Groans: 433
(Thread Starter) | Not Ranked : 0 score Let this be the beginning. I have 2 so far that I need to add. Potentially a third.
| The Following User Says Thank You to Chimmike For This Useful Post: | TiGraySpeed6 (09-17-2012) |
![]() Join Date: Apr 2009 Location: near the springs, co
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 44
| Not Ranked : 0 score AC compressor didn't fit |
| Not Ranked : 0 score I have found a few times where parts listed for my Speed6 is wrong on Rock Auto because for some dumb reason, a lot of parts were listed to work with 2.3L motor and Mazdaspeed MZR even though this isn't right. I mean, the parts sort of fit, but they are different enough to be a PITA; In other words, the part will fit and not leave you stranded, but its just different enough to cause the OCD in you to flare up. A lot of part manufacturers must have assumed the 2.3L and MZR are basically one in the same and didn't do a lot of research. Specifically for me, the thermostat and radiator. The thermostat on the 2.3L has a longer neck, by about 1.5" then my MS6. The MS6 neck is shorter to clear the power steering hose. The longer neck does fit and will work, but the power steering hose has to be scooted over a bit. The supposed MS6 drop in radiator from them has different lower mounts and the auto trans cooler hookups. I massaged it to work because I was in a pinch, but I will eventually get my stock radiator repaired and reinstalled. |
![]() Join Date: May 2011 Location: Greenville, SC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 58
Groaned at 6 Times in 3 Posts
| Not Ranked : 0 score Blower motor for MS6 doesn't fit. They list it under "2.3L L4 Turbocharged", but it's definitely not a match.
__________________ 2007 Speed6 GT - LPM RMM 88 | JBR SSP, SSB & Heavy Knob | NGK Iridiums | Cobb AP SURE Full3 3" Aeros | M2 Downpipe | Autotech Internals | Forge BPV MagnaFlow CBE | SURE Dreadnaught / Juggernaught | Whiteline RSB | H&R Sports E85 Stratified |
| Not Ranked : 0 score I'll see if I can look up some of the bad part numbers tomorrow, but last I looked, only one passenger side front cv axle, out of 6 different axles, both pass & drivers side, actually fits the speed6. I also have the specs, dimensions & such that I'll add to feed the search engines and help folks be able to identify speed6 axles from 2.3 na axles which are much smaller
![]() Join Date: Nov 2009 Location: Dallas, Texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 31,116
Groans: 549
| Not Ranked : 0 score i bought two rear ABS sensors. they both fit. in fact, they say "fomoco" on them. however, i think one is broken. i'm still working on determining that, though...
__________________ it's fun to do bad things |
| Lol someone in SoCal Nator was just pointing to me about this $63 axle they wanted to buy from them.. I hope they see this thread.
![]() Join Date: Nov 2010 Location: Murrieta, CA
Rep Power: 1393 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14,136
| Not Ranked : 0 score Yes I see this thread lol. I ended up just buying a OEM axel
__________________ 2009 CWP Speed3 |
![]() Join Date: Dec 2008 Location: VA Beach
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 930
| Not Ranked : 0 score Rock auto is an awesome site for parts, but I always reference the part number to a regular 2.3l before I purchase from them though. I wouldn't be suprised if 20% of the parts listed for our cars didn't fit.
