| Cobb Tuning Cobb Tuning is the leader in Mazdaspeed 3 & 6 Performance! |
![]() | | #41 | ![]() |
| The Following 2 Users Say Thank You to Lex For This Useful Post: | djuosnteisn (12-27-2011), rfinkle2 (12-16-2011) |
![]() | | #42 | ![]() |
![]() Join Date: Apr 2011 Location: Weston, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,511
Groans: 39
| Not Ranked : 0 score Right, but when the fix comes out whats going to happen?
__________________ 2011 MS3 / Fully Bolted / 290whp - 320wtrq ~ Sold 2010 Accord Coupe EX-L V6 ~ Current ~ K&N SRI / 4300k HIDs |
| The Following User Says Thank You to G26 For This Useful Post: | djuosnteisn (12-27-2011) |
![]() | | #43 | ![]() |
(Thread Starter) | Not Ranked : 0 score That depends on how your map is setup. If you increase timing in the high load areas to compensate for this then you may run into KR. I wouldn't make timing changes until COBB fixes this so that the load-timing relationship in the map matches the load-timing the car is actually running. If you're on an OTS map I wouldn't worry about it.
| The Following User Says Thank You to Lex For This Useful Post: | rfinkle2 (12-16-2011) |
![]() | | #44 | ![]() |
Groans: 39
That should be alright correct?
__________________ 2011 MS3 / Fully Bolted / 290whp - 320wtrq ~ Sold 2010 Accord Coupe EX-L V6 ~ Current ~ K&N SRI / 4300k HIDs | |
![]() | | #45 | ![]() |
| Not Ranked : 0 score An easy thing to do would be to take an ots map (after bug fix), copy it to an excel spreadsheet (data analyzers like you are excel experts), do the same with your current table, making sure load lines match up, and subtract the two tables. |
| The Following User Says Thank You to rfinkle2 For This Useful Post: | RichieRichness (12-16-2011) |
![]() | | #46 | ![]() |
Groans: 39
| Not Ranked : 0 score Yeah, I will probably do that. Now I want this fix, running 10 degrees at 6k rpm 1.75 load is LOW, no wonder my virt dynos show my power dropping off up there.
| The Following User Says Thank You to G26 For This Useful Post: | rfinkle2 (12-16-2011) |
![]() | | #47 | ![]() |
| Approved MSF Vendor ![]() Join Date: May 2008
Rep Power: 2548 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6
The load axes should go from roughly .10 to 2.00 on the gen2. -David@COBB | |
![]() | | #48 | ![]() |
Groans: 39
Thats a pretty big thing to over look? Also, I have a 2011, so I guess this is all gen 2's.
![]() | | #49 | ![]() |
| Not Ranked : 0 score 2010's atr has .31-2.19 Edit: forget everything except there is no reason to panic. The change of 3 load lines is not enough to cause serious issues, and as Lex stated, it will likely decrease your timing.
It looks to be 2010 specific. @David@COBB, could this fix the idle issue on 2010's as well? Last edited by rfinkle2; 12-16-2011 at 11:47 AM. Reason: MSF Database - Automerged Doublepost | |
![]() | | #50 | ![]() |
(Thread Starter) | Not Ranked : 0 score All gen2s that have their axes go to 2.19 are affected
![]() | | #51 | ![]() |
| Not Ranked : 0 score Ok. So the thing to do is: 1) not panic 2) wait for the next atr version 3) see where your loads line up 4) trust Cobb to fix it safely (since they have fixed everything in the past for us) 5) enjoy your car in the mean time. I get what you are saying Lex, I'm going to have some work to do myself. |
| The Following 2 Users Say Thank You to rfinkle2 For This Useful Post: | Lex (12-16-2011), RichieRichness (12-16-2011) |
![]() | | #52 | ![]() |
![]() Join Date: Feb 2011 Location: Irvine,CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 346
| Not Ranked : 0 score @David@COBB any eta on the atr fix?
