| Cobb Tuning Cobb Tuning is the leader in Mazdaspeed 3 & 6 Performance! |
![]() Join Date: May 2019
Rep Power: 0 ![]() Thanks: 1
(Thread Starter) | Not Ranked : 0 score HI everyone! Ive been reading and reading on the forums but i cant seem to find an answer to the problems im having with my car. I bought this car about a month ago and i wanted to do a cobb stage tune 2 eventually. I bought stage 1+ including the internal/ intake/ turbo inlet. I installed these parts myself. After the install the car was running fine until i blew the turbo seal. I took it to the dealership(stealership) and they put in new turbo/ coil packs and spark plugs. When i picked it up they told me that it needs a tune because of the HPFP. I put the COBB stage map tune on it. That didnt fix it. The car will idle fine for about 10 minutes and it then eventually dies and i get a fuel system too rich in bank 1. Mazda tells me it needs a tune, Cobb tells me its mechanical issue. I need help please!Attached are the logs of it idling. Should i just go back to stock internal? Last edited by Amnesia; 05-03-2019 at 08:12 PM. |
![]() Join Date: Aug 2017
Groaned at 18 Times in 7 Posts
| Not Ranked : 0 score seems to be running fine in this datalog. please post one where the problem occurs. In this datalog is runs for 30+ seconds without an issue.
__________________ HPFP, Corksport Dp to CBE, cobb SRI and TIP, Cobb big front mount intercooler, corksport RMM, eibach lowering springs, accessport v3 with e50 tune by Will @ pd tuning 22 psi 11.8 AFR |
(Thread Starter) | Not Ranked : 0 score The End of the log is when the car died. It also started having white smoke now. As it was before the turbo replacement. When i got the car back from the dealership, i Drove it for probably 50 miles and got to a stop sign and the car died. Going 60 on the high way and put it in neutral and the car died. i wish i had it logged.. |
![]() Join Date: Jan 2019
Rep Power: 20 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14
| Not Ranked : 0 score Did this problem ever get resolved? |
Rep Power: 3745 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,744
To me, this looks like you're either running entirely the wrong tune for the modifications on your car, or you've got a something blocking airflow in the intake tract. For the moment, there is no reason to remove the fuel pump internals that you have installed. Aftermarket HPFP internals can be run on the OEM tune without problems. Likewise, they can be run on aftermarket tunes without issues. What *exact* tune map are you running, and what *exact* modifications are on the car? Have you checked the intake system to see if there is anything blocking airflow?
__________________ Having trouble finding something on MSF? Use MS3Shadow's search tool:SEARCH MSF HERE! | ||
| The Following User Says Thank You to Vansquish For This Useful Post: | dagrimey1 (08-26-2019) |
| Mazdaspeed 6 issues... | drive_sideways | Mazdaspeed3/6 General Discussion | 45 | 10-01-2017 05:55 AM |
| 2013 speed starting issues | kennyg1966 | Gen2 MS3 General Discussion | 20 | 09-27-2017 09:00 PM |
| 2007 Mazdaspeed 3 Misfiring issues HELP | Eustache | MazdaSpeed 3 - Engine, Transmission & Driveline | 9 | 01-08-2016 09:19 AM |
| VVT actuator issues on my 2013 | Jinba Ittai | 2010 MS3 - Engine, Transmission & Driveline | 13 | 04-07-2014 01:36 AM |