__________________ 06 Speed 6 GT: True twin scroll T4 PTE Billet 6262, dual MVS, SP 10.6:1 pistons, K1 rods, sleeved block... 08 Speed 3|SOLD |
| Not Ranked : 0 score Rock Auto- MS6 axle listing has been improved, but still not perfect. At least it's better than it was. Only a single CV appears to be incorrect. I can guarantee that Cardone # 608190 is correct, that one was in my car for a couple of months till the rebuild failed- just lucky there. They're usually not bad. It's reasonably safe to "assume" the rear axles would be right, the application shows '06 & '07 only, and hey, they're rear axles.... The first one in the list is certainly incorrect (MZ8338A), and is used as an example of what to watch out for in the pics below. The entire list- much shorter than it used to be: See anything amiss with this application list? Here's a good application list: Mazdaspeed6 Front CV Axle specs compared to the N/A 2.3 CV axles: Dimensions: The Speed6 axles have a much larger nut, 35mm -vs- 32mm, on the splines/hub side. This is the one I've been using a 36mm socket on, by mistake apparently. This nut size can also be referred to as M24-1.5 on the Speed6, and as M22-1.5 for the smaller NA axle. Spline section diameter on the speed6 is 32.5mm, and is only 29mm on the NA axle. Passenger side is also longer for the Normal 6 2.3, since there is no PTO to deal with - top is the Speed6, bottom is normal 6 passenger side
| The Following User Says Thank You to TiGraySpeed6 For This Useful Post: | manu (11-14-2016) |
![]() Join Date: Jul 2012
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() Thanks: 21
| Not Ranked : 0 score Exedy Clutch kit doesnt fit. |
![]() Join Date: Jan 2013 Location: Waltham , MA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7
| Not Ranked : 0 score Does anyone know if the ball joint moog MDBJ4869 they offer for the speed fits? Or the DEEZA Part # MDH201—
__________________ 2007 Mazdaspeed GT Autotech Internals :Mazdaspeed cold air intake v2 : Corksport TIP : Cobb Accessport : Turbo XS Hybrid BOV cuz pssshhhhhhhhhhhh : Corksport RMM :Corksport Testpipe: JBR Shifter Bushings: Homedepot special OCC : Koni Yellows : Cobb rear sway bar : Resonator delete : Rallyarmor Mudflaps cuz rally car Last edited by lopezsr20; 03-29-2013 at 02:32 PM. |
![]() Join Date: Mar 2009 Location: Coventry, Rhode Island
Rep Power: 0 ![]() ![]() ![]() ![]() Thanks: 0
| Not Ranked : 0 score I ordered a cabin air filter last week for my speed 6. I received it today and it did not fit. |
| Not Ranked : 0 score What's the part number for the filter which doesn't fit?
Rep Power: 3167 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,400
Groans: 221
| Not Ranked : 0 score Strut mount kit for the 3 - Mevotech MS76201 does not come with the strut boot and bump stop, even though it shows both of those in the pictures. More Information for MEVOTECH MS76201 Details
![]() Join Date: Apr 2013 Location: Arkansas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 99
| Not Ranked : 0 score The shaft pivot seal doesn't fit, too big in diameter. I just re-used the old seal but took the spring ring (or whatever its called) out of the new seal and put it in the old one. Been about two weeks and no leaks
__________________ 06 MS6 GT // PTE 6266 GEN2 // Kozmic 6th Port Inj. 1200cc // Weisco Pistons (0.020 over) // Manley H+ Rods // JDM Sport EM // Tial 38mm EWG // SP63 Keyed & Polished Crank & Sprockets // 4" WPI // P&P IM // Cobb AP // Custom DP CP-E Safe Seals // CP-E Rear Diff Mount // Bosch 3.5 BAR // Sure ShortCut // TWM Shift Knob // AutoTech HPFP internals // H&R Springs // DRAG DR-34 +35mm // CS2 Front Lip // CX Racing Air to Water IC // Custom Matt Damond Dual OCC HTP Small Batt Tray // SP63 EBCS // HKS BOV // Kozmic Oil Feed Line // JBR EGR block off // JBR BSD // JBR Counter-weight // NGK // DW 65c ITFP // JBR PMM // JBR SSB // SU RMM // Corksport TMM Insert // FREEK Tune in progress 305/364 (K04) // 367/387 (2871r) 454/417 (PTE6262 R.I.P) |
| Not Ranked : 0 score Can you post the part number you ordered from RA, or any other details? Knowing RA, they have some that do fit & some that don't so any details you can provide on what didn't work would be great!
