| Cobb Tuning Cobb Tuning is the leader in Mazdaspeed 3 & 6 Performance! |
![]() Join Date: May 2015 Location: NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 67
(Thread Starter) | Not Ranked : 0 score Hey all, So I posted a while back that my AP v2's USB portion on the dongle for the OBDII port detached from the circuit board and unfortunately is unrepairable. I've had multiple people say to contact Cobb support, but with the support for this model of AP being obsolete, there is no way I can order a new dongle. What is even more worse than not being able to power on the device is knowing that I cannot even unmarry the AP from the car. Calling Cobb, I was told I am eligible for the V2B and V3 upgrade, but I can't even do this since I cannot unmarry the AP from the car. Am I seriously SOL and in no way of recovering from this? I find it hard to believe that there is not a single dongle I can order from somewhere. For reference, it's the piece in the attached pic.
__________________ RIP 2006 MS6:: CP-E CAI // 3" CP-E TIP // SU Turbosmart BPV // M2 3" Catless DP // Cobb AP v2 //CP-E Rear Motor Mount // JBR SSP //JBR OCC // 1" Springs // EGR Unplugged // JBR Coolant Bypass // JBR TIG 2010 Genpu:: JBR SRI // JBR TIH // SU Turbosmart Full Recirc BPV // Cobb AP v2 // S-OTS Tuned // RallyArmor UR |
![]() Join Date: May 2010 Location: Maryland
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 848
| Neutral : +1 score Marrying the AP to your car prevents the AP from being used with another vehicle, it doesn't prevent you from marrying ANOTHER AP to your car. Get another AP and you'll be fine... EDIT: Or are you saying that COBB won't accept your old AP as a trade-in because it's still married to a vehicle? |
| The Following User Says Thank You to frothy For This Useful Post: | tmaiorca (12-31-2016) |
| Neutral : +1 score Did you take the dongle apart? Was the circuitboard compromised? If not, and it's just the usb port, you can buy a new one for $5 and solder it in. |
| Neutral : +1 score Is the cable simply mini USB to USB? Would a OBD2 to USB cable work just as well then? |
I actually did take it apart and solder a new USB port on there, but it would appear that when it broke it ripped off a layer of the board with it ![]() But you know, I never tried another OBDII dongle to USB. The Dongle is USB Mini, so from your picture, I guess I could get away with one that's already attached to it's dongle and get away with a USB A to plug into the AP. Is that dongle only responisble for powering on the AP and transferring data to/from ECU? Meaning, it's not proprietary to Cobb?
__________________ RIP 2006 MS6:: CP-E CAI // 3" CP-E TIP // SU Turbosmart BPV // M2 3" Catless DP // Cobb AP v2 //CP-E Rear Motor Mount // JBR SSP //JBR OCC // 1" Springs // EGR Unplugged // JBR Coolant Bypass // JBR TIG 2010 Genpu:: JBR SRI // JBR TIH // SU Turbosmart Full Recirc BPV // Cobb AP v2 // S-OTS Tuned // RallyArmor UR | |
| Neutral : +1 score
EDIT: @tmaiorca; Meh. From reading through some of the COBB threads on the Subie sites, it sounds like the AP iterations before the V2B didn't have all of the necessary components in the AP itself. So your dongle has something inside that a typical cable wouldn't. Do you have any pictures of the guts? Last edited by frothy; 12-31-2016 at 10:51 AM. | |
"Ours is COBB specific. Call customer support, we should have replacements. -Chris" Might be SOL. I guess its worth $10 trying though.. EDIT: Nvm kept reading. "Ah, I misread, I thought you were looking for the v2b cable, those dongles are few and far between. -Chris" "Yes, as long as it is a 7 pin/red logo dongle, like the one above, which means it is a CAN dongle. -Chris"
On the Spec page it says it supports both baud rates of ISO CAN 15765-4. Emailed cobb just a second ago, but won't hear back until Monday I'm sure. I can also look at the dongle and compare it to the link here OBD2 protocols. Essentially, I think Cobb is just using a specific standard and protocol set with their dongle on the v2. The VAG-COM one's from VW and such use a different protocol, one that is not compatible with the CAN-Bus system in our speeds.
