 Old 09-13-2014, 11:06 AM   #1
droflow's Avatar
Posts: 114   (View Stats)
droflow has a reputation beyond reputedroflow has a reputation beyond reputedroflow has a reputation beyond reputedroflow has a reputation beyond reputedroflow has a reputation beyond reputedroflow has a reputation beyond reputedroflow has a reputation beyond reputedroflow has a reputation beyond reputedroflow has a reputation beyond reputedroflow has a reputation beyond reputedroflow has a reputation beyond repute
Default Very odd breakdown
I cleaned my air filter yesterday afternoon, let it dry, and reinstalled. Car sat for about 5 hours before driving. Went on a drive, cruising in fourth gear. Was cruising for about 10 minutes. The car started to slow down, and i had no idea what was happening. I tried to give it more gas to see if it would do anything, nothing happened. Downshifted into 2nd and then the car stalled out. Tried to restart it and the engine turned, but no start. Let it sit for 10 minutes, pushed it off the road, successfully started the car and then engine stalled after 5 seconds. Let it sit longer, started and then stalled again. Car is in the shop but no word.... What are the possible things that could be happening here?
2007 Cosmic Blue Mica Mazdaspeed3 GT
Mazdaspeed CAI, Autotech HPFP, Corksport TMIC, E-cutout, corksport test pipe, stratified tune
In the works:
Built engine- Bored .020 over, Eagle Rods, Wiseco 88mm pistons, Damond PCV plate, corksport injector seals, ported IM
droflow is offline   Reply With Quote
 Old 09-13-2014, 12:08 PM   #2
dale_gribble's Avatar
Posts: 4,720   (View Stats)
Hpfp or hprv
MINI H1 6.0 - CAR LED TAILS
 Old 09-13-2014, 12:13 PM   #3
droflow's Avatar
Hpfp or hprv
damn i didn't even consider it to be my HPFP. I literally just logged my HPFP pressure yesterday and was sitting perfectly around 1700.
In the works:
 Old 09-13-2014, 12:31 PM   #4
Sid3wayS's Avatar
Posts: 6,790   (View Stats)
Groans: 97
Is it an oiled filter.
TEAM LUXURY
 Old 09-15-2014, 11:30 AM   #5
nekret's Avatar
Posts: 421   (View Stats)
nekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the world
^^This^^
Sounds like the filter may be oiled and it coated your MAF. test by unplugging MAF (if it idles ok and starts then its fairly confirmed) and resolve by cleaning MAF and replacing filter with a dry one.
2011 Mazdaspeed3 non-tech package
Drivetrain
CorkSport 3.5" MAF & TIP | CP-E FMIC | Synapse BPV | CorkSport EBCS (Interrupt) | Bosch 3 bar MAP | CorkSport HPFP Internals | CP-E Catted Downpipe | CP-E Triton 3" CBE | JBR Stage 2 OCC | Kozmic Primary EGR Delete | JBR Secondary EGR delete | NGK 6510 | TB coolant Bypass | JBR IM & TB Gaskets | Damond RMM, PMM, & TMM | JBR light shift weight | TWM Full Replacement Shifter | Cobb AccessPort V3 | FreekTune
Chassis
JBR Front & Rear Sway Bars | JBR Billet Rear Sway Bar Brackets | Whiteline Adjustable Front&Rear sway bar links | JBR Coilovers | Corksport BBK | Corksport Lower Tie Bar | Corksport Mid Chasis Brace
Rice
LED bumper reflectors | Morimoto LED Fog lights | VLEDs LED Highbeams | Independent Fogs | AP Engine & HPFP cover | CorkSport Pulleys | Corksport Leather Shift Knob | Corksport Steering Wheel | Damond front plate mount | Lukas LK-9750 2ch dashcam | Eonon GA7163 | thespeedline.com blue mirrors | thespeedline.com hood dampers
nekret is offline   Reply With Quote
 Old 09-15-2014, 01:51 PM   #6
Big Dog's Avatar
Posts: 730   (View Stats)
Big Dog is the leader of the worldBig Dog is the leader of the worldBig Dog is the leader of the worldBig Dog is the leader of the worldBig Dog is the leader of the worldBig Dog is the leader of the worldBig Dog is the leader of the worldBig Dog is the leader of the worldBig Dog is the leader of the worldBig Dog is the leader of the worldBig Dog is the leader of the world
Groans: 89
Groaned at 9 Times in 9 Posts
Yeah, oiled filters are no good. Even K&N now makes everyone's Dry-Flow filters.