There was only one shift shaft seal that came up for the 06' ms6. The seal didnt fit no matter how hard I tried. Seal is slightly too big for housing. Also the new seal wasnt as thick as OEM
__________________ 06 MS6 GT // PTE 6266 GEN2 // Kozmic 6th Port Inj. 1200cc // Weisco Pistons (0.020 over) // Manley H+ Rods // JDM Sport EM // Tial 38mm EWG // SP63 Keyed & Polished Crank & Sprockets // 4" WPI // P&P IM // Cobb AP // Custom DP CP-E Safe Seals // CP-E Rear Diff Mount // Bosch 3.5 BAR // Sure ShortCut // TWM Shift Knob // AutoTech HPFP internals // H&R Springs // DRAG DR-34 +35mm // CS2 Front Lip // CX Racing Air to Water IC // Custom Matt Damond Dual OCC HTP Small Batt Tray // SP63 EBCS // HKS BOV // Kozmic Oil Feed Line // JBR EGR block off // JBR BSD // JBR Counter-weight // NGK // DW 65c ITFP // JBR PMM // JBR SSB // SU RMM // Corksport TMM Insert // FREEK Tune in progress 305/364 (K04) // 367/387 (2871r) 454/417 (PTE6262 R.I.P) Last edited by spd6demon; 07-31-2013 at 09:19 AM. | |
| The Following User Says Thank You to spd6demon For This Useful Post: | TiGraySpeed6 (07-31-2013) |
![]() Join Date: Mar 2012 Location: Middletown, CT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 84
Groaned at 7 Times in 5 Posts
The radiator doesn't fit. The brackets for the fans are all wrong and one of the hose fittings on top is different. It would be nice if it did fit since RA's is $119 and the only other place I could find one was OEM at $350 I also bought a PCV valve from them and the jury is still out on its functionality. Last edited by Mandinca; 08-01-2013 at 01:18 PM. Reason: MSF Database - Automerged Doublepost | |
| Not Ranked : 0 score My friend actually ordered it for me. Didn't think rock auto's would be different. Guessed wrong lol.
![]() Join Date: Sep 2008 Location: Clayton, NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 33
| Not Ranked : 0 score Fel-pro donut exhaust gasket fits but isn't thick enough to make a seal.
__________________ 2008 CBM MS3 CP-E RMM | JBR 3.5" WP | GTX3071R | JBR OCC + IM TIG | SU TMIC | Turbosmart Compact BPV | Autotech Internals | Cobb AP + TBE + EBCS | NGK 1 Step Colder | TWM Shifter | Hotchkis Sways | Bilstein Sports | Swift SPEC-Rs | SPC Camber Arms | Freektune |
![]() Join Date: Mar 2008
| Not Ranked : 0 score I ordered the LUK clutch kit and it fit fine, I also ordered two axles that fit fine to. I ordered two front bearings with hubs and they did not fit. Bearing with Hub: PRECISION AUTOMOTIVE 513211 - Did not fit. Clutch Kit: LUK 10064 - Fit Axle: EMPI 803952 - Fit Axle: EMPI 803957 - Fit Clutch Slave Cyl: WAGNER SC143568 - Fit
__________________ 07 Cosmic Blue Speed 3, BNR S2 Turbo Cobb AP BEGI SRI CNT Catted Downpipe Forge BOV CorkSport Turbo Inlet Pipe / Silicone BPH / Boost Tubes / Dry Flow Air Filter Fidanza Aluminum Flywheel CPE Xflex Stage 2 Driver Side MM CPE Xflex Stafge 2 Rear MM AWR Passenger Mount 88 Duro Power Slot Rotors Last edited by Rcimp; 01-23-2014 at 06:53 AM. Reason: MSF Database - Automerged Doublepost |
![]() Join Date: Apr 2011
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 346
I also called EMPI and about 5 months ago they were working on tooling for the passanger side, guy said new tooling takes between 5-6 months to perfect.