| The Following 2 Users Say Thank You to tmaiorca For This Useful Post: | frothy (12-31-2016), Nliiitend1 (01-03-2017) |
![]() Join Date: Mar 2011 Location: Cambridge, Ontario, Canada
Rep Power: 221 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 138
| Not Ranked : 0 score Cobb isn't choosing a protocol to communicate with your ECU. The cars ECU communication protocol is selected by the manufacturer of the vehicle/ECU manufacturer and Cobb designed their dongles to support the protocol. Also, I bet the adapter you found won't work because Cobb would prevent their software from working with non Cobb hardware. What you could do is try and change the adapter driver to have windows recognize it as a Cobb AccessPort and hopefully the configuration is the same via software (unlikely).
__________________ 2011 MAZDASPEED3 Hypnotic Tuned - Rob CPE HPFP - CPE Catted Downpipe - CPE Catback Exhaust - 3" ETS TMIC - Cobb RMM - AEM Boost Gauge & Vent Pod - CANBus Triple - Corksport BPV - Corksport hood strut - Corksport RSB - Corksport Short Shifter - HTP 3.5" Intake - Damond TMM - Damond Vented CC - Vented Oil Cap - Tokay v2 Seals - GTX3067R - Damond PCV Plate - Built Engine (Manley Rods, 88mm Supertech 4032 Piston) - |
| The Following User Says Thank You to Polish_Eagle For This Useful Post: | tmaiorca (01-01-2017) |
| Approved MSF Vendor ![]() Join Date: May 2008
Rep Power: 2548 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6
| Not Ranked : 0 score Hey just checking in on this to make sure you've been taken care of. I didn't receive a response to the PM I sent you last month, but hopefully you contacted COBB customer service and have this all sorted out. Mike @ COBB
__________________ ![]() MAZDASPEED EXPERT GROUP - ADAM HILL | MIKE MCGINNIS | RYAN LAMBERTH | CHRIS MOUNTAIN | MARSHALL GLASGOW ![]() COBBTUNING.COM | LIKE US ON FACEBOOK | SEARCH KNOWLEDGE BASE | EMAIL CUSTOMER SERVICE |
| Not Ranked : 0 score No worries! I'm just glad you're taken care of! Mike @ COBB
![]() ![]() Join Date: Jun 2010 Location: Morton Grove, il
Rep Power: 1485 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 16,886
Groans: 78
| Not Ranked : 0 score Dammit, Mike. Didn't you hear Cobb abandoned the platform and doesn't care about the common user? Stop being helpful. /sarcasm In case someone has this issue in the future, I'm sure someone would be willing to let you use their dongle for a bit to unmarry. Always ask your local Nator group. Just another option.
__________________ "Well, Racecar=Broke. Other kinds of awesome may not, but racecar does. But racecar=best kind of awesome." -Wetz QFT |
| Not Ranked : 0 score Haha thanks xfeejayx! We're happy to help, but it's awesome that you guys help each other too. We're all enthusiasts and I love seeing the positive side of forums, rather than people making fun of someone else's stickers, wheels, haircut... ![]() Have a great day guys! Mike @ COBB
| The Following User Says Thank You to Cobb Tuning For This Useful Post: | Yatta (02-16-2017) |
| How to fix trunk release handle sticking / stuck / stiff / broken | aviator79 | MazdaSpeed 6 - How-To's | 3 | 05-02-2017 03:30 AM |
| Rock stuck in brakes? | Ms3jerm | Mazdaspeed3/6 General Discussion | 4 | 09-26-2015 08:05 PM |
| Fuel Cap Stuck/Broken | Deblaca | Mazdaspeed3/6 General Discussion | 11 | 06-02-2014 06:21 AM |
| Dongle vs. No Dongle - need your opinions | wherewuat | 2010 MS3 - ECU Computer Tuning | 3 | 06-11-2012 11:25 PM |
| between a rock and a hard place (please help) | danesti | Mazdaspeed3/6 General Discussion | 14 | 10-29-2008 12:27 PM |
