> Cobb Tuning
 Old 08-06-2013, 07:16 PM   #1
Pocket Rocket's Avatar
Posts: 47   (View Stats)
Pocket Rocket is a splendid one to beholdPocket Rocket is a splendid one to beholdPocket Rocket is a splendid one to beholdPocket Rocket is a splendid one to beholdPocket Rocket is a splendid one to beholdPocket Rocket is a splendid one to behold
Default Question about OTS maps
So I have installed on my car..
autotech internals
CS TMIC
CS SRI with TIP
CS Catted DP
CS Catback Exhaust
The only OTS maps I can find on cobbs web site for these mods dont include the CS SRI or CS Catted DP. They say they require Cobb SF intake and Cobb catted DP.
My questions is will this stage 2 map work with the CS SRI and CS catted DP instead?
Pocket Rocket is offline   Reply With Quote
 Old 08-06-2013, 07:18 PM   #2
Benis's Avatar
Posts: 413   (View Stats)
Benis is the leader of the worldBenis is the leader of the worldBenis is the leader of the worldBenis is the leader of the worldBenis is the leader of the worldBenis is the leader of the worldBenis is the leader of the worldBenis is the leader of the worldBenis is the leader of the worldBenis is the leader of the worldBenis is the leader of the world
Yes.
Benis is offline   Reply With Quote
The Following User Says Thank You to Benis For This Useful Post:
Pocket Rocket (08-06-2013)
 Old 08-06-2013, 07:34 PM   #3
Goodrich27's Avatar
Posts: 678   (View Stats)
Goodrich27 is the leader of the worldGoodrich27 is the leader of the worldGoodrich27 is the leader of the worldGoodrich27 is the leader of the worldGoodrich27 is the leader of the worldGoodrich27 is the leader of the worldGoodrich27 is the leader of the worldGoodrich27 is the leader of the worldGoodrich27 is the leader of the worldGoodrich27 is the leader of the worldGoodrich27 is the leader of the world
Search button much?
Go fasters:Manley H beams and Wiseco 87.5mm Forged pistons with stock compression, GTX3076 with Tial 38mm EWG, Full Race exhaust manifold w/2000* ceramic coating, MD meth injection TB spacer and Devils Own DC30 WMI with DO14 nozzle, Cobb 3 port ebcs, Ultimate Racing V2 Catless DP, Relentless Customs PNP IM with VTCS delete, TR11 core with HTP under route piping,ACT 6 puck, Corksport catless RP and CBE, CPE Stage II RMM,Cpe side mounts, perm plate with MD sealed and VTA OCC, HTP 4in Intake,ISC N1 coilovers, CS RSB, Tial BPV, Auto tech internals, Cobb ap v3, CPE injector seals,ngk step colder plugs, JBR throttle body TIG and coolant bypass, Corksport polyurethane exhaust hangers, Motorcraft unicorn juice, t6 rotella, Stoptech slotted and drilled front rotors with posi quiet pads.
Rice:corksport led fogs, Corksport eyelids, Corksport hood struts ,blacked out genpu rims, red evil M front and rear, red calipers, Corksport black mud flaps, Corksport shift knob, powder coat red valve cover, Intercooler pipes, and black gloss intake manifold A pillar gauge mount w/ AEM AFR, Oil temp, and Oil pressure gauges.
Goodrich27 is offline   Reply With Quote
The Following User Says NO Thank You to Goodrich27 For This Un-useful Post:
 Old 08-07-2013, 03:48 AM   #4
Quigs's Avatar
Posts: 1,152   (View Stats)
You can't find the Stage 2 Corksport intake maps? I'm pretty sure I see them on this page:
Maps-Archives
2009 Mazdaspeed3
2000 Mazda Miata MX-5
NASA TTE build ongoing
The Following User Says Thank You to Quigs For This Useful Post:
bostongeorge (08-07-2013)
 Old 08-07-2013, 04:24 AM   #5
6Y MAZDA's Avatar
Posts: 1,775   (View Stats)
^^^ i was gonna say...their new site layout is gay, but you just go to map archives as pointed out above
1996 Miata
Question about OTS stage 2 maps DownSideFX 2010 MS3 - ECU Computer Tuning 10 03-03-2012 09:30 PM
question about OTS maps and an Injen CAI tar0s 2010 MS3 - ECU Computer Tuning 6 11-19-2011 11:54 AM
Ignition tables in the OTS 1.02 Gen 1 boost maps, hugely different from the Load maps FreeFlyFreak MazdaSpeed 3/6 - ECU Computer Tuning 11 08-18-2011 11:03 PM
Question about OTS maps for AP drenkel 2010 MS3 - ECU Computer Tuning 7 05-22-2011 11:42 PM
Any input from Stage 2 ONLY maps (not + SF, MSCAI maps) steven88
Cobb Access Port/Maps
8 10-15-2008 06:48 AM
Page generated in 0.25819 seconds with 24 queries