__________________ Velocity Red Mica 06 Speed6 (ricer) #834 Some shitty; s300sx fmw turbo, home made fmic setup, home made 4" Intake, 3.5 blowthrough maf, home made downpipe, poorly self tuned. More motor mounts then necessary. Gay and coated white enkei rpf1s with stupid 245/45 tires. Pointless drilled and slotted rotors. Clunky coilovers. Ricer lips and lights. | |
| The Following User Says Thank You to madspd6 For This Useful Post: | Guano5150 (07-25-2016) |
![]() | | #24 | ![]() |
![]() Join Date: Jul 2013 Location: Rosamond, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 70
| Not Ranked : 0 score Radiator was mentioned. Of course, this will include the drain plug. Thread is too small to fit oem radiator Sent from my SM-N900T using Tapatalk |
![]() | | #25 | ![]() |
![]() Join Date: Jun 2014 Location: Alberta, Canada
Rep Power: 0 ![]() Thanks: 3
| Not Ranked : 0 score I got the engine gasket set, 4 exhaust valves and a pcv valve from them and I havnt had any issues except a minor seaping around the valve cover that I attribute more to the some rusty (+1 missing/snapped) cover bolts. So far I guess i was lucky ![]() Anyone know about the rack and pinion boots? Last edited by arias valentia; 09-24-2014 at 06:47 PM. |
![]() | | #26 | ![]() |
![]() Join Date: Oct 2011 Location: brooklyn, ny
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 240
| Not Ranked : 0 score Has anyone ever tried the oxygen sensors for the speed 6? I might need one and wanted to know if they are the right part. |
![]() | | #27 | ![]() |
![]() Join Date: Oct 2014
Rep Power: 0 ![]() Thanks: 0
| Not Ranked : 0 score Ngk 02 sensors should be ok but the dorman intake manifold runner control or ebcs has the wrong male pluge |
![]() | | #28 | ![]() |
![]() Join Date: Aug 2012 Location: Mundelein, IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 322
| Not Ranked : 0 score The ngk/ntk o2 sensor part number 24357 worked perfectly for my 08 speed 3. They list part number 24354 for the speed 6. I am not sure if the connectors are different between the 2 cars but this is probably why it has a different part number. If it is pictured with the heat shield it should be the one you want.
__________________ The Car - 08.5 True Red MS3 GT - MODS -Cp-e nano sri, HTP 3" tip, Autotech internals, Custom fmic 28x8x3.5 cx core, Cobb ap, Autolite XP5263, Turbo_Steve SHIFT HAMMER SSP, TRZ rear mount. Atp Downpipe and custom catted mid pipe. JBR TIG, tb gasket & egr delete, XS POWER V2 turbo manifold, Aem 30-3000 WMI Kit, Ported intake By Turbo_Steve. ADAPTED PERFORMANCE SHIFT HAMMER SSP - ADAPTED PERFORMANCE ENGINE COVERS Soon to come. WHO KNOWS? A.D.D. FTW! |
| The Following User Says Thank You to Turbo_Steve For This Useful Post: | cshunter (10-29-2014) |
![]() | | #29 | ![]() |
![]() Join Date: Nov 2014 Location: Geneva, IL
| Not Ranked : 0 score I overhauled most of the suspension on my MS6 last summer with rockauto parts. Only a few parts gave me problems. The Beck/Arnley rear lateral links don't fit a MS6. The part number is 1016605. I'm not sure about the Mevotech or Moog lateral links, but with the Beck/Arnley ones I could not adjust rear toe at all. The Beck/Arnley control arms fit. I've had them on my car for over a year and haven't had a problem with them. These are the part numbers: Rear upper CA's - 1017042 Front upper CA's - 1015535 (Left) / 1015534 (Right) Front lower rear CA's - 1015533 (Left) / 1015532 (Right) For the Front lower front CA's, I bought Dorman #520809 which fit perfectly and have held up well. KYB Strut mounts #SM5540 fit but after about a month they began making noise, so I would avoid these.
__________________ 2007 MS6 GT Cobb AP / JBR SRI + TIP / Fleabay TP / JBR TIGS / Sure RMM + Diff Mounts / Koni Yellows (Front) / Bilstein HD (Rear) / Cut OEM Springs / SPC Balljoints / JBR SSP / Denso ITV-22's |
| The Following 2 Users Say Thank You to Slick6 For This Useful Post: | season_of_ages (11-21-2014), TiGraySpeed6 (11-13-2014) |
![]() | | #30 | ![]() |
Sent from my SM-N900T using Tapatalk | |
![]() | | #31 | ![]() |
I don't have any pull while driving after installing these and getting a good alignment.