Clean your maf thoroughly with MAF cleaner ONLY. If you use anything else you will destroy your expensive maf sensor.
2007 MS6 GT:
HTP 3" Full Intake, CS TMIC, AutoTech Internals, APv3, Forge Version 2 BPV(Blue+1 Shim), CP-E Catted DP, Whiteline RSB, CP-E Rear Diff mount, CP-E RMM, CS transmission mount insert, JBR Stage 2 OCC, JBR Boost tubes and recirc hose, Bilsteins B6's all around, Techna-Fit SS clutch and brake lines with ATE fluid, FreekTuned!
Big Dog is offline   Reply With Quote
 Old 09-15-2014, 06:31 PM   #7
sheston's Avatar
Posts: 1,847   (View Stats)
Would it do something like this if the turbo inlet tube came off while he was playing with the filter?
 Old 09-15-2014, 06:50 PM   #8
btstarcher's Avatar
Posts: 4,852   (View Stats)
I let mine dry for 8 hours and it was still damp. Car drove OK until I went WOT, then had some issues. Might try cleaning the MAF sensor and letting the filter dry some more.
SnailTune in progress
 Old 09-15-2014, 06:57 PM   #9
kby
kby's Avatar
Posts: 653   (View Stats)
kby is the leader of the worldkby is the leader of the worldkby is the leader of the worldkby is the leader of the worldkby is the leader of the worldkby is the leader of the worldkby is the leader of the worldkby is the leader of the worldkby is the leader of the worldkby is the leader of the worldkby is the leader of the world
Start it and try to look at MAF voltage and MAF g/s. If it doesn't move at all, then you probably messed up your MAF.
kby is offline   Reply With Quote
 Old 09-15-2014, 07:01 PM   #10
btstarcher's Avatar
Oh and for some odd reason, after all that my O2 sensor took a shit. No idea why but it had to be related somehow because it happened at the same time.
 Old 09-16-2014, 09:23 PM   #11
droflow's Avatar
Okay.... so here it is... the dealer told me that my fuel pump is going out, and i have carbon build it.... and the CDFP and some sensor need to be replaced. They said they could change them out for $400. but I'm broke. i was looking at internals but it's not just internals that i need changed apparently.
In the works:
 Old 09-18-2014, 06:45 PM   #12
rob ms6gt's Avatar
Posts: 416   (View Stats)
A new HPFP and any sensor installed at the dealer should be more than $400. Maybe scam? I agree with above posts, MAF is prolly covered in filter oil. Did you have any CEL's?
ROB MS6GT
2006 Liquid Platinum Metallic Mazdaspeed 6
Stratified Tune, Stratified GA V2, Cobb AP V2, GTX3071R, HTP 4" Intake, Synchronic Diverter Valve, 3 bar MAP, Stratified Boost Dial, Corksport Injector Seals, Autotech Internals, Ebay DP, Custom TR8 FMIC, DevilsOwn Meth, Damond Catch Can, JBR 70 Duro Trilogy, TT front diff mount, Penis Eater top diff mount, Cut OEM Springs, Koni Yellows
rob ms6gt is offline   Reply With Quote
 Old 09-18-2014, 07:45 PM   #13
droflow's Avatar
yeah i thought so too, OEM fuel pumps run about $350. but the car is running now, a sensor got unplugged somehow (didn't unplug anything) and that was it........ are you kidding me. Fuel pump is fine so idk what they were talking about. I don't trust dealerships around here. But any who... car is running a lot stronger since the carbon blasting
In the works:
ms6mil Rear Axle Breakdown ms6mil MazdaSpeed 6 - Engine, Transmission & Driveline 168 03-05-2016 09:40 AM
Breakdown of MS3 front strut zenit MazdaSpeed 3/6 - Suspension & Brakes 17 08-03-2013 11:42 AM
Breakdown of Chrysler's Big Day [w/POLL] Haltech Automotive News 0 04-30-2009 12:10 PM
Page generated in 0.33156 seconds with 28 queries
