![]() Join Date: Aug 2009 Location: glen burnie md
(Thread Starter) | Not Ranked : 0 score Now these are made in house and are all made out of T309 Stainless Steel with a 1/2" flange. They will be tubular as well. Here is a picture of the Sidewinder Manifold that we made for Conso's car for those who would like to see our work. thanks, Adam Minzer Vivid Motorsports Last edited by aminzer; 02-05-2010 at 06:04 AM. Reason: more information |
| The Following 7 Users Say Thank You to aminzer For This Useful Post: | AmillieMS6 (02-05-2010), ATAZ (02-06-2010), atenza_freak (02-04-2010), bioevolve (02-05-2010), Buildabong (02-05-2010), madvillain (02-05-2010), SpeedSixxx (02-05-2010) |
(Thread Starter) | Not Ranked : 0 score updated OP |
![]() Join Date: Apr 2009 Location: Bethpage, New York
Rep Power: 4481 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 16,850
Groans: 778
| Not Ranked : 0 score what does it look like on the car?
__________________ 2003 SilverStone Grey Honduh S2000 ![]() ![]() |
(Thread Starter) | Not Ranked : 0 score well that isnt the mani i am talking about making. That mani sits the turbo next to the engine, but also requires the ecu to be relocated. All that pictures purpose was for showing off what we can do.... Im looking to create and sell manifolds that will keep the turbo behind the engine like stock, but just have it mounted up top with the runners underneath. Similar to how the turbo sits on my car |
| The Following 2 Users Say Thank You to aminzer For This Useful Post: | Docnox (02-06-2010), SpeedSixxx (02-05-2010) |
![]() Join Date: Sep 2009 Location: CREVE COUER, MO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 263
Groans: 75
| Not Ranked : 0 score i would be interested if it didnt cost a butload... |
Groans: 356
| Not Ranked : 0 score and whats the point of all this? just to be able to swap turbos more quickly?
| Driver ![]() Join Date: May 2008 Location: Toronto
Rep Power: 1986 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,158
Groans: 44
| Not Ranked : 0 score I think back in the day, it was so you can light up a cigarette with your toasty turbo after a spirited run ...
__________________ ![]() DONE . Cobb AP 22-psi Self-Tuned . ATP GT3071 . CP-e 3.25" MAF+4" inlet . Denso ITV-24 . CP-e HPFP . CP-e FMIC . Turbosmart Ultimate BPV . 50/50 Meth w/ M5 nozzle . PTP IM Spacer+EGR delete . GrimmSpeed EBCS 3-port . SteedSpeed Mani . CP-e TBE . Greddy OCC w/ 2nd PCV valve . F2 BSD + oil-pan baffle . Hawk HP+ pads . Goodridge SS brake lines w/ Ford Super Dot 4 . Cobb Springs+FSB . Tri-Point RSB+Endlinks . Koni Yellows . KMAC Camber Plates . 60mm Boost Gauge . TWM Complete Shifter w/ JBR SSP+weight . CP-e RMM+PTP trans+kicker mount . Sparco Harness Bar w/ MOMO 4-pt harness . Rays/Volks 57F 18x8.5" +45mm 235/40/18 Hankook V12 . BBS RK 17x8" +45mm 235/45/17 RA1/R6 . OEM Snowflakes w/ 215/50/17 Nitto NT-SN1 . 3rd in CSCS 2009 Time Attack Championship - Super Street FWD . 360whp/390wtrq . SOON . 3-bar MAP sensor . MSpeed Tuning & Diagnostics - The Street Lab is ALWAYS OPEN FOR BUSINESS "It is amazing how many drivers, even at the Formula One Level, think that the brakes are for slowing the car down." -- Mario Andretti -- |
![]() Join Date: Mar 2008 Location: STL, MO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,984
| Not Ranked : 0 score It looks way better. |
| The Following User Says Thank You to ATE BALLER For This Useful Post: | Fagwagon (02-05-2010) |
Groans: 75
| Not Ranked : 0 score |
| Banned ![]() Join Date: Jun 2008
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 283
Groans: 213
Groaned at 274 Times in 187 Posts
| Not Ranked : 0 score yayay for top mounted!! go do work amnizer! |
(Thread Starter) | Not Ranked : 0 score yea alot of people just seem to like to see there turbo when you pop the hood....i mean i just went into the shout box and asked what people wanted and they said top mount turbo, so im trying to make it happen. |
Groans: 75
| Not Ranked : 0 score id like to get one made pending cost...i already have a nice medival mani i was about to use with my setup but if this one isnt much more i would love to have it made! PM me on initial pricing. |
Groans: 60
| Not Ranked : 0 score Top mounted definitely looks the best!
