 Old 03-11-2018, 01:58 PM   #1
Eatliftweld's Avatar
Posts: 11   (View Stats)
Eatliftweld is an unknown quantity at this point
Default In-tank fuel pump problem
I just replaced the in-tank full pump assembly with an OEM Mazda assembly. Everything is wired right, torqued to spec, etc. The problem is that the pump is only pushing 4.5-5.5 PSI with the key on/engine off. Which is the reason I replaced the pump in the first place, same issue. Tested the old pump, it was going out, so went ahead and got the new one. If I jump the circuit relay (not F/Pump 2), the pump kicks on and runs perfect. Car runs perfect, fuel pressure is good, everything. Drove it 5 miles with the jumper in just to make sure. I replaced the relay with a brand new one, still having the same issue.
Why won't the fuel pump kick on, or push 50+ PSI, without the jumper in??
Help. I need my car fixed asap.
Eatliftweld is offline   Reply With Quote
In tank fuel pump not running Thestaplegunkid MazdaSpeed 3/6 - Troubleshoot/Diagnostics 9 07-26-2015 10:39 AM
in tank fuel pump daltonroberts MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 9 01-08-2015 07:30 PM
In tank fuel pump question avesfan101 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 6 11-23-2013 02:22 PM
IN-TANK FUEL PUMP Adrenaline Mazdaspeed3/6 General Discussion 6 04-12-2013 10:22 AM
In tank fuel pump and fuel rail valve Seatime3 2010 MS3 - Fuel, Nitrous & Water Injection 1 04-30-2012 08:44 PM
Page generated in 0.22312 seconds with 21 queries