__________________ 2010 ms3-sold ww evo x -385/360 |
![]() | | #53 | ![]() |
(Thread Starter) | Not Ranked : 0 score Just to update, got word from COBB and it looks like the fix will be coming in the new year.
| The Following 5 Users Say Thank You to Lex For This Useful Post: | atvfreek (12-23-2011), djuosnteisn (12-27-2011), Oliverms3 (12-22-2011), rfinkle2 (12-22-2011), Zbrit00x (12-22-2011) |
![]() | | #54 | ![]() |
Groans: 39
| Not Ranked : 0 score Sounds good to me.
| The Following User Says Thank You to G26 For This Useful Post: | rfinkle2 (12-23-2011) |
![]() | | #55 | ![]() |
Groans: 39
![]() | | #56 | ![]() |
![]() | | #57 | ![]() |
| Not Ranked : 0 score There was an ap firmware update for the recovery fix.. I'm assuming the atr fix is coming pretty soon now
![]() | | #58 | ![]() |
(Thread Starter) | Not Ranked : 0 score Certainly hope so!
| The Following User Says Thank You to Lex For This Useful Post: | rfinkle2 (01-06-2012) |
![]() | | #59 | ![]() |
(Thread Starter) | Not Ranked : 0 score Just PMed COBB again on an ETA for this. FYI: It is becoming increasingly important to fix this because if the incorrect axis values are used and ignition map tuned as of right now, the car may run too much timing when the issue us resolved. For example, the 2.00 load values could erroneously be increased too far such that the car will knock when the 2.19 y-axis becomes accurate. It was not dangerous to make the initial mistake, but if people tune their cars using the newest ATR version and the problem is corrected; there is a potential for the vehicle to run too much timing.
![]() | | #60 | ![]() |
![]() Join Date: Jan 2012
| Not Ranked : 0 score Shocker, Cobb sitting on a bug for over a month. A really annoying/dangerous bug at that. |
| The Following User Says Thank You to VitViper For This Useful Post: | rfinkle2 (01-12-2012) |
![]() | | #61 | ![]() |
![]() Join Date: Mar 2010 Location: Manassas, VA
Rep Power: 2313 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,791
Groans: 35
| Not Ranked : 0 score I'm sure this isn't an easy fix. Have faith that Cobb will resolve this issue soon. Best thing to do is make all timing values vs rpm the same from 2 +.
__________________ CP-e Atmosphere GTX3076r w1.06 Tial | JMF IM | NATOR D.C. FMIC | JBR Wide Path | Autotech Internals | HKS SSQV2 | Ebay DP | Denso ITV24 | CP-e RDM | AutoExe Strut Tower Bar | Whiteline RSB | Sonic Tuning Coils | DSS Driver Side Axle | JMF OCC BT - 395 awhp 345 awtq @ Moore Automotive 4/12/2014 on 93 octane Stock Turbo - 331 awhp 397 awtq @ Moore Automotive 11/10/2012 on ~e48 12.263 @ 111.75 mph 1.669 60' 11/17/2012 |
| The Following User Says Thank You to RichieRichness For This Useful Post: | rfinkle2 (01-12-2012) |
![]() | | #62 | ![]() |
When I tune, I want to make sure the tune stays current - last thing I want is a tune that changes timing values after a software update.
| The Following User Says Thank You to Lex For This Useful Post: | djuosnteisn (01-12-2012) |
![]() | | #63 | ![]() |
![]() Join Date: Mar 2010 Location: BOCA RATON FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 524
| Not Ranked : 0 score I don't post much but was following this this thread because I was upping my timing tables along the load curve and noticed that they ended at 2.0 also. Low and behold i loaded a fresh map from Cobbs site 1/5/11 and this is what appeared on the new map and all my previous itterations. Not sure if the change came through the new map or the AP update a week and a half ago. All seven tables extend down to 2.19 with new values. I tried copy and pasting an older reworked table onto one of the new table and noticed that values have changed in cells that I never previously touched. Anyway I'm no tuning guru and if this isn't what the current conversation is about then disregard. Pic is of a unedited OTS table.