__________________ 2007 MS6 GT Cobb AP / JBR SRI + TIP / Fleabay TP / JBR TIGS / Sure RMM + Diff Mounts / Koni Yellows (Front) / Bilstein HD (Rear) / Cut OEM Springs / SPC Balljoints / JBR SSP / Denso ITV-22's | |
| The Following User Says Thank You to Slick6 For This Useful Post: | season_of_ages (11-21-2014) |
![]() | | #32 | ![]() |
![]() Join Date: Sep 2014 Location: Arlington, Texas
Rep Power: 0 ![]() ![]() ![]() Thanks: 2
| Not Ranked : 0 score Bought a throw out bearing for my genwon and it was wrong. Claimed to be for the turbo engine but its definitely wrong. Ended up going to Mazda and buying. Part # N4115
__________________ 88mm Wiseco pistons_Manley H- beam rods_CPE Injector seals_Clevite Bearings_Autotech Internals_HKS SSQV_Cobb SRI/TIP_COBB V3_JBR 88 duro pmm_JBR rmm_Turbine Tech FMM_CxRacing FMIC_TurboXs Catless DP/TP_South Bend Stage 3 DD_That Corn Shit_FREEKTUNE! |
| The Following User Says Thank You to myspeed90 For This Useful Post: | illegal shishkebab (10-22-2017) |
![]() | | #33 | ![]() |
![]() Join Date: Jun 2012 Location: Wichita, KS
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 155
| Not Ranked : 0 score I forgot to post this some time ago but the Beck/Arnley 037-6112 intake gasket fits perfectly. Their TB gasket fits 100% as well I just don't have the P/N handy.
__________________ '10 VRM MS3 3" JBR WP, ETS TMIC, KMD/Aviva HPFP, NGK LTR7IX, M2 TP, Grimmspeed, JBR & MD EGR delete, MD OCC, MD PMM, CPe Stg2 RMM, CS TMM insert Mazda Motorsports C/O, JBR RSB, SPC camber arms, Konig Hypergram 17x9 +40 & 200 UTQG rubber or Drag DR-49 18x8 +45, Michelin Pilot Sport A/S 3 Strive for perfection in everything. Take the best that exists and make it better. If it doesn't exist, create it. Accept nothing nearly right or good enough. Sir Henry Royce |
![]() | | #34 | ![]() |
![]() Join Date: Apr 2010 Location: Des Plaines, IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 234
Groaned at 53 Times in 17 Posts
| Not Ranked : 0 score WIX Cabin Air Filter fitted perfectly gen1. ACDelco rear coil springs were about half inch longer, though no noticeable change in car height or handling. The springs hardness feels same as the stock one, if not even slightly firmer. MEVOTECH Rear LCA also fitted fine. Last edited by dead-zone; 09-06-2016 at 11:06 PM. Reason: Keep adding stuff |
![]() | | #35 | ![]() |
![]() Join Date: Mar 2010 Location: Wellington, Ohio
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 0
| Not Ranked : 0 score I had to return an A/C compressor. The return was really easy, that place is awesome for parts (when they fit). |
| The Following User Says Thank You to cjbevington For This Useful Post: | illegal shishkebab (10-22-2017) |
![]() | | #36 | ![]() |
![]() Join Date: May 2009
| Not Ranked : 0 score Do not use National # 510096 front wheel bearing for Mazdaspeed 3. It fits but the wheel speed sensor won't get the correct signal and you'll get DSC and ABS dash lights. |
![]() | | #37 | ![]() |
![]() Join Date: May 2013 Location: dearborn heights, MI
Rep Power: 0 ![]() ![]() Thanks: 5
| Not Ranked : 0 score has anyone purchased a clutch from rock auto ? if so which one do you recommend im looking to purchase one from them thanks |
![]() | | #38 | ![]() |
![]() Join Date: Apr 2016 Location: Richmond, VA
Edit: You MUST replace the flywheel bolts if you replace the flywheel or have it cleaned up. They are one-time use only. Don't forget about those. | |
![]() | | #39 | ![]() |
![]() | | #40 | ![]() |
| Not Ranked : 0 score It is 100% necessary for the flywheel to have a clean, perfect mating surface for the clutch to grab. If the clutch wore down to the rivets or damaged the flywheel at all, it will have to be replaced or at least resurfaced. Fidanza is a cheap option and it's lighter, which is just a bonus. OEM Flywheel is hella expensive. If the flywheel is undamaged, clean it well with denatured alcohol. Be VERY careful to only use a TINY bit of lubricant on the splines and be careful when you re-grease the fork and release bearing. That shit's gonna spin at 6000 RPM, which will send any excess lubricant all over the place. If any lubricant at all gets into the clutch, you're gonna have a bad time. |
| The Following User Says Thank You to Solarsurge For This Useful Post: | skyms6 (09-15-2018) |
| Rock vs Fog light | SWAY | Gen2 MS3 General Discussion | 41 | 09-10-2011 03:11 PM |
