| Cobb Tuning Cobb Tuning is the leader in Mazdaspeed 3 & 6 Performance! |
![]() Join Date: Nov 2011 Location: Salisbury/Charlotte, NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 274
(Thread Starter) | Not Ranked : 0 score I plugged my Accessport V2 into my car today just to monitor and the screen never lit up. After checking with it connected my computer, it appears to be just a screen issue because all of my maps are still stored on the unit and it even updated itself to the most recent version. I've done some searching and have already found that some AP V2s had screen issues and heard that Cobb should warranty those. I have already sent @Cobb Tuning; an email detailing my situation and I am awaiting a reply from them. I'm not here to bash or vent at Cobb but I was wondering if it is still possible to uninstall the AP from my car with the screen being dead and unable to read the output message/status? IIRC, these steps should get me to the uninstall screen:
After you click OK the last time, I think you should be at the install screen. Can anyone confirm this for me, or has anyone tried doing this? TLDR: AP screen died, Can you uninstall AP if screen is dead?
__________________ 2012 Mazdaspeed3 Black Mica w/ Tech -~COBB AccessPort - SURE Full3 ID300 Aeros - Ultimate Racing TP - Autotech HPFP Internals - NGK 1 Step Colder Spark Plugs - JBR RMM Chrome-Moly 88duro, Stage 2 OCC, LTD Silver Vein Heavy Shift Knob, Short Shift Plate, Solid Shifter Bushings, Boost Tubes, Bypass Hose, Intake Maniford TIG, Throttle Body TIG - Black TRMotorsport C3 Wheels with JBR 5mm spacers - Tuned by Boost_creep~- |
![]() Join Date: Jan 2013 Location: OC, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 633
| Not Ranked : 0 score When I warrantied mine I didn't uninstall my tune since it had a 3" intake on it and obviously wouldn't be drive-able. You can warranty the AP to them with the tune still on the car. I know that probably didn't answer your question, but yes, the AP does still work even though the screen isn't showing. |
| The Following User Says Thank You to He Hate Me For This Useful Post: | Awesomesauce (11-08-2014) |
(Thread Starter) | Not Ranked : 0 score I do have the 3" intake, but I have a work car that I could drive if the mazda was down.
| Not Ranked : 0 score Most send it back married. New screen won't mean that it's getting replaced. |
| The Following User Says Thank You to Raider For This Useful Post: | Awesomesauce (11-08-2014) |
![]() Join Date: Oct 2009 Location: Gilbert, Az
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 347
| Not Ranked : 0 score I sent mine in still paired with the car. $100 later it was sent back to me with just the screen replaced. |
| The Following User Says Thank You to SJP0tato For This Useful Post: | Raider (11-09-2014) |
![]() Join Date: Jul 2011 Location: Cranston, RI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14
| Not Ranked : 0 score i have the same issue but just ordered the v3 to do the upgrade is it possible to hook my laptop up to it to initiate the uninstall? Matt
__________________ 2006 Silver Speed6 soldCobb AP CP-E TMIC CP-E Nano CP-E TIP Sure RMM ATP Catted DP CP-E dual exhaust NGK 6510 Autotech internals HKS Gen1 SSQV JBR 80Duro TMM/PMM 277hp/343tq freektune |
![]() Join Date: Mar 2012 Location: Erie, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 225
| Not Ranked : 0 score Someone else on the forum had luck disassembling and re-connecting the plug for the screen. Obviously don't do this if your V2 is still under warranty. AP v2 screen failure possible fix
__________________ 2007 COSMIC BLUE MICA MS3 GT ENGINE↑ AUTOTECH CDFP ♦ BNR S3 V2 ♦ CP-E: DP, SAFESEAL ♦ DO 2.5 BAR KIT ♦ ETS TMIC ♦ JBR: 3" WP, 88 DURO TRILOGY, EGR DELETE, TIG ♦ MAGNAFLOW CBE ♦ SYNAPSE DV SUSPENSION≈ BILSTEN B8 ♦ SWIFT SPEC-R ♦ WHITELINE: ALK, BUMP STEER CORRECTION, POLY BUSHINGS WHEELS & TIRES↓ ENKEI EVOLUTION X ♦ MICHELIN PILOT SUPER SPORT CREATURE COMFORTS☺ TWM FULL ASSEMBLY ♦ STRATIFIED EXTENDER TUNED BY ![]() |
![]() Join Date: Jan 2013 Location: Cincinnati, OH
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 774
| Not Ranked : 0 score I've also had a dead screen. Sent into to Cobb and they foxed it even tho it was about 6 months out of warranty. Was very pleasantly surprised!
__________________ 2013 MS3 BM Cobb AP, SRI, TIH OBX Test Pipe JBR RMM Autotechs E85 Freektune |
| Display Modes | |
| Accessport screen locked | Mazda_Mike | 2010 MS3 - ECU Computer Tuning | 6 | 01-28-2013 02:13 PM |
| Cobb AccessPort Screen Protector | SLOWHATCH | Cobb Tuning | 6 | 03-16-2012 09:33 PM |
| Navi Screen stopped working after Accessport flash? | spotmaxdog | 2010 MS3 - Troubleshoot/Diagnostics | 2 | 07-04-2011 09:12 AM |
