 Old 11-15-2018, 05:14 PM   #1
Walter's Avatar
Posts: 9   (View Stats)
Walter is an unknown quantity at this point
Default Suggestions on WOT KR...
Hey guys,
Now i know everybody says they have searched the forums, but I really think I have.
I've been getting some weird WOT knock retard for a few months now on and off. It usually happens after about 4500 RPM, and never goes higher than 3.8 (highest i have seen). 3rd and 4th gear only, never in 1st or 2nd. Most of the time i notice is when I'm shifting into the next gear (3rd to 4th is clean but then when get back on the gas in 4th KR comes up). Currently I'm looking for some suggestions/opinions on what to try next. Here is what iv'e already tried.
-Added gallon or two of e85, KR persists.
-New plugs correctly gapped to .26.
-tightened up all boost hose clamps.
-No vibration in clutch (No bent rods I hope)
-Re-flashed the stock map on AP, drove like that for a while, KR still there.
2007 Speed 3 ~ 115k miles
Mods:
Corksport SRI and TIP, Damond RMM, Tuned by Stratified on 93.
If anybody has any suggestions or opinions please throw them out there. I'll try to get some AP logs in here as well.
Thanks!
Walter is offline   Reply With Quote
 Old 11-15-2018, 05:25 PM   #2
Fstrnyou's Avatar
Posts: 2,498   (View Stats)
Check motor mounts.
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
 Old 11-15-2018, 07:30 PM   #3
APEXistud's Avatar
Posts: 57   (View Stats)
APEXistud is a splendid one to beholdAPEXistud is a splendid one to beholdAPEXistud is a splendid one to beholdAPEXistud is a splendid one to beholdAPEXistud is a splendid one to beholdAPEXistud is a splendid one to beholdAPEXistud is a splendid one to behold
Have you ever cleaned your intake valves and have you replaced your injector seals yet? Those are also things that may help reduce KR. There is also the possibility of ghost KR.
APEXistud is offline   Reply With Quote
 Old 11-15-2018, 09:01 PM   #4
Walter's Avatar
Intake valve cleaning and injector seals are actually next on the agenda. Mainly looking to see if other people had this issue and what they have done for a remedy. Thanks for the reply!
 Old 11-16-2018, 12:41 AM   #5
APEXistud's Avatar
Got it! I actually cleaned my intake valves and did injector seals at the same time earlier this year and saw some improvements in my datalogs. Kr went down a lot on full throttle pulls in 3rd and 4th gears. Also be sure to do pulls on a flat smooth road. From what I have read on the forums the part throttle and off throttle Kr is somewhat acceptable and may be ghost Kr, but full throttle Kr is no bueno. Good luck sir!
 Old 11-16-2018, 06:49 AM   #6
Fstrnyou's Avatar
Ya, he added E85 with no change in KR, so it's highly unlikely to be real knock.
High KR at a shift tells me the motor might be rocking around and clunking on something.
Other rides:
History:
 Old 11-16-2018, 08:38 AM   #7
Posts: 2,235   (View Stats)
engine mount or loose timing chain....My first engine was rising KR between shift or when i was just releasing the pedal after a low boost condition. The chain was hittong the valve cover....rebuilded it and this strange knock vanished. But IT was never there at wot, just when the engine goes from load to compression...
Some also mentionned loose part on the engine or exaust but not sure about how much it can affect the knock readding....exaust heat shield, lose tmic etc...
You can also make a compression test to check engine health prior to look for anything but the engine...
 Old 11-16-2018, 09:24 PM   #8
Walter's Avatar
Chain is loose on cold start, but if i let it run for about 10 seconds, and turn it off there is no play whatsoever. So i don't think it's that. Also just changed the rear motor mount about a month ago thinking that was the issue. Torqued everything down to the T from the directions damond sent me, and the KR was still there. Could the PMM be causing this?
Did a few pulls today to try and log and it didn't knock. It's really weird. Weather does not seem to affect it, and its just random. So it very well could be something loose in the bay. Have yet to do a compression test though. So that may be something to do this weekend if I can find some time.
Need some suggestions 1nstinct Gen2 MS3 General Discussion 3 03-22-2014 07:53 PM
Any suggestions? Beck MazdaSpeed 3 - Engine, Transmission & Driveline 4 04-16-2013 08:54 AM
Need suggestions or how to ZoomZoom_ms6 MazdaSpeed 6 - How-To's 6 12-09-2009 12:52 PM
Page generated in 0.28977 seconds with 23 queries
