![]() Join Date: Oct 2012 Location: Richmond, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,593
(Thread Starter) | Not Ranked : 0 score The MS3 dashboard is pretty flat, so I know it will be easy to mount to the dash and I was thinking about one of those sticky pads that don't have adhesive on them and are built to put a GPS mount suction cup on. For example: I have had one of these before in my 240SX (though not built for a GPS, I just used it to hold my phone flat on the dash) and it worked awesome. However, even though it did not use adhesive, it still left a a pretty nasty residue on the dash during the summer if I didn't take it off and clean underneath it every other day or so. I know there are literally a metric shit ton of options for doing this, but here are my concerns/requirements that I am hoping someone can shed some light on with their personal experience. - I don't want anything that is permanently mounted. - I don't want anything that uses an adhesive backing (like the little GPS disks that 3M to the dash and suction cup goes on top) - And I don't want anything that will leave a residue on the dash if left up for more than a day or two. So yes, I know I'm being picky, but I know that there has to be other people that are just as anal about nasty residues or adhesive all over their dashboards. The phone mount will be used mostly on longer trips and to and from work, so I don't want a permanent addition to my dash as I will be taking it down fairly often most likely. Basically I am just looking for any specific product recomendations that people have had success with on the MS3 dash specifically (I have a Gen 1) that doesn't leave a residue and has been sufficient for holding a GPS or phone up, especially on on the larger side. It seems every product on Amazon seems to leave some sort of residue even if it is non-adhesive, so I may just have to suck it up haha.
__________________ 2009 Mazdaspeed3 Bolted, Mounted, Hypnotic Tuned 2000 Mazda Miata MX-5 NASA TTE build ongoing |
![]() Join Date: May 2010 Location: Maryland
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 848
| Not Ranked : 0 score I'd be very wary of those "sticky" pads. You may have been able to clean the residue off of your 240SX, but i've seen those things cause permanent discoloration on several cars. I use a vent clip mount for my AP. It's mounted to the right of my steering wheel. I like it a lot. The only thing that irks me about it is that it covers up the clock display on my dash. Edit: FWIW, I was gifted one of those sticky pads close to a decade ago for Christmas. I noticed it leaving an oily residue causing discoloration after a couple months. Point i'm trying to make is that I was using it during the winter. So i'm apt to believe it's their use in general that leaves residue and not just warm climates. |
![]() Join Date: Oct 2012 Location: Colorado Springs, CO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 757
| Not Ranked : 0 score The only mount I have found to work 100% of the time.I have tried sticky pads that either stick too well (crap on the dash, shiny marks/residue) not well enough (bouncing suspension, acceleration, phone in flight) suction cups (not one of these seems to tolerate the hot/cold temp range in a sub zero climate)... It holds the iPhone 5 and 6 well (haven’t tried a 6 plus but that thing really is an iPad mini - mini) It works in both horizontal and vertical mounts and it is easy to remove/transplant to other vehicles. The only issue I have had is that you need to close the vent it is in front of if you are using heat, our heaters can overheat the iPhone...
__________________ mods: \\// AT HPFP // AccessPort // CS S2 TIP, SRI and TMIC // CPe S2 RMM // Synapse BPV // Mazda gutted secondary cat // S-OTS+ 91S2 // HKS TP DLi II // Wilwood DP6 13” brakes // TCE 2 piece rear rotors // Maxwell SuperCap/LiFePO4 cell \\// waiting for install: \\// CPE Catted DP // CS Battery Box // Devils Own Meth kit // H&R Coilovers \\// |
(Thread Starter) | Not Ranked : 0 score Yeah, that's why I'm wary of those mats and wanted to post up and see what other people's experiences have been, especially with these cars in particular. I would be pissed to find a bunch of residue because the pad melted to the dash. Reviews on Amazon are hard to go by since most people are completely ignorant to possible damage to the car, nor do they drive the way we do. The reason I went with the dash mount idea is because I already have my AP on the vent. Though I only have a V2 and I have an extremely low profile mount, it still blocks most of the left side of the center vent, and I'd hate to lose another vent to mount my phone as well. The Note 4 is comparable in size to the iPhone 6 Plus. Thanks for the input so far guys.
![]() Join Date: Jan 2011 Location: Jacksonville, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 311
| Not Ranked : 0 score This works perfect for me 100% of the time for my S3 using my Torque app for monitoring. Suctions to the dash and/or window.
__________________ 08 MazdaSpeed3 | Cobb AP | MS Intake | CS TIP | CP-E FMIC | CNT Catless TBE | ITV22 | | AutoTech Internals | TurboSmart BOV | BC Racing Coilovers | CS RMM | CS TMM | | Black Powdercoated Stockers | Built Motor | | Mahle 88mm Pistons | Manley H-Beam Rods | |
| Not Ranked : 0 score You could possibly mount it to the windshield with a suction cup as I did my GPS: ![]() My GPS is hardlined. I wrapped a loop with the cord once around the rearview just in case the mount should fall on a particularly hot day. Post#10 of this thread explains how I wired it: convert dash cam cig power plug to hardwire If you're not into splicing up the wiring to your mount (assuming your mount has special wiring) you could always splice in some sort of USB hub or extension and tuck it behind the light/headliner. I've learned to put the suction cup on and LEAVE it. I have a second mount should I ever feel the need to use the GPS in a different vehicle. Taking it off and on compromises the suction cup pretty quickly. |
| Not Ranked : 0 score @frothy; I'm definately stealing that for my phone.
| The Following User Says Thank You to Easter Bunny For This Useful Post: | frothy (02-23-2015) |
![]() Join Date: Sep 2013
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 789
| Not Ranked : 0 score I use a Ram x-mount. They are really nice mounts. I have one suction cup base and another base that attaches to the headrest for filming.
