> Cobb Tuning
 Old 12-02-2010, 02:53 PM   #1
Travis@Cobb
Lurkers
Travis@Cobb's Avatar
Posts: n/a
Default AccessTUNER Race Installer Bug Work Around
Some users have reported issues installing the latest BETA version of AccessTUNER Race. We have identified a bug in our installer. The temporary work around is the following:
1) Uninstall AP
2) Update AP Firmware (this firmware is BETA, you must select update to BETA firmware if you wish to use this update)
3) Install new AccessTUNER RACE
4) Use new ATR to open and re-save any maps you plan to flash to ECU. This puts the new code into the map file.*
5) Install AP to ECU. This puts the new code onto the ECU.
We are currently working on a fix for this bug. This bug is not known to interfere with AccessPORT operation and only affects installation of the new software. Once the new software is installed, simply reinstall your updated AccessPORT and load your updated calibrations.
*All calibrations MUST BE UPDATED if you update your AccessPORT to take advantage of the new boost logging change, otherwise boost will not display correctly.
Note: The boost logging change is backwards compatible, meaning if you use older AccessPORT firmware/AccessTUNER Race software to log boost when using a new map it will work. The Dashhawk will still work as well. However, if you update the AccesPORT Firmware, you MUST update your map and flash it to the ECU.
 Old 12-02-2010, 03:12 PM   #2
Please let us know when the bug has been fixed for the installer. Thanks Travis
I went ahead and uninstalled, got the ATR installed, now i am in the process of updating the firmware and loading and re-saving the maps. This work around does work.
AccessTUNER Race Install Bug Work Around Travis@Cobb
Cobb ATR Support
22 12-06-2010 10:04 PM
AccessTuner Race help Jdizzle659 MazdaSpeed 3/6 - ECU Computer Tuning 0 10-12-2009 12:44 PM
AccessTUNER Race for MAZDASPEED3 & 6 Cobb Tuning MazdaSpeed 3/6 - ECU Computer Tuning 407 04-23-2009 10:55 PM
Webinar for AccessTuner Race (when released)? smakdown61 MazdaSpeed 3/6 - ECU Computer Tuning 7 02-23-2009 05:30 PM
Looks like the subbies get Cobb AccessTUNER Race for free! Haltech MazdaSpeed 3/6 - ECU Computer Tuning 60 09-15-2008 12:49 AM
Page generated in 0.23928 seconds with 20 queries