__________________ 2018 Audi S6 Prestige. APR Tuned 575 AWHP (current) 2017 Audi A4 APR tuned 315 AWHP (sold) 2014 IS350 (sold) 2013 MS3 Stage2 E85 (sold) 2011 MS3 Stage2 (sold) |
![]() | | #64 | ![]() |
| Not Ranked : 0 score That is what happens when you open a map in the new version, whether or not the old values were modified. All load lines > 2.0 are populated with the same value as the 2.0 load line. |
![]() | | #65 | ![]() |
__________________ ![]() 07 Red MS3 GT - E40 - Carrillo Rods - Wiseco Pistons - BSD - JBR 3.5 WidePath - ATP GTX3071 - Forge BPV - GA - Cobb v2 FMIC - CPE EM - CPE DP - CNT CBE - APv3 - Grim EBC - PERM dual port PCV plate - Dano dual OCC - CPE CDFP - Labonte S2 WMI - ACT Street Kit - SUv2 RMM - SU TM - "Stiffy" MM - DG CF wing ext, skirts & front lip - Hotchkis RSB/FSB w PowerGrid Links - Koni FSDs - DBA SX4000 Rotors - Hawk Pads - Silver OZ Ultraleggera - 235/40/18 NT-01 | |
![]() | | #66 | ![]() |
| The Following User Says Thank You to rfinkle2 For This Useful Post: | Dano (01-12-2012) |
![]() | | #67 | ![]() |
(Thread Starter) | Not Ranked : 0 score It's not just the top row. The entire table is shifted wrong. @David@COBB - an ETA please. I don't want to see cars be damaged due to this issue.
| The Following User Says Thank You to Lex For This Useful Post: | Zbrit00x (01-13-2012) |
![]() | | #68 | ![]() |
Just to reiterate, it is an axis error, all the table data is still the same and won't be affected. -David@COBB | |
| The Following 5 Users Say Thank You to Cobb Tuning For This Useful Post: | atvfreek (01-13-2012), djuosnteisn (01-18-2012), Lex (01-13-2012), wolly6973 (01-13-2012), Zbrit00x (01-13-2012) |
![]() | | #69 | ![]() |
Thanks David, So when the fix is made, is the table reverted back to an axis with load going to 2.00? I just want to know how the fix is implemented so that I know how to change the table data to match the fixed axis.
| The Following User Says Thank You to Lex For This Useful Post: | atvfreek (01-13-2012) |
![]() | | #70 | ![]() |
0.13 0.19 0.25 0.31 0.38 0.44 0.50 0.56 0.63 0.69 0.75 0.81 0.88 0.94 1.00 1.06 1.13 1.19 1.25 1.31 1.38 1.44 1.50 1.56 1.63 1.69 1.75 1.81 1.88 1.94 2.00 -David@COBB | |
| The Following 8 Users Say Thank You to Cobb Tuning For This Useful Post: | atvfreek (01-13-2012), djuosnteisn (01-18-2012), f-castrillo (01-13-2012), Lex (01-13-2012), rfinkle2 (01-13-2012), RichieRichness (01-18-2012), wolly6973 (01-13-2012), Zbrit00x (01-13-2012) |
![]() | | #71 | ![]() |
(Thread Starter) | Not Ranked : 0 score Muchos gracias! This will allow me to resume the stalled 2010+ tuning
| Smoothing timing tables | superskaterxes | Cobb ATR Support | 39 | 12-05-2012 01:13 PM |
| Share your E85/Cobb AP timing tables? | bnoon | MazdaSpeed 3/6 - ECU Computer Tuning | 8 | 08-16-2011 03:50 PM |
| Any risk when setting throttle req load tables high to force boost by gear tables? | 08Anamoly | Cobb ATR Support | 5 | 03-29-2010 08:52 PM |
| Chicago 2010: Bad Timing Dept. - Prius MotorWeek Drivers' Choice winner; Toyota declines JDM award | Haltech | Automotive News | 0 | 02-11-2010 08:10 AM |