__________________ 2009 MS3 GT - JBR SRI/TIP - CS Racepipe - TurboXS CBE - Cobb AP - Stratified E85 Flash Tune Stg. II (294/342) - Stratified Guardian Angel - Autotechs - CP-e S2 RMM - KW V2 - SPC RUCAs |
![]() Join Date: May 2009 Location: Orange County, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 806
Groaned at 9 Times in 5 Posts
| Not Ranked : 0 score If wanting to avoid residue on the dash, you're only option is to rip out the HU or do a windshield mount. Here's my recommendation:
I ended up mirroring mine wirelessly from the center console: https://www.youtube.com/watch?v=zEhruQ45UVA | |||
![]() Join Date: Oct 2013 Location: Detroit, MI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 509
| Not Ranked : 0 score I use a CD slot mount.
| The Following User Says Thank You to aackthpt For This Useful Post: | FrozenFloridian (03-07-2015) |
(Thread Starter) | Not Ranked : 0 score Thanks for all the input guys. I am definitely going to look into putting it up at the top of the windshield like you have it @frothy;. I like that idea a lot. The mount does not have its own wiring, it works with a standard vehicle charger. I'll play around with it and see what I can come up with. For reference, this is the mount I ordered and also my current dash set up regarding where my AP sits. I'm wondering if the suction cup with stick on the dash without any other sort of mounting to go underneath it. That would solve the whole problem haha. I was originally planning on putting it pretty much right above the hazard lights button between the two vents on the dash. Doesn't block the view of the road and it would sit just to the right of the AP. I think I'd like to stay away from a permanent mount for now @dinoxor; only because I'm just not a huge fan of adhesives on the dash. Though I may just end up going that route in the end with one of those adhesive suction cup disk things since I'm sure 3M will be much easier to clean up than a melted sticky pad. Thanks for the input so far guys, I'll definitely be looking into all those options.
| The Following User Says Thank You to Quigs For This Useful Post: | tmillner (03-15-2015) |
![]() Join Date: Mar 2014 Location: Durham, NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10
| Not Ranked : 0 score I also agree with the windshield mount! I have my LG G2 windshield mounted and couldn't be happier, most of these mounts you can dash mount but mine also has a sticky suction cup. I use it for torque monitoring GPS etc, at least with the dash mount I can throw the car through turns without issues as it's very sturdy. I'd be willing to say it would probably hold up fine even through autocross it's so sturdy. |
| The Following User Says Thank You to Omega For This Useful Post: | jabeel00 (07-27-2015) |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 205
| Not Ranked : 0 score I use an old Garmin friction mat or suction cup mount depending on the vehicle I'm driving. My new deck in the ms6 does screen mirroring, so I'm sure that is going to be my answer for all of my vehicles soon. |
![]() Join Date: Nov 2011 Location: Clermont, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 355
| Not Ranked : 0 score This is what I use. It is magnetic and mounts in the CD slot (cause Noone uses CDs anymore) http://www.meritline.com/m/showprodu...oductid=117840 sent from my new LG G3
__________________ JBR: 88 duro RMM, Short Shifter Plate, Solid Bushings, Shift Weight CorkSport: SRI, TIP, HPFP, Test Pipe Other: Cobb V2 AP, TurboSmart Kompact BOV, CP-E TMIC, NGK ILTRA6-8G Plugs, MOTEGI Racing 18 X 8 MR131 TRAKLITE Bronze wheels , NYS legal tint (whatever that is), Black Emblems, spoiler for my spoiler |
| The Following User Says Thank You to FrozenFloridian For This Useful Post: | jabeel00 (07-27-2015) |
![]() Join Date: Aug 2012 Location: Beaverton, Oregon
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 158
| Not Ranked : 0 score I use the larger spider podium to mount my 10.1 inch tablet to my dash (or anything else I want). No sticky residue and lots of options as far as position/location. I like the look of that CD mount as well. http://usa.breffo.com/pages/spiderpodium
__________________ 2012 CS SRI+TI+Racepipe+SSP+anchors+TMIC / CPE "stage 2" RMM / HKS SSQV recirc / Autotech internals / AP Stage 2 91 OTS / NGK's 1 step cold/ Knob |
| The Following User Says Thank You to DevinTheDood For This Useful Post: | jabeel00 (07-27-2015) |
__________________ 2009 Mazdaspeed3 Bolted, Mounted, Hypnotic Tuned 2000 Mazda Miata MX-5 NASA TTE build ongoing | |
| The Following 2 Users Say Thank You to Quigs For This Useful Post: | FrozenFloridian (03-16-2015), jabeel00 (07-27-2015) |
![]() Join Date: Feb 2016
Rep Power: 0 ![]() Thanks: 3
| phone mount/holder for dash compartment MS6 | paxtonschwendner | MazdaSpeed 3/6 - Car Audio & Electronics | 2 | 07-25-2014 08:04 AM |
| Mount options for cell phone | mpetruzz | Interior | 12 | 02-23-2014 06:11 PM |
| How To: Install Cell phone mount (KUDA) Installation | Constantin | MazdaSpeed 3 - How-To's | 7 | 11-20-2012 04:11 PM |
| Dashboard Removal | Salukis10 | CX-7 > Car Audio & Electronics | 5 | 02-17-2012 01:34 PM |
| Icon on dashboard | kish89 | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 6 | 10-10-2011 11:52 AM |