Groans: 356
| Not Ranked : 0 score i was just asking for my personal knowledge, yeah if customers want that give it to them y not
| Banned ![]() Join Date: Feb 2010
Rep Power: 0 ![]() ![]() ![]() ![]() Thanks: 6
| Not Ranked : 0 score i kind of like seeing the manifold runners. to each their own. looks cool, either way. |
Groans: 213
| The Following User Says Thank You to Buildabong For This Useful Post: | SpeedSixxx (02-05-2010) |
Groans: 75
Groans: 78
| Not Ranked : 0 score haha that manifold in the top post is bananas. sweet work guys
| The Following User Says Thank You to madvillain For This Useful Post: | SpeedSixxx (02-05-2010) |
(Thread Starter) | Not Ranked : 0 score thanks im thinking with the manifold, and downpipe the cost will be around a $1k |
![]() Join Date: Jan 2010
| Not Ranked : 0 score thats not that bad id consider that |
Groans: 75
| Not Ranked : 0 score So like 500 without the dp? |
![]() Join Date: Aug 2009 Location: south dakota
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 233
| Not Ranked : 0 score I will be down in a year or so when i have more money. Looks freakin amazing when you open the hood. One of the reason's i havnt bought a downpipe and manifold for my stock turbo shit. Good job guys looks amazing.
__________________ 2010 ford focus andy |
![]() | | #24 | ![]() |
![]() Join Date: Jan 2009
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 100
| Not Ranked : 0 score good work man, they look amazing. |
![]() | | #25 | ![]() |
![]() Join Date: Sep 2008 Location: CT/NY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,375
Groans: 35
| Not Ranked : 0 score I love the top mount look. SS' car is fuckin' sexy, damn. Your work looks good and your prices are very reasonable too, if only I had the money.
__________________ ---------------------------------------------------------------------------- '06 Speed 6 Black MicaMazdaspeed SRI, Medieval inlet, Eibach Springs, Magnaflow cbe, 3 ebay catless dp, SU rmm, HKS ssqv, JBR stage 2 ssp Altered Customs fmic, Autotech fp internals Cobb AP, Stage 2+ 93 tweaked Centric blanks, EBC red pads Lotek center gauge pod: AEM wideband, Autometer boost and volts Tints, blacked emblems, spec-v front lip, Shark fin Redline MT-90, ITV-22s, Matt Damond OCC 13.66@102 Lebanon Valley 4/10/11 (sri, tp, rmm, ap) DO Meth kit waiting on install |
![]() | | #26 | ![]() |
(Thread Starter) | Not Ranked : 0 score I thank all of you with the compliments of our work here at vivid, and i will have some more pictures of other manifolds that we have made, actually working on one now at the shop for a ka24de to fit a top mount Holset hx40. I wish business wasn't slow so that i wouldn't be asking for a deposit to make these manifolds and you could see the final product and the gains before purchasing but i can't afford it right now. So for those interested and still skeptical, i will have no problems answering any questions that you may have. |
| Pro Mod Turbo manifold | medieval | Mazdaspeed3/6 General Discussion | 11 | 05-25-2009 12:24 AM |
| in need of a turbo manifold | specvspeedfreak | Mazdaspeed3/6 General Discussion | 1 | 04-24-2009 08:54 PM |
| High strength studs for turbo (manifold to head and manifold to turbo) | bnoon | MazdaSpeed 3/6 - Turbo Induction | 4 | 03-11-2009 10:26 PM |
| Externally Wastegated Turbo Manifold vs Tubular Turbo Manifold | nobmood | Mazdaspeed3/6 General Discussion | 18 | 03-01-2009 08:14 PM |
