2019, 10:45 AM   #1
memin's Avatar
Posts: 994   (View Stats)
Default power window issue
So, I have a 2006 Mazdaspeed 6 and some reason I cannot roll down the rear driver window all way down or up. No matter witch control I used The window just move about 6 inches in either direction and stop.I already disconnected the battery with no luck, Does anyone one has a idea of what is the problem?
 Old 05-17-2019, 05:03 PM   #2
Fstrnyou's Avatar
Posts: 2,498   (View Stats)
Making any noises?
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
 Old 05-17-2019, 08:19 PM   #3
mazda62006's Avatar
Posts: 65   (View Stats)
mazda62006 is a splendid one to beholdmazda62006 is a splendid one to beholdmazda62006 is a splendid one to beholdmazda62006 is a splendid one to beholdmazda62006 is a splendid one to beholdmazda62006 is a splendid one to behold
If it is making noise, like a clicking noise it could be one of the gears in the window motor. Well not really the motor but part of the motor assembly.
mazda62006 is offline   Reply With Quote
 Old 05-17-2019, 08:28 PM   #4
SSinstaller's Avatar
Posts: 3,989   (View Stats)
Groans: 60
Regulator is probably bad. Time to replace it.
 Old 05-17-2019, 09:00 PM   #5
memin's Avatar
it just double click like when the window reach it limits.
 Old 05-23-2019, 09:21 AM   #6
shawnmos's Avatar
Posts: 60   (View Stats)
shawnmos is a jewel in the roughshawnmos is a jewel in the roughshawnmos is a jewel in the rough
The motor is encountering too much resistance. Most likely the motor itself is bad.
2008 Mazdaspeed 3
2010 Mazda 5
shawnmos is offline   Reply With Quote
 Old 05-23-2019, 11:25 AM   #7
Posts: 2,235   (View Stats)
open the door trim and look at window linkage, the mecanism could be corroded or broken....Sometimes it comes with the motor and sometimes it is 2 separate parts that can be replaced separately if you cannot just clean and grease it.
Power window issue?? Reap3rVIRUS MazdaSpeed 3/6 - Troubleshoot/Diagnostics 36 09-11-2018 03:20 PM
Power window issue '13 tech package joshalabama 2010 MS3 - Troubleshoot/Diagnostics 7 02-12-2014 08:32 PM
Power window issue doctavus Gen2 MS3 General Discussion 9 02-12-2014 10:46 AM
MS6 Power Window Issue melly mel MazdaSpeed 3/6 - Car Audio & Electronics 6 03-23-2013 02:58 PM
Window issue 2006MS6 MazdaSpeed 3/6 - Car Audio & Electronics 5 07-11-2011 06:21 AM
Page generated in 0.27742 seconds with 25 queries
