Mazdaspeed Forums
-   [ETS] Extreme Turbo Systems (http://www.mazdaspeedforum.org/forum/forum/f513/)
-   -   Overheating and heater issues (http://www.mazdaspeedforum.org/forum/forum/f513/overheating-heater-issues-215531/)
diztunde 12-26-2017 10:07 AM
My 2008 Mazda 6 heater won't work and the car temp is going through the roof. Someone help please.
Sent from my SM-G950U using Tapatalk
JakeMS3 12-26-2017 10:30 AM
Has to be a troll ^^^
monkey.bones.007 12-26-2017 06:53 PM
Get some matches and gas and make it even hotter! https://uploads.tapatalk-cdn.com/201...072c788d66.jpg
crapatalk it sucks for free
diztunde 12-26-2017 07:15 PM
There's something called life, please get one.
monkey.bones.007 12-26-2017 07:17 PM
Naw, it's much more fun to troll you and your stupid question.
drive_sideways 12-26-2017 08:51 PM
Your thermostat is stuck shut, you will need a new one, also make sure your car has coolant in it.
Btw a simple google search would have answered your question much quicker.
mituc 12-27-2017 03:26 AM
Most probably no coolant.
With the thermostat stuck shut there's plenty of cabin heating because the heater is using the same coolant at the engine. Actually turning the cabin heat all the way up is one way of cooling the engine when the thermostat is stuck shut. Of course, assuming that the heat control works in the center console... because it may be that as well.
On the other hand @diztunde, did you phoken notice where you did phoken post? Wotta phock your (over)heating problem has to do with aftermarket performance parts supplied by ETS?
monkey.bones.007 12-27-2017 07:40 AM
He's also posting about a regular 6 and not a speed. More than likely his water pump is shot, hence no circulating of coolant. He posted on the wrong section, posted about a wrong car, and was generally a twat who won't be back. This is why we can't have nice things.
Djohns 12-27-2017 08:42 AM
OP can suck a bag of dicks.
Page generated in 0.18024 seconds with 11 queries
